Heat Pump Water Heater vs Electric: Which Tank Makes Sense for Your Home?
Maybe your old electric tank just sprang a leak, or the installer's replacement quote has you second-guessing. Either way, the heat pump water heater vs electric question tends to show up fast. Both run on electricity, but they work very differently. A standard tank heats water with glowing metal elements, while a heat pump model pulls warmth out of the room air. This guide compares their efficiency with federal ratings and looks at where heat pump units struggle. It also covers keeping hot water during an outage.
How Each Tank Turns Electricity Into Hot Water
A standard electric tank heats water directly with one or two resistance elements, like a giant kettle. A heat pump water heater uses a compressor and refrigerant to pull heat from the room air into the tank, like a refrigerator in reverse. So heat pump vs water heater isn't quite the right framing. It's an electric heat pump water heater vs electric water heater choice, and the heat pump vs electric hot water gap comes from that difference.
The efficiency number that matters: UEF
When you compare water heaters, look for the Uniform Energy Factor, or UEF. ENERGY STAR calls it DOE's industry standard for efficiency. Higher is better. ENERGY STAR's guide to Uniform Energy Factor says a standard electric storage water heater might rate 0.93. Certified heat pump models typically land between 3.3 and 4.1. To earn the label, ENERGY STAR's current water heater criteria require a UEF of 3.30 or higher for integrated heat pump models. Plug-in 120V models on a 15 amp circuit and split systems need 2.20 or higher.
The Department of Energy is more cautious. It says heat pump water heaters can be two to three times more efficient than electric resistance units. That's lower than the raw UEF ratio because UEF comes from a lab test, and real homes vary.
Here's how two 50-gallon models compare in the heat pump water heater vs electric water heater matchup. They're named examples, not recommendations, with figures from each maker's listing.
Spec (maker listing)
Standard electric example
Heat pump example
Model
A.O. Smith ProLine ENT-50 (50 gal)
Rheem ProTerra PROPH50 T2 RH400-30 (50 gal)
Voltage
240V
208V to 240V, single phase
Heating method
Two 4,500W elements (4,500W max)
Compressor plus a 4,500W element
Electrical
Amps not listed on the maker page
5,000W total unit wattage, 21A max, 30A breaker
UEF
0.92 in the spec table (page text says 0.95)
3.88
First hour rating
62 gallons
67 gallons
What the UEF gap means in energy terms
So what does 0.92 versus 3.88 mean? For the same test draw, energy use scales with 1 ÷ UEF. Divide 0.92 by 3.88 and you get about 0.24, so the heat pump example uses roughly a quarter of the energy under DOE test conditions.
That's not a bill estimate, though. Because a heat pump moves heat instead of making it, heat pump water heater savings depend heavily on where the tank sits and how warm that room stays. Whether your basement, garage, or utility closet can deliver that is another question.
Climate, Space, and Wiring: Where Each Tank Fits
A resistance tank works almost anywhere you can run a 240V circuit. A heat pump unit needs warm air and room to breathe. That's why the water heater vs heat pump decision often depends on the room more than the price tag.
Room temperature and air volume
ENERGY STAR says heat pump water heaters belong in interior spaces that stay between 40°F and 90°F year-round. They also need about 1,000 cubic feet of air space around the unit. That's the general guideline, and makers set their own limits. Rheem's ProTerra spec sheet lists a 37°F to 145°F operating range and says a non-ducted unit runs in rooms down to 450 cubic feet, with reduced output below 700.
Cold spaces are the weak spot. ENERGY STAR notes these units run less efficiently in colder spaces. With colder incoming water, they may also switch to a backup standard electric mode for a while. The upside comes in hot, humid months, when the unit can help cool and dehumidify a muggy Gulf Coast basement.
Electrical needs
Wiring is the other big question. The A.O. Smith tank runs on 240V with 4,500W elements, while the Rheem calls for 208V to 240V and a 30 amp breaker.
No spare 240V circuit? Plug-in heat pump models change the picture. A.O. Smith's Voltex 120V lists a 120V, 15 amp shared circuit, a 9.38 amp draw, 900W max, and a UEF of 3. ENERGY STAR sets a lower bar for 120V models, so don't compare that rating head to head with the Rheem's 3.88.
Install question
Standard electric tank
Heat pump water heater
Room temperature
Not a limit in the sources used
40°F to 90°F year-round (ENERGY STAR)
Air space
Not required
About 1,000 cu ft (ENERGY STAR); maker minimums vary
Effect on room
None noted
Can cool and dehumidify the space
Circuit
240V; element size sets the load
208V to 240V with a 30A breaker in the Rheem example; 120V plug-in models exist
Upkeep
Not compared in the sources used
Air filter changes, possible annual service (ENERGY STAR)
Many buyers assume they'll need new wiring, but the question of whether heat pumps need 240 volts now has more than one answer. Once the tank and its circuit are settled, it's worth asking a separate question: what happens to hot water when the grid goes down?
Backing Up the Tank You Choose (and Topping It Up With Solar)
Neither electric water heater makes hot water in an outage, though an insulated tank holds heat for a while. A home battery won't make either tank more efficient. It just keeps the circuit energized, so planning comes down to element wattage, what else shares the battery, and how you'll recharge.
Count the real load, not the label on the compressor
Rheem lists five ProTerra modes: Energy Saver, Heat Pump, High Demand, Electric, and Vacation. In Electric or High Demand mode, the unit can call on its 4,500W element. Rheem lists 5,000W total unit wattage, so plan around that number, not the compressor. A standard tank's element (4,500W in the A.O. Smith example) is the load whenever it heats.
Then add everything else that could run at once, like the fridge, lights, Wi-Fi, and a sump pump, using nameplate watts. If your manual allows a heat-pump-only mode, using it during an outage keeps the element off.
Example energy budget (labeled estimate)
How long could a battery keep that element going? This rough estimate uses 0.85 for conversion losses.
Battery setup
Calculation
Element heating time
One 5kWh battery
5,000Wh × 0.85 ÷ 4,500W
About 0.94 hours
Two batteries (10kWh)
10,000Wh × 0.85 ÷ 4,500W
About 1.9 hours
Elements cycle, so this is heating time, not clock time. Still, it shows why the water heater should be a deliberate choice on your backup panel.
Reliable Backup Power for Essential CircuitsReliable Backup Power for Essential Circuits
If backing up that circuit is part of your plan, two EcoFlow models fit the job. EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus share the same 7.2kW battery output, so the real difference is how much solar you plan to connect.
EcoFlow TITAN 5000
Now picture a home with a bigger array on the roof or in the yard. If you want more daytime solar flowing into the battery, EcoFlow TITAN 5000 Plus takes up to 8kW across two solar inputs. It isn't automatically better at running a water heater, though, since its battery output is the same 7.2kW.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
EcoFlow TITAN suits a home backing up a 240V water heater plus a few essential circuits, with any direct solar within its single 4kW input. EcoFlow TITAN Plus fits a bigger array, up to 8kW across two inputs, but it isn't automatically better at running a water heater. A 4,500W element leaves about 2.7kW for everything else, so a licensed electrician should count every load that could run at once.
Solar notes for daytime recharging
Already have panels on the roof? A standard grid-tied rooftop system shuts down in an outage, so ask your installer how yours behaves before counting on it. Panels wired to the TITAN's own solar input are a different setup, and short winter days may not bring a full refill.
TITAN units are IP20 indoor products that charge only from 32°F to 113°F. A cold garage that suits a resistance tank may be wrong for the battery, and for a heat pump tank too.
Living With Each Tank Day to Day
The choice doesn't end at efficiency. A heat pump tank behaves differently in the house, and some families notice it right away.
Picking the Right Mode
When holiday guests stack up showers, a mode like Rheem's High Demand helps the tank keep up by using the electric element more. That pushes energy use closer to a standard tank, so switch back once the crowd leaves. Rheem's Vacation mode can be set for 2 to 28 days while you're away.
Comfort and Upkeep
You may notice cooler, drier air around a heat pump unit. That barely matters in a garage, but it's worth weighing in a finished basement your family uses in winter.
ENERGY STAR says heat pump units may need annual maintenance, including air filter changes. Its installer guidance also says to clean condensate lines yearly. Your manual lists the exact schedule for either tank type.
If space is the real constraint, it helps to weigh the trade-offs of tankless water heaters before ruling out a tank altogether. With the pros and cons laid out, a short decision guide makes the final call easier.
Quick Decision Guide: Which Water Heater Should You Pick?
Still stuck on electric vs heat pump water heater? Most homes can use either type, but a few details tip the scale, so run through these with your plumber.
Choosing the Right Water Heater for Your HomeChoosing the Right Water Heater for Your Home
If this describes your home
Lean toward
Why (source)
Unit would sit in a space that stays 40°F to 90°F with plenty of air
Heat pump
ENERGY STAR install guidance
Tank lives in a small closet with no venting option
Standard electric, or a ducted heat pump setup
Air volume requirement
Unheated garage in a cold-winter state
Standard electric, or relocate
Heat pump efficiency drops in cold spaces (ENERGY STAR)
120V plug-in heat pump
A.O. Smith Voltex 120V listing
Hot, humid basement
Heat pump
Dehumidifying side benefit (ENERGY STAR)
When the electric water heater vs heat pump debate comes down to dollars, check with your utility for current rebates. One federal option has ended. The IRS says the Energy Efficient Home Improvement Credit covered qualifying property placed in service through December 31, 2025. It won't cover a 2026 installation. Rebate rules vary by state, so look up any federal rebates for heat pumps your state energy office still runs.
The heat pump water heater vs electric choice comes down to where the tank will live. Under DOE's test, a heat pump model uses far less energy than a standard tank. It just needs a warm, roomy space, and a standard tank is simpler to place. Measure the room, check its winter temperature, and confirm your circuit. Then decide separately whether the tank belongs on backup. If it does, EcoFlow TITAN 5000 or EcoFlow TITAN 5000 Plus with Smart Home Panel 10 is worth a look, with a licensed electrician sizing the circuits.
Is a heat pump water heater better than a standard electric water heater?
On efficiency, yes. ENERGY STAR says certified heat pump models usually rate 3.3 to 4.1 UEF, versus about 0.93 for a standard tank. But the unit needs a 40°F to 90°F space with roughly 1,000 cubic feet of air.
Can a heat pump water heater go in a garage?
Yes, if it stays within ENERGY STAR's 40°F to 90°F range all year. In a garage that gets very cold, the unit runs less efficiently and may lean on its backup electric mode.
Do I need a 240V circuit for a heat pump water heater?
Not always. Many models, like the Rheem example here, need 208V to 240V with a 30 amp breaker. Plug-in models such as A.O. Smith's Voltex 120V run on a 15 amp shared circuit instead.
Does a heat pump water heater work during a power outage?
Not by itself, since it needs electricity like any electric tank. It can run on a home battery if an electrician puts it on a backed-up circuit and the total load fits the battery's output.
Is there still a federal tax credit for heat pump water heaters?
Not for new installs. The IRS says the 25C credit, worth up to $2,000 a year for qualifying heat pump water heaters, covered property placed in service through December 31, 2025. Ask your utility or state energy office about current rebates.
Home Solutions
