Heat Pump vs Air Conditioner: How They Cool, How They Heat, and Which One Fits Your Home
Walk down a typical American street in July, and you probably couldn't tell which house has a heat pump and which has central air. The boxes outside look nearly identical, and on a hot day they do the identical job. The gap only shows up once it turns cold, because a heat pump can reverse itself and warm your home while an AC can't. Below, we put heat pump vs air conditioner side by side on cooling, heating, efficiency ratings, and cost, match each to US climates, and look at outage backup for every type of AC.
Heat Pump vs Air Conditioner: The Short Answer and a Side-by-Side Table
An air conditioner only cools. A heat pump cools the same way and also heats by running its refrigerant cycle backward. ENERGY STAR describes a ducted air-source heat pump as "a central air conditioner that also works in reverse" to heat the whole house in winter. So a home with central AC still needs a furnace or another heat source, while a heat pump can cover both seasons in many climates.
Central air conditioner
Air-source heat pump
Cooling
Yes
Yes, same refrigerant cycle
Heating
No; paired with a furnace, boiler, or other heat
Yes; reverses the cycle, with backup heat for cold snaps
Key outdoor part that differs
No reversing valve
Reversing valve lets it switch modes
Efficiency ratings
SEER2 (plus EER2 in the Southwest)
SEER2 for cooling, HSPF2 for heating
Federal minimum, new split system
13.4 to 14.3 SEER2 by region
14.3 SEER2 and 7.5 HSPF2 nationwide
Typical heating partner
Gas or oil furnace
Electric heat strips, or a furnace in a dual-fuel setup
Typical electrical supply
240V outdoor unit
240V outdoor unit
Almost nine in ten U.S. homes have some form of AC, and roughly two in three rely mainly on a central unit or central heat pump, according to EIA household energy data.
Wondering about heat pump vs hvac? HVAC (heating, ventilation, and air conditioning) is the umbrella term, so a heat pump is one type of HVAC equipment, not an alternative to it.
So the heat pump versus air conditioner question comes down to heating, and the refrigerant cycle explains why.
How Each System Cools the Same Way and Why Only One Heats
Both systems use a compressor, two coils, and refrigerant to pull heat out of your house and dump it outside. A heat pump adds a reversing valve so it can run that cycle backward in winter. That one part is why it can replace both an AC and a furnace in many homes.
Cooling Mode (Both Systems)
  1. The indoor coil absorbs heat from your indoor air.
  2. The compressor pressurizes the refrigerant, raising its temperature.
  3. The outdoor coil releases that heat outside.
  4. The refrigerant flows back inside, and the loop repeats.
In any AC vs heat pump matchup, you won't notice a difference here.
Heating Mode (Heat Pump Only)
In winter, the heat pump flips the cycle. Even cold outdoor air holds some heat, and the outdoor coil absorbs it and moves it inside. Nothing gets burned. The unit relocates warmth, so each unit of electricity it draws can bring more than one unit of heat into your home.
Output drops as it gets colder. On the coldest days, a backup source such as electric strips or a furnace picks up the slack.
Cold-Climate Heat Pumps
Live somewhere like Minnesota or Maine? Look for a cold-climate model. ENERGY STAR's certification requires third-party testing down to 5°F, which tells you more about how a unit handles a real January night.
Cooling the same way also means both systems lose power the same way. So first, let's look at what each needs when the grid goes down.
Backup Power Needs of Different AC Systems in an Outage (EcoFlow TITAN Classic and EcoFlow TITAN Plus)
Backup Power Keeps AC RunningBackup Power Keeps AC Running
If a summer storm knocks out your power, what can you keep cool? Window units, portable ACs, central air, and heat pumps need very different amounts of power. Window and portable units usually plug into a 120V outlet, while central AC and heat pump outdoor units usually run on a 240V circuit.
System (named model)
Voltage
Published input watts or current ratings
Published starting-related rating
6,000 BTU window AC (LG LW6017R)
115V
520W, 4.9 rated amps
Not listed
6,000 BTU portable AC (LG LP0624WFR)
115V
865W, 10.4 rated amps
Not listed
About 24,000 BTU window AC (GE ASM24DD)
230/208V
Not listed
Not listed
3-ton central AC outdoor unit (Trane A5AC3036B1000A)
208/230V
Compressor RLA 13.9 A; fan FLA 0.85 A
Compressor LRA 75 A
3-ton heat pump outdoor unit (Trane A5HP5036A1000A)
208/230V
Compressor RLA 14.1 A; fan FLA 0.64 A
Compressor LRA 83.2 A
  • RLA (rated load amps) and FLA (full-load amps) are electrical current ratings, not measured operating watts. Trane identifies compressor RLA as a branch-circuit selection value. Multiplying the listed currents by 230V does not establish actual input power; use manufacturer input watts or real-power measurements under stated conditions, including the indoor blower.
  • LRA (locked rotor amps) is a locked-rotor current rating, not a measured startup-current curve. Have a qualified installer assess starting requirements separately from actual running watts.
  • Not every window AC is 120V. Check the plug and nameplate first.
Running watts climb with size, and this look at window AC power use shows which room units fit a 120V plan.
Rough runtimes (assuming 85% usable energy, a planning figure, not an EcoFlow spec; real runtime varies as ACs cycle):
  • 5kWh battery, 6,000 BTU window AC: about 8 hours
  • 5kWh battery, 6,000 BTU portable AC: about 5 hours
  • Central AC or heat pump: calculate runtime from actual combined input power for the outdoor unit, indoor blower, and other backed-up loads. The current ratings in this table do not establish a runtime.
A battery doesn't make your AC more efficient. It just keeps it running. In a heat pump vs air conditioning unit comparison during an outage, voltage and starting current matter most.
If you rely on window or portable units, EcoFlow TITAN Classic can run a spec-matched 120V AC alongside your refrigerator, lights, and Wi-Fi router. It's 120V only, so it isn't designed for central AC or a heat pump outdoor unit.
EcoFlow TITAN 5000 Classic
• 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don't even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
For a central system, EcoFlow TITAN Plus works with compatible 240V central AC or heat pump circuits. In EcoFlow's defined 240V test scenario, it can start a 3-ton central AC while running about 1kW of essential loads. It won't fit every system, so have an electrician compare your unit's nameplate (volts, RLA, LRA) and other loads against its output.
EcoFlow TITAN 5000 Plus
Both connect to home circuits through the matching Smart Home Panel 10 (120V or 240V version), installed by a licensed electrician.
Outage draw is one measure. The yellow EnergyGuide label shows how efficiently each system runs over a full season.
Heat Pump vs AC Efficiency: SEER2, EER2, HSPF2, and the 2023 Federal Minimums
Does a heat pump cool more efficiently? Not by default. In a heat pump vs AC comparison, both use the same cooling ratings, SEER2 and EER2. HSPF2, the heating rating, applies only to heat pumps. Since January 1, 2023, new equipment must meet higher federal minimums.
Region
Split-system central AC
Split-system heat pump
North
13.4 SEER2
14.3 SEER2, 7.5 HSPF2
Southeast
14.3 SEER2 under 45,000 Btu/h; 13.8 at 45,000 and up
Southwest
Southeast SEER2 values plus EER2 of 11.7 under 45,000 Btu/h (11.2 at 45,000 and up), or 9.8 if SEER2 is 15.2 or higher
Here's what DOE's 2023 standards FAQ adds:
  • Heat pumps have one nationwide standard. Only air conditioners have regional minimums.
  • Up North, the factory date counts. Down South and out West, the install date counts.
Since both systems share one cooling scale, knowing what a SEER rating measures makes contractor quotes easier to compare.
Efficiency shapes your monthly bill, but upfront cost and upkeep matter too.
Cost, Maintenance, and Tax Credits: Heat Pump or Air Conditioner in 2026
Shopping for a heat pump or air conditioner this year? A heat pump usually costs more than an AC-only outdoor unit, but it can replace a furnace too, so compare it against an AC plus a furnace. Installed price depends on size, ductwork, and local labor, so get written quotes. And for 2026, the federal heat pump tax credit is gone.
Heat Pump vs AC ExpensesHeat Pump vs AC Expenses
  • Upfront cost: The air conditioner vs heat pump price gap shrinks once you count the furnace a heat pump can replace.
  • Operating cost: Heat pumps use far less electricity than baseboards or other electric resistance heat. Against gas, it depends on your local rates, so compare electric vs gas heating costs for your area.
  • Dual fuel: ENERGY STAR says pairing a heat pump with an existing furnace "creates a dual-fuel system for a modest extra cost over an AC system."
  • Maintenance: A heat pump runs year-round, so it racks up more hours than a summer-only AC. Both need regular service.
  • Federal tax credit: The IRS home improvement credit page says the credit covers property placed in service before December 31, 2025. So a system you put in this year won't earn it.
  • Rebates: Some utilities and state programs still offer heat pump rebates, so check with yours.
From there, your climate and existing equipment usually settle it.
Which Should You Choose? Matching a Heat Pump or Air Conditioner to Your Climate and Home
Neither side wins the heat pumps vs air conditioners debate outright. A heat pump fits best where one system can handle both seasons. An AC still makes sense where heating is rare or a working furnace is staying.
Your situation
Usually a better fit
Mild or moderate winters, AC due for replacement
Heat pump
Hot climate with little heating need
Either; an AC is often simpler
Very cold winters
Cold-climate heat pump, or dual fuel with a furnace
You have a gas furnace that still runs well
Heat pump as dual fuel, or AC
Electric resistance heat today
Heat pump
No ductwork
Ductless heat pump (mini-split)
In northern states, knowing how heat pumps handle winter shows why cold-climate models and backup heat matter.
Before you sign a contract:
  • Request a Manual J load calculation, which matches equipment size to your house.
  • Ask what backup heat the heat pump uses and its kW rating.
  • If outage backup matters, ask about voltage and starting current before the install.
In the heat pump vs central air choice, both cool the same way and carry the same SEER2 ratings, but the heat pump also heats, which lets it replace a furnace in many US climates. Compare it against an AC plus a furnace, check SEER2 and HSPF2 against the 2023 minimums, plan backup heat for cold winters, and remember the 25C credit has ended. If outages worry you, consider EcoFlow TITAN Classic for compatible 120V room units and essentials, or EcoFlow TITAN Plus for a compatible 240V central system. Plug-in appliances can connect to appropriate main-unit outputs according to the product guide; connecting fixed home circuits through the matching SHP10 requires a licensed electrician.
Is a heat pump better than an air conditioner?
It depends on your climate and current heat. A heat pump cools and heats, which helps most with mild winters or when replacing electric resistance heat.
Can a heat pump replace central air?
Yes. It provides the same central cooling and adds heating, though cold climates may need backup heat for the coldest days.
Is a heat pump more efficient than an AC at cooling?
Not automatically. Both use the same SEER2 scale. A heat pump's edge is in heating, compared with electric resistance heat.
Is there still a federal tax credit for heat pumps?
No. The IRS credit covers property placed in service before December 31, 2025, so 2026 installs don't qualify.
Can a home battery run central air during an outage?
Some can, if the equipment and loads are compatible. EcoFlow TITAN Plus can start a 3-ton central AC in EcoFlow's defined 240V test scenario. EcoFlow TITAN Classic supports compatible 120V room units and basic loads through the main unit's outlets, following the product guide. Connecting central AC or other fixed home circuits through a matching SHP10 requires a licensed electrician.
Home Solutions
