Why Your Home Needs a Generator Transfer Switch for Summer Storm Season
Summer storms can bring power outages, but the heat of the season is when you need electricity the most. Without power, you don’t have air conditioning, refrigeration, or the use of essential medical devices.
Backup power is a safeguard against summer storms, but most independent systems like generators require you to manually connect your new power source, which can be inconvenient or even put your family’s health at risk.
Transfer switches create a seamless transition to your backup power solution, eliminating the need for manual plugging in and setting up each time. Learn more about generator transfer switches and why investing in one for the summer (and year-round) is a good idea.
What Is a Generator Transfer Switch?
A generator transfer switch connects your backup generator to your home’s electrical panel. These switches can be manual or automatic, with manual switches (MTS) costing less but requiring your involvement, and automatic switches (ATS) costing more but serving as a more convenient option.
ATS are sophisticated electronic devices that use sensors to monitor utility power for any voltage fluctuations or loss of energy supply. As soon as it picks up an outage, it starts the generator automatically and switches your home’s energy supply from the grid to a generator like the EcoFlow DELTA Pro 3.
MTSs are less sophisticated and require the homeowner to manually change the power supply from the grid to the generator. However, they still make the process easier than taking your generator out of storage and plugging it into your electrical panel or essential appliances.
ATSs create a separate circuit for your essential appliances and systems so that this equipment can still be sustained with generator power even when the power is lost. It allows you to power your hardwired home appliances, not just plugged-in devices, creating a whole-home backup system.
Transfer switches also serve an important role for the grid and its workers. They prevent power from backfeeding into utility lines, which can put line workers at risk of electrocution.
Why You Should Invest in a Transfer Switch
Generator transfer switches help keep you safe, protect you financially, and provide convenience and comfort in times of emergency or severe weather.
Safety is paramount, and transfer switches eliminate the risk of electrocution posed to line workers. Connecting your generator directly to your electrical panel also reduces the fire hazards that overloaded extension cords can cause.
While these switches are an investment, they’ll save you money in the long run. By seamlessly transitioning to backup power, you’ll have no more spoiled food in your refrigerator or freezer, avoid burst pipes from failed sump pumps, and keep your home security systems working when the power is out and your home is more vulnerable. If you work from home, you won’t lose wages or business if the grid cuts out during office hours.
You also can’t look beyond the convenience of an ATS or MTS. It directly powers hardwired systems like AC, garage doors, and water heaters. Those elusive systems that can’t get plugged into a generator like other appliances or devices will finally be protected from outages.
If you choose an automatic model, you won’t need to intervene or even be home for it to work. It will immediately start up your backup generator without missing a beat.
EcoFlow DELTA Pro 3
Why Are Power Outages Worse During Summer Storms?
Power outages occur more frequently during the summer months due to the extreme weather and increased demand on the grid.
High winds can bring down utility poles and power lines when storms or hurricanes roll in. Heavy rain can cause equipment to short or transformers to fail. Flooding can submerge ground-level equipment, and heat can stress electrical components to failure.
In addition, summer is when temperatures are their hottest. Children are home from school, and families spend more time indoors during the day, so HVAC systems are widely used. Residents want cool air, and with every degree the thermostat is reduced, more and more energy is needed.
Utility grids often operate at maximum capacity during heat waves, leading to overloaded systems and widespread equipment failure. Rolling blackouts may also be employed to prevent total grid collapse, but they lead to more frequent outages.
Pairing a Transfer Switch with a Smarter Backup System
Solar generators and batteries are modern, innovative backup systems. They operate silently to avoid disturbing your neighbors or your own sleep. They don’t create any emissions, making them safe to use inside the home without concern. Their minimal maintenance requirements take responsibility off of you, and their instant power activation without the need for fuel means quick response time.
Pairing a powerful solar generator with the EcoFlow Smart Home Panel 2, which features an integrated automatic transfer switch, seamlessly connects your home to your emergency power supply without your involvement. You can monitor the system remotely via the EcoFlow app and prioritize critical loads.
It’s the optimal configuration: The transfer switch safely disconnects you from utility power, the EcoFlow Smart Home Panel 2 intelligently manages your power distribution, and the solar generator provides clean and quiet backup electricity.
Do I Really Need a Generator Transfer Switch?
You don’t need a generator transfer switch if you’re using an independent generator, but it’s incredibly convenient and makes using your backup generator safer. However, if you’re installing a permanent standby generator, most jurisdictions will require a transfer switch. Still, installing one is a convenient and safe choice.
Is It Illegal to Run a Generator Without a Transfer Switch?
Running a generator without a transfer switch isn’t explicitly illegal, but many building codes require them for permanent installations. If your jurisdiction requires one and you don’t have one, your utility company may disconnect service due to safety violations.
Transfer Switches Enable Safe Power During Summer Storms
Summer storms drive frequent outages and put critical energy needs at risk. With a backup generator and a transfer switch, you can conveniently and safely switch from grid power to your backup supply and avoid backfeeding electricity into the grid. Modern battery and transfer switch systems like the EcoFlow Smart Panel 2 optimize your entire setup and help manage your critical loads without your involvement. You’ll enjoy power, safety, and peace of mind.
Home Backup
