Furnace Installation Cost: What Drives the Price and How to Compare Quotes
Replacing a furnace can be a major home expense, and two installation quotes for the same house may look very different. The price depends on more than the equipment. Fuel type, efficiency, ductwork, venting, electrical work, permits, and labor all affect the final bill. This guide explains what goes into furnace installation cost, how gas and electric systems compare, and what to check before choosing an installer. It also covers a separate way to keep work lights and phones running while the installation crew is on-site.
What Goes Into Furnace Installation Cost
The furnace itself is only one part of the installation bill. Labor, materials, and changes to existing gas lines, electrical circuits, ducts, or venting can add to the total. Ask the contractor to break out each charge so you can see what the job includes.
What Goes Into Furnace Installation CostWhat Goes Into Furnace Installation Cost
Main factors that affect the price
Cost driver
Why it matters
Furnace type and size
Gas vs electric, capacity, single vs variable speed
Efficiency (AFUE)
Higher-efficiency condensing gas units need different venting
Ductwork
Repairs or new runs add labor and materials
Venting
Condensing gas furnaces vent through plastic pipe; may need new route
Gas line or electrical work
New or upgraded gas line; 240V circuit for electric furnaces
Permits and inspection
Required in most areas
Removal of old unit
Disposal and labor
Furnace size and efficiency matter
An installer should size the furnace based on your home's square footage, insulation, windows, and local climate, not just the old unit. Gas furnace efficiency is measured by AFUE, with ENERGY STAR requiring at least 95% in the South and 97% in the North for qualifying models. Higher-efficiency units may need additional venting and a condensate drain. For electric models, compare wattage and running costs with your electrical capacity and local utility rates. Also, plan for temporary lighting if installation work requires shutting off power.
Installation Day: Temporary Lights and Phones (A Separate Budget Line)
A furnace replacement can leave part of your home without power while the crew disconnects the old equipment and connects the new system. Basements, utility rooms, and crawl spaces can get dark quickly. A portable power station can run work lights and charge phones during the job, with that purchase budgeted separately from the furnace installation.
What might need temporary power?
For a typical installation day, you may want to keep a few basic devices running:
  • LED work lights: Help installers see in basements, utility rooms, and other dim areas.
  • Phones: Keep communication available while the work is underway.
  • Wi-Fi router: Maintain an internet connection if its outlet remains available and the network service is still working.
Ask the installer which circuits will be shut off and whether their tools need a separate power source. Don't assume a household power station can run every tool. Check each tool's rated wattage and startup requirements, and confirm that the equipment is suitable for the available outlet and circuit.
EcoFlow DELTA 3 Classic for installation-day essentials
If you want a separate source of power for lights and communication, the EcoFlow DELTA 3 Classic has a 1,024Wh LFP battery. It can support a small group of household devices during installation, depending on their combined power use. It's an optional purchase, not a required furnace accessory, and it won't run a 240V electric furnace.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Estimate how long it can run
The following example uses two LED work lights, a router, and phones with placeholder loads of 40W, 10W, and 20W, respectively. At a combined load of about 70W, the EcoFlow DELTA 3 Classic has an estimated runtime of around 12 hours, based on 870Wh of usable capacity.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
Two LED work lights + router + phones (placeholders 40W + 10W + 20W)
about 70W
about 12 hours
Use the actual wattage printed on your devices to get a more useful estimate. The calculation assumes 85% of the battery's rated capacity is usable: Usable battery capacity (Wh) ÷ average load (W) = estimated runtime (hours). For a separate look at home heating during an outage, read about whether a gas furnace runs without electricity. The answer depends on the furnace and the electrical components it needs to operate.
Gas vs Electric Furnace Installation Cost Factors
Gas and electric furnaces have different installation requirements. A gas model needs a suitable gas connection and venting, while an electric furnace needs a properly sized 240V circuit. The equipment, labor, and changes to your home's existing setup all affect the quote.
What does a gas furnace installation involve?
A gas furnace needs a gas line that can supply it with fuel and an exhaust system that safely vents the combustion gases. If you are installing a high-efficiency condensing model, the contractor may have to add PVC vent pipes and a condensate drain. Check the combustion setup and carbon monoxide safety requirements as well. If the existing gas line or vent route does not meet the requirements for the new furnace, some additional work may be needed. That can make replacing an older model more involved than a straightforward equipment swap.
What does an electric furnace installation involve?
An electric furnace needs a dedicated 240V circuit and a properly sized breaker. If your electrical panel can't support the additional load, an electrician may need to upgrade it. Electric models do not need gas lines or combustion venting, but running costs are based on electricity rates. Compare local utility rates and heat pumps versus furnaces before choosing a system.
Check federal tax credit eligibility
The IRS says the Energy Efficient Home Improvement Credit applies to qualifying equipment placed in service through December 31, 2025, so it doesn't cover furnace installations in 2026. The previous credit offered up to $600 for qualifying gas furnaces and up to $2,000 annually for heat pumps. Check local utility rebates before finalizing your budget.
How to Compare Furnace Installation Quotes
Get at least two or three written quotes before choosing an installer. Make sure each contractor is pricing the same type of equipment and scope of work. A lower quote may leave out duct repairs, venting changes, permits, or removal of the old unit.
How to Compare Furnace Installation QuotesHow to Compare Furnace Installation Quotes
Use the same checklist for every quote
Ask each contractor to include:
  • Furnace details: Manufacturer, model number, fuel type, heating capacity, and AFUE rating.
  • Sizing method: A load calculation that accounts for your home's heating needs.
  • Installation work: Duct repairs, gas line changes, venting, electrical work, and condensate drainage where needed.
  • Permits and inspections: Who handles them and whether the related fees are included.
  • Removal: Disconnecting and disposing of the old furnace.
  • Warranty: Equipment coverage and any separate labor warranty.
  • Installer credentials: Confirm the contractor meets local licensing and insurance requirements.
Ask whether the quote includes a thermostat or if you'll pay for it separately. If you're considering an upgrade, find out whether a smart thermostat is compatible with the new furnace and what installation would add to the bill.
Look beyond the bottom line
Once you have the quotes, compare the equipment and work line by line. Check that each contractor has included the same installation tasks, warranty terms, and permit requirements. Ask about anything listed as an allowance or possible extra charge, too. A contractor should be able to explain why they chose a particular furnace size and what changes your home needs. If one quote is much lower than the others, ask what it leaves out before making a decision.
Furnace installation cost depends on the equipment, fuel type, efficiency, ductwork, venting, electrical or gas work, permits, and labor. Get several itemized quotes. Ask each contractor to include a load calculation to confirm the right furnace size. The federal Energy Efficient Home Improvement Credit ended for property placed in service after December 31, 2025. Don't include it in a 2026 installation budget. If installation work cuts power to your basement or utility room, an EcoFlow DELTA 3 Classic can keep LED work lights and phones running. Treat it as a separate, optional expense.
What affects furnace installation cost?
Furnace type, size, and efficiency all affect the price. Ductwork, venting, gas line or electrical changes, permits, old equipment removal, and labor also contribute to the final quote.
Is electric furnace installation cheaper than gas?
An electric furnace doesn't need a gas line or combustion venting, but it requires a properly sized 240V circuit. A panel upgrade may add work. Compare itemized quotes for your home rather than assuming one type will cost less.
Is there a tax credit for a new furnace in 2026?
No. The IRS says the Energy Efficient Home Improvement Credit applies to qualifying property placed in service through December 31, 2025. It doesn't cover furnace installations completed in 2026.
What AFUE should a new gas furnace have?
ENERGY STAR's criteria require qualifying gas furnaces to have at least 95% AFUE in the South and 97% in the North. Check the current criteria and the model's certification before choosing a unit.
How do I compare furnace installation quotes?
Compare the model number, capacity, AFUE rating, labor, duct and venting work, permits, removal, and warranty. Ask each contractor for a load calculation so you're comparing systems sized for the same home.
Home Solutions
