Induction Cooktop Energy Use: Wattage, Power Requirements, and What a Meal Really Costs
An induction cooktop may have a power rating of several thousand watts, but its actual energy consumption depends on the power setting and how long you cook. Watts measure instantaneous power, while kilowatt-hours (kWh) measure energy used over time. For example, a cooking scenario that uses an average of 1,000 watts for approximately 26 minutes consumes about 0.43 kWh. This is an illustrative calculation, not a claim about the energy used by a typical meal. Understanding induction cooktop energy use helps you estimate electricity costs, choose the right appliance, and plan for power outages. In this guide, we compare portable 120V and built-in 240V models, calculate cooking costs, and explain when a portable power station may be able to run your cooktop.
Induction Cooktop Wattage at a Glance: Portable 120V vs. Built-In 240V
Induction cooking wattage depends on the type and design of the appliance. Portable cookers usually plug into standard 120V household outlets, while built-in cooktops and induction ranges use higher-voltage circuits to support multiple cooking zones.
Model
Type
Voltage
Rated wattage (source)
Duxtop 9600LS
Portable, 1 zone
120V
1,800W
NuWave PIC Flex Pro
Portable, 1 zone
120V
1,400W (official manual, model 30503)
NuWave PIC Double Pro
Portable, 2 zones
120V
1,800W total, shared (official manual, model 30603)
Frigidaire Gallery GCCI3070B
Built-in 30-inch
Verify against official documentation
Up to 3,600W boost on one element
Confirm wattage and boost rating
GE Profile PHS930
Slide-in range with oven
240V / 208V
Up to 3,700W on one element
Samsung NZ36C3060
Built-in, 36-inch
240V
Zones rated from 1,800W to 3,800W
These figures come from manufacturer specifications and ENERGY STAR product listings. Check the exact model documentation before making an installation or purchasing decision. Rated wattage represents the maximum specified power draw, not the amount of electricity used continuously.
Why portable cookers top out around 1,800W
A portable induction cooker designed for a standard 120V, 15A outlet is generally rated at up to 1,800W, while built-in cooktops can draw considerably more power through higher-capacity electrical circuits. However, circuit requirements vary by model. For example, check the manufacturer's instructions for the Duxtop 9600LS to confirm whether a dedicated circuit is required before installation or use. Since a portable unit may share a circuit with other kitchen appliances, understanding the difference between a 15-amp and 20-amp circuit is useful before plugging in a kettle or another high-power device. Always follow the cooktop manufacturer's electrical requirements, check the circuit rating, and account for the load from other connected appliances to avoid overloading the circuit.
Induction Cooktop Energy Use per Meal and per Year (kWh and Cost)
The basic formula for calculating energy consumption is:
Energy (kWh) = Power (W) × Time (hours) ÷ 1,000
For example, a 1,400W cooker running continuously for one hour would use 1.4kWh. However, many cooking sessions combine a short period at high power with a longer period at a lower setting.
How much energy does one cooking session use?
Consider a NuWave PIC Flex Pro with a 1,400W setting and a 600W setting. Suppose you use the higher setting for 10 minutes and simmer for another 20 minutes.
  • Boiling: 1,400W × 10 ÷ 60 = approximately 233Wh.
  • Simmering: 600W × 20 ÷ 60 = 200Wh.
  • Total: 433Wh, or approximately 0.43kWh.
This is an illustrative calculation using manufacturer-listed power levels and assumed cooking times. Actual energy use varies with the food, cookware, selected settings, and the cooker's power cycling.
What does induction cooking cost?
The U.S. Energy Information Administration's October 2026 Short-Term Energy Outlook (Table 2, Residential Electricity Prices) reports an average U.S. residential electricity price of 17.30 cents per kWh for 2025 and forecasts 18.21 cents per kWh for 2026. The 2026 figure is a forecast, not a finalized annual average.
Cooking scenario
Energy used
Estimated cost
Example 30-minute session
0.43kWh
7.4 cents
One hour at a continuous 1,800W
1.8kWh
31 cents
Annual use at 189kWh
189kWh
$32.70
Your actual electricity rate may be higher or lower, so check your utility bill, including applicable delivery charges, to estimate your costs more accurately. This guide to calculating electricity costs explains how your rate affects the total. For context, the ENERGY STAR listing for the Summit REN24SS7 induction range reports estimated annual cooking-top energy consumption of 189 kWh. This standardized estimate is based on 418 cooking events per year, averaging 31 minutes each, under the applicable U.S. Department of Energy test procedure. It is a test-based estimate for that specific model, not a prediction of every household's consumption. Actual energy use and annual costs vary with the appliance, cooking frequency, and usage patterns.
Powering a Portable Induction Cooker in an Outage: When EcoFlow DELTA 3 Max Fits
A portable power station can run a compatible induction cooker during a power outage, provided its output rating, voltage, outlets, and available battery capacity meet the appliance's requirements. A battery stores energy; it does not reduce the cooker's energy consumption. Before connecting a cooker, check its rated input and account for every other device operating at the same time.
What to Check Before Cooking
Before connecting an induction cooker to a portable power station, check its wattage, voltage, and expected runtime to ensure compatibility. Understanding which appliances a portable power station can run can help you assess the load, available battery capacity, and whether the unit can safely support your cooking needs during an outage.
  • Rated output: Match the cooker's input wattage against the power station's rated output. Do not rely on X-Boost as a substitute for the standard rating.
  • Other appliances: A cooker drawing 1,800W leaves 600W of rated output for other simultaneous loads.
  • Voltage and connection: Use a compatible 120V appliance and an appropriate AC outlet.
  • Battery capacity: Output determines which appliances can operate; battery capacity determines how long they can run.
  • Cooktop type: A 120V power station cannot directly replace the dedicated 240V circuit required by a built-in cooktop.
How Long Could a Battery Run the Cooker?
The DELTA 3 Max has a listed capacity of 2,048Wh, giving an estimated 1,741Wh of usable energy when assuming 85% availability after conversion losses. This could support approximately four cooking sessions at 433Wh each or about 58 minutes of continuous operation at 1,800W, although actual runtime varies with power settings, battery conditions, and other connected devices. When planning for outages, compare your cooking needs and expected runtime with the available portable power station options from EcoFlow to find a suitable capacity and output.
EcoFlow DELTA 3 Max: A Portable Cooking Backup
The EcoFlow DELTA 3 Max is a portable power station for households that need a reliable backup cooking option during power outages. With a 2,048Wh capacity and 2,400W rated AC output, it can power a compatible 120V induction cooker within its operating limits while supporting other essential devices. It offers four charging methods and can recharge from 0% to 80% in 68 minutes using wall or generator charging, making it a practical option for preparing simple meals when grid power is unavailable.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA 3 Max can power a compatible 120V portable induction cooker rated at or below 2,400W, providing roughly four short cooking sessions per charge based on the estimate above. During an outage, knowing how long food stays safe without power can help you decide what to cook first. However, the DELTA 3 Max is not designed to power a built-in 240V cooktop or range, and its rated output should not be exceeded when cooking.
Induction Cooktop Power Requirements for Built-In Models: Volts, Amps, and Circuits
Built-in induction cooktops and ranges require dedicated circuits sized to their electrical specifications, so check the manufacturer's installation requirements before buying. For example, the Frigidaire Gallery GCCI3070B has a 7.2kW connected load at 240V and requires a minimum 30A circuit, while the GE Profile PHS930 lists a 12.5kW connected load at 240V and requires a 40A circuit. These ratings indicate the electrical capacity needed for installation, not the power the appliance continuously consumes during every meal.
Induction Cooktop Electrical RequirementsInduction Cooktop Electrical Requirements
Will you need an electrical panel upgrade?
An electrical panel upgrade isn't always necessary when replacing a gas stove with an induction cooktop. A licensed electrician can assess your existing panel, available capacity, and wiring requirements, including the factors that determine whether an induction retrofit needs a panel upgrade. Always follow the manufacturer's installation instructions and local electrical codes rather than choosing a breaker based only on wattage estimates.
What Raises or Lowers Induction Cooker Power Consumption
Two households using the same cooktop can consume different amounts of electricity. Cooking duration, selected settings, power sharing, cookware, and standby operation all influence the final total.
Cookware Compatibility Test for Induction CooktopsCookware Compatibility Test for Induction Cooktops
Key Factors to Understand
  • Boost settings: Some built-in elements increase from standard power levels to higher boost levels for faster heating. Use boost when you need rapid heating, then reduce the setting when appropriate.
  • Power sharing: Some portable cookers distribute available power between two zones. Running both zones does not necessarily double the total wattage.
  • Power level: A portable cooker offering settings from 100W to 1,800W can operate below its maximum rating during simmering or gentle heating.
  • Cookware compatibility: Induction requires suitable magnetic-bottom cookware. Place a magnet against the pan's base; if it sticks, the pan is generally compatible.
  • Standby consumption: Some cooktops consume small amounts of electricity in low-power mode. ENERGY STAR records include examples of approximately 4–5kWh annually for certain models.
Induction cooker energy use depends on cooking time, power settings, cookware compatibility, and standby operation. Even when the cooktop is off, some appliances draw small amounts of electricity, contributing to standby power that adds up quietly across your household. Checking your cooktop's rated wattage and tracking how long you use it can help you estimate its actual energy consumption.
Estimate Your Own Induction Cooking Energy in Four Steps
Your cooktop’s specifications and electricity bill provide the information needed to estimate cooking costs and energy use. Understanding the difference between kW and kWh helps you convert the cooktop’s wattage into energy consumption, electricity costs, and estimated battery runtime.
  1. Find the wattage: Check the cooktop's rating label or manufacturer’s specifications for the power levels you use, such as 600W, 900W, or 1,400W.
  2. Track cooking time: Record the minutes spent boiling and simmering. Calculate energy use with this formula: watt-hours = watts × minutes ÷ 60.
  3. Calculate the cost: Convert watt-hours to kilowatt-hours, then multiply by your electricity rate. If you need a rough estimate, the 2025 U.S. national average was 17.3 cents per kWh.
  4. Estimate battery runtime: Multiply the battery capacity in watt-hours by 0.85 as a planning allowance, then divide by the energy used per cooking session. Ensure the cooktop and other connected devices stay within the battery’s rated output.
Induction cooktop energy consumption depends on wattage, cooking time, and the power settings you choose. Portable 120V cookers typically reach 1,800W, while built-in 240V models require substantially more power. Check your cooktop’s specifications, track how long you use each setting, and calculate costs using your electricity rate. During outages, the EcoFlow DELTA 3 Max can power a compatible 120V portable induction cooker within its 2,400W rated AC output, providing a practical backup cooking option.
How many watts does an induction cooktop use?
Portable 120V models commonly use up to 1,800W. Built-in 240V cooktops may have individual zones rated from around 1,800W to 3,800W or more, depending on the model.
How much electricity does an induction cooktop use per meal?
It depends on the settings and cooking duration. In the example above, 10 minutes at 1,400W followed by 20 minutes at 600W uses approximately 0.43kWh.
Home Solutions
