Does Water Work When the Power Is Out? What to Expect From City Water, Wells, and Your Water Heater
When the power goes out, you may wonder whether you can still shower, flush the toilet, or safely drink water from the tap. The answer depends on your water source and water heater. City water often continues flowing for a while, while a private well usually stops when its electric pump loses power. Hot water availability also varies by heater type. This article explains what to expect, how to recognize boil water advisories, and how backup power can keep a well pump running during an outage.
Does Water Work When the Power Is Out? It Depends on Your Water Source
Plumbing itself doesn't generally require electricity, but the equipment that supplies, heats, and drains water often does. According to the CDC, nine out of ten people in the United States get their tap water from a public water system, while the EPA estimates that more than 43 million Americans rely on private wells. Here's a quick comparison of what usually happens when the electricity goes out.
Water source or system
What usually happens during an outage
City water
Water may keep flowing while pressure and supplies remain available.
Private well
Water usually stops when the electric pump loses power.
Gravity-fed plumbing
Water may continue flowing without an electric pump, depending on the setup.
Electric water heater
Existing hot water remains available, but reheating stops.
Gas water heater
It may work if its ignition and venting systems don't require electricity.
Septic or grinder pump
Wastewater movement may stop if the system depends on electricity.
Water availability during a power outage depends on your water source, local utility conditions, and equipment. Planning for water security during a power outage starts with understanding that city water may continue flowing temporarily, while private wells usually stop when electric pumps lose power. Hot water availability also depends on your heater type, so prepare an emergency water supply and consider suitable backup power if your home relies on a well.
City Water in an Outage: Gravity, Utility Pumps, and Boil Water Notices
If your home receives municipal water, you probably won't lose running water immediately. Water utilities use treatment facilities, electric pumps, storage tanks, and distribution networks to deliver water to homes. Elevated storage tanks can maintain pressure through gravity, while backup generators may keep essential equipment operating. However, these protections vary by utility and may not last throughout an extended outage.
Homeowner inspecting a private well pumpHomeowner inspecting a private well pump
When does city water stop working?
City water may stop flowing or lose pressure if utility pumps fail, storage tanks run low, or treatment and distribution systems are disrupted. Watch for reduced water flow, utility alerts, or boil water notices, as low pressure can allow contaminants to enter the supply. Follow local utility instructions even if the water looks clear.
What should you do if a boil water notice is issued?
If a boil water notice is issued, use bottled water or follow official guidance to make tap water safe. The CDC recommends boiling clear water for one minute, or three minutes above 6,500 feet. Preparing a disaster kit with essential power, water, and shelter supplies can help you prepare for emergencies by keeping drinking water and essential supplies ready.
Well Pumps and Backup Power: Planning Selected Circuits With EcoFlow TITAN Plus
If your home uses a private well, losing power can mean losing access to running water almost immediately. The well itself may still contain plenty of water, but an electric pump is needed to bring it into your home. A battery backup can help keep that pump running. However, you must check its voltage, running wattage, and startup requirements before choosing a system. Backup power cannot restore a city water supply if the utility loses pressure.
Why Well Pumps Need Careful Sizing
A pump's starting current can be much higher than its normal running current. For example, Franklin Electric's motor data lists a 1/2-horsepower, two-wire motor drawing approximately 5 amps while running and 32.2 amps at startup under the specified conditions. Many residential well pumps use 240V, although some operate at 120V. Check the motor label and consult a qualified electrician before connecting a backup system.
How EcoFlow TITAN Plus can support a well pump
The EcoFlow TITAN Plus can help power a compatible well pump during an outage, delivering 7,200W at 120V/240V and up to 10,000W when battery and solar power work together. Paired with the Smart Home Panel 10, it can support essential circuits, including a well pump, refrigerator, and lights. Actual runtime depends on battery capacity, pump usage, and other connected appliances. Before installation, have a licensed electrician verify the pump’s startup requirements and system compatibility.
EcoFlow TITAN 5000 Plus
For homes that rely on well water, the EcoFlow TITAN Plus may help power a well pump, refrigerator, and selected lights during an outage, provided an electrician confirms the pump’s starting requirements. Choosing the right setup starts with understanding the battery size needed for your well pump, as the system may not run every pump and an electric water heater simultaneously. Cold water is one concern; hot water depends on your heater type.
Does Hot Water Work When the Power Is Out? It Depends on the Water Heater
A tank containing already-heated water can still provide hot water during a blackout. The bigger question is whether your heater can continue operating or reheat the water once it cools. Bradford White explains that water heaters requiring external electricity cannot operate normally without it. The exact result depends on the appliance's design.
Water heater type
What happens during an outage
Electric tank
Existing hot water remains, but reheating stops.
Heat pump water heater
Usually heating stops without electricity.
Gas tank with standing pilot
May continue heating if it requires no electricity for operation.
Gas heater with electronic ignition
It usually cannot restart without electricity.
Power-vent gas heater
Typically stops because its fan requires power.
Tankless electric heater
Stops heating without electricity.
Gas tankless heater
Usually, electricity is needed for controls and ignition.
A water heater may still provide heated water before the outage, but continued heating depends on its type and electrical requirements. Since gas water heaters can also depend on electricity for ignition or venting, check your model's instructions before relying on it during a blackout, and never adjust or relight it outside the manufacturer's guidance.
Toilets, Septic Systems, Grinder Pumps, and Sump Pumps in an Outage
Your water supply is only half the story. You also need a way to remove wastewater and prevent unwanted water from entering your home. A conventional gravity toilet can generally flush if its tank refills and the drain system remains functional. But a home with a well pump, sewage ejector, or grinder pump may lose some or all of its normal plumbing function.
What Happens to Different Plumbing Systems?
  • Toilets: If the tank cannot refill, adding water to the bowl may allow a manual flush, depending on the toilet and plumbing arrangement. Use water sparingly.
  • Septic systems: Conventional gravity systems may continue working, but systems with electric pumps or controls can stop. Reduce water use if wastewater cannot move safely.
  • Grinder and ejector pumps: These systems move wastewater where gravity drainage is insufficient. If power fails, limit flushing and water use to avoid backups. Follow the manufacturer's alarm instructions.
  • Sump pumps: A sump pump that loses power cannot remove incoming groundwater normally, increasing the risk of basement flooding.
If your basement is prone to flooding during heavy rain, check your sump pump's running and startup wattage before choosing backup power. Understanding how sump pump battery backup works can help you select a suitable system to keep the pump operating during a power outage.
Before and After an Outage: Store Water, Protect Pipes, and Restart Safely
Preparing before a power outage can help protect your household's water supply and reduce disruption. Store enough drinking water, plan for sanitation needs, and learn how to protect pipes from freezing in cold weather. Identify which water systems depend on electricity, such as well pumps and sump pumps, and know how to restart equipment safely once power returns.
Before power goes out
  • Store water: The CDC recommends at least one gallon per person per day for three days. A two-week supply is preferable when possible.
  • Sanitation plan: Keep water available for essential toilet flushing and basic cleaning.
  • Protect pipes: Insulate exposed pipes in unheated areas. During freezing weather, follow local guidance on preventing frozen pipes.
  • Prepare backup power: Identify essential circuits and confirm the electrical requirements of your well pump, sump pump, and other critical equipment.
  • Charge your battery: If you have a home battery, keep it charged and understand which appliances it can support.
A home backup system can keep essential equipment running during an outage, provided its capacity matches your household's power needs. Exploring whole-house battery backup options for power outages can help you decide which circuits to prioritize, from well pumps and refrigerators to lights and other essential appliances.
After power returns
  • City water users: Follow utility announcements and continue observing any boil water notice until officials lift it.
  • Well owners: Check the pump and plumbing for damage. If pressure was lost or contamination is possible, follow local health guidance, arrange appropriate testing, and disinfect the well professionally when necessary.
  • Homes with wastewater pumps: Confirm that the equipment is operating normally before resuming heavy water use.
  • Homes with frozen or damaged pipes: Check for leaks before restoring normal water use.
Before returning to normal water use, check for leaks, confirm pumps are working, and follow any remaining water safety advisories. During colder months, including frozen pipe prevention in your winter outage plan can help reduce the risk of burst pipes and water damage when temperatures drop and power is interrupted.
City water often continues flowing during short outages but may lose pressure during prolonged disruptions. Private wells typically stop when their electric pumps lose power, while hot water availability depends on your heater type. Identify your water source, store at least one gallon of drinking water per person per day, and follow boil water notices. If your well pump needs backup power, check whether the EcoFlow TITAN Plus with Smart Home Panel 10 (240V) meets its voltage and starting requirements.
If you lose power, do you lose water?
Not necessarily. City water usually continues flowing during a short outage, although pressure can change. Private wells typically stop supplying water when their electric pumps lose power.
Does hot water work when the power is out?
It depends on your heater. Electric heaters stop heating, although stored hot water remains available for a while. Some gas heaters with standing pilot lights can continue working without electricity, while models with electronic ignition or power vents may stop.
Can I shower during a power outage?
Yes, if your water supply remains available and you have hot water. Keep showers short if you're using stored water, relying on a private well, or connected to a wastewater system that needs an electric pump.
Does plumbing use electricity?
Basic gravity-fed plumbing and conventional toilets don't usually require electricity. Well pumps, booster pumps, sump pumps, some septic systems, and most modern water heaters rely on electrical power for at least part of their operation.
Is tap water safe after a power outage?
Usually, if the municipal water utility hasn't issued a safety notice and the supply remains properly pressurized. Follow local instructions if a boil water notice is issued. Private well owners should seek guidance on flushing, testing, and disinfection if pressure is lost or contamination is possible.
Power Outages
