Best Indoor Heater for Power Outage: Propane, Kerosene, and Electric Options Compared
- Best Indoor Heaters for Power Outages, Grouped by Fuel
- Electric Heat Without the Grid: EcoFlow TITAN Classic for One Heater, EcoFlow TITAN Plus for Home Heating Circuits
- Propane and Kerosene Heaters Indoors: What "Indoor Safe" Really Requires
- How to Choose the Best Indoor Emergency Heater for Your Home
- Conclusion
- FAQs
When the furnace goes quiet during a winter outage, you're left with a real choice. One path is a heater that burns propane or kerosene in your living space. The other is an electric model, which won't run until you give it a power source. This guide compares named heaters by fuel, heat output, and indoor rules. Then it covers two battery paths. One runs a plug-in electric heater from a 120V home battery. The other backs up your home's own heating circuits. And whichever heater you choose, the safety rules from CPSC and CDC apply.
There's no single best indoor emergency heater, because each fuel trades something away. Propane and kerosene heaters need no electricity, but they add combustion gases to the room. Electric heaters add no fumes, but they need a power source. The table groups the best indoor heaters for power outages by fuel, not rank. Specs come from each maker's page, checked October 13, 2026.
Option | Fuel or power | Heat output (maker) | Indoor rating (maker's wording) | Built-in safety and key rule |
Propane: Mr. Heater Portable Buddy MH9BX | For emergency indoor home use, a disposable 1 lb propane cylinder. Follow the US manual and local restrictions; never bring a refillable propane cylinder indoors. | Low 4,000 BTU/hr, high 9,000 BTU/hr; maker rates it for spaces to 225 sq ft | "Indoor-safe: Yes" | Oxygen depletion sensor and tip-over shutoff. US manual: at least 9 square inches of ventilation at ceiling level and at floor level; never operate while sleeping. Maker lists 7,000 ft maximum elevation. |
Kerosene: Dyna-Glo WK24BK convection heater | 1-K kerosene, 1.9-gallon tank | 23,000 BTU per hour (features list); up to 1,000 sq ft | "safe supplemental indoor heating" | Tip-over shutoff. CPSC: 1-K kerosene only, door open to the rest of the house, window open about one inch. CDC: check with your fire department, since kerosene heaters may not be legal where you live. |
Electric, ceramic: Lasko 754200 | 120V household wall outlet on a suitably backed-up circuit; no other appliances on the same branch circuit | 900W low, 1,500W high | Standard household space heater | Overheat protection, cool-touch housing (no tip-over switch listed for this model) |
Electric, oil-filled: De'Longhi TRH0715 | 120V household wall outlet on a suitably backed-up circuit; no other appliances on the same branch circuit | 700W min, 800W mid, 1,500W max | Standard household space heater | Thermal cut-off and safety thermostat (no tip-over switch listed) |
Electric heater on a 120V home battery: EcoFlow TITAN Classic (5kWh) | Stored battery power | Supplies a compatible 120V heater; the named electric models require a backed-up household wall receptacle | No combustion in the room | For these wall-outlet heaters, use Smart Home Panel 10 (120V), installed by a licensed electrician. Runtime is limited; see the estimate below. |
Home heating circuits on a home battery: EcoFlow TITAN Plus | Home battery through Smart Home Panel 10 | Powers selected circuits for your existing heating equipment, if compatible | Installed by a licensed electrician | Equipment voltage, starting power, and other loads must be checked first; see the next section |
Mr. Heater lists about 3 hours at 9,000 BTU and 6 hours at 4,000 BTU per 1 lb cylinder.
Dyna-Glo lists 8 to 12 hours of runtime per tank.
Electric heaters need a power source, hence the last two rows.
It helps to know what BTU ratings mean. Fuel models list BTUs, and electric ones list watts. Neither of the bottom two rows burns anything inside your house. The first feeds one plug-in heater; the second keeps your existing heating system going.
Want heat with no flame indoors? Neither product is a heater. They're power supplies. EcoFlow TITAN Classic can run a 120V space heater for a limited time. If your heating runs on 240V, or you need heat alongside other household loads, EcoFlow TITAN Plus can back up selected home circuits instead.
One electric heater on EcoFlow TITAN Classic
The Lasko 754200 and De’Longhi TRH0715 manuals require a household wall receptacle, with no other appliances on the same branch circuit. To back up that circuit with EcoFlow TITAN Classic, use Smart Home Panel 10 (120V), installed by a licensed electrician. A 1,500W heater draws 12.5A at 120V; check the circuit and receptacle ratings as well as the battery’s 4,000W total output. Keep refrigerators and other loads on separate circuits. Never use a power strip or extension cord, as CPSC advises. Follow both products’ manuals.
How long will it run? Here's an estimate. With the base 5kWh battery, usable energy is about 5,000Wh × 0.85 ≈ 4,250Wh, where 0.85 is a planning guess for conversion losses.
Lasko 754200 on high (1,500W): 4,250 ÷ 1,500 ≈ 2.8 hours
Lasko 754200 on low (900W): 4,250 ÷ 900 ≈ 4.7 hours
De'Longhi TRH0715 on min (700W): 4,250 ÷ 700 ≈ 6.1 hours
These assume full wattage the whole time. A cycling thermostat or extra TITAN batteries (up to 30kWh) stretch them, but a 5kWh unit won't carry a 1,500W heater through a long night. It recharges from the wall at up to 4,000W or from solar at up to 3,200W. If you use a gas generator to recharge, CPSC says it belongs outdoors, at least 20 feet from the house, with exhaust directed away from nearby buildings.
Home heating circuits on EcoFlow TITAN Plus
Does your heating run on 240V, like a heat pump or electric furnace? Or do you need heat plus the fridge, well pump, and lights at once? That's when TITAN Plus fits, backing up circuits already in your home. It needs Smart Home Panel 10 (240V version), put in by a licensed electrician. Your electrician starts with the rating labels stuck on the furnace blower, the heat pump, or any electric heating unit. They check voltage (120V or 240V), running watts or amps, starting (inrush) current, and other loads like a well pump.
Those totals get compared with 7.2kW from the battery alone. The 10kW figure applies only while compatible solar panels are producing. Whether a heat pump, electric furnace, or heat strips will run depends on that check. Got gas heat? Plenty of gas furnaces can't light or move air without power for the fan, ignition, and control board. Your manual will spell this out.
Need to warm one room and keep a few essentials going? EcoFlow TITAN Classic stores 5kWh and delivers up to 4,000W. For the wall-outlet heaters listed here, back up the heater’s household circuit through Smart Home Panel 10 (120V), with a licensed electrician handling installation. Keep the heater on its own branch circuit and check other loads separately. Runtime depends on the total load.
For 240V heating equipment, or heat alongside other household loads, a split-phase home battery is the bigger step. EcoFlow TITAN Plus delivers 7.2kW from the battery alone and backs up to 10 selected circuits through Smart Home Panel 10. It starts at 5kWh and grows to 30kWh, but an electrician must install the panel and check your equipment first.
EcoFlow TITAN Classic can supply compatible 120V heating loads, while EcoFlow TITAN Plus can back up compatible 120V/240V heating circuits. For the electric heaters listed here, use a household wall receptacle on an appropriately backed-up circuit. Both batteries are power sources, not heaters; size the system using the total load and required runtime. Fuel heaters have additional ventilation and fuel-handling rules.
Indoor-rated doesn't mean set-and-forget. Fuel-burning heaters still make carbon monoxide. So the maker's vent rules, CPSC's advice, and a no-sleeping rule all apply.
Here's why it matters. CDC's carbon monoxide basics say more than 400 Americans die each year from accidental CO poisoning not linked to fires. More than 100,000 go to an emergency room. The CDC's list of the usual warning signs runs from headache, dizziness, and weakness to an upset stomach, vomiting, chest pain, and confusion.
Indoor propane heaters
The Mr. Heater MH9BX US manual requires ventilation openings of at least 9 square inches at ceiling level and at floor level. Follow the manual supplied with your US model and check local restrictions before indoor use. Never operate it while sleeping. The manual permits only the low setting in bathrooms. Without sufficient fresh air, the heater can produce excessive carbon monoxide.
CPSC's portable heater and camping guidance agrees. Its rule: if you're going to fall asleep inside a tent, camper, or car, don't have a fuel-burning heater going. Use only indoor-rated heaters with the maker's own parts.
Kerosene heaters
CPSC's kerosene heater safety sheet says to "use only water-clear 1-K grade kerosene" and never gasoline. Its other key rules:
Run the heater in a room with a door open to the rest of the house.
Open an outside window about one inch to let in fresh air.
Never refuel indoors, and never refuel while the heater is hot or in use.
Keep it at least three feet from furniture or clothing.
They aren't legal everywhere, either. The CDC's winter storm guidance says to ask your local fire department first.
Rules for every portable heater
Some rules don't change with the fuel. Follow these every time:
Turn off every portable heater, including electric models, before sleeping or leaving it unattended.
Keep all sides at least three feet from beds, clothes, curtains, papers, and sofas.
Set it on a stable, level surface where it won't get knocked over.
Plug electric heaters into a wall outlet, never a power strip, and never run the cord under rugs.
Never use these for heat
The CDC says never to heat your house with a gas oven. A generator doesn't belong inside the house, either. Set it up outdoors, more than 20 feet from any window, door, or vent, with exhaust directed away from buildings.
Sealed-up homes in storms are where the carbon monoxide dangers in winter show up most. That's why CO alarms come before any fuel heater.
The right heater fits the room you'll actually live in during an outage. Think about its size, how long you need heat, and who sleeps there. Local rules and altitude can also rule options out.
Your situation | What to look at | Option from the table that fits |
Heating a single small room for part of the day or evening | Low wattage or low BTU setting | Electric heater on low with EcoFlow TITAN Classic, or MH9BX on 4,000 BTU with ventilation |
A larger open area | Maker's square-foot rating | Kerosene convection heater rated for the space, if legal locally |
Young children, pets, or elderly family members sharing the space | Tip-over shutoff, cool-touch surfaces, no flame | Electric options; check the model's safety features |
Staying warm while you sleep | Turn off all portable heaters before sleeping, including electric models (CPSC). | Extra blankets, sleeping bags, and warm coats (CDC); battery runtime depends on load and capacity, so don't count on all night |
High elevation | Maker's elevation limit | MH9BX lists 7,000 ft max |
Multi-day outages | Fuel or recharge plan | Stored 1-K kerosene or propane per the maker; generator or solar recharging for batteries |
Most heater mistakes happen in the dark, in a hurry. A short fall checklist sorts out alarms, fuel, and power ahead of time.
CO alarms: CPSC says to use battery-operated or battery-backup alarms. Linked alarms are best, because "when one sounds, they all sound." Test them monthly.
The warm room: Pick the room your heater is sized for, with a door and a window you can crack for a fuel heater.
Fuel storage: Store propane and 1-K kerosene per the maker, and refuel kerosene heaters outdoors.
Battery readiness: Keep EcoFlow TITAN Classic charged. Note your heater's wattage so you know your runtime.
Home circuits: For EcoFlow TITAN Plus, have a licensed electrician check your heating nameplates. Pick which circuits go on Smart Home Panel 10 while it's still mild out, not in January.
Test run: Run the heater once before winter, manual in hand.
Emergencies: For downed lines or immediate danger, call 911 first.
Stocking alarms, fuel, and a charged battery is the core of preparing for a winter power outage. Do it before the first ice storm.
The best indoor heater for power outage use depends on fuel. Indoor-rated propane and kerosene heaters work without power. But they need the ventilation specified in their manuals. Turn off every portable heater, including electric models, before sleeping. Electric heaters need a battery or backed-up circuits. Choose by room size and household, test your CO alarms, and follow CPSC's three-foot and ventilation rules. If you'd rather avoid flames, EcoFlow TITAN Classic can supply compatible 120V electric heat for a limited time; the named wall-outlet models need a circuit backed up through Smart Home Panel 10 (120V), installed by a licensed electrician. If your heating runs on 240V or shares the load with other appliances, EcoFlow TITAN Plus can back up those circuits through an electrician-installed panel.
What is the best indoor heater for a power outage?
It depends on your home. A propane model rated for indoor use, such as the Mr. Heater MH9BX, keeps working with the grid down. In return, you must follow its ventilation requirements and local restrictions, and install working CO alarms according to their instructions. An electric heater adds no fumes, but it needs a battery or backed-up circuit.
Are indoor propane heaters safe during a power outage?
Only if you follow the rules. Use an indoor-rated model with the airflow its manual asks for. Keep three feet of space around it, and have a working CO alarm. Never run one while you sleep.
Can I leave an emergency heater on all night?
No. CPSC says to turn off portable heaters before sleeping, including electric models. Use warm clothing, blankets, and sleeping bags instead. If your home cannot stay safely warm, arrange to stay somewhere with safe heating.
How long can a portable power station run a space heater?
It depends on battery size and heater wattage. As an estimate, a 5kWh EcoFlow TITAN Classic has about 4,250Wh usable (5,000Wh × 0.85). That runs a 1,500W heater for about 2.8 hours, or about 6.1 hours at 700W.
Is it legal to use a kerosene heater indoors?
It depends on where you live, so the CDC advises asking your local fire department. If it's allowed, follow CPSC's rules on 1-K fuel, ventilation, and outdoor refueling.
