Wildfires in Michigan: How to Check Fires and Smoke, and How to Keep Power for Phones and Lights If You Have to Leave
- Where Are the Wildfires in Michigan? How to Check Official Fire Information Today
- How Long Will the Wildfire Smoke Last in Michigan? Reading EGLE and AirNow Forecasts
- Power for the Go-Bag and the Evacuation Center: EcoFlow DELTA 3 Classic
- Ready, Set, Go!: What Each Evacuation Stage Means in Michigan
- Why Michigan Wildfires Start: Debris Burning, Power Lines, Red Flag Days, and Burn Permits
- Wildfire Power Outages in Michigan: Consumers Energy, DTE Electric, and Upper Peninsula Utilities
- Conclusion
- FAQs
Wildfires in Michigan can start in dry grass, leaves, and wooded areas, especially across the northern Lower Peninsula and Upper Peninsula. Smoke can travel much farther, reaching communities nowhere near the flames. The Michigan Department of Natural Resources (DNR) says people cause nine out of ten wildfires in Michigan. Knowing where to check fire updates, how to read smoke forecasts, and when to leave can help you prepare.
Wildfire reports can become outdated quickly. For the latest information, start with the agency managing the fire. The Michigan DNR handles many wildfires on state-protected land, while federal agencies and local fire departments may handle incidents elsewhere.
Check the Michigan DNR's fire resources
Visit the Michigan DNR Fire Management page for official wildfire information and tools to check fire danger, track incidents, and follow updates.
Daily fire danger map: Check current fire danger across the region.
Wildland fire web application: Look for available information about wildfire activity.
Wildfire data dashboard: Explore fire data and related information.
DNR news releases: Read updates on named fires, including reported acreage and containment.
Email updates: Sign up for wildfire news from the DNR.
Fire danger maps show whether conditions favor wildfires, but they don't confirm an active fire. Check the latest Michigan DNR updates for incident details, and call 911 if you spot a wildfire. Never approach the flames. The DNR's 2022 report recorded 231 fires and 3,415 acres burned by DNR crews. These figures don't cover every wildfire in Michigan. To prepare for fire season, clear dead brush, plan your evacuation routes, and pack an emergency bag.
There isn't a reliable number of days for a smoke event. Its duration depends on where the fires are burning and how the wind carries smoke. Michigan's Department of Environment, Great Lakes, and Energy (EGLE) provides air quality forecasts, while the federal AirNow service tracks air quality and smoke across the country.
Where to check smoke and air quality
Resource | What to check |
Michigan air quality forecasts and alerts | |
Smoke patterns and air quality near your location | |
What the Air Quality Index means for your health |
EGLE uses air models to forecast when air quality may worsen. Its meteorologists work across 13 forecasting areas to help determine where alerts should be issued. Conditions can vary across the state, so check the forecast for your own community rather than relying on a statewide headline. To follow a smoke event, check your local AQI forecast, sign up for EGLE alerts, and revisit the Fire and Smoke Map each day. Watch for changes in the forecast instead of assuming smoke will clear by a certain date.
Protecting your household indoors
During wildfire season, limit outdoor activity when smoke affects your area. Set your HVAC system to recirculate air and use a MERV 13 filter if your system supports it. Avoid frying food or using gas-powered appliances indoors, as they add pollution. For health questions, call the MDHHS Environmental Health Hotline at 800-648-6942. Learn more about PM2.5 and indoor air quality to understand the risks of fine smoke particles. A battery backup cannot clean air or prevent fires, but it can keep a compatible air purifier or fan running during an outage. If you need to evacuate, it can also help keep your phone and essential lights powered.
During a wildfire evacuation, phones, flashlights, and emergency alerts become essential. A portable power station like the EcoFlow DELTA 3 Classic can keep compatible devices charged in your car, at a relative's home, or at an evacuation center. It does not prevent fires or clean wildfire smoke. During the DNR's "Set" stage, monitor emergency alerts and get your vehicle ready to leave. Pack a charged power station with your go-bag to keep essential devices powered. Before heading to a shelter, check whether it allows personal power stations or has available outlets. If the power goes out, the unit can run a compatible air purifier. It cannot remove smoke from the air. Here are the key specs to consider for a go-bag and shelter setup:
Where it fits and where it doesn't: The EcoFlow DELTA 3 Classic (1,024Wh) can power phones, lights, a Wi-Fi router, and a compatible air purifier plugged directly into it. Its stated 45-minute charge from 0 to 80% may help during a short evacuation warning. It cannot power house circuits without compatible equipment and professional installation, and it should not replace essential go-bag items such as water, medications, and documents. Keep it dry and away from smoke and heat.
Estimated runtime: Actual results vary by device and power use. Using 85% of capacity as a planning estimate gives about 870Wh of usable energy.
Wi-Fi router: Runtime depends on the router's power consumption. Check its wattage label and divide the estimated usable capacity (870Wh) by its wattage to estimate runtime.
Air purifier: A purifier rated at 50W would run for about 17 hours. Check your model's power label for a more accurate estimate.
Phones and lights: Check their wattage to estimate runtime. Charging multiple devices at once uses more power.
A home trial can help with testing power station runtime before emergencies so you know what to expect.
The go-bag is only useful if you leave at the right time. Michigan's "Ready, Set, Go!" stages help you prepare and act.
Michigan's DNR uses the Ready, Set, Go! system to help residents prepare for wildfires and know when to act. Each stage calls for a different level of readiness.
Ready: Stay informed, review your evacuation plan, pack an emergency bag, and keep your phone charged. Make sure family members know how to reach one another.
Set: Prepare to leave at short notice. Monitor local news and emergency alerts, load your car with essential items, and check your evacuation routes.
Go: Leave when officials tell you to evacuate. Follow their instructions and do not wait for further updates before acting on an evacuation order.
Go-bag checklist:
Phones and chargers: Keep phones powered to receive emergency alerts and contact family.
Portable power station: Charge phones and run compatible lights when outlets are unavailable.
Flashlights: Prepare for power outages and travel after dark.
Medications and documents: Pack essential prescriptions and copies of important records.
Water and N95 masks: Carry drinking water and masks to reduce exposure to wildfire smoke.
Pet supplies: Bring carriers, leashes, food, and other essentials for your animals.
In rural areas, where homes may be far from town along forest roads, plan two ways to leave and choose a meeting place. Prepare for pets and livestock, too, with this guide to evacuating pets and livestock safely. Most Michigan wildfires never lead to evacuations. Understanding what causes them can help you reduce risks around your property.
Many Michigan wildfires start with everyday activities. The DNR says nine out of ten wildfires in Michigan are caused by people. Its 2022 Wildland Fire Report listed debris burning as the leading known cause at 27%, followed by undetermined causes at 22% and power lines at 21%. Dry vegetation can fuel a fire even when the landscape looks green. The DNR has also warned that downed wood from the March 2025 ice storm had dried out in parts of the northern Lower Peninsula by May 2026, adding to the available fuel.
Red Flag Warnings in Michigan
A Red Flag Warning means weather conditions could raise the risk of fire. Fire can spread faster when the weather is hot, the air is dry, and winds are strong. The National Weather Service offices in Michigan set criteria for their own areas. For example, the Detroit/Pontiac office uses criteria that include sustained winds averaging at least 15 mph, relative humidity of 25% or less, and temperatures of 75°F or higher, along with high to extreme fire danger. Other offices may use different criteria, so follow the warning issued for your location.
Check burn permit rules before lighting a fire
Burn permit requirements vary by location. In the Upper Peninsula and northern Lower Peninsula, check the DNR's burn permit information or call 866-922-2876. In the southern Lower Peninsula, ask your local fire department or governing body about permit rules. Check for daily burning restrictions before lighting a fire. Never burn trash or treated wood. Keep brush piles within three feet in height and width, and leave at least 10 feet between the pile and nearby logs, stumps, or other debris. Keep water and a metal shovel nearby, and never leave a fire unattended. Continuous snow cover may affect permit requirements, but local ordinances and air quality rules can still apply, so check the rules for your area before lighting a fire.
Michigan doesn't have one outage map for every household. The utility that serves you depends on where you live, and Upper Peninsula residents may have a different provider from neighbors in the Lower Peninsula. Find the company name on your electric bill and save its official outage page before wildfire season. Start with your provider's own website to check for outages and restoration updates:
Consumers Energy: Serves many communities in the Lower Peninsula.
DTE Electric: Serves customers across southeast Michigan.
Upper Peninsula Power Company (UPPCO): Serves parts of the Upper Peninsula.
Co-ops and municipal utilities: Use the outage page provided by your local utility.
Check each provider's service territory and outage page directly. Don't assume a nearby home's utility is the same as yours. Also, don't assume a utility has a wildfire-related shutoff program unless it describes that program on its own website. If you see a downed power line or face immediate danger, call 911 first. Then contact your utility to report the problem. Stay well away from fallen lines. The same outage information can help during summer storms and ice storms, too. If you want to plan for longer household outages, explore EcoFlow's home backup power options and check which setup fits your needs.
Wildfires in Michigan often start with human activity, while smoke can travel across the state from distant fires. Bookmark the DNR's fire resources, follow EGLE and AirNow forecasts, and learn what Ready, Set, and Go mean before an evacuation order arrives. Check local burn rules before lighting a fire, and keep your go-bag packed with essentials. A charged portable power station can help keep phones, lights, and a compatible air purifier running when you need to leave or the power goes out. The EcoFlow DELTA 3 Classic is one option for those smaller devices, but it should be part of a broader emergency plan.
Where are the wildfires in Michigan right now?
Check the Michigan DNR's fire resources and news releases for updates on active wildfires, reported acreage, and containment. Check the date of each update, as fire conditions can change quickly. If you spot a wildfire that poses an immediate danger, call 911.
How long will wildfire smoke last in Michigan?
Wildfire smoke can clear quickly or linger for days, depending on the fire, wind, and weather. Check EGLE's air quality forecasts and alerts, along with the AirNow Fire and Smoke Map, each day. If smoke reaches your area, limit outdoor activity and follow local health guidance.
Do I need a burn permit in Michigan?
In the Upper Peninsula and northern Lower Peninsula, check the DNR's burn permit status or call 866-922-2876. In the southern Lower Peninsula, permits may come from your local fire department or governing body. Local rules still apply.
What causes most wildfires in Michigan?
According to the Michigan DNR, people cause nine out of ten wildfires in the state. Its 2022 report listed debris burning as the leading cause, accounting for 27% of reported wildfires. Unattended fires and burning debris under unsafe conditions can put nearby homes and forests at risk.
Can a portable power station run an air purifier during a smoke event?
Yes, if the purifier's power needs fit the station's output and available capacity. The EcoFlow DELTA 3 Classic can run a compatible purifier plugged directly into it, but the power station itself doesn't filter smoke or improve air quality.
