California Winds: What High Wind Alerts Mean and How to Keep the Power On When They Hit
- California Wind Alerts Explained: Wind Advisory vs. High Wind Warning, and Where to Check Yours
- When California Winds Cut the Power: Downed Lines and Public Safety Power Shutoffs
- Backup Power for Wind Outages and PSPS: EcoFlow TITAN Classic and EcoFlow TITAN Plus
- Santa Ana and Diablo Winds: Why California's Fiercest Gusts Blow From Land to Sea
- PG&E, SCE, SDG&E, and City Utilities: Outage Maps and PSPS Lookups
- Before, During, and After a California High Wind Event: A Household Checklist
- Conclusion
- FAQs
Here's a surprise for many newcomers. Some of the strongest California winds blow under clear blue skies. There's no storm and no rain. Dry air just pours off the deserts and mountains toward the coast. This guide explains what a Wind Advisory and a High Wind Warning mean here. It also shows why the numbers change by NWS office and terrain. You'll learn why your utility might cut power on purpose, plus ways to keep the fridge, Wi-Fi, and phones going. You'll also get a checklist for before, during, and after the next wind event.
The National Weather Service (NWS) issues wind alerts in California. But there's no single statewide number. Each NWS office sets its own trigger points, so a gust that earns an advisory on the coast may not earn one on a ridge.
Alerts come in three levels. Here's what each means, per the NWS definitions:
High Wind Watch: Steady, strong wind could develop, so it's time to plan.
Wind Advisory: Strong wind is blowing now, but it stays below warning level.
High Wind Warning: Strong wind is blowing steadily now, and the gusts are even stronger.
So a search for "high winds california," "high wind advisory california," or "high wind warning california" won't give you one answer. Here's how the NWS San Diego guide and the NWS Bay Area sheet set the bar.
Alert | NWS San Diego (updated August 2025) | NWS Bay Area (updated November 2014) |
Wind Advisory | Coast and valleys: sustained 25 mph or more, or gusts 35 mph or more. Ridges, passes, canyons: sustained 35 or gusts 50. Deserts: sustained 30 or gusts 45. | Steady wind of 35 mph or more lasting at least an hour. Or gusts of 45 to 57 mph (900 feet and below) or 45 to 69 mph (900 to 2,500 feet). |
High Wind Warning | Coast and valleys: sustained 40 mph or more, gusts 58 mph or more. Ridges, passes, canyons: sustained 50 or gusts 70. Deserts: sustained 45 or gusts 58. | Sustained 40 mph or more for an hour or more. Or gusts of at least 58 mph (900 feet and below) or 70 mph (900 to 2,500 feet). |
High Wind Watch | Not listed. | Same thresholds as the warning, possible within 12 to 48 hours. |
Both offices raise the bar on higher ground. The NWS Bay Area forecast glossary adds that a place that's windy all the time, like the bay in summer, won't get an advisory for its usual breeze.
Where to check live California wind alerts
News about high winds in California goes stale fast. Check the source instead:
Your address: Type your city or ZIP code into the search box at weather.gov.
Your NWS office: weather.gov/lox (Los Angeles), /sgx (San Diego), /mtr (Bay Area), /sto (Sacramento), /hnx (Hanford), or /eka (Eureka).
Each alert lists a sustained speed and a peak gust, so it helps to know how wind speed is measured. In California, strong wind can also mean a planned shutoff.
High winds cut power in two ways. Debris brings down lines, or utilities shut power off ahead of fire weather. Planned shutoffs can last until crews inspect the lines.
Per the CPUC's PSPS overview, a utility may switch off a line on purpose, as a last resort, when its own gear could start a fire. Its Phase 3 rules (D.21-06-034) also push utilities to add medical-device charging at Community Resource Centers.
Utility | What it says about notice | Alerts |
It tries to warn you early, day or night. Since forecasts shift, the first alert can arrive on the day of the shutoff. | Account holders get them automatically. | |
Notices can start up to three days ahead, with a final 1 to 4 hour warning. | Alerts for a specific address are open to everyone. | |
Its warning message gives roughly a 24 to 48 hour heads-up. | Renters and caregivers can sign up for notifications. |
PG&E doesn't use a set wind speed to decide. Its checklist covers humidity, the wind outlook, how parched the ground cover is, how close plants grow to its wires, any NWS Red Flag Warning, and live crew reports.
Rely on powered medical gear? PG&E sends those customers extra alerts, possibly in person. San Diego Gas & Electric's message points them to 211. Start preparing for public safety power shutoffs before fire season, not when the first alert arrives.
Utilities try to warn you early, but SCE says fast-changing winds can mean little to no notice. Keep your battery charged before fire season, and top it off while the grid is on once an alert comes.
Plan around the fridge first. FoodSafety.gov's outage guidance gives you about four hours with a closed fridge before food is at risk. Keep the freezer shut and a full one lasts about two days, while a half-full one lasts about one.
For the fridge, lights, Wi-Fi, and phones, a 120V home battery is the simpler route. EcoFlow TITAN Classic stores 5kWh and delivers 4,000W at 120V, so you can plug essentials straight into it. With the 120V Smart Home Panel 10, installed by an electrician, up to 10 selected circuits switch over on their own. It isn't for 240V appliances.
Need 240V loads like central AC, or more solar? EcoFlow TITAN Plus is the step up. It runs split-phase 120V/240V through the 240V version of Smart Home Panel 10, installed by a licensed electrician. Central AC still depends on its nameplate and other loads.
How long would they last? Say your fridge uses about 1,700Wh a day and your router about 168Wh (7W). Knock off about 15% for conversion losses, and either base unit (5kWh) keeps both going roughly 2.3 days. Estimates only.
Most of the year, California's breeze comes off the ocean. During offshore events, the flow reverses and dry inland air rushes downhill toward the coast.
Santa Ana winds (Southern California)
The NWS mountain and valley winds page traces Santa Anas to a high-pressure system parked over the desert Southwest. Air from that high squeezes through Southern California's passes on its way to lower pressure offshore. NWS says you'll see them most often in the cooler part of the year, from September to May.
Diablo winds (Bay Area)
Think of Diablo winds as the Bay Area's cousin of the Santa Ana, per the NWS Bay Area glossary. They pour down canyons in the East Bay hills, and the worst ones top 60 mph.
Why offshore winds raise fire danger
For fire forecasters, the worrying mix is California high winds and bone-dry air. San Diego's office flags fire weather when steady wind tops 25 mph or gusts top 35 mph while humidity stays at 15% or lower for six hours or more, per its Red Flag criteria. Other offices set their own criteria.
PG&E counts Red Flag Warnings among its PSPS factors, so offshore winds and shutoffs tend to arrive together. Learn more about Red Flag Warnings and fire weather.
Each provider has its own outage tools. PG&E, SCE, and SDG&E follow CPUC rules, while city utilities like LADWP and SMUD set their own.
Utility | Outage map or status page | PSPS lookup or alerts | Phone (only as the utility labels it) |
PG&E | For downed powerlines, PG&E's PSPS page says to call 9-1-1, "Then call PG&E at 1-800-743-5000." | ||
SCE | Check Outage Status. Search by address, outage number, or meter number. SCE says reported outages may take up to 30 minutes to appear. | If you can't find your outage, SCE's status page says to "please call us at 1-800-611-1911." | |
SDG&E | Downed lines: call 911. PSPS restoration details: 1-800-411-7343. | ||
LADWP (Los Angeles) | Check LADWP's own site. | 24/7 emergency and outage line: 1-800-342-5397. Medical emergency: call 911. | |
SMUD (Sacramento) | Check SMUD's own site. | Non-emergency outages: 1-888-456-7683. Sparking or downed wires: call 911 first. |
Spot a fallen wire? Keep back and dial 911 before calling the utility. PG&E's number for that second call is 1-800-743-5000. Smaller providers have their own pages, so check the name on your bill.
Most wind damage at home comes from things that move, like patio furniture and trash cans. A short routine covers the yard, the car, and the fridge.
Before (High Wind Watch or Wind Advisory)
Tie down or bring in anything loose outside, and shift your plans so you aren't stuck outdoors.
Top off phones and your power station, and double-check that your PSPS alerts are on.
Fill empty freezer space with full containers, since a full freezer stays safe longer.
During (High Wind Warning)
Head inside. If you must drive, grip the wheel with both hands and ease off the gas.
Stay away from downed lines, and keep fridge and freezer doors shut.
After
Toss refrigerated perishables after 4 hours without power, per FoodSafety.gov.
Once the grid is back, plug your battery in so it's full for next time.
Using a gas generator? A February 19, 2026 CPSC safety release says to keep it outdoors and at least 20 feet from your home, and to test CO alarms once a month. For more, see keeping fridge and freezer food safe during an outage.
California winds are judged by local NWS criteria that change with terrain, so the same gust can mean an advisory in one town and nothing in the next. Santa Ana and Diablo events can bring downed lines and planned PSPS shutoffs, sometimes with little notice. Learn your office's alert levels, turn on your utility's PSPS alerts, and plan backup around the fridge, lights, and Wi-Fi. For 120V essentials, EcoFlow TITAN Classic is worth a look. For compatible 240V loads and more solar input, consider EcoFlow TITAN Plus.
What is the difference between a high wind advisory and a high wind warning in California?
An advisory means strong wind below warning level. A warning means steady strong wind with even stronger gusts, using your NWS office's own mph limits.
What mph is a high wind warning in California?
It depends on the office. San Diego uses sustained 40 mph and gusts of 58 mph for coast and valleys, higher on ridges.
When do Santa Ana winds happen?
They show up most from September to May. Desert high pressure shoves dry air toward the coast.
How much warning do you get before a PSPS shutoff?
It varies and isn't guaranteed. SCE can start up to three days out, SDG&E gives about 24 to 48 hours, and PG&E's first alert might land the same day. Some come with little to no notice.
Can a portable power station run a refrigerator during a PSPS?
It can, if the fridge's draw fits within its output, and so can a 120V home battery like EcoFlow TITAN Classic. Runtime depends on daily use and other loads.
