Do Solar Panels Need to Be Cleaned? Here's What the Research Says
Solar panels are built to withstand rain, dust, pollen, and changing weather, but that does not mean they never need cleaning. For some homeowners, rainfall is enough to keep panels performing well. For others, dust, pollution, bird droppings, and wildfire ash can gradually reduce output. This guide explains whether solar panels really need cleaning, how often you should clean them, when professional service is worth the cost, and the signs that tell you your panels may need attention.
Do Solar Panels Really Need to Be Cleaned?
For the vast majority of U.S. homes, natural rainfall handles most dirt removal. A study from the University of California San Diego found that daily production losses caused by standard dust accumulation were less than 0.05%. In practical terms, washing a 5 kW residential system midway through a dry summer drought season only yielded roughly $20 in extra energy output.
Installation angle plays a critical role in natural cleaning. Solar arrays require at least a 5-degree tilt for rainwater runoff to wash away grime effectively. Flat or nearly flat installations tend to pool water and trap sediments around the lower frame edges.
However, the need for cleaning increases significantly in arid, high-dust, or industrialized regions. Research across Eastern China, Northern India, and the Arabian Peninsula found production losses of 17% to 25% with monthly cleaning and 25% to 35% when cleaning was delayed to every two months. In these environments, fine particulate matter and pollution can adhere to the glass surface, creating persistent obstruction and further affecting efficiency through factors such as heat and shade.
Certain types of debris also require direct intervention regardless of rainfall frequency:
  • Bird droppings: Dense and opaque, droppings block light entirely from individual cells.
  • Tree sap: Sticky resin traps airborne particulates and resists standard rainwater runoff.
  • Wildfire ash: Oily, fine residues create a semi-permanent film that impedes sunlight transmission.
When localized debris covers a specific cell, it creates uneven electrical resistance known as a "hot spot," potentially damaging the module over time.
Since regional weather and ambient debris dictate how fast dirt builds up, the core question is determining the right cleaning frequency for your specific environment.
Solar panels cleaningSolar panels cleaning
How Often Should Rooftop Solar Panels Be Cleaned?
There is no universal solar panel cleaning schedule for every solar installation. For many homeowners, once or twice a year is a reasonable starting point, while some systems may need little or no manual cleaning when rainfall regularly removes surface dirt.
  • Dry, dusty, or agricultural areas
Homes near farms, unpaved roads, construction sites, or dry landscapes may experience faster buildup. In these conditions, checking panels every few months can help determine whether cleaning is actually affecting performance.
  • Rainy or coastal climates
In areas with frequent rainfall and relatively low airborne dust, natural rain can do most of the cleaning. A yearly professional inspection may still be useful for checking the system, roof attachments, wiring, and other components even when the panels themselves look clean.
  • After unusual events
You may also want to inspect panels after wildfire smoke or ash, heavy pollen, prolonged dry weather, or nearby construction. These situations can leave more persistent deposits than ordinary dust.
The best approach is therefore to use the calendar as a guide rather than a strict rule. If your panels remain clean and production is normal, cleaning more frequently may not provide enough additional energy to justify the cost.
Condition
Suggested Cleaning Frequency
Regular rainfall, low dust
Rain-cleaned; annual inspection
Moderate dust/pollen
1–2x per year
Dry, dusty, or near agriculture/highways
Every 2–3 months
Heavy pollution or arid climate
Monthly to bi-monthly
  • Monitoring can help identify real output changes
A solar monitoring system can make this decision easier by showing how much electricity your system is actually producing. For example, the EcoFlow DELTA Pro Ultra combines substantial solar input capacity with app-based monitoring, allowing users to track system performance rather than relying only on how dirty the panels look.
For portable or ground-level setups, the EcoFlow 400W Portable Solar Panel is easier to access and wipe down than a roof-mounted array, making routine surface maintenance considerably simpler.
1. The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use. 2. 7.2-21.6kW output, powerful enough to run your whole home even with a central AC 3. 6kWh-90kWh capacity, whole house backup for weeks with comfort 4. Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2 5. 5 Charging Options, even plan B has a plan B
1. Charge faster with high 400W solar input 2. • Up to 23% conversion rate 3. • Durable, multi-layered materials 4. • Self-supporting with an adjustable angle 5. • IP68 waterproof rating
Knowing how often to clean is only half the picture, though. The other half is figuring out what that cleaning actually costs, and whether it’s worth paying someone else to do it.
Professional Cleaning Cost vs. DIY
Professional Cleaning Cost vs. DIYProfessional Cleaning Cost vs. DIY
Professional solar panel cleaning typically costs around $10–$20 per panel, with a typical residential cleaning service often falling in the $150–$500 range, depending on system size, roof accessibility, location, and the amount of buildup.
For roof-mounted systems, professional cleaning can be the safer option. Climbing onto a roof introduces fall risks, while improper cleaning techniques can potentially damage the panels.
Avoid using pressure washers, abrasive brushes, or harsh chemicals. Cleaning a hot panel under intense direct sunlight can also create thermal stress. Manufacturers may have specific maintenance recommendations, so checking the equipment documentation before cleaning is a good idea.
DIY cleaning makes more sense when panels are ground-mounted or easily accessible. For light buildup, plain water and a soft brush may be sufficient. If soap is necessary, use a mild solution that is compatible with the manufacturer's recommendations.
Before paying for a cleaning service, consider the potential return. If dirt is causing only a fraction-of-a-percent reduction in production, spending $150 or more to recover that small amount of generation may not make financial sense.
It is also important to distinguish dirt-related losses from the gradual decline that naturally occurs as solar panels age. Solar modules can lose some performance over their operating life even when they are perfectly clean, which is why understanding how solar panel efficiency changes over time can help put a cleaning-related output drop into perspective.
All of this points to one practical question: how does a homeowner actually know when their own panels have crossed the line from "fine" to "needs attention"?
Signs Your Solar Panels Actually Need Cleaning
Instead of cleaning panels simply because a certain amount of time has passed, look for signs that buildup may be affecting performance.
  • Visible dirt or debris: A substantial layer of dust, pollen, bird droppings, or other material covering the surface is a good reason to inspect the panels more closely.
  • Sustained output decline: A monitoring app showing lower-than-expected production across several otherwise comparable sunny days may indicate a problem worth investigating.
  • Uneven production: If one panel or string consistently produces less than comparable panels, localized debris or shading could be contributing to the difference.
  • Persistent bird droppings or sap: These materials can remain on the panel after rainfall and may block sunlight in concentrated areas.
  • Wildfire ash or heavy pollution: Ash and sticky particulate matter can create deposits that ordinary rainfall may not remove effectively.
  • No performance monitoring: Without production data, it is harder to determine whether cleaning would actually improve your system's output.
Keep in mind that a single low-production day does not necessarily mean your panels are dirty. Clouds, temperature, shading, seasonal sunlight, equipment issues, and grid conditions can all affect generation.
For most homeowners across the U.S., rain and a properly angled roof handle the bulk of the cleaning on their own, and dirt-related output loss is smaller than most people expect. The exceptions are dry, dusty, or heavily polluted regions, plus stubborn stuff like bird droppings or wildfire ash that rain just won't touch.
Before you pay for a cleaning service, pull up your monitoring app and check for a real, sustained drop in output, not just one gray day. Then weigh that against the typical $150-$500 cost, since most systems will only see a modest bump from cleaning.
To track system performance and capture real-time power metrics, explore the EcoFlow DELTA Pro Ultra, or consider the EcoFlow 400W Portable Solar Panel for an accessible, low-maintenance power setup.
Do solar panels need to be cleaned regularly, or does rain handle it?
In most temperate regions, regular rainfall combined with a pitched roof (at least 5 degrees) removes the majority of ambient dust. Regular manual cleaning is generally only required in arid regions, agricultural zones, or areas with persistent soot and pollution.
How often do solar panels need to be cleaned?
Most systems can be checked once or twice a year, while dry or dusty locations may require attention every two to three months. Heavily polluted or arid areas may need more frequent cleaning based on actual buildup and performance.
Do rooftop solar panels need professional cleaning, or can I do it myself?
Professional cleaning is generally safer for roof-mounted panels because of fall risks and the potential for equipment damage. DIY cleaning can be reasonable for accessible ground-mounted systems when using appropriate, non-abrasive methods.
Does dirt on solar panels actually reduce energy output?
Yes, dirt can reduce solar output by blocking some sunlight from reaching the cells. However, the effect varies considerably with the amount and type of buildup, rainfall, panel angle, climate, and local pollution levels.
How can I tell if my solar panels need cleaning?
Look for substantial visible buildup and compare your system's production over multiple similar sunny days. A sustained drop in output combined with visible debris is a stronger reason to investigate cleaning than a single low-production day.
Solar Panels
