EcoFlow DELTA 3 Ultra Plus vs. EcoFlow DELTA Pro 3: Which Backup is Right for You?
Finding the right backup battery station is not an easy task at first. There are many options to choose from, each with different specs. They have different AC outputs, storage capacity, number of outlets, and sizes. EcoFlow provides a power station to meet anyone’s lifestyle and needs, but you still need to look at what each one offers.
Keep reading to learn why you need backup power, the difference between semi-permanent and portable options, and compare the difference between two of EcoFlow’s top power stations: the EcoFlow DELTA 3 Ultra Plus and the EcoFlow DELTA Pro 3.
EcoFlow DELTA Pro 3
Why Backup Power Matters More Than Ever
Electricity is essential for many parts of everyday life. But you never know when there won’t be access to a power outlet, whether that’s from an unexpected power outage or a planned off-grid camping trip.
Having backup power is no longer considered a luxury; it’s an essential. It provides peace of mind in the new digital age, allowing you to charge phones, other electronics, and appliances.
Understanding Portable vs. Semi-Permanent Backup Power
Portable options are grab and go single-style units, designed to move wherever you need electricity. You can move it in your house between rooms or put it in your car for a road trip. They’re great for apartments or RVs because they are small and not integrated into your home’s electrical wiring.
Semi-permanent stations are physically portable, but are designed to be a whole-home backup solution. They are integrated into your home’s electrical wiring through a smart home panel.
EcoFlow DELTA 3 Ultra Plus: Portable Backup Power for Flexible Use
The EcoFlow DELTA 3 Ultra Plus is EcoFlow’s top portable power station in the series. It offers 3.6kW AC output and has 3kWh capacity. In X-Boost mode, it can run appliances that require 4.6kW of continuous AC output.
It’s designed to integrate into your home’s electrical system or move with you. The power station features a suitcase-style handle and wheels to easily transport it. It’s the best option for camping, backyard parties, or long road trips.
DELTA 3 Ultra Plus Portable Power Station
The EcoFlow DELTA 3 Ultra Plus delivers 3072Wh of smart, reliable backup power you can scale up to 11kWh. Prioritize essential circuits, power heavy appliances with 3600W output, and recharge fast with 48-minute Dual Charging. With long-lasting LFP cells, 10ms auto-switching, ultra-quiet operation, and OASIS 3.0 app control, it’s a compact, future-ready solution for seamless home backup.
EcoFlow DELTA Pro 3: High-Capacity Backup for Home and Off-Grid Power
If you’re looking for a larger whole-home backup option, the EcoFlow DELTA Pro 3 delivers 4kW of AC output and has 4kWh storage capacity. In X-Boost, the AC output jumps to 6kWh.
This power station is designed to be semi-permanent. The large capacity and AC output specs are best suited for home integration, but it can be disconnected for use elsewhere when ended. With EcoFlow’s modular battery design, you can chain multiple EcoFlow DELTA Pro 3 together for a total combined capacity of up to 48kWh with 12 units.
EcoFlow DELTA 3 Ultra Plus vs. DELTA Pro 3: Power, Portability, and Setup
The EcoFlow DELTA 3 Ultra Plus offers less AC output and storage capacity than the EcoFlow DELTA Pro 3, but it’s more portable. It’s easy to roll with the suitcase design and only weighs 74.3 lbs. The EcoFlow DELTA Pro 3 provides an extra 1kWh of storage capacity, for a total of 4kWh. This station also has wheels and an extendable, but it weighs 113.5 lbs. It’s difficult to lift into cars, trucks, or RVs with only one person, but perfect for home integration.
Best Use Cases for EcoFlow DELTA 3 Ultra Plus and EcoFlow DELTA Pro 3
This is the best choice for mobile power. It fits perfectly into tight spaces like vans or RVs. It’s also easy to lift, so contractors and DIYers love it. They can lift it into a truck bed easily when moving between job sites. It’s a standalone unit in apartments where you can’t hardwire into the electrical system.
EcoFlow DELTA Pro 3
If you want to integrate into your home’s electrical system with enough power to back up all your appliances and electronics, you need the EcoFlow DELTA Pro 3. It’s built for supporting home resilience. It’s not ideal for moving from home to another location regularly, but the expandable handle and wheels provide that option if it’s needed in a pinch.
Battery Expansion and Long-Term Backup Planning
The EcoFlow DELTA Pro 3 is great for at-home use because of the modular design. You can chain together multiple units for up to 48kWh of storage capacity, that’s enough to power the average American home for a day and a half. Install EcoFlow solar panels for extended, long-term backup power during a power outage and reduce your carbon footprint.
EcoFlow DELTA 3 Series
EcoFlow DELTA 3 Max line delivers 2,048Wh portable power with 2,400–3,000W output (up to 6,000W surge) and X-Boost for heavy-duty appliances. It recharges fast via multiple methods (0–80% in as little as 43–68 minutes), expands from 2–10kWh, and adds app-based output priority plus 10ms auto-switch backup. Built with long-life LFP cells, whisper-quiet ≤25dB operation, OASIS 3.0 control, and up to a 5-year warranty.
Can You Use a Portable Power Station Indoors?
You can use EcoFlow portable power stations indoors. They rely on electricity stored in the battery system, unlike traditional fuel generators that create electricity from combustion reactions. EcoFlow backup stations are quiet and emission-free, so you can use them indoors without worry of carbon monoxide accumulation.
Will an EcoFlow DELTA 3 Run a Refrigerator?
Yes, the Ecoflow DELTA 3 will run a refrigerator. The EcoFlow DELTA 3 Ultra Plus is the best option in the EcoFlow DELTA 3 Series, with 3600W of AC output and an additional 7200W of surge. It can handle running the fridge and the initial starting wattage for it to turn on.
Can EcoFlow DELTA Pro 3 Power Your Whole House?
Yes, the EcoFlow DELTA Pro 3 can power your whole house. With just one unit, you can power the essential core appliances and devices. For more complete home backup, expand the capacity with multiple EcoFlow DELTA Pro 3 power stations for a total of 48kWh.
Upgrade Your Backup Power with EcoFlow DELTA 3 Series
You need a backup power option. Energy resilience at home is a necessity these days, and EcoFlow offers practical, affordable, and reliable solutions. The EcoFlow DELTA 3 Ultra Plus is a portable but powerful choice to run the essentials on the go. Take it camping, RVing, around the yard, or leave it at home.
The EcoFlow DELTA Pro 3 is a semi-permanent option that is integrated into your home’s electrical system for next-level backup security. No matter which power station you’re leaning towards, any option from EcoFlow’s DELTA 3 Series lineup is ready to reliably power your electronics and appliances.
Home Backup
