Deep Cycle Battery Solar Guide: Choosing, Sizing, and Caring for Your Battery Bank
- What makes a deep cycle battery the right fit for solar?
- Flooded, AGM, Gel, and LFP: comparing solar deep cycle batteries
- Integrated LFP alternatives to building a DIY battery bank
- How to size deep cycle batteries for solar panels?
- Safety, maintenance, and recycling for solar deep cycle batteries
- Conclusion
- FAQs
If your solar panels are already installed, the next question is often which battery bank to use. Deep cycle batteries come in many types and price ranges. The wrong choice can mean poor service life, more maintenance, or an unsafe setup. This guide compares four common battery types, explains how to size a bank, and covers key safety and recycling rules.
A car battery is designed to deliver a large burst of power for a few seconds. A solar battery has a different job. It must discharge steadily and recharge again and again. This repeated drain and refill is what makes a battery a deep cycle battery.
One key term is depth of discharge (DOD). It shows how much of a battery's capacity you use before recharging it. For example, using 30% of a battery's capacity means the battery has a 30% DOD for that cycle.
DOD has a direct effect on lead-acid battery life. Sandia research on sealed lead-acid batteries found about 150 to 200 cycles at 100% DOD, compared with 1,000 or more cycles at 30% DOD. This shows why shallower daily cycles can help extend lead-acid battery life.
For solar systems, this can mean choosing a larger lead-acid bank than your daily energy use might suggest. The extra capacity lets you use a smaller share of the bank during each cycle.
Before buying a battery, check these key specifications:
Voltage
Amp-hour (Ah) or watt-hour (Wh) capacity
Rated DOD or usable capacity
Operating temperature range
Warranty terms
Understanding how deep cycle batteries differ from starting batteries can help you avoid using a car battery in a solar system.
Solar storage uses several battery chemistries. DOE lists lithium-ion as the most common battery cell chemistry for energy storage, with lead-acid among the other common options. Within these groups, flooded lead-acid, AGM, gel, and lithium iron phosphate (LFP) are common choices.
Flooded lead-acid
Flooded lead-acid batteries usually have the lowest upfront cost. They also need more upkeep than sealed designs.
NREL notes that vented lead-acid batteries are often the least expensive option but require ongoing maintenance, including adding water. Charging can also release gas. Sandia notes that escaping hydrogen is highly flammable. For this reason, flooded batteries need a suitable ventilated location. They also need regular checks and proper handling.
AGM and gel (sealed lead-acid)
AGM and gel batteries are sealed, valve-regulated lead-acid designs. They do not require regular water additions.
Sandia explains that these batteries can recombine oxygen during overcharge. This reduces the need for maintenance compared with flooded batteries. Heat remains an important concern. Sandia reports that every 15°F (8°C) rise in temperature can cut sealed lead-acid battery life in half. A cool installation area can therefore help protect service life.
Lithium iron phosphate (LFP)
LFP is a lithium-ion chemistry used in many solar batteries and power stations. It generally requires less routine maintenance than flooded lead-acid batteries.
NREL's 2019 analysis used a 90% round-trip efficiency assumption for lithium-ion systems and 80% for lead-acid. Its modeled results also found lower lifecycle costs for lithium-ion systems across the cases studied. The study modeled NMC lithium-ion batteries, so these figures should be treated as context rather than direct LFP performance data. NREL also notes that LFP batteries can typically be stored at full charge with less degradation.
Deep cycle solar battery types at a glance
Type | Maintenance | Venting needs | Heat sensitivity | Upfront cost | Best fit |
Flooded lead-acid | Regular | Yes | High concern | Low | Buyers focused on lower upfront cost |
AGM | Low | Lower than flooded | High concern | Medium | Low-maintenance lead-acid setups |
Gel | Low | Lower than flooded | High concern | Medium | Sealed lead-acid applications |
LFP | Low | No routine venting | Follow maker's limits | High | Solar storage with low upkeep |
If you prefer a traditional lead-acid bank, learn about setting up lead-acid batteries with solar before choosing cables, fuses, and other components.
Building a battery bank from separate components takes careful planning. You must match battery voltages, balance batteries, choose a charge controller and inverter, and provide proper ventilation for flooded cells. An integrated LFP system combines the battery, battery management system, and inverter in one enclosure. This can simplify solar storage for both homes and smaller setups.
EcoFlow DELTA Pro Ultra X
The EcoFlow DELTA Pro Ultra X is designed for installed home energy storage. Its standard bundle includes one inverter and two Smart Extra Batteries, providing 12kWh of storage and 12kW of output. Each Smart Extra Battery adds 6,144Wh and uses EV-grade LFP cells.
The system can expand to 180kWh, depending on the configuration. EcoFlow states that actual performance varies by setup. The system can pair with Smart Home Panel 3 or Smart Gateway 200A and requires installation by a licensed electrician.
For rooftop solar charging through the Smart Home Panel 3 or Gateway, current transformers are required. EcoFlow also offers a bundle with four 400W solar panels, which it says can provide up to 1.6kW of solar input.
Heavy loads such as central air conditioning, electric ranges, well pumps, and electric water heaters depend on the number of batteries and the system configuration. Renters and mobile home owners may also need approval from a landlord or park.
EcoFlow DELTA 3 Max
The EcoFlow DELTA 3 Max provides 2,048Wh of LFP storage in one portable unit. It can be paired with EcoFlow solar panels rated from 220W to 500W.
This setup can suit sheds, cabins, and RVs where a small DIY battery bank would otherwise require separate batteries, wiring, and other components. As an energy comparison, 2,048Wh is roughly equal to:
System voltage | Approximate equivalent capacity |
12V | 170Ah |
24V | 85Ah |
48V | 43Ah |
These figures show energy equivalence only. They do not represent expected runtime.
Homeowners comparing a DIY bank with a packaged system can also review battery storage for solar panels and compare the storage capacity with their expected solar production.
Comparing the two approaches
The EcoFlow DELTA Pro Ultra X is intended for a larger, installed home energy system connected to rooftop solar. The EcoFlow DELTA 3 Max is a portable option for smaller applications such as sheds, cabins, and RVs.
The main difference is the scale and installation method. A DIY battery bank gives you control over individual components. An integrated system packages several key components into one unit.
Battery capacity is often listed in amp-hours, while appliances use watts. To size a battery bank, start by converting your expected energy use into watt-hours.
DOE recommends estimating daily energy use by multiplying an appliance's wattage by the number of hours it operates each day. Once you know your daily watt-hour use, you can estimate the storage capacity needed.
1. Add your daily energy use
List the appliances you want the battery to power. Multiply each appliance's wattage by its daily operating hours.
For example:
Watts × hours = watt-hours
Add the results for all appliances to get your estimated daily energy use.
2. Account for cloudy days
Decide how many days of stored energy you want available when solar production is low. Multiply your daily watt-hour requirement by that number of days.
More days of autonomy require more battery storage.
3. Account for usable battery capacity
Do not assume that every watt-hour listed on a battery can be used without affecting its service life.
For lead-acid batteries, a lower DOD can help extend cycle life. LFP batteries can generally use a greater share of their rated capacity, but you should follow the usable-capacity figure provided by the manufacturer.
4. Convert watt-hours to amp-hours
Once you know the required energy storage, divide watt-hours by system voltage:
Ah = Wh ÷ system voltage
For example, 5,000Wh of storage is approximately:
System voltage | Approximate capacity |
12V | 417Ah |
24V | 208Ah |
48V | 104Ah |
The energy is the same in each example. A higher system voltage requires less current for the same amount of power. This can allow for smaller cables and fewer parallel battery strings.
Understanding what amp-hours on a battery measure can make battery labels easier to compare.
Avoid mixing old and new batteries or different battery chemistries in the same bank. Follow the manufacturer's instructions for series and parallel connections.
A correctly sized battery bank still needs proper installation and care. The safety and maintenance needs can vary greatly by battery type.
Batteries store a large amount of energy in a small space. Each chemistry has different safety needs. Flooded lead-acid batteries can release gas and need water. AGM, gel, and LFP batteries do not need routine watering, but they still need correct charging and temperature control.
Ventilation and handling
Flooded lead-acid batteries need good ventilation because charging can release hydrogen gas. OSHA 29 CFR 1926.441 requires ventilation in battery handling areas to prevent an explosive gas mixture from building up. It also calls for eyewash or drench facilities within 25 feet of battery handling areas.
For a home solar setup, keep flooded batteries in a suitable ventilated space. Keep them away from sparks and open flames. Wear eye protection when checking or adding battery water.
Always follow the battery maker's installation and handling instructions. Battery banks can carry high current, so avoid working on live connections unless you have the proper training.
Temperature and charging
Temperature can affect battery life. Sandia reports that every 15°F (8°C) rise can cut sealed lead-acid battery life in half. It also notes that charging above 2.40V per cell can shorten service life through grid corrosion.
Use the charging settings specified by the battery manufacturer. Do not guess the voltage or charging profile. Keep batteries away from hot attics and areas exposed to direct sun. This matters even more in warm climates, where high ambient temperatures can raise battery temperature for long periods.
LFP batteries also need to stay within the temperature range set by the manufacturer. Their battery management system can help control charging and protect the cells, but it does not replace correct installation and operating conditions.
Recycling and disposal
Old batteries should not go into regular household waste. EPA guidance says lead-acid batteries should be returned to a retailer or taken to a local household hazardous waste program.
Lithium-ion batteries should not be placed in household trash or municipal recycling bins. EPA recommends contacting the battery maker or installer for recycling and disposal options. Battery terminals should be taped, and batteries should be placed in a bag to reduce fire risks during handling and transport.
Local recycling rules can vary. Check the requirements in your area before taking a battery to a collection site.
Charging habits matter as much as battery chemistry. Learn how to charge a deep cycle battery by using the correct charging method for your setup.
Battery type | Main maintenance task |
Flooded lead-acid | Check water levels and terminals |
AGM | Keep the battery cool and use the correct charge profile |
Gel | Keep the battery cool and use the correct charge profile |
LFP | Stay within the manufacturer's temperature range and follow its charging guidance |
Choosing a deep cycle battery for solar starts with your energy needs and the way you plan to use the system. Flooded lead-acid batteries can offer a lower upfront cost, but they require more maintenance. AGM and gel batteries reduce routine upkeep. LFP batteries offer low maintenance and can support deeper cycling, subject to the manufacturer's specifications.
Start by calculating your daily energy use in watt-hours. Then account for the number of days of storage you need and the usable share of the battery. Finally, convert the required watt-hours to amp-hours based on your system voltage.
If you want to avoid building a battery bank from separate components, an integrated system can simplify the setup. For larger home solar systems, consider the installed EcoFlow DELTA Pro Ultra X. For smaller setups, the portable EcoFlow DELTA 3 Max can provide an alternative to a small DIY battery bank.
What is the best deep cycle battery for solar?
The choice depends on your budget, maintenance needs, and storage requirements. LFP does not need watering and supports deeper cycling. Flooded lead-acid has a lower upfront cost.
How many deep cycle batteries do I need for solar panels?
Calculate your daily watt-hours, multiply by the required days of autonomy, divide by the usable proportion (e.g., 0.8 for 80%), and then divide by system voltage to estimate amp-hours.
Can I use a car battery for solar?
No. Starting batteries are designed for short bursts of high current rather than repeated deep discharge. A solar battery should be designed for regular cycling.
How long do deep cycle solar batteries last?
Service life depends on factors such as depth of discharge, temperature, charging, and battery type. Sandia's data shows that deeper cycling and higher temperatures can reduce lead-acid battery life.
How do I dispose of an old solar deep cycle battery?
Return lead-acid batteries to a retailer or local household hazardous waste program. Do not place lithium-ion batteries in household trash or curbside recycling bins. Follow local recycling guidance.
