Small Solar Power System: What It Takes to Build One
A small solar power system can cover a surprising amount of everyday power use without covering your entire roof in panels. A cabin, RV, garage, or small home setup may only need a few panels and a battery-based power station. The right size depends on what you want to run, how much electricity you use, and whether you need power at night or during an outage.
The core components of any solar system
A solar setup has a few basic jobs to handle: make electricity, control it, store it if needed, and turn it into the type of power your appliances use. You can buy those parts separately or choose a system that puts several of them in one unit.
The core components of a solar systemThe core components of a solar system
Solar panels
Solar panels turn sunlight into DC electricity. The amount of power they produce depends on the panel wattage, the number of panels, sunlight, shading, and how the panels are positioned. For a small setup, you might only need a few panels. A cabin that uses a few lights and charges phones needs far less solar capacity than a home trying to run central air conditioning.
Charge controller
A charge controller manages the voltage and current coming from the solar panels before that power reaches a battery. It helps keep the battery from receiving more charge than it can handle. If you're building a system from separate components, the charge controller is one of the pieces you'll need to size correctly. A portable power station handles this part inside the unit, so you don't have to wire a separate controller.
Battery storage
A battery stores solar energy, so you can use it after the sun goes down or when clouds reduce panel output. You don't necessarily need one for a grid-connected system, but battery storage becomes much more useful if you want backup power or an off-grid setup. For a closer look at a beginner-friendly setup, this guide to a small solar panel kit covers how panels and home battery storage can work together.
Inverter
Solar panels and batteries produce DC electricity, while most household appliances use AC power. An inverter converts the stored DC electricity into the AC power your refrigerator, TV, laptop charger, and other household devices need. That means a complete system needs more than panels alone. The way those components are connected depends on whether you're staying connected to the utility grid.
Off-Grid, On-Grid, and Hybrid Systems
A small solar power system can be set up in a few different ways. Your choice depends mostly on whether you want to stay connected to your local utility and whether you need electricity when the grid goes down.
System Type
Key Characteristic
Off-grid
Fully independent, requires battery storage
On-grid
Connected to utility power, no storage battery needed
Hybrid
Grid-connected with battery backup for outages
Off-grid solar
An off-grid system has no utility connection to fall back on. That makes battery storage a key part of the setup because you need somewhere to keep the energy produced during sunny hours. This type of system can make sense for a remote cabin, hunting property, workshop, or other location where connecting to the utility isn't practical. You'll need enough solar and battery capacity to cover your normal use and periods of poor weather.
On-grid solar
An on-grid system stays connected to your local utility, with solar panels reducing how much power you draw from the grid. You don't need a battery for a basic setup, but standard grid-tied solar usually won't power your home during an outage. See this guide to on-grid and off-grid solar for the key differences.
Hybrid solar
A hybrid system combines solar, utility power, and battery storage. During normal conditions, you can use solar energy and the grid as needed. When the grid goes down, the battery can supply backup power to selected loads or circuits, depending on the system. For homeowners who want solar but also care about outage protection, this setup can offer more flexibility than panels alone.
Starting Small With a Battery-Based System
Building a solar system from individual panels, a charge controller, an inverter, and a battery bank can get complicated fast. You need to size each part correctly and wire everything, so the components work together. A portable power station takes care of much of that setup inside one unit. You can connect compatible solar panels to the power station instead of building the battery, inverter, and charging system separately.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
•Ultra-Fast AC Recharging: Features four flexible charging methods, topping off from 0% to 80% in just 45 minutes via standard AC power. • 1,800W Output with 3,600W Surge: Delivers 1,800W continuous output (3,600W surge) and leverages X-Boost™ technology to power high-demand devices up to 2,600W, including refrigerators, microwaves, and air conditioners. •10ms Auto-Switch UPS: Provides rapid emergency switching to keep critical electronics, NAS systems, and servers running without interruption. •Whisper-Quiet Operation: Runs at an ultra-low noise level of ≤30dB at 600W output for quiet indoor and outdoor use.
If your power needs may grow over time, the EcoFlow DELTA 3 Plus gives you expandable capacity from 1kWh to 5kWh. It also delivers 1,800W of continuous output, supports five charging methods, and can handle higher-demand devices with X-Boost.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
Whichever setup you choose, sizing it correctly helps you avoid paying for more equipment than you need or ending up without enough power. Start with your daily electricity use, then match the panels and battery capacity to those needs.
Roughly Sizing a Small Solar System
The right size depends on how much electricity you need each day. A small solar power system for a cabin, tiny home, or mobile setup may produce around 0.5 to 5 kWh per day, depending on the panel capacity and local sunlight.
Start with your actual power use
If you're sizing a system for your home, check your recent electric bills to see how much electricity you use. For a cabin or RV, make a list of the appliances and devices you plan to run, then estimate how many hours you'll use them each day. This gives you a realistic daily kWh target before you start shopping for panels or batteries. It also helps prevent buying a system that's much larger than you need.
Pay attention to panel placement
Where you put the panels matters just as much as their rated wattage. A south-facing array with little shade can produce more energy than the same-size array blocked by trees or buildings for part of the day. Your local weather and seasonal sunlight also affect production. If you're planning a larger home setup, this guide to sizing a home solar system covers the calculation in more detail. Getting the size right from the start leaves you with a system that's easier to manage and gives you room to add capacity later.
What a Small System Can Realistically Power
A small solar power system can handle many of the basics you use every day. A system producing around 0.5 to 5 kWh per day can typically cover lights, a small refrigerator, phone and laptop charging, and Wi-Fi.
What a Small System Can PowerWhat a Small System Can Power
Everyday essentials
Smaller loads are good for a starter system because they don’t typically require a lot of power at one time. You can use a small setup for basic lighting, a compact refrigerator, phone and laptop charging, Wi-Fi, and other everyday electronics without building a large solar array or battery bank.
Larger appliances
Large appliances can quickly increase your power needs because they draw more watts and may run for several hours. A full-size air conditioner, electric range, electric water heater, or clothes dryer can require far more solar production and battery capacity than a small starter system can provide.
Start small and expand
You don't have to build the biggest system right away. Starting with essential loads lets you keep the initial setup manageable, and you can add more panels or battery capacity later as your needs grow. Once your system is running, these solar maintenance tips can help you keep it in good shape.
A small solar power system can cover useful everyday loads, without the large expensive setup. First check your actual electricity usage, then calculate the panels and battery for the appliances you want to run. You can start with lights, Wi-Fi, device charging and a small refrigerator, but larger appliances may require more capacity. A portable power station can also make the setup easier by combining the important components into one. EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Plus give you a practical starting point, with the option to add capacity as your power needs grow.
How much does a small solar power system cost?
It is dependent on the amount of power you need, how many panels you install, and if you add battery storage. A small setup with a few panels and a portable power station can cost less than a full home solar installation, especially if you're starting with essential loads and adding capacity later.
Can a small solar system run a whole house?
A small system usually can't run every appliance in a typical home. It can handle essentials such as lights, Wi-Fi, device charging, and a small refrigerator, while central AC, electric water heaters, dryers, and electric ranges usually need a larger system.
What size solar system do I need for a cabin?
First, make a list of the appliances and devices you will use and how long you will run them each day. A cabin with basic lighting, refrigeration, Wi-Fi, and device charging may fit within a 0.5 to 5 kWh daily setup, while electric heating, AC, or cooking will require more capacity.
Do I need a battery for a small solar system?
Not necessarily. An on-grid system can work without a battery because you can still draw electricity from your local utility when solar production drops. Battery storage becomes important for off-grid setups and can also provide backup power when the grid goes down.
How many solar panels does a small system need?
There's no single panel count for every small system. The number depends on your daily electricity use, panel wattage, sunlight, shading, and panel placement. Calculate your daily kWh needs first, then choose enough panel capacity to produce the energy your setup requires.
Solar Panels
