How to Estimate DELTA Pro Ultra X Runtime for Your Home
- What Should You Confirm Before Comparing Battery Options?
- Why Is Usable Energy Lower Than Nameplate Capacity?
- How Do You Build a Critical Load List Before Doing the Math?
- How Do You Measure Your Loads Without Guessing?
- How Do You Estimate Runtime without Solar?
- How Do You Estimate Runtime With Solar?
- Final Thoughts
- Frequently Asked Questions
When the power goes out, the question is simple: how long will your battery keep the essentials running? The answer depends on which loads stay on, how often they cycle, what starts together, battery temperature and age, and whether solar is available. Start with your real load list—not a headline number of days—and you can estimate 24-, 48-, and 72-hour runtime without guessing.
Start with your measured load list before comparing packages. No specific DELTA Pro Ultra X configuration is valid without daily kWh, running watts, motor starting data such as surge watts or LRA, voltage, likely overlaps, temperature, reserve, outage duration, connection method, and any solar or generator input. Every number below is a planning estimate with its assumptions shown; EcoFlow or a qualified installer must verify the final system. This guide does not promise a 5-ton air conditioner, every household circuit, or every well pump.
Usable energy is lower than nameplate capacity because reserve, the planned SOC window, conversion losses, temperature, battery age, and standby controls all sit between the cells and your outlets. Three homes can own the same battery and see three different outage nights: one keeps only a refrigerator, medical device, and router running; another adds a well pump and furnace; a third leaves cooling and cooking on.
1. The reserve you set
Choose a planning stop point instead of assuming the pack will be used to zero. The available SOC window is starting SOC minus planning stop SOC; if you start at 100% and plan to stop at 10%, the window is 0.90. That 10% is a planning choice, not a factory limit or the app's Backup Reserve setting.
2. Depth of discharge
LFP cells can generally use a deeper planned window than lead-acid batteries, but the usable window still depends on the system's controls, temperature, age, and the reserve you choose. Use the current EcoFlow specification and manual for product-specific limits.
3. Round-trip and inverter efficiency
Stored energy is DC and household outlets use AC. The inverter, wiring, cooling, controls, and standby draw consume some of that energy. This guide uses 0.90 as a visible planning assumption, not as a published DELTA Pro Ultra X round-trip-efficiency claim.
4. Temperature
The current product documentation lists the DELTA Pro Ultra X battery range as −4°F to 113°F (−20°C to 45°C); the inverter range is listed separately as −4°F to 122°F (−20°C to 50°C). Those are operating limits, not a full-capacity curve. For this demonstration, use a 0.90 temperature factor at 32°F (0°C) and 0.80 at 14°F (−10°C), unless EcoFlow provides a hardware- and firmware-specific curve.
Battery temperature | Planning factor on usable energy |
59–113°F (15–45°C) | ~100% |
41–59°F (5–15°C) | ~95–100% |
32–41°F (0–5°C) | ~90–95% |
14–32°F (−10–0°C) | ~85–90% |
−4–14°F (−20 to −10°C) | ~75–85% — the edge of the operating envelope; plan on the low end |
*Illustrative LFP derating for planning only. Confirm exact figures against the official EcoFlow specification sheet for your region before purchase.
5. Battery age
Battery age changes the starting point. The 0.95 remaining-capacity factor used below is an illustrative planning assumption, not a warranty threshold, cycle guarantee, or prediction for a particular unit. Replace it with app data or a controlled test when available.
So, for the actual usable energy, here is a formula:
Usable delivered energy (kWh) = nameplate (kWh) × available SOC window × remaining-capacity factor × temperature factor × discharge-to-AC efficiency
Example: 12.288 kWh × 0.90 × 0.95 × 0.90 × 0.90 = 8.51 kWh
Inputs: 12.288 kWh official standard capacity; 100% starting SOC minus a 10% planning stop (0.90 window); 0.95 illustrative remaining capacity; 0.90 illustrative temperature factor at 32°F; and 0.90 illustrative discharge-to-AC efficiency. Only the first figure is a product specification. The other values are visible planning choices.
Under these demonstration assumptions, 12.288 kWh × 0.90 × 0.95 × 0.90 × 0.90 = 8.51 kWh of planned AC energy. That is a worksheet result, not a runtime promise.
At the example load of 9.84 kWh/day and with no recharge, the average-energy runtime estimate is 8.51 ÷ 9.84 × 24 ≈ 20.8 hours. This result applies only to the stated assumptions. Actual depletion time also depends on when the loads run.
Before any calculation, you need your list. Not "the house," but the individual things you will actually leave on. Sort every appliance into three tiers. This is the single most useful habit in home backup planning.
Tier | What belongs here | Planning role |
Must-Run | Fridge, freezer, well pump (if you have one), medical devices, WiFi/router, a fridge-light circuit, sump pump in wet season | Sets your minimum battery size. Non-negotiable. |
Intermittent | Microwave, coffee maker, washing machine, TV, LED lighting in evening, tool use | Adds energy but on a duty cycle — not 24/7. |
Sacrifice | Electric dryer, oven (use gas if available), pool pump, EV charging, second fridge | Dropped first when the math gets tight. |
Keep three numbers for every load
Running watts: the power used after the appliance is operating. This helps test simultaneous output.
Starting watts, surge, or LRA: the brief demand when a compressor, pump, or motor starts. This answers "Can the system start it?"
Daily energy in kWh: power multiplied by actual operating time. This answers "How long can it run?"
Mix them up and you'll either over-buy or, worse, buy a system that starts nothing because surge math was wrong. Moreover, the number that sizes your battery is daily energy in kWh. Here's a formula:
Daily kWh = running watts × hours/day ÷ 1,000
Example refrigerator assumption: 150 W × 8 hours ÷ 1,000 = 1.20 kWh/day.
Three ways to get real numbers instead of remembering "the fridge is, uh, big":
Plug-in appliances: Where the appliance manufacturer permits it, use a suitably rated plug-in energy meter to record kWh over representative days. Include the weather and usage conditions relevant to your outage plan.
Hardwired and 240 V loads: Ask a qualified electrician to measure operating demand and motor startup with appropriate equipment. Do not open the electrical panel to follow this worksheet.
Nameplate information: Record voltage, rated power or current, and any LRA information. Use measured daily energy for runtime planning where available. LRA is a current rating in amperes, not starting power in watts, and should be interpreted with the motor and supply details.
Start with a no-solar baseline: assume zero solar energy during the outage. That gives you a conservative answer for nighttime outages, snow-covered panels, smoke, storm clouds, or a grid-tied system that shuts down when the grid fails.
Load | Running power (W) | Equivalent operating hours/day | Energy (kWh/day) | Assumed starting power (W) |
Refrigerator | 150 | 8 | 1.20 | 1,200 |
Medical device* | 60 | 24 | 1.44 | 60 |
Modem/router | 25 | 24 | 0.60 | 25 |
LED lights | 40 | 5 | 0.20 | 40 |
Phones and laptop | 100 | 3 | 0.30 | 100 |
Gas-furnace blower | 600 | 8 | 4.80 | 1,500 |
Well pump | 1,000 | 1 | 1.00 | 3,500 |
Microwave | 1,200 | 0.25 | 0.30 | 1,200 |
Total daily energy | — | — | 9.84 | Check simultaneous start events separately |
Note: The appliance figures are demonstration inputs; replace every row with your measurements. Weather, water use, room temperature, and appliance condition can change the result.
Step 1: calculate energy for 24, 48, and 72 hours
Do not multiply each appliance's nameplate wattage by 24. The worksheet above uses measured or assumed operating hours and duty cycles load by load.
In words: multiply your measured daily total by the number of outage days, then divide by the complete usable-energy factor to estimate required nameplate battery capacity.
Required delivered energy = 9.84 kWh/day × outage days
Required nameplate capacity = required delivered energy ÷ (0.90 × 0.95 × 0.90 × 0.90)
Target | Delivered load energy | Calculation | Demonstration nameplate need |
24 hours | 9.84 kWh | 9.84 ÷ 0.69255 | 14.21 kWh |
48 hours | 19.68 kWh | 19.68 ÷ 0.69255 | 28.42 kWh |
72 hours | 29.52 kWh | 29.52 ÷ 0.69255 | 42.62 kWh |
Here, 0.69255 is the combined usable-energy factor: 0.90 usable window × 0.95 remaining capacity × 0.90 temperature × 0.90 inverter efficiency. If the season, reserve, measured efficiency, or battery health changes, the answer must change.
A 12.288 kWh nameplate system supplies 8.51 kWh under these assumptions. Against a 9.84 kWh/day plan, the arithmetic estimate is 8.51 ÷ 9.84 × 24 = 20.8 hours. That is a worksheet result, not a DELTA Pro Ultra X runtime promise and not a package recommendation.
Step 2: test running power and motor starts separately
The current official DELTA Pro Ultra X specifications list 12 kW AC output at 120/240 V, 60 Hz for one inverter. Use that page to verify the current rating; then have EcoFlow or the installer confirm the real circuit and motor combination.
For the demonstration list, a deliberately crowded running event is:
600 furnace + 1,000 well pump + 150 refrigerator + 60 medical + 25 router + 40 lights + 1,200 microwave = 3,075 running W
If the well pump starts during that event, replace its 1,000 running watts with the assumed 3,500 starting watts:
3,075 − 1,000 + 3,500 = 5,575 W during the assumed pump-start event
The 5,575 W result only validates this invented load set against a power ceiling on paper. It does not validate a real pump.
Keep the no-solar baseline as your conservative plan. Model solar separately as a daily inflow; never add it to the battery's nameplate capacity.
Use a low-production "design day" for the relevant month and location, then test a sequence of those days. The NLR's PVWatts calculator can estimate location-specific production, but shading, snow, smoke, panel orientation, outage mode, starting SOC, overnight demand, storage headroom, and charging limits still need verification.
This demonstration assumes:
4.0 kW DC solar array;
1.5 peak-sun-hours per cloudy design day;
0.75 delivered-yield factor covering the stated example's temperature, wiring, controller, charging, and conversion losses;
9.84 kWh/day of household loads from the no-solar example;
three consecutive design days; and
the same 0.69255 usable-battery factor used above.
Here is a formula to calculate solar delivered per day:
Solar delivered per day = array power × peak-sun-hours / day × the delivered-yield factor
So, for the assumed demonstration:
the solar delivered per design day = 4.0 kW × 1.5 h × 0.75 = 4.50 kWh/day
daily battery draw = 9.84 load − 4.50 solar = 5.34 kWh/day
three-day battery draw = 5.34 × 3 = 16.02 kWh delivered
demonstration nameplate need = 16.02 ÷ 0.69255 = 23.13 kWh
Under this separate solar scenario, one 12.288 kWh nameplate system still represents 8.51 kWh of delivered stored energy under the example factors. The three-day modeled shortfall is 16.02 − 8.51 = 7.51 kWh delivered. This is aggregate energy math, not a verified three-day configuration; EcoFlow or an installer must check the actual array, charging path, and storage.
Ready to compare your options? Once you have measured daily kWh, check the largest start event, and modeled a no-solar baseline, use those numbers to compare the current DELTA Pro Ultra X bundles―not just headline capacity.
Before you decide, use the DELTA Pro Ultra X support hub to verify the exact battery and inverter models, the required accessories and circuit path, the firmware version and applicable control behavior, and the installation route, including permits, utility or AHJ requirements, and commissioning. The goal is a written, site-specific answer before equipment reaches the garage.
What can a 10 kWh battery power?
It depends on usable delivered energy and the load list. With the demonstration factors in this guide, 10 kWh nameplate becomes 6.93 kWh delivered to AC loads. That is about 39.6 hours for a 4.2 kWh/day essentials plan, or 5.5 hours for a 30 kWh/day heavy-use plan.
Does enough battery capacity guarantee that my well pump will work?
No. Energy capacity answers how long the pump can run. Inverter output, voltage, measured inrush or LRA, start duration, wiring, breaker, controls, and concurrent loads determine whether it can start. EcoFlow or the installer must verify the exact pump.
Can rooftop solar recharge a home battery during an outage?
Only if the installed solar and backup equipment are designed and approved to operate together while isolated from the grid. Many standard grid-tied systems shut down during an outage. Confirm the outage power path and model solar as a separate cloudy-day case.
