Cost of Solar Panels in Texas in 2026: A Real Pricing Breakdown
Texas remains one of the strongest solar markets in the U.S., but the price of going solar depends heavily on system size, location, roof conditions, and equipment. In 2026, the federal residential solar tax credit is no longer available for newly installed systems, making local incentives and utility programs more important. This guide breaks down the cost of solar panels in Texas, what homeowners can expect to pay by system size and city, available incentives, and how long it may take to recover the investment.
Average Cost of Solar Panels in Texas Right Now
As of August 2026, EnergySage estimates that the average Texas homeowner needs a 12.65 kW solar system costing about $28,455 before incentives, with typical prices ranging from $28,000 to $36,500. The estimated payback period is about 13 years.
That makes the current Texas market somewhat different from older estimates that centered on smaller 5 kW systems. Texas homes often have substantial electricity demand, particularly because of air-conditioning loads during long, hot summers. A larger system can therefore be necessary to offset a meaningful share of annual electricity use.
The exact cost of installing solar panels in Texas varies by installer, equipment, roof design, location, and system size. For example, current EnergySage data puts average installation costs at about $2.25/W in Austin, $2.21/W in Dallas, $2.24/W in Houston, and $2.19/W in San Antonio.
Homeowners comparing prices on Reddit and other forums may see considerably different quotes, even within the same metro area. That isn't necessarily a red flag: installers may use different panels, inverters, warranties, financing structures, and labor assumptions.
The important takeaway is that an online average is a benchmark, not a personalized quote. Your home's electricity consumption and roof determine how much solar you actually need.
What Solar Panels Cost by System Size
System size is one of the biggest factors affecting the total price. Using a broad Texas installed-price range of roughly $2.24–$3.18 per watt, smaller systems can cost more per watt because fixed expenses such as permitting, design, labor, and inverter equipment make up a larger share of the project.
Solar panels cost by system sizeSolar panels cost by system size
System Size
Estimated Cost (before incentives)
3 kW
~$6,700
5 kW
~$11,200
6 kW
~$13,400–$19,100
8 kW
~$17,900–$25,400
10 kW
~$22,400–$31,800
A few things worth keeping in mind as you compare these numbers to your own quote:
  • Smaller systems cost more per watt than larger ones, since fixed costs like permitting, labor, and equipment like inverters don't scale down proportionally.
  • Roof complexity, panel brand, and whether battery storage is included all shift the final number, which is why it's worth looking at a full breakdown of individual cost components before comparing quotes side by side.
EcoFlow 400W Rigid Solar Panel
1. • A 23% conversion rate to sunlight 2. • All-black design that fits any house style 3. • Built to last with an IP68 waterproof rating 4. • Fast and Easy Installation 5. • Up to a 10-year warranty *Note: This oversized item ships by truck. Processing time is 7–10 business days before shipping.
EcoFlow DELTA Pro 3
EcoFlow DELTA Pro 3
Expandable Capacity: 4–48kWh, from 1 day to week of home power during outages. Powerful and Versatile: Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed. Continuous Output While Charging: Provides stable, uninterrupted power at 120/240V with a maximum continuous output of 4000W, even during pass-through charging. Endless energy: Compatible with portable generators, auto recharging when connecting with EcoFlow Smart Generator 4000.
None of those numbers tell the whole story, though. What matters next is how much of that upfront price you can offset through incentives.
Incentives That Actually Lower the Cost in Texas
The incentive picture changed significantly in 2026. The federal Residential Clean Energy Credit no longer applies to newly installed residential solar property after December 31, 2025. The IRS confirms that the former 30% credit covered qualifying property installed through that date.
That means homeowners installing a new system in 2026 generally cannot simply subtract 30% from their purchase price as they could in previous years.
Texas still has several incentives and programs worth checking:
  • Texas solar property tax exemption: Adding panels boosts your home value, but under Texas law, 100% of the added value from a renewable energy system is exempt from property taxes. That saves most homeowners roughly $450 to $650 every year automatically, with no extra paperwork required.
  • Austin Energy rebate: Austin Energy offers a $4,000 residential solar rebate for eligible home solar installations. Applicants must have Austin Energy residential electric service, install a qualifying system of at least 3 kW DC, use a participating contractor, and receive a Solar Rebate Confirmation Letter before installation.
  • Utility & battery programs: Utilities like Oncor offer battery incentive programs for solar-paired storage in the DFW area.
  • Retail Electric Provider (REP) solar buyback: In deregulated areas, you can shop for retail plans that pay you for the excess electricity you push back to the grid. Buyback rates vary widely, typically ranging from $0.04 to $0.12 per kWh, so reading the fine print on contract terms is essential.
With those incentives factored in, the number that actually matters is how long it takes for the system to pay for itself.
Payback Period and Long-Term Savings
For homeowners buying a system outright with cash, the payback period in Texas typically sits around 12 to 13 years. That timeline is a bit longer than what you might see in states with sky-high utility rates, mainly because the federal residential tax credit is no longer part of the financial equation. Even so, the long-term return remains solid: over a 25-year lifespan, estimated net savings average roughly $32,000 to $37,000 based on current system costs and utility rate trends.
Financing your setup with a solar loan is another route that cuts out the heavy upfront expense, though paying interest over time will eat into your total lifetime savings. That said, zero-down financing options can still make sense month-to-month, often locking in a fixed loan payment that is lower than your current electric bill from day one.
Solar panels in Texas typically cost about $2.24 to $3.18 per watt, with many homes needing an 11 to 13 kW system that can cost roughly $28,000 to $36,500 before incentives. With the federal solar tax credit gone for new 2026 installations, payback takes around 12 to 13 years. Before signing, get multiple quotes based on your home's energy needs, check whether the property tax exemption, Austin Energy rebate, or Oncor battery incentives apply, and compare equipment quality, not just price per watt. If you're pricing equipment separately, explore the EcoFlow 400W Rigid Solar Panel and DELTA Pro 3.
What is the average cost of solar panels in Texas?
The average cost of solar panels in Texas is about $28,455 before incentives for a typical 12.65 kW system. Actual prices vary based on system size, equipment, roof complexity, installer, and location across the state.
How much does it cost to install solar panels in Texas?
Installing solar panels in Texas typically costs about $2.24 to $3.18 per watt. A larger home system can cost $28,000 to $36,500 before incentives, depending on equipment, installation requirements, system size, and permits plus labor.
Are solar panels in Texas still worth it without the federal tax credit?
Yes. Even without the federal tax credit, solar panels protect homeowners against rising utility rates and grid instability. Most systems generate an estimated $32,000 to $37,000 in net utility bill savings over a 25-year lifespan.
What incentives are still available for solar in Texas in 2026?
Texas offers a 100% property tax exemption on solar home value increases. Homeowners can also access municipal rebates like Austin Energy's program, Oncor battery storage incentives, and retail electric provider buyback plans for exported power.
How long does it take for solar panels to pay for themselves in Texas?
A cash-purchased solar system in Texas typically pays for itself in roughly 12 to 13 years. The exact timeline depends on your household energy usage, roof orientation, local electric buyback rates, and available utility rebates.
Solar Panels
