Cleco Outage Map: How to Track Louisiana Power Outages in Real Time
Louisiana's weather doesn't give much warning before the power goes out, but Cleco's outage map can. For Louisianians served by Cleco, checking if there is a power disruption is easy. Cleco provides a convenient, interactive outage map available online.
Keep reading to learn how to use the map, what causes Cleco outages, and how to prepare ahead of the next power disruption.
What Is the Cleco Outage Map?
The Cleco outage map tracks real-time power interruptions across Louisiana. The map is interactive, providing customers with up-to-date information on current outages, affected areas, and estimated restoration times.
You can share your location or enter your address to move the map to your exact location. It also includes weather details — just click the weather option to activate it. If there are no active storms, zoom out to see the weather across the country and what might be headed your way.
Cleco isn’t the only utility offering this kind of visibility. The South Central power outage map gives Ohio customers the same kind of real-time tracking, and Cleco’s tool works the same way for Louisiana, pinpointing outages, restoration times, and affected areas as they happen.
If the map’s weather overlay shows a storm coming, that’s your cue to prepare. Fully charge your EcoFlow DELTA 3 Classic (1024Wh), if it’s not already, so you’re not caught without power when the storm hits.
How Often Does the Cleco Outage Map Update?
The map updates approximately every 5 to 10 minutes. Automated digital reporting updates these metrics in real time. Accurate restoration times require site assessment from dispatched crews. Better restoration time estimates and causes of outages may take a little longer to reflect on the outage map.
How Do You Read Outage Icons and Restoration Times?
The interactive Cleco map uses a visual system to help users quickly understand where outages are and how widespread they are. Here’s what different icons communicate:
  • Color-coded circular icons: The circle indicates an outage. The color of the circle ranks the severity according to the legend.
  • Size variation: A larger circle indicates a large number of affected customers. A smaller circle indicates fewer impacted customers.
  • Dynamic clustering: When you zoom out of the map, the circular icons cluster together. When you zoom in, they separate to show more detail.
  • Legend: The legend details what each color means and the range of customers impacted.
Other utilities use similar systems — Dayton Power and Light’s outage map, for example, follows a comparable structure.
What Causes Power Outages in Cleco's Louisiana Service Area?
Storms and Severe Weather
The subtropical climate of Louisiana makes weather the most common cause of widespread power outages. Severe thunderstorms in the summer bring severe lightning and straight-line winds that destroy electrical equipment.
Hurricanes and tropical storms bring heavy rainfall, strong winds, and flooding that damage power equipment. That level of damage leads to widespread power outages that can last several days.
Grid Reliability and MISO-Directed Outages
Cleco operates within MISO (Midcontinent Independent System Operator). MISO spreads across 15 states to manage and balance power supply to meet demand. MISO can issue a mandatory load-shed when supply-and-demand are unbalanced.
Extreme heat and cold spikes cause customers to max out AC or heat, driving up demand. A mandatory, rotating power outage reduces grid strain, preventing damage.
How Can You Report or Check on a Cleco Outage?
There are several ways to report or check on power disruptions with Cleco:
  • Directly report an outage via text message if your phone number is linked to the Cleco MyAccount. Just text “out” to 69378.
  • Report the outage online through the web portal. Log into your account and look for the button on the dashboard, or click on your location on the map.
  • Call Cleco’s automated service number at 1-800-622-6537. It’s available 24/7 to report outages.
Just as Omaha residents can track outages and set up alerts through OPPD, you can monitor outages or sign up for alert notifications through MyAccount.
How Can You Prepare for Outages Before They Happen?
Knowing when an outage happens is helpful, but that doesn’t prepare you for the event. You need to prepare an emergency kit that includes backup lighting, power banks, food, water, and medical supplies. Start with a small kit, then build up to a week's worth of supplies.
Install electronic protection throughout your home with surge protectors. When an outage happens, unplug sensitive electronics like computers to protect them from damage when power returns.
For powering essentials (phones, medical devices, a Wi-Fi router, small appliances) during a shorter outage, the EcoFlow DELTA 3 Classic (1024Wh) gives you a portable, ready backup source you can charge ahead of a storm and keep on hand year-round.
If you want your whole home covered, an EcoFlow whole-home generator keeps your appliances, electronics, and lights running automatically when the grid goes down, without you having to manage individual devices.
A person works at a desk with a tablet and laptop beside a large EcoFlow power station.
What Does "Evaluating" Mean on the Cleco Outage Map?
When an outage status reads “evaluating”, it means that Cleco has line crews on site determining the cause of the disruption and estimated time of restoration. Once the crew has finished the assessment, the restoration time will be updated. Meanwhile, Cleco will try and reroute electricity to minimize affected customers.
How Do You Report a Power Outage to Cleco?
You can submit an outage to Cleco through text message, phone call, or website. Text OUT to 69378, call 1-800-622-6537, or log into Cleco MyAccount. Online, track the outage severity, restoration time, and cause of the disruption.
Which Louisiana Parishes Are Most Affected by Cleco Outages?
Outage impact varies across Cleco's Louisiana service area. Densely populated parishes tend to see more customers affected by a single outage, simply due to the concentration of homes on the grid. Coastal and low-lying parishes typically face the most disruption during hurricane season, while wooded areas see more outages from fallen trees and limbs after storms.
Backup Power Keeps Louisiana Homes Running When Cleco Outages Strike
Louisianians deal with power disruptions often. This Gulf state experiences the brunt of tropical storms, hurricanes, and severe thunderstorms that damage power lines, transformers, and vegetation. Cleco provides an interactive power outage map for those serviced by them. The map provides real-time updates on outage severity and estimated restoration times.
Being aware of an outage is good, but being prepared is better. A portable power station gives you a reliable, ready source of backup power whenever Cleco outages strike — and if you want broader protection, a whole-home backup system keeps your entire house running through extended events.
Power Outages
