How to Compare Installed Quotes for a 13kW Solar System
To compare 13kW solar quotes, ask local installers for a cash price before incentives and check that their proposals cover the same work. Berkeley Lab's 2026 data update puts the median U.S. home solar system at 7.7 kW in 2025, so a 13kW array is larger than the national median. This guide explains how to compare installed quotes on the same basis, price battery storage separately, and account for the federal tax credit change affecting 2026 installations.
How Should You Compare 13kW Solar System Prices Across Brands?
Compare installed quotes by price per watt, using the same equipment and installation scope. Each quote should list the panels, inverter, racking, labor, permits, and warranty terms. Write down the quote date, too. Solar prices change by region and over time, so figures from different years aren't a fair comparison.
How Should You Compare 13kW Solar System Prices Across Brands?How Should You Compare 13kW Solar System Prices Across Brands?
Start with the installed price per watt
Berkeley Lab found that installed prices for U.S. residential, host-owned stand-alone solar fell by $0.50 per watt from 2024 to 2025, after adjusting for inflation. The figures are upfront prices before incentives and exclude third-party-owned systems. That gives you a useful market reference, but it doesn't establish what a 13kW system should cost in your area. A larger array may need different equipment, roof work, or electrical upgrades. Installer pricing also varies. Divide the installed solar-only cash price before incentives by 13,000 watts. Compare the results once you have checked that the proposals cover the same equipment and work.
Put each quote side by side
A low total can hide missing costs. One installer may include permits and electrical work, while another lists those items separately. Use the table below to record quotes for the same address and quote period. For a worked example, imagine two 13kW proposals that cover the same equipment, labor, permits and interconnection, with no battery or incentives. A $31,200 quote comes to $2.40/W and a $35,100 quote comes to $2.70/W. The figures illustrate the calculation.
Line item
Quote A
Quote B
Quote C
Panel brand and watts
Inverter type
Battery (separate line)
Labor, permits, interconnection
Warranty terms
Total ÷ 13,000W
Ask each installer to explain differences in panel output, inverter capacity, equipment warranties, and labor coverage. Check whether the quote includes monitoring equipment, permit fees, utility interconnection, and any work needed to bring your electrical system up to code. A brand name alone won't tell you which quote offers better value. Look at the full system and the work behind the price. If you're sizing up from a smaller installation, see 10kW solar system costs before comparing the larger array.
How Does a Home Battery Fit Into a 13kW Array?
A home battery adds a separate cost to a solar installation. For a new DC connection, EcoFlow TITAN 5000 Plus accepts up to 8 kW of solar input through two 4 kW inputs. If you already have a compatible rooftop array and inverter, ask your electrician about AC coupling through Smart Home Panel 10 (240 V) with a CT sensor.
How EcoFlow TITAN 5000 Plus fits a larger solar array
For direct DC charging, the two inputs accept up to 8,000 W combined. Dividing 8,000 W by the array’s 13,000 W nameplate rating gives about 62%. That ratio compares two ratings. A licensed electrician must still size the strings to each input. With a compatible existing rooftop system, AC coupling lets you retain the array and inverter and store surplus energy while grid-connected using Smart Home Panel 10 (240 V) and a CT sensor. The SHP10 setup uses No Export control. A conventional grid-tied inverter normally shuts down during an outage. Ask your electrician to confirm which circuits will have backup and what can recharge the battery when the grid is down.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
Check the panel strings and existing equipment
For each DC input, EcoFlow lists a 40–450 V operating range, a 60 V start-up threshold, a 16 A input limit and a 20 A short-circuit current limit. Have a licensed electrician check that each string can start the input, stays within the operating and current limits, and has a cold-weather open-circuit voltage within the 450 V maximum. The electrician should also check inverter compatibility, roof layout and permit requirements.
Item
Figure
Source
Array size
13,000W
Reader's quote
Max direct DC solar input into EcoFlow TITAN 5000 Plus
8,000W (2 × 4,000W)
EcoFlow US page
Input rating as a share of array nameplate
About 62% (8,000 ÷ 13,000)
Arithmetic only
Compatible existing rooftop PV
Retain the array and inverter with approved AC coupling
EcoFlow AC-coupling guidance
Ask for the battery, installation labor, electrical work, and any inverter changes as separate quote items. That gives you a clearer comparison across installers and regions. Check the current product listing for updated availability.
Why Do Solar Prices Differ by Region and Date?
Two homeowners can receive different prices for similar 13kW systems. Local labor rates, roof conditions, permitting, utility requirements, and equipment availability all affect the final quote. The date matters, too. A proposal from last year may no longer reflect current equipment or installation costs.
Compare local quotes, not overseas price lists
Solar comparison sites sometimes show prices from the United States, United Kingdom, and Australia on the same results page. Those figures don't translate directly to a U.S. installation. Labor costs, incentives, electrical standards, utility rules, and system designs differ by country. For a useful comparison, collect at least two or three quotes from installers who work in your area. Make sure each proposal uses the same system size and includes comparable equipment and services. Record the date next to every price. In Berkeley Lab’s 2025 sample of cash-purchase residential systems, the median price for solar plus storage was $2.10 per watt of PV capacity higher than for solar alone. About 80% of the paired-system price data came from California. Use the finding as a market benchmark and ask your installer for an itemized price for your battery and installation.
Look beyond the panel price
A 13kW installation may need more than panels and an inverter. Ask whether the proposal includes:
  • Roof repairs or reinforcement, if needed
  • Racking and mounting hardware
  • Electrical upgrades or panel work
  • Permits and inspection fees
  • Utility interconnection
  • Monitoring equipment
  • Battery installation, if included
The roof can affect the design and labor estimate. A complex roof with multiple faces may require more planning than a large, unobstructed roof. Local utility rules can also affect the interconnection process. These are some of the regional factors that affect solar prices that deserve attention before you sign a contract.
What Changed With the Federal Solar Tax Credit for 2026?
The federal residential clean energy credit under Section 25D ended for expenditures made after December 31, 2025. The IRS treats the expenditure for a new system as made when the original installation is completed. A solar installation completed in 2026 therefore does not qualify for a new Section 25D credit. If a 2026 proposal still subtracts the former 30% residential credit from the price, ask the installer to explain the calculation.
What Changed With the Federal Solar Tax Credit for 2026?What Changed With the Federal Solar Tax Credit for 2026?
Check the installation date and tax assumptions
The IRS considers the installation date when determining eligibility for the Section 25D credit. A new installation completed after December 31, 2025, does not qualify even if you signed a contract or paid a deposit earlier. Check your quote for outdated 30% credit estimates, and ask your installer to list the price before incentives. State and utility incentives may still apply, but their rules vary by location. Check with your utility or a tax professional before counting on them. Also, ask how the installer plans series or parallel solar wiring, since the layout affects string voltage and current.
A 13kW solar system price is useful only when you know what's included. Compare installed quotes per watt, use the same equipment and labor scope, and write down each quote date. Keep battery storage on its own line, check the array's electrical design, and leave the former 30% federal residential credit out of a quote for a new installation completed in 2026. If you want to add EcoFlow TITAN 5000 Plus, have a licensed electrician assess a direct DC connection within the 8 kW total input limit or AC coupling with an existing compatible inverter, Smart Home Panel 10 (240 V) and a CT sensor. Ask which circuits will receive backup power and how the battery can recharge during an outage.
How much does a 13kW solar system cost?
The installed price depends on the location, equipment, roof and quoted scope. Divide a complete solar-only cash quote before incentives by 13,000 watts. For example, an illustrative $31,200 quote works out to $2.40/W. Use local proposals to estimate what your own system will cost.
Is 13kW a big home solar system?
Yes. Berkeley Lab's 2026 data update puts the median U.S. residential system at 7.7kW in 2025. A 13kW array is larger than that median, although the right size for a home depends on its electricity use, roof, and utility arrangement.
Does a new solar installation completed in 2026 qualify for Section 25D?
No. The IRS treats the expenditure as made when the original installation is completed. A qualifying unused credit from an earlier installation can still carry forward to 2026 under the Form 5695 instructions.
Should the battery be included in the solar system price?
Ask the installer to list it separately. A separate battery price makes it easier to compare solar-only and solar-plus-storage proposals. It also shows which costs come from the panels and which come from storage and its installation.
Can EcoFlow TITAN 5000 Plus work with a 13kW solar array?
It supports up to 8,000 W of direct DC solar input across two 4,000 W inputs. With compatible existing rooftop solar, a licensed electrician can assess AC coupling through Smart Home Panel 10 (240 V) and a CT sensor while retaining the existing inverter. Ask whether that setup can recharge the battery during an outage.
Solar Energy
