Net Metering Texas: How Solar Credits Work Without a Statewide Rule
If you're searching for net metering in Texas, your options depend on where you live. Texas does not have a single uniform net metering system that applies across every service area. A homeowner in a competitive area may be able to choose a retail solar buyback plan; someone served by a regulated investor-owned utility follows that utility's approved tariff, and customers of a municipal utility or electric co-op follow that provider's own rules. Before installing solar or changing plans, check your service area, export meter requirements, and the terms that determine what your extra electricity is worth.
Does Texas Have Net Metering?
Texas does not have a uniform net metering system applicable to all service areas. Under Texas Utilities Code §39.916 (including subsections (h) and (j)), electric utilities or retail electric providers may contract with distributed renewable generation owners to purchase surplus electricity in applicable contract and competition zones. Meanwhile, Texas Utilities Code §39.554 (subsections (e)–(h)) sets separate metering and compensation requirements for covered regulated electric utilities and eligible customers. Because rules vary by market structure and provider, two homes with similar solar systems can receive different credits depending on their utility, retail provider, and tariff.
Does Texas Have Net Metering?Does Texas Have Net Metering?
Who determines your solar credits?
Your options generally fall into three categories:
Where you live
Who sets solar credits
First step
Deregulated area (ERCOT competitive)
Your retail electric provider's plan (under Texas Utilities Code §39.916)
Compare REP plans with solar buyback terms and review Oncor's DG FAQs
Regulated investor-owned electric utility (e.g., El Paso Electric in Texas)
Approved utility tariff (such as El Paso Electric's Schedule 48 for eligible Texas customers under Texas Utilities Code §39.554)
Review the utility's solar tariff and El Paso Electric's Texas Interconnection guide
Municipal utility
City council/utility
Read the utility's solar tariff
Electric co-op
Co-op board
Read the co-op's DG policy
In deregulated parts of Texas, you can usually choose a REP, but you can't choose the company that maintains the local power lines. Companies such as Oncor (see Oncor's Distributed Generation FAQs), CenterPoint Energy, AEP Texas, and TNMP handle distribution services in their territories, while your REP sets the retail electricity plan and its solar buyback terms. Outside ERCOT competitive zones, regulated investor-owned utilities like El Paso Electric handle excess generation under approved tariffs such as Schedule 48, and municipal utilities and co-ops set their own policies. Before comparing plans, confirm which providers serve your address, check current utility rebates and local property tax exemptions, and review the IRS Residential Clean Energy Credit rules, which apply only to eligible installations completed on or before December 31, 2025, to understand the financial considerations affecting your installation.
Storing Solar When Buyback Credit Is Low
A solar buyback plan pays you for eligible electricity you send to the grid. A home battery stores excess solar so you can use it later, when your panels produce less power. If your REP pays a low export rate, using more of your own electricity may be worth more than sending it to the grid.
Compare the value of stored power and exported power
Check which REPs serve your address, then compare your electricity plan's energy charge with its solar buyback rate. Review the current Electricity Facts Label (EFL) for credit limits, time-based rates, monthly fees, and other conditions. Account for battery losses and fixed charges, too. For example, if you store 4kWh of midday surplus and assume a 10% round-trip loss, you'll have about 3.6kWh available to use later.
Example
Value
Midday solar surplus
4kWh
Assumed battery loss
10%
Energy available for evening use
3.6kWh
Value of stored energy
3.6kWh × your plan's energy charge
Forgone export credit
4kWh × your plan's buyback rate
Net value of storage
Stored energy value minus forgone export credit
These figures are an example, not a guaranteed saving. The 10% battery loss is a placeholder. Use your actual electricity and buyback rates, along with the battery manufacturer's efficiency figures, to make the comparison.
Where EcoFlow TITAN fits into a Texas solar setup
EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus are home battery systems with built-in solar inputs. Paired with a Smart Home Panel 10 (SHP10), they can store solar energy and provide backup power to selected household circuits. A qualified, licensed electrician must install the SHP10. Its grid connection is configured for No Export, so the stored energy is intended for household use rather than earning additional export credits.
EcoFlow TITAN 5000 for one solar array
For a single compliant DC solar array rated up to 4,000W, the EcoFlow TITAN 5000 has one solar input rated for a 40 to 450V range and a 16A limit, with a required minimum PV input of 60V per EcoFlow's product selection notice. Its 5kWh base battery capacity can expand to 30kWh with additional batteries. It can store excess daytime solar for use later, subject to the array's electrical specifications and the system's installation requirements.
EcoFlow TITAN 5000
EcoFlow TITAN 5000 Plus for Two Solar Arrays
For homes with east- and west-facing solar arrays, EcoFlow TITAN 5000 Plus offers two independent solar inputs, each supporting up to 4,000W. This allows the system to handle both arrays separately, with up to 8,000W of combined solar input to store excess energy for later household use.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
How the products divide the job
The right setup depends on your solar array and whether you already have an inverter. EcoFlow TITAN 5000 supports one compliant DC array up to 4kW. EcoFlow TITAN 5000 Plus has two separate solar inputs, supporting up to 8kW combined. If your home already has a solar inverter, have a qualified electrician check its compatibility with the SHP10, including the 240V connection, current transformer (CT) placement, and AC-coupling requirements.
Solar setup
What to consider
One DC solar array up to 4kW
EcoFlow TITAN 5000 has one solar input rated up to 4,000W (40–450V range, 16A limit, with a 60V minimum PV input requirement)
Two arrays, such as east- and west-facing roof sections
EcoFlow TITAN 5000 Plus has two inputs rated up to 4,000W each
Existing solar inverter
An electrician must review SHP10 compatibility, CTs, and AC coupling
Example: Is storing excess solar worth it?
Say your solar system has 4kWh of excess electricity at midday. If the battery loses 10% during charging and discharging, you'll have about 3.6kWh available for evening use.
Example
Value
Midday surplus stored
4kWh
Round-trip loss (placeholder 10%)
0.4kWh
Used in evening
3.6kWh
Self-use value
3.6kWh × your plan's energy charge (from EFL)
Forgone buyback
4kWh × your plan's buyback rate (from EFL)
Net example value
Self-use value minus forgone buyback
These figures are estimates using a placeholder 10% battery loss. Your actual result depends on the system's efficiency and the rates in your current Electricity Facts Label (EFL). Compare the value of the 3.6kWh you can use later with the credit you'd receive for exporting the original 4kWh. Keep monthly fees and other plan charges in your calculation, too. Weigh net metering versus batteries using your actual energy charge and buyback rate before deciding whether storage makes financial sense. Once you've compared the value of storing and exporting solar, check the steps required to get your system connected and start receiving credits.
How to Get Solar Credits in Texas
Getting solar credits usually involves three steps: utility interconnection, the right meter, and enrollment in a plan that accepts exported electricity. Each step has its own requirements. Don't assume your system will earn credits as soon as the panels start producing power.
Step 1: Apply for utility interconnection
Before connecting a solar system to the grid, submit an interconnection application to the utility that maintains your local distribution lines. Texas Utilities Code §39.916 allows a customer to request interconnection by filing an application with the utility. The utility may require system details, electrical drawings, equipment specifications, and inspection documents. Requirements vary by provider and system size—for example, see El Paso Electric's Texas Interconnection of Facilities or Oncor's Distributed Generation FAQs. Get approval before operating the system in parallel with the grid.
Step 2: Confirm the meter can record exports
Your home needs a meter that can measure electricity flowing in both directions or otherwise record exported energy for the applicable plan. The utility handles the meter requirements and installation process.
Ask these questions before your system goes live:
  • Does the meter record electricity exported by the solar system?
  • Is an interval meter or specific meter configuration required?
  • Does the REP need export data before it can enroll you in a buyback plan?
  • Are there any utility fees or installation charges?
Don't switch to a solar buyback plan until you know the meter is ready and the provider can process your exports.
Step 3: Read the Electricity Facts Label
The EFL explains the plan's pricing and key terms. For a solar customer, pay close attention to:
  • Energy charge: The price you pay for electricity you use.
  • Buyback terms: How the REP calculates credits for eligible exports.
  • TDU charges: Delivery charges passed through from the transmission and distribution utility.
  • Monthly fees: Charges that may apply regardless of your electricity use.
  • Export limits and eligibility: Conditions that determine which solar production qualifies for credit.
A plan's advertised buyback rate may not tell you what you'll receive for every kilowatt-hour your panels export. Some plans have eligibility rules, caps, or different terms for imports and exports. Read the full EFL and contract rather than choosing a plan based on one advertised number. It also helps to understand the utility and retail provider roles before contacting either company. Your REP handles your electricity plan, while the utility manages the meter and grid connection.
Municipal Utility Example: Austin Energy Value of Solar
Austin Energy uses a Value of Solar tariff rather than a standard REP-style solar buyback plan. The utility credits eligible solar production at its published Value of Solar Rate, while customers still pay for the electricity they consume. Under the Austin Energy Value-of-Solar Rider (effective October 1, 2026), Austin Energy calculates credits based on 100% of metered solar generation. Unused credit balances roll over from month to month, apply exclusively to the same account's electricity bill, are non-transferable, and expire upon termination of service. Because rates and tariff terms can change, check the current Austin Energy Value-of-Solar Rider before using a figure in a cost comparison.
Municipal Utility Example: Austin Energy Value of SolarMunicipal Utility Example: Austin Energy Value of Solar
How the Value of Solar approach works
Austin Energy bases solar credits on your system's electricity production, while your bill still includes the electricity your home consumes. This differs from export-only buyback plans, which credit power sent to the grid. If you're an Austin Energy customer, check its current solar tariff and billing rules rather than assuming a REP's buyback terms apply. Other municipal utilities and electric co-ops, including CPS Energy, may have different credit structures, application requirements, and meter rules. Review your provider's policy and compare the expected credits with your full electricity costs, including delivery charges and fixed fees. The average Texas electric bill can provide a starting point, but use your recent bills for a more accurate estimate.
Net metering in Texas depends on your service area and electricity provider, as the state does not have a uniform net metering system that applies everywhere. How your excess solar power is credited depends on whether you are in a competitive REP market under Texas Utilities Code §39.916, served by a regulated utility tariff (such as El Paso Electric's Schedule 48 under §39.554), or connected to a municipal utility or co-op. Confirm your service area, complete utility interconnection, and compare current EFLs or utility tariffs before choosing a plan. If your export credit is low, a home battery such as EcoFlow TITAN 5000 or EcoFlow TITAN 5000 Plus may help you use more of your own solar power later. Compare that value with the credit you'd give up by storing the energy, and have a qualified electrician review the system before installation.
Does Texas have net metering?
Texas does not have a single uniform net metering system applicable across all service areas. Instead, surplus electricity is governed by market structure and provider rules: Texas Utilities Code §39.916 addresses sales arrangements in contract and competition zones, while §39.554 outlines metering and compensation requirements for covered regulated electric utilities. Your options depend on your REP, regulated utility tariff, municipal utility, or electric co-op.
Who sets solar buyback rates in Texas?
In deregulated areas, your retail electric provider sets buyback terms in its plan. In regulated utility territories (such as El Paso Electric in Texas), excess power follows approved tariffs like Schedule 48, while municipal utilities and co-ops set their own policies. Check your current EFL, utility tariff, and interconnection rules (such as El Paso Electric's Texas Interconnection page or Oncor's DG FAQs) before estimating export credits.
Does Austin Energy have net metering?
Austin Energy uses a Value of Solar tariff rather than a standard retail-provider buyback plan. It credits eligible solar production at its published rate, while customers still pay for the electricity they consume. Check the current tariff for the applicable rate and billing terms.
Do I need a special meter for solar buyback in Texas?
Your utility must have a meter configuration that can record exported electricity for your plan. The exact requirements depend on the utility and REP. Confirm the meter setup and enrollment rules before switching to a solar buyback plan.
Is a battery worth it in Texas?
It depends on how much your REP pays for exported solar power compared with what you pay to buy electricity later. A battery can store excess daytime production for evening use, but round-trip losses and equipment costs affect the calculation. Compare your actual EFL rates before deciding.
Solar Energy
