Solar Power for Well Pump Systems: Direct Solar Pumping vs Battery Backup
Running a well pump on solar takes a little planning. One setup uses a DC pump connected to solar panels and fills a tank while the sun is out. Another uses a home battery and inverter to keep an existing AC well pump running at night or during a power outage. These systems solve different problems. This guide explains how each works, what you need to size it, and what an electrician should check before connecting a home battery to your well pump.
Two Ways to Use Solar Power for a Well Pump
Two Ways to Use Solar Power for a Well PumpTwo Ways to Use Solar Power for a Well Pump
Solar power can run a well pump in two ways. A DC solar pump draws power from panels during the day and fills a storage tank. A home battery can keep an existing AC pump running at night or during a power outage.
Setup
How it works
Best for
Direct DC solar pump
Panels → pump controller → DC pump; fills a storage tank
Livestock, cabins, irrigation, daytime pumping
AC well pump + home battery
Battery and inverter run the existing 120V or 240V pump
Homes needing water at night or in outages
How direct solar pumping works
A direct solar pumping system typically includes a well, solar panels, a pump controller, a DC pump, a storage tank, and a float switch. Colorado State University Extension recommends choosing a pump specifically designed for solar power. The USDA Natural Resources Conservation Service (NRCS) also explains that these systems need sufficient sunlight to operate. The controller manages the power supplied to the pump, which moves water into the storage tank.
How battery backup works
A home battery supplies electricity to an existing AC well pump through a compatible inverter. This lets the pump operate when solar panels aren't producing enough power or the grid goes down. Check well pump power requirements before choosing a battery, including its running wattage and starting surge. If your home already has an AC well pump and you need water after sunset or during an outage, battery backup is the option to explore.
Backing Up an Existing AC Well Pump With a Home Battery
If you rely on a well for household water, a power outage can leave your pump out of service. A home battery can keep an existing AC well pump running, provided its inverter can handle the motor's starting surge and the battery has enough capacity for daily use. Have a licensed electrician check the pump's nameplate, control box, voltage, and starting current before choosing a backup system.
What to check before choosing a battery
Start with the pump's electrical specifications. The electrician should check:
  • Pump voltage: Confirm whether it uses 120V or 240V power.
  • Running wattage: Find out how much power the pump needs while operating.
  • Starting surge: Check the extra current the motor draws when it starts.
  • Control box: Confirm that the battery system supports the pump's control equipment.
  • Daily runtime: Estimate how long the pump runs each day to calculate battery capacity.
  • Solar recharge: Check whether your panels can recharge the battery while supplying your other household loads.
These details help to determine if the battery can start the pump and keep it running when needed. Fixed AC circuits also require professional installation.
Using EcoFlow TITAN 5000 for well pump backup
For homes with an existing AC well pump, EcoFlow TITAN 5000 is an option to consider. It delivers 7,200W of rated 120V/240V split-phase output and has a 5kWh base storage capacity, expandable to 30kWh with additional batteries sold separately.
The system can connect to selected household circuits through Smart Home Panel 10 (SHP10), which must be installed by a qualified, licensed electrician. Its grid connection operates in No Export mode. The 7,200W rated output may cover many residential well pump circuits, but the pump's starting surge must be checked before installation. The electrician should also verify the control box, circuit requirements, and overall system compatibility.
EcoFlow TITAN 5000 specifications
Feature
Specification
Rated output
7,200W
Output voltage
Base storage
5kWh
Expandable storage
Up to 30kWh
Solar input
Up to 4,000W
Home connection
Smart Home Panel 10
Installation
Qualified, licensed electrician required
A well pump usually runs for short periods, so its daily energy use may be lower than its rated wattage suggests. But the motor still needs enough power to start. Check that requirement first, then size the battery around your daily pumping time.
EcoFlow TITAN 5000
Estimating how long a battery can run a well pump
Battery runtime depends on the pump's wattage and how long it runs each day. Here's an example using a 1,000W pump that operates for one hour daily.
Example
Value
Pump running watts (placeholder from nameplate)
1,000W
Pumping time per day (placeholder)
1 hour
Daily pump energy
about 1,000Wh
EcoFlow TITAN 5000 usable (5,017.6Wh × 0.85)
about 4,265Wh
Days of pumping alone
about 4 days
These figures are estimates, not guaranteed runtimes. Actual results depend on pump demand, battery efficiency, and other connected loads. To estimate runtime, divide the battery's usable energy by the pump's daily energy consumption. The calculation above doesn't account for motor starting surge. An electrician must check the pump's starting current against the inverter's capabilities separately. Before choosing a battery, work through well pump battery sizing using your pump's actual specifications and daily runtime.
How to Size a Direct Solar Well Pump System
Start by estimating how much water your property needs each day. Then check how far the pump must lift the water, from the well to the storage tank. These figures help you choose a pump and solar array that can meet your daily demand.
Calculate your daily water needs and pumping lift
According to the USDA Natural Resources Conservation Service (NRCS), two key factors in sizing a solar pumping system are the amount of water needed and the maximum lift from the well to the delivery point. Calculate your daily water requirements for domestic use, livestock and irrigation. Then measure the pumping lift. This includes the depth to the water level and the height of the storage tank. Pump makers publish flow rates at different head heights and power levels. Use these specifications to find a pump that can deliver the required amount of water.
Match the solar panels to your pump
Your solar array needs to produce enough power to run the pump during available daylight hours. Check the average daily sunlight in your area using NREL's solar resource data. Panel output changes with sunlight, shading, and seasonal conditions. Learn how to calculate solar panel output to estimate how much electricity your panels can produce.
Add a storage tank for nights and cloudy days
A direct solar pump generally stops when sunlight is insufficient. A storage tank lets you use the water pumped during the day. For livestock solar pumping systems, especially without another backup power source, Colorado State University Extension recommends storage equal to three days of average demand to cover nights and cloudy weather. Using that guideline as an initial estimate, 500 gallons of daily demand would call for 1,500 gallons of usable storage. This is not a universal minimum for every domestic well system: confirm the reserve, usable tank capacity, and backup arrangements for your site with the system designer. Next, consider the safety checks and routine maintenance that help keep your solar well pump system working properly.
Safety and Maintenance for Solar Well Pumps
A well system brings water into your house for drinking and cooking. Correct installation, electrical protection, and regular maintenance are all important. Pay attention to both the pumping equipment and the water storage setup.
Safety and Maintenance for Solar Well PumpsSafety and Maintenance for Solar Well Pumps
Protect the pump and electrical connections
Be careful with water and electricity, especially near a well, pressure tank, or outdoor solar equipment. Any fixed AC wiring, battery connections, circuit protection, and electrical work involving the home’s breaker panel should be done by a licensed electrician. A licensed well contractor should do the pump and well work. Remember these things:
  • Use electrical equipment rated for its installation environment.
  • Protect wiring and connections from moisture and physical damage.
  • Follow the pump manufacturer's grounding and circuit protection requirements.
  • Make sure the battery and inverter are installed according to their specifications.
  • Keep the wellhead and surrounding area protected from potential contamination.
If your pump uses a separate control box, include it in the electrical inspection. The electrician should verify that the entire circuit can operate safely with the backup system.
Maintain the solar panels, controller, and water system
A direct solar pumping system needs occasional inspection to keep water flowing consistently. Check the following items as part of your regular maintenance routine:
  • Solar panels: Remove dirt, leaves, and other debris that block sunlight. Check for nearby trees or structures that may create new shade.
  • Pump controller: Look for warning indicators and follow the manufacturer's maintenance instructions.
  • Float switch: Confirm that it responds correctly when the storage tank fills or the water level drops.
  • Check valve: Colorado State University Extension recommends installing one if the pump doesn't already have one. It helps prevent water from flowing backward into the well.
  • Water storage: Inspect the tank, connections, and fittings for leaks or signs of damage.
  • Well condition: Arrange inspections when needed and follow local guidance for protecting drinking water.
If you're building a larger off-grid setup, review the main off-grid solar components to understand how the panels, electrical equipment, and storage work together.
There are two ways you can get solar-powered water for well pump systems. A direct DC solar pump uses the sun to run during the day and pumps water to a tank. A home battery can run an existing AC pump after dark or during an outage. Start with your daily water demand, the pumping lift, and local sunlight conditions. The EcoFlow TITAN 5000 offers a 7,200W split-phase output and expandable storage for your existing AC pump. Have a licensed electrician verify the motor's starting requirements and circuit compatibility before connecting it through Smart Home Panel 10.
Can solar power run a well pump?
Yes. A solar-powered well can be a DC pump connected to solar panels through a controller or an existing AC pump powered by a suitable battery and inverter. Which is best depends on the electrical requirements of the pump and when you need water.
Will a solar well pump work at night?
A direct solar pump will usually operate whenever there is enough sunlight. You can store water in a tank during the day and use it at night. If you want the pump itself to work after dark, you'll need a suitable backup power source, such as a compatible battery system.
How big a water tank do I need for a solar well pump?
Colorado State University Extension recommends storage equal to three days of average demand for livestock solar pumping systems, particularly where no other backup power is used. Estimate your daily water use. Multiply that by three as a starting point, then confirm the usable tank capacity and reserve needed for your property's water use and backup arrangements with the system designer.
Can a home battery start a well pump?
This is possible if the inverter on the battery can handle the motor’s starting surge and the system meets the pump’s voltage and circuit requirements. Have a licensed electrician check the pump's nameplate, control box, and starting current before selecting a battery.
Do I need a special pump for direct solar?
Yes. A solar power–specific pump is recommended by Colorado State University Extension. These pumps are compatible with solar controllers that regulate the electricity produced by the panels. An ordinary AC well pump needs a different electrical setup.
Solar Energy
