Electric Towel Rails UK: How Much Do They Cost to Run?
Stepping out of a warm shower and into a chilly bathroom is always an unpleasant experience, especially during the cold winter months in the UK. An electric towel rail helps you dry and keep your towels warm, but how much will it affect your electricity bill? By understanding wattage and running costs, as well as learning about things like thermostats, timers, and other innovative energy solutions, this guide explores how to heat your bathroom efficiently. You will find out ways to keep using your electric heated towel rail or choose a power bank of electricity for your everyday needs.
1. Understanding Electric Towel Rails and How They Work
Electric towel rails are a great way to keep towels warm and dry in UK bathrooms. Here are their types, wattages, sizes, and smart controls that can help you pick the right one and make the best use of electric power.
What Is an Electric Towel Rail and How Does It Work?
The electric towel rail is a heating element for the bathroom that is powered by electricity to heat up and dry towels. In contrast to a regular radiator that depends on the central heating system, the electric towel rail has an inbuilt heating element that heats the towel rail itself.
Most of the liquid-filled models operate according to the following principle:
Electricity supply - the heating element works with the connection to the mains.
Heat generation - the element heats the liquid that is in the towel rail.
Heat distribution - the heated liquid circulates through the bars and creates heat on the towel rail.
Towel drying - the heated bars give heat to the towels that are hung on them.
The electric towel rail can provide additional heating for the bathroom. However, the smaller versions may serve more for drying towels than for bathroom heating.
Different Types of Electric Heated Towel Rails for UK Bathrooms
Choosing the ideal model of electric heated towel rail will depend on your bathroom layout, heating needs and fuel of choice. In the UK, there are great options available to house owners.
Type | How It Works | Best For |
Electric-only towel rails | Use an internal electric element without connecting to central heating | Year-round towel warming and bathrooms without radiator pipework |
Dual-fuel towel rails | Combine central heating connections with an electric heating element | Homes wanting flexible heating in winter and summer |
Fluid-filled towel rails | Use an electric element to heat sealed thermal fluid | Even heat distribution and consistent towel warming |
Dry-element towel rails | Heat the metal rail directly using an electrical element | Models designed for direct electric heating |
For example, using an electric towel rail is quite beneficial in a bathroom remodel or a garden shower where adding extra pipework may be difficult. On the other hand, dual-fuel towel rails provide the option of using central heating in winter months and electrical heating during the hot months.
Your choice will be determined by how often you use your bathroom and whether you just need to dry towels, provide heat or both.
Electric Towel Rail Sizes, Wattages and Heating Performance
The output produced by an electric towel heater and its energy consumption depend on its size. As a rule of thumb, a big heater has to work with a high-wattage element, while smaller ones are meant to heat up less space and towels.
The table below outlines indicative size and wattage ranges to compare various models available on the market. Always check specific technical specifications for a particular manufacturer and model.
Towel Rail Size | Typical Wattage Range | Suitable Application |
Small (600 × 400 mm) | 50–100W | Cloakrooms and compact en-suites |
Medium (800 × 500 mm) | 100–200W | Standard bathrooms and everyday towel drying |
Large (1,200 × 500 mm) | 200–400W | Family bathrooms and multiple towels |
Extra-large (1,800 × 600 mm) | 400–900W | Larger bathrooms and multiple towel requirements |
Note: These are ranges that are typical of comparisons, but they are not industry benchmarks. Always use the number of elements recommended by the towel rail manufacturer. |
Things to consider when selecting wattage:
Size of bathroom: Bigger bathrooms may require more heat than just a towel rail.
Number of towels: Many towels or thicker towels may force you to get a bigger rail that can provide enough heat.
Heating capacity: A small electric towel rail can dry the towels but might not provide enough warmth for the entire bathroom.
Energy use: High-wattage models work more and consume more power during the same time interval.
Electric Towel Rails with Thermostats and Timers: What Are the Benefits?
Thermostats and timers are now more common in electric towel rails, which improve control over bathroom heating for homeowners and reduce the amount of electricity used while keeping towels warm.
Feature | How It Works | Main Benefit |
Built-in thermostat | Regulates heating to maintain a selected temperature | Helps prevent unnecessary overheating |
Programmable timer | Switches the rail on and off at scheduled times | Avoids continuous operation |
Thermostat and timer combination | Controls temperature and operating schedules | Offers greater flexibility and energy management |
Manual control | Allows users to switch heating on or off | Simple operation and basic control |
An electric towel rail with a thermostat and timer is a very useful instrument for families that usually shower both in the morning and in the evening. Heating can be scheduled so that it starts before a shower and is turned off immediately after, instead of working throughout the day.
For instance, one family may program the heating on the electric towel rail for 2 hours in the morning and 1 hour in the evening, depending on how much drying is needed.
A thermostat measures the temperature, while a timer is responsible for the operating time. Neither of the devices lowers the bills automatically. However, their correct application may contribute to efficient electricity usage.
Getting to know the types, sizes and controls of electric towel rails is just the beginning. The crucial aspect to understand for UK households is how much electricity is consumed. Thus, it is time to compare the electricity consumption of devices with various wattage ratings and their hourly and, in some cases, daily usage.
2. How Much Does an Electric Towel Rail Cost to Run in the UK?
The cost of using an electric towel rail varies depending on the wattage, the time it runs every day, and the electricity rate. Knowing how much energy an electric towel rail consumes and comparing its usage to different heating schedules will allow UK homeowners to keep their towels warm without paying more for electricity than necessary.
How Much Electricity Does an Electric Heated Towel Rail Use?
Electric towel rails can consume different amounts of electricity based on their wattage and how long they keep working. Because electricity is measured in kilowatt-hours (kWh)—the unit of measurement used by UK energy companies for the calculation of general electricity bills—electricity consumption is also measured in the same unit.
You can easily calculate energy consumption using this simple formula:
Energy (kWh) = Wattage Hours / 1,000
For example:
A 100W electric towel rail running for 1 hour uses 0.1kWh.
A 150W model running for 2 hours uses 0.3kWh.
A 200W model running for 4 hours uses 0.8kWh.
A 300W model running for 8 hours uses 2.4kWh.
So electricity consumption could be less than stated above when using the model with a thermostatic control that turns the heater on and off. Nevertheless, the rated power gives us a good idea for estimating the costs.
Electric Towel Rail Running Costs by Wattage and Usage
Electric heated towel rails’ wattage affects their use of energy when working at full power. However, daily use has great importance as well. One hour of usage with a 300W towel rail might be cheaper than continuous use of a towel rail that consumes 100W.
When it comes to running costs for UK homes, the following aspects need to be considered:
Wattage; more powerful towel warmers use more energy;
Use hours; the longer the use, the more energy is consumed;
Thermostat settings: If you choose a device with a thermostat, it will switch off once the desired temperature is reached.
Bathroom environment: if a bathroom gets cold and towels are damp and thick, it will take more energy to heat everything.
Hourly, Daily, Weekly and Monthly Electricity Costs
The estimates below showcase 100W, 150W, 200W and 300W towel rail electric in four different types of daily usage patterns. However, calculations are made based on the assumption of constant operation of the heating element at its rated wattage, thus covering all hours of operation for seven days a week and 30 days a month.
Wattage | Cost/hour | 1 hr/day | 2 hrs/day | 4 hrs/day | 8 hrs/day |
100W | 2.63p | £0.79/month | £1.58/month | £3.16/month | £6.32/month |
150W | 3.95p | £1.18/month | £2.37/month | £4.74/month | £9.48/month |
200W | 5.26p | £1.58/month | £3.16/month | £6.32/month | £12.63/month |
300W | 7.90p | £2.37/month | £4.74/month | £9.48/month | £18.95/month |
The monthly estimates are rounded off. The weekly and daily figures can be determined by multiplying the obtained hourly rate by the number of hours of operation.
Note: If you want to make your own calculations, please use your actual tariff, not the Ofgem average. You can find the official rates here: Ofgem electricity unit rates and standing charges. |
How Do Thermostats, Timers and Bathroom Temperature Affect Running Costs?
The electric towel rail’s energy impact largely depends on the controls utilised. For instance, thermostats are responsible for regulating the temperatures, while the timers determine how many hours the heating is used.
Factor | Effect on Electricity Consumption | Energy-Saving Approach |
Thermostat settings | Higher temperature settings may increase heating demand | Choose a comfortable temperature rather than maximum heat |
Programmable timer | Longer schedules increase total operating time | Schedule heating around morning and evening showers |
Bathroom temperature | Colder surroundings can increase heat loss | Avoid unnecessarily high temperature settings |
Towel thickness | Thick or damp towels may require longer drying periods | Spread towels evenly across the bars |
Continuous operation | Keeps the rail available throughout the day, potentially using more electricity | Switch off when towels are dry, and heating is unnecessary |
Shower frequency | More frequent towel use can increase drying requirements | Use separate heating schedules for busy periods |
For example, if a household uses its electric towel rail for only two hours daily when taking morning showers and an hour in the evening. There is no need to heat the towel rail during any other part of the day.
Timers and thermostats operate well together: the first should regulate the temperature while the second will decide when the heating can be done.
Electric Towel Rail vs Bathroom Heating: Which Is More Energy Efficient?
The functions of a towel rail and a bathroom heater differ from each other. The towel rail heats and dries towels, while the heater raises the average temperature of the bathroom as a whole.
Heating Option | Main Purpose | Typical Power Range | Best Application |
Small electric towel rail | Warming individual towels | 50–150W | Compact bathrooms and en-suites |
Standard electric towel rail | Drying multiple towels | 150–300W | Everyday towel warming |
High-output towel rail | Towel drying and supplementary warmth | 300–900W | Larger bathrooms, depending on heat output |
Electric panel heater | Heating the bathroom | 500–2,000W | Raising the overall room temperature |
Central heating radiator | Providing room heating through the boiler | Varies by model | Regular whole-room heating |
Which option do you choose?
• For towel drying: One of the small or medium electric towel rails will do, using little electricity.
• For heating the bathroom: The bathroom heater or a properly sized radiator is more suitable.
• For combinations: The electric towel rail for dry and warm towels, along with the bathroom heater when needed.
One should not think of the towel rail as a substitute for the main heating system of the bathroom, as its efficacy depends on heat output, size of the room and insulation.
3. How to Reduce Electric Towel Rail Running Costs and Make Better Use of Solar Energy
Cutting down on the costs of electric towel rails is not synonymous with sacrificing warm and dry towels. Households in the UK can keep their warmth and comfort while also managing their bathroom power consumption through appropriate schedules, skilled use of thermostats, and by using the most renewable electricity sources.
Practical Ways to Reduce Electric Towel Rail Electricity Consumption
Little alterations to your usual way of heating can help minimise towel rail electricity consumption. Instead of keeping it switched on all the time, just turn it on when required to save energy.
Some suggested measures that can help significantly reduce heating costs include:
Energy-Saving Tip | How It Helps | Practical Application |
Choose the right wattage | Avoids using a higher-powered rail than necessary | Match the towel rail to your bathroom and drying requirements |
Switch off when not needed | Reduces unnecessary operating hours | Turn off the rail once towels are dry |
Use a thermostat | Helps maintain a suitable temperature | Avoid setting the heating higher than necessary |
Improve bathroom ventilation | Helps remove excess moisture and supports towel drying | Use an extractor fan appropriately |
Avoid overcrowding the rail | Allows better airflow around towels | Hang towels separately across the bars |
Consider solar electricity | Can offset some grid electricity consumption | Use stored solar energy during scheduled heating periods |
For example, a household using a 200W heated electric towel rail, if operated for two hours now instead of the usual eight hours, stands to save on wasteful consumption. At an example cost of 26.32p/kWh, the corresponding monthly cost the owners may expect to face would drop from £12.63 to £3.16, assuming full-power operation during specified hours.
Using Timers and Thermostats to Heat Towels Around Shower Times
An electric towel rail with a thermostat and timer makes it feasible to utilise the heater only when it is required. Rather than heating towels all day long, you can set the rack to turn on before your daily bathing routine.
Here are a few practical ways to schedule heating periods:
Morning baths: have your heater turned on right before your family gets up.
Evening baths: set another heating time before taking baths in the evening.
Between heating periods: switch off the rack as soon as the towels are dry and warm enough.
In summer: reduce heating time due to quicker towel drying.
For families who have a stable routine, such a towel warming device can prevent heating up towels unnecessarily. With the thermostat, the towel rack also has temperature control features that enable it to stop heating when the desired temperature has been reached.
Making the Most of Solar Energy for Everyday Bathroom Electricity Use
Solar energy solutions present another avenue of addressing electric costs in the home, as one can generate renewable energy when there is sunshine. However, depending on when solar energy generation is generated and when one might want to heat the bathroom might not match up. There could be a need for heated towels in the early morning or later in the evenings, when one might not generate that much electricity from their solar panels.
This is where home battery storage comes in handy, as one can make use of solar batteries to accumulate extra electricity generated in the daytime.
For households within the UK, storage batteries can be used for heating towels and for any other electrical appliances.
What is the role of solar battery storage?
Use solar surplus energy: Use excess solar energy generated rather than consuming it.
Access solar energy: One can use the accumulated electricity during morning and evening routines.
Save grid energy: Superfluous energy can be used to fulfil household electricity demand.
Improve solar self-consumption: The energy generated can be well employed.
EcoFlow STREAM 5000 Solar Battery 5kWh: Solar Storage for New Home Energy Setups
EcoFlow STREAM AC 5000: Storing Solar Power for Existing Solar Panel Systems
Using an electric towel rail will ensure that your towels are dry and warm, but selecting the correct power, adjusting the heating period and avoiding unnecessary use will help to reduce the operating costs. Using timers, thermostats and other systems or investing in solar batteries can help British households to control the use of their electricity every day.
Technology is constantly improving, and it might be worth considering EcoFlow STREAM 5000 Solar Battery with its 5 kWh of power for a solar energy storage system, or EcoFlow STREAM AC 5000 that will provide solar storage. Discover the possibilities of working with EcoFlow STREAM devices and how they can help you save electricity generated by solar panels and used in everyday life.
Are Electric Towel Rails Expensive to Run in the UK?
Electric towel rails are generally economical to run, as most have much lower wattages than standard electric heaters. For instance, using a 100W towel rail for two hours each day leads to a bill of approximately £1.58 a month (26.32p/kWh). However, the actual amount you have to pay will depend on the wattage, the duration of its use, and the settings of the thermostat, as well as your electricity rates.
How Many Watts Does an Electric Towel Rail Use?
Electric towel rails consume anywhere from 50W to 900W, depending on their size, type, and heating capacity.
An electric towel rail in a small size requires between 50 and 100W.
An electric towel rail of medium size consumes between 100 and 200W.
An electric towel rail in large size has a wattage of 200 to 400W.
An electric towel rail can consume between 400 and 900W.
Check the manufacturer's information to find out the wattage required for your bathroom and towel-drying needs.
Is an Electric Towel Rail with a Thermostat More Efficient?
Yes, using an electric towel rail with a thermostat allows you to save on energy bills, as it can control temperature and thus contribute to avoiding overheating. When used with a programmable timer, it becomes possible to turn on the heater right before taking a shower while ensuring that there is no heating during the day.
Can Solar Panels Power an Electric Bathroom Towel Rail?
Yes! Electric bathroom towel rails can be powered by solar panels as long as energy generation is high enough. However, solar energy production is not constant throughout the day and depends mostly on weather. In order to make plenty of solar energy available, it is necessary to have battery storage that keeps the excess energy produced when there is no sun at hand, such as EcoFlow STREAM 5000 or STREAM AC 5000.
What Size Electric Towel Rail Do I Need for a Small Bathroom?
The wattage of a bathroom electric towel rail, around 50-100W, is sufficient only for the heating and drying of towels. The actual wattage required will depend on how many towels need to be hung on the rail, how much free space there is on your walls, and your overall heating needs. If you wish to heat the bathroom as well, you should purchase another heating system that is big enough.
