Dehumidifier vs Tumble Dryer for Winter Washing in UK Homes
- What Does One Load Cost in a Tumble Dryer and With a Dehumidifier?
- How Long Does Each Method Take and Which Loads Suit It?
- How Do You Dry Washing Indoors Without Condensation and Mould?
- What Changes the Cost: Room Conditions, Load Size and Power Ratings?
- Which Method Suits Your Household?
- Spreading the Cost of Laundry Day With Home Energy Storage
- Conclusion
- FAQ About Dehumidifier vs Tumble Dryer
Choosing between a dehumidifier vs tumble dryer is a decision that affects both your electricity bill and how quickly the washing gets done. A tumble dryer finishes a load in hours, often less, while a dehumidifier and clothes airer need more time. The cost difference is less straightforward than it looks. A heat pump dryer is significantly less expensive to operate than an older condenser dryer while dehumidifier-assisted drying costs depend heavily on room temperature and drying time.
At 26.32p per kWh under the current Ofgem price cap, every drying session adds to the household bill. A solar battery offers another way to manage the electricity used for laundry. With home energy storage, households have more control over when they use stored solar electricity rather than relying entirely on the grid.
This guide compares the cost per load, drying times and electricity consumption of both methods. It also looks at condensation, suitable room conditions and ways to manage winter laundry without spending more than necessary.
The dehumidifier vs tumble dryer comparison starts with the electricity used to dry one load. Ofgem sets the average Direct Debit electricity rate at 26.32p per kWh for 1 October to 31 December 2026. Your actual rate depends on your region, payment method and tariff.
To calculate running costs, multiply the electricity consumed in kilowatt-hours by your unit rate. The daily standing charge is excluded because it applies whether the appliances are running or not.
Tumble Dryer Cost per Load by Type
Which?'s October 2026 figures provide a useful comparison of the three main tumble dryer types.
Dryer type | Cost per load | Approximate electricity |
Heat pump | 35p | 1.33kWh |
Condenser | 89p | 3.38kWh |
Vented | 90p | 3.42kWh |
The electricity costs are based on Which?'s average running costs per year, with the October 2026 electricity cost of 26.32p/kWh. The comparison is based on three loads/week with cotton laundry filling 70% of the dryer's rated capacity.
For anyone calculating the cost to run dehumidifier vs tumble dryer, the dryer type makes a substantial difference. A heat pump model uses much less electricity than older condenser and vented machines, even though its purchase price is usually higher.
Dehumidifier and Airer Cost per Load
A compressor dehumidifier paired with an indoor airer offers another way to dry clothes. Take the Meaco Arete Two 20L as an example. At 20°C and 60% relative humidity, it draws approximately 207W, costing around 5.4p per hour at the current electricity rate.
Running time | Energy | Electricity cost |
2 hours | 0.41kWh | 11p |
4 hours 45 minutes | 0.98kWh | 26p |
6 hours | 1.24kWh | 33p |
8 hours | 1.66kWh | 44p |
12 hours | 2.48kWh | 65p |
However, running time is not the same as drying one load. Which? estimates that its tested dehumidifiers cost an average of 26p per litre of water extracted. Its test load released around two litres, putting the estimated cost at approximately 52p. Its more efficient Best Buy models cost around 20p per litre, bringing that figure closer to 40p.
This makes the cost of dehumidifier vs tumble dryer comparison more interesting. The actual result depends on the machine, room conditions and how much moisture the washing releases.
Note: Dehumidifier drying costs depend on the amount of moisture removed, room temperature, relative humidity and operating time. The example figures use the Meaco Arete Two 20L's approximate power consumption at 20°C and 60% relative humidity. They should not be treated as a guaranteed cost for drying every load. |
Electricity Use Side by Side
A six-hour dehumidifier session uses approximately 1.24kWh. That is close to the 1.33kWh derived for a heat pump dryer load and considerably below the 3.38kWh figure for a condenser dryer.
Looking at dehumidifier vs tumble dryer electricity use alone does not tell the whole story. The drying time matters just as much.
Which? reports tumble dryer drying times of 14–40 minutes per kilogram of laundry. A dehumidifier-assisted airer takes considerably longer, even when its electricity demand is lower.
That distinction matters when comparing dehumidifier vs tumble dryer energy consumption. One appliance finishes quickly, while the other spreads electricity use over several hours.
Where the Two Break Even
At 5.4p an hour, the example compressor dehumidifier costs roughly 33p over six hours. That is close to the 35p cost of one heat pump dryer load.
The comparison changes against older machines. A condenser load at 89p costs considerably more than a six-hour dehumidifier session.
For anyone weighing up heat pump tumble dryer vs dehumidifier options, the difference is much smaller than it is with a condenser dryer. Six hours per load, three times a week, costs approximately £51 over a year at the stated rate. Which?'s heat pump figure works out at around £54 annually for three comparable weekly loads.
The dehumidifier vs tumble dryer cost calculation therefore needs to include the appliance type and the amount of laundry dried.
Drying time is where tumble dryers have the advantage. They move warm air through clothes inside a rotating drum, removing moisture without occupying a separate room.
Drying Times Compared
A tumble dryer takes approximately 14–40 minutes per kilogram, according to Which?'s testing. A heated clothes airer takes around four to five hours to dry a small cotton load.
Meaco also tested indoor laundry drying using 13 T-shirts in the same utility room. Its manufacturer experiment recorded around 20 hours for natural drying. A compressor dehumidifier reduced this to approximately 4 hours 45 minutes, while adding a pedestal fan brought the time down to around two hours.
Its DD8L Pro desiccant model took approximately three and a half hours without a fan and one hour 40 minutes with one. These are manufacturer test results, not guaranteed drying times in every home.
The tumble dryer vs dehumidifier decision therefore involves a clear trade-off. A dryer finishes faster, while a dehumidifier provides another option for households looking to reduce the use of older, energy-hungry machines.
Note: Drying times vary with fabric thickness, load size, washing machine spin speed, room temperature and humidity. Manufacturer test results provide a useful comparison, but actual drying times in your home will differ. |
Which Loads Suit Which Method?
Tumble dryers suit towels, bedding, jeans and large family loads. Their drum capacity handles several bulky items together, which is difficult to replicate with a standard clothes airer.
A dehumidifier and airer suit smaller mixed loads, delicate garments and clothes whose care labels prohibit tumble drying. Space the garments apart to improve airflow.
Heated airers offer another option. Which? estimates that drying three separate 2.15kg cotton loads weekly costs around £55 annually with its average tested heated airer.
Several Loads in One Day
A busy household faces a different problem. One clothes airer holds only so much washing, and each load occupies the space until it dries. A tumble dryer will free up that space in much less time. A tumble dryer can be more convenient for homes that have multiple large loads per day, though a heat pump model is far more cost-effective than an older vented or condenser dryer. Don't leave a tumble dryer on when you are sleeping. According to Which? it should be used only when someone is in the house and awake.
Indoor laundry drying is also a moisture-management problem. Every wet garment releases water into the surrounding air as it dries.
How Much Moisture a Load Adds
Manchester City Council estimates that drying clothes indoors adds around 10–15 litres of water to a home each week. Which?'s own laundry experiment collected approximately two litres of moisture from one test load.
Condenser and heat pump dryers are unvented and collect most moisture in an internal tank, though they can still add some warmth and humidity to a poorly ventilated room—especially if filters or condensers are clogged.
The difference between dehumidifier vs tumble dryer UK options is therefore not simply the electricity bill. Poorly managed indoor drying raises humidity, especially in small homes with limited ventilation.
Ventilation and Room Choice
A spare bathroom or utility room is usually a better drying location than a bedroom. Close the room door to limit moisture spreading through the house, while maintaining appropriate ventilation. Use an extractor fan where fitted and follow the manufacturer's instructions for the dehumidifier. Do not put wet laundry on the heating radiators. It restricts circulation of heat, and increases moisture in the room. Vented tumble dryers must have an outside exhaust path. Condenser and heat pump models use a built-in water collector, and do not require an external vent.
Setting Up an Effective Drying Space
Start with a sturdy clothes airer and leave gaps between garments. Do not push it up against walls or fill all space with washing. Place the dehumidifier within a reasonable distance to effectively dehumidify the air and within required spacing from walls. A pedestal fan opposite the airer is used to circulate air around the clothes.
Which? recommends setting a dehumidifier to a target humidity of 30–40% when using it for laundry. Check the clothes periodically and stop the machine when they are dry. An extra spin cycle before hanging the washing also removes more water. That means less moisture needs to evaporate indoors.
Electricity costs follow a simple formula: power consumption multiplied by operating time and the unit rate. The actual drying session changes with the conditions inside your home.
Room Conditions
Dehumidifiers are influenced by temperature. Compressor models do a better job of removing moisture from warm rooms, whereas desiccant models work better in cooler rooms. This is important when comparing the cost of tumble dryer vs dehumidifier in an unheated spare bedroom. A compressor in a cold room will take longer to dehumidify than in a heated utility room.
Load Size and Spin Speed
A small load needs less drying time than a full drum of heavy towels. Do not overstuff the tumble dryer, as this blocks airflow and slows down drying. The spin speed of the washing machine is also important. When an extra spin is done, even prior to drying, water is removed to reduce the effort needed from either drying process.
Measuring Your Own Load
A plug-in energy monitor gives a useful reading for appliances with a suitable plug and rating. Record the electricity used from the start to the end of the drying session, then multiply the kWh figure by your actual tariff.
For a proper tumble dryer vs dehumidifier cost comparison, include the fan's electricity consumption too. A heated airer also adds its own demand, so include it when comparing the full setup.
The dehumidifier vs heat pump tumble dryer decision is closer than a comparison against older dryer types. A household with a heat pump dryer benefits from keeping it for bedding, towels and large loads. A dehumidifier and airer provide an alternative for delicate garments and smaller loads.
Owners of condenser or vented machines have a stronger financial reason to consider indoor drying with a dehumidifier. The savings are most relevant when the room is warm enough for efficient compressor operation.
A spare utility room, a few weekly loads and enough time to dry clothes suit the airer approach. A large family with limited drying space will appreciate the speed and capacity of a tumble dryer. The best tumble dryer vs dehumidifier choice is the one that fits your laundry habits, available space and electricity tariff.
Laundry day puts several appliances to work. The washing machine, tumble dryer or dehumidifier, lighting and heating all contribute to household electricity demand. Home energy storage helps manage when that electricity comes from the grid. Solar panels generate power during daylight, while a battery stores surplus generation for later household use. This is particularly useful for households that run appliances in the evening after solar production falls.
A Storage-Led Starting Point for Homes Without Solar Panels
If you're planning to add solar panels to your home, the EcoFlow STREAM 5000 gives you a way to store the electricity they generate. It starts with 5kWh (5,024Wh) of storage and can expand to 90kWh as your household's energy needs increase. The 5,000W PV input is split across four 1,250W MPPT channels, making room for a larger solar setup. Intelligent Mode+ handles energy management automatically, and the built-in handle makes the unit easier to move into position during installation. It's another way to manage household electricity use while keeping winter laundry costs in check.
Adding Battery Storage to a Home With Solar Panels Already Fitted
Households with existing solar panels face a different challenge: storing surplus daytime generation for use during evening laundry sessions. The EcoFlow STREAM AC 5000 is designed for this type of existing-solar retrofit. It provides 5kWh / 5024Wh capacity, expandable up to 90kWh, with 3000W AC output. Intelligent Mode+ manages energy automatically, while Local Mode supports offline operation and the system carries a 10,000-cycle guarantee. It offers existing solar owners another way to manage electricity around their dehumidifier vs tumble dryer choice.
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries, including the EcoFlow STREAM 5000 and STREAM AC 5000, are not plug-in solar products. They must be professionally installed and must comply with the IET Wiring Regulations (BS 7671) and DNO connection requirements. Follow GOV.UK guidance, and obtain professional advice and guidance from a qualified installer to determine the type of work your home requires. |
The dehumidifier vs tumble dryer comparison comes down to cost, speed and household needs. Which? estimates a heat pump dryer costs around 35p per load, compared with 89p for a condenser and 90p for a vented model. A 207W compressor dehumidifier operates at about 5.4p per hour and six hours of dehumidifying would cost about 33p. But the actual laundry expenses vary according to the moisture that has to be removed, drying time and room conditions. Good ventilation is also essential when drying clothes indoors.
For households managing regular winter laundry, home energy storage provides another way to manage electricity use across the day. EcoFlow offers the STREAM series for households planning solar installations and existing solar owners adding battery storage. Explore the EcoFlow STREAM series to see how home energy storage fits a household that runs the washing machine, dryer and dehumidifier all winter.
Is a heat pump tumble dryer worth buying to replace a condenser dryer?
Which? estimates annual savings of around £85 when replacing an average condenser dryer with a heat pump model. Compare that saving with the purchase price difference and how often you dry clothes before deciding.
What size dehumidifier do you need to dry a family's washing?
Look at the extraction capacity, room temperature and humidity rather than treating litres per day as a laundry capacity rating. Larger households also need enough airer space for their regular washing loads.
Is it cheaper to dry washing overnight on a cheap-rate tariff?
A cheaper off-peak electricity rate reduces the running cost of either appliance. Check the tariff's exact hours and compare the rate with your daytime unit price. Never leave a tumble dryer running while you sleep.
