Take Control of Your UK Battery With EcoFlow App Local Mode
The EcoFlow app is a mobile application you can use to monitor, control and automate EcoFlow’s ecosystem of portable power stations, solar generators and whole-home energy systems. It’s available on iOS and Android and serves as a real-time energy dashboard and remote control hub that lets you manage both standalone devices and interconnected home energy setups from anywhere. Local Mode is a new option in the EcoFlow app built to help you control your home ecosystem when the cloud is down. It enables your phone to communicate with your system over your home network without an EcoFlow cloud connection. It’s a local control that keeps your data local; it’s optional and disabled by default.
This guide looks at:
  • What the Local Mode in the EcoFlow App is
  • The key benefits of the Local Mode for your home energy system
  • Features that work over your home network when the Local Mode is activated
  • Features that stop working when you activate the Local Mode
  • How to turn on the Local Mode in the EcoFlow App settings
  • How to connect Local Mode to Home Assistant
  • What you should know before switching to the Local Mode
  • How to solve the cloud-dependence problem without losing smart control using home energy storage
 A home owner looking at the EcoFlow app dashboard
What Is Local Mode in the EcoFlow App?
Local Mode in the EcoFlow app is a connection option that lets your phone and system talk over your home Wi-Fi instead of through the EcoFlow cloud. It's off by default, so you switch it on yourself. The Cloud mode is usually on by default and gives you remote reach and smart automation. Local Mode keeps everything home-side.
It’s supported by STREAM 5000 and STREAM AC 5000. It’s not supported by second-generation STREAM products independently, but can use it if integrated into a system with STREAM 5000 or STREAM AC 5000. The Local Mode feature needs a smart meter, so check the EcoFlow app manual for your model.
Does the EcoFlow App Work Without Wi-Fi or Internet?
It works without the internet, but it still needs your home Wi-Fi. That means an EcoFlow app without Wi-Fi isn't possible in Local Mode. Your devices must already be paired to Wi-Fi, and your phone and system must sit on the same network.
The app has two setup conditions: your main breaker meter or socket is set up, and the system is switched to Self-powered. If your router goes down, Local Mode can't help—so think "no cloud connection", not "offline". If your login expires, you need the internet to sign back in.
Key Benefits of Local Mode for Your Home Energy System
Keep Essential Functions Running When the Cloud Goes Down
With Local Mode on, you can still monitor system status and manage supported basic functions over your home network. A cloud connectivity issue no longer leaves you shut out of the EcoFlow app. Your battery keeps doing its job, and now you can watch it do it.
Keep Your Energy Data on Your Own Network
Core operating data stays within your local network instead of going up to the EcoFlow cloud. That's local control plus keeping your data local. The only tradeoff is that newly generated statistics aren’t uploaded to the cloud, and you only see real-time data.
See Every STREAM Unit at Once Without Bluetooth Hopping
If you have installed several EcoFlow STREAM units, you can view all their specific data over your home network. You don’t have to connect to each unit individually via Bluetooth. This means, if you have a multi-battery setup, you can see everything on a single screen instead of a round of pairing.
Handle Everyday Energy Management Without Relying on the Cloud
Self-consumption, battery charge management, grid charging power settings and feed-in control continue over your home network. That covers the daily routine of a solar battery. It's a simple option if you prefer local operation, not a replacement for cloud-based smart features.
Count on Your System for the Long Haul
Local Mode backs EcoFlow's long-term reliability message: essential functions stay reachable without cloud services. EcoFlow covers STREAM 5000 and STREAM AC 5000 with a 10-year warranty, subject to its terms. That's the full extent of the promise. Still, reaching your system without a cloud service is one less dependency to plan around.
Enjoy Local Control Many Rival Systems Don't Offer
Monitoring and controlling your system in the app over your home network—even when cloud services are unavailable—is the standout point. Many rival home batteries lean on the cloud for the app experience. Compare specifications before you buy, because features vary by brand and firmware version.
What Still Works Over Your Home Network in Local Mode
Local Mode is optional—you decide if you want local control and keep your data locally. It supports essential monitoring and control but not all STREAM features.
Real-Time Energy Flows and Total Power
You see how solar, home use and grid power are moving right now. Total power appears as live figures rather than history. It's a live snapshot of where your electricity is going.
Battery Charge and Device Status
Check your state of charge, measured against the 5,024 Wh in each STREAM 5000 or STREAM AC 5000 unit. You also see whether each device is running normally.
Self-Consumption
Keep using the mode that prioritises your own solar power. Surplus daytime generation charges the battery, and the battery covers your evening use. Nothing changes in how it behaves—only in how you reach it.
Battery Charge Management and Grid Charging Power Settings
You can adjust how your solar battery charges, including charging using grid power. The EcoFlow STREAM units accept up to 3000W of AC charging, which means that with the app you can decide to charge using cheap off-peak rates. All changes go through your home network.
Feed-In Control
Keep control of what goes back to the grid. You can still manage how much surplus leaves your home. That's useful when you'd rather store the energy than export it.
What Stops Working While Local Mode Is On
Remote Monitoring and Control Away From Home
Your phone must be on the home network. There's no checking in from work or while you're on holiday. If you travel often, that single limit may decide which mode suits you.
AI Mode and Time-Based Custom Mode
Both rely on cloud services and are unavailable in Local Mode. Tariff integration and solar forecasting are also unavailable. If you rely on automated tariff chasing, stay in Cloud Mode.
Device Sharing, Automations and Cloud-Dependent Third-Party Interactions
Sharing access with family, cloud-based automations and some third-party interactions pause. Third-party devices without a local connection can't join the system. Only locally connected EcoFlow ecosystem devices support local automation.
Firmware Updates
You need the cloud connection to update the firmware. So, whenever there is a new EcoFlow app or firmware update, you have to switch back to Cloud Mode. Once updated, you can switch back to Local Mode. Always check for EcoFlow app updates once a month to keep our ecosystem running with the latest settings.
Historical Statistics
New data generated in Local Mode isn't uploaded to the cloud or saved locally, so only real-time data is visible. Your history charts will show a gap for the period you spent in Local Mode. If you want history charts or remote checks while away, stay in Cloud Mode.
How to Turn On Local Mode in the EcoFlow App Settings
Download the EcoFlow App and Update It First
To download EcoFlow app safely, use the official App Store listing on iPhone or Google Play for the EcoFlow Android app. Searching for an EcoFlow app download free version? The official listings already cost nothing, though some features may need a premium subscription. Skip any EcoFlow app APK from a random website—an unofficial EcoFlow app APK can't be verified.
Currently, there is no native EcoFlow app for Mac, EcoFlow app for PC or EcoFlow app for Windows, so don't trust sites offering one. Before switching modes, check that the app and your system firmware are up to date. The EcoFlow app download itself is quick; an EcoFlow app update takes minutes.
Switch to Local Mode Step by Step
This EcoFlow app tutorial should look similar on iPhone and EcoFlow app Android, though screens vary. Everything happens in the EcoFlow app settings:
  1. Open “System Settings” and click “Cloud/ Local connection mode” and select “Local Mode” to begin the setup
  2. Add all devices to the same system and then connect them and your phone to the same WiFi network
  3. Click “Main breaker meter/ Main plug” to view compatible devices. Then, click “Add device” followed by “Link” beside the Smart Meter or the Smart Plug. Wait for the “Linked successfully” pop up message. Then return to the Local Mode setup screen. Check the green check mark beside “Main breaker meter/ Main plug”. Click “Switch to Self-Powered”, then click “Switch”. Select Self-powered mode on the operating mode page. Confirm both check marks are green, then click “Next”.
  4. Click “Feature limitation list” and swipe up to review the list, then click “Confirm” to enable Local Mode.
  5. Wait for the mode switch to complete. Once you see “Connected successfully”, the Local Mode is now enabled in the EcoFlow app.
  6. On the home page, check the icon beside the system name to verify the mode status.
You can use the EcoFlow app user guide for reference.
Currently Supported Devices in Local Mode
  • EcoFlow Smart Meter Dual CT
  • EcoFlow P1 Meter
  • EcoFlow Smart Meter IR
  • EcoFlow & Shelly Smart Meter
  • EcoTracker IR
  • EcoTracker P1
  • HomeWizard P1 Meter
  • EcoFlow Smart Plug
  • EcoFlow & Shelly Smart Plug
Connecting Local Mode Users to Home Assistant
What the Official Home Assistant Integration Offers
Home Assistant is an open-source smart-home platform, and EcoFlow's integration is a separate feature from Local Mode, working through a local API. You authorise access under Third-Party Control in the app, and the screens show Modbus TCP as the connection method. You can monitor solar generation, household loads, grid power and battery state of charge, and choose view-only or view-and-control access.
What UK Households Should Know Before Switching
Professional Installation Is Still Required
STREAM batteries must be installed by a certified, registered electrician, and the unit ships with a stripped-end cable that needs hardwiring. Plug-in solar rules that came into force on 27 August let households in Great Britain use kits up to 800 W, but plug-in battery storage isn't covered. So your battery can't just go into a three-pin socket.
Note: Rules can change. Check the official UK government portal for the latest plug-in solar and battery guidance.
Why Local Control Matters on a UK Tariff
Many UK homes with time-of-use tariffs charge their power storage batteries using both solar and cheap overnight off-peak rates, and discharge during peak hours. With reliable local access, your charge status doesn’t depend on a cloud service running. You can check your battery’s charge status and grid charging settings before the evening rate, with or without cloud.
Note: Tariffs vary by supplier and change often. Check Ofgem official website for current guidance.
Warranty and Durability You Can Plan Around
EcoFlow STREAM series units have a 10-year warranty and 10,000 charge-discharge cycles. The STREAM 5000 and STREAM AC 5000 have an IP65 rating. At the end of its life, the batteries retain at least 60% capacity. Real-world results depend on how you use the battery. You can get all warranty-related details on the EcoFlow warranty page.
Note: Specifications can change. Verify them on the live product pages before you buy.
What UK Smart Meter and Data Rules Say About Your Energy Data
The Smart Meter Data Access and Privacy Framework governs how suppliers, networks and third parties reach your consumer energy data via the smart meter. Smart Energy GB says you should always be able to see your usage and control who else can access it. You can get further explanation from the official UK government portal smart meter pages.
For personal data more broadly, UK GDPR is regulated by the Information Commissioner's Office. Check both for current rules.
Solving the Cloud-Dependence Problem Without Losing Smart Control
Being locked out, juggling units and keeping controls usable were the pain points above, so the hardware matters too.
Keep Your Solar Storage Reachable When the Cloud Isn't
If you are starting solar storage from scratch, then your system choice decides how much control you keep. For example, the EcoFlow STREAM 5000 pairs 5 kWh of LFP storage with four MPPT inputs for direct solar. You can expand it to 90 kWh as your energy demand grows and has a 10-year warranty. This unit supports Local Mode and you can monitor and control charging using the EcoFlow app over your home network without cloud connection.
EcoFlow STREAM 5000
Save an estimated £ 903 per year; results vary by household 5kWh storage with 100% usable capacity, no waste Powers kettles, dryers and more with up to 3000W output Connect up to 12 solar panels with 5000W solar input Expand from 5kWh up to 90kWh as needs grow Intelligent mode charges when cheap, discharges when prices peak 10,000 charge cycles backed by a 10-year warranty Compact design with 40% smaller footprint than comparable 5kWh systems 45.4kg body with a built-in handle for easier placement during installation IP65-rated for indoor or outdoor use, from -20°C to 55°C Keep essentials running during power cuts 15 protection layers plus proactive overload safeguards Hardwired installation by a registered electrician required in the UK
Add Storage to a Solar Setup You Already Have
Plenty of UK homes already have panels or microinverters and just need somewhere to put the surplus. The EcoFlow STREAM AC 5000, for example, has no solar inputs—it's AC-coupled, so it slots in beside an existing array. It also supports Local Mode and stacks with other units, so a multi-unit system can be viewed together in the EcoFlow app. A certified electrician still handles the installation.
Save an estimated £ 221 per year; results vary by household 5kWh capacity powers your home from day into night 100% usable capacity, so no stored energy goes to waste Up to 3000W off-grid output for kettles, dryers, stoves, and more Expandable up to 90kWh as your energy needs grow Smart modes use weather and tariffs to cut your bills Backup power during outages for appliances on the AC outlet Compact 44.6kg body designed to fit into spaces around the home IP65-rated for indoor or outdoor installation 40% smaller footprint than comparable 5kWh batteries Built to last: 10,000 cycles and 10-year warranty Control and track your savings from the EcoFlow app Installation by a certified electrician required in the UK 3000W output with expansion battery; single unit delivers 2500W
The EcoFlow app is introducing a new Local Mode feature to allow UK homeowners to control their products locally without connecting to the cloud. This feature is a choice and gives you dependable control over your home network and keeps new data local. When you activate Local Mode in your EcoFlow app, you lose control of features that rely on being connected to the cloud, such as remote access, history charts, AI Mode, Custom Mode, sharing and cloud-based firmware updates. You retain control of other important features, such as self-consumption, charge management, grid charging power and feed-in control. The Local Mode allows you to see all connected STREAM units in one view.
Cloud Mode suits you if you want remote access and AI features. Local Mode suits you if you prefer local operation. This EcoFlow app explained comes down to one habit: check for app and firmware updates, then decide which mode fits your household. Explore the EcoFlow STREAM series on EcoFlow UK to find the home battery that fits your setup.
EcoFlow App Frequently Asked Questions
Is the EcoFlow App Free?
Yes. The EcoFlow app is free to download from the App Store and Google Play. If you want an EcoFlow app download free of charge, the official stores are the place. There are some features that may need a premium subscription, so check what applies to your system.
Is the EcoFlow App Good?
Yes. The EcoFlow app is well regarded by the buyers who've reviewed it on EcoFlow UK's STREAM 5000 page. Most reviews say that it’s easy-to-use and intuitive. An EcoFlow app review written before Local Mode arrived won't cover it, so check the date on any EcoFlow app review you read.
What Can I Do If the EcoFlow App Isn't Working?
Start with your phone's Wi-Fi or mobile data, then update the app. On EcoFlow app Android devices, check Google Play; iPhone users check the App Store. If it's a cloud outage and you've already enabled Local Mode on your Wi-Fi, you can still reach your system. Reinstalling the EcoFlow Android app or contacting EcoFlow support are the next steps.
What Does an EcoFlow Smart Meter Do?
An EcoFlow smart meter is a sensor that measures how much power your home draws from or sends to the grid, so your STREAM system can respond. It's different from your supplier's smart meter. EcoFlow's UK product page lists several compatible meters, and Local Mode needs one.
Is EcoFlow Worth the Money?
Yes. EcoFlow is worth it if your household has enough solar surplus or cheap overnight power to use the storage well. Savings depend on your usage, tariff and system size, and EcoFlow doesn't guarantee financial returns. Compare quotes and payback estimates before buying.
