Average Electricity Consumption: What's Normal for Your Home?
Ever looked at your electricity bill and wondered, “How much power are we actually using?” Understanding electricity average consumption can give you a clearer idea of what’s normal, and maybe even reveal where your home is secretly burning through energy. In the UK, daily and monthly usage can vary a lot depending on household size and lifestyle. In this article, we’ll break down what an average household uses, what drives higher consumption, and share some simple tips to help you cut down on your bills.
What Is the Average Household Electricity Consumption in the UK?
The average electricity usage in a UK home can vary quite a bit depending on the number of people living there, the size of the house, and the type of appliances you use. On average, a typical UK household uses around 2,700 kWh of electricity per year. Breaking that down, it’s roughly 225 kWh per month or about 7–8 kWh per day.
If you live alone in a small flat, your average home electricity consumption will likely be lower—around 1,800 kWh per year. A medium-sized household with 2–3 people usually falls close to the national average of 2,700 kWh per year. Larger households with 4–5 people can see their electricity usage rise to over 4,000 kWh annually.
Here’s a quick overview of average electricity consumption per day and per year based on household size:
Household Size
Daily Usage
Monthly Usage
Annual Usage
1–2 people (small flat)
5 kWh
150 kWh
1,800 kWh
2–3 people (medium home)
7–8 kWh
225 kWh
2,700 kWh
4–5 people (large home)
11 kWh
340 kWh
4,100 kWh
These numbers give a good benchmark for comparing your own electricity use. Many factors can push your consumption higher, like working from home, running older appliances, or having electric heating. By keeping track of your daily habits, you can get a better sense of your average UK electricity consumption per household and spot opportunities to save energy—and money.
Which Appliances Use the Most Electricity?
Here’s a breakdown of the biggest electricity users in a typical UK home:
  • Fridge & Freezer – Runs 24/7 to keep food fresh, often the largest contributor to your electricity bills.
  • Washing Machine & Dishwasher – Hot water cycles consume a lot of energy; using eco modes saves power.
  • Tumble Dryer – Very energy-hungry, especially in winter when air-drying isn’t possible.
  • Oven, Microwave & Kettle – High-wattage appliances used for cooking and boiling water.
  • TVs, Computers & Gaming Consoles – Steady load; standby mode can add up to 10% of annual electricity use.
Factors Affecting Household Electricity Consumption
Several factors influence how much electricity your home uses, and knowing them can help you save energy.
1. Home Size & Occupancy
Larger homes and more people naturally use more electricity for lighting, appliances, and electronics. For example, a five-bedroom home with a family of four can consume almost twice as much as a one-bedroom flat with one person.
2. Heating System
Homes with electric heaters or heat pumps use more electricity than those with gas heating. Even efficient heat pumps draw significant power, while gas boilers shift most heating energy away from electricity bills.
3. Lifestyle & Daily Habits
Leaving lights on, running appliances unnecessarily, or keeping devices on standby all increase usage. Small habits like turning off lights, using appliances only when full, or unplugging unused devices can reduce consumption.
4. Age & Efficiency of Appliances
Older appliances often consume more energy. Upgrading to energy-efficient models—like LED lights, eco-mode washing machines, and smart fridges—can save both electricity and money.
5. Insulation & Home Efficiency
Poor insulation makes electric heating or cooling work harder. Sealing drafts, insulating lofts and walls, and using thermal curtains can lower electricity use.
6. Smart Devices & Technology
Smart bulbs, plugs, and devices draw power even when idle. While small individually, together they can add several kWh monthly. Using smart plugs or managing devices carefully can help reduce this extra usage.
How to Reduce the Average Electricity Consumption
Cutting down your electricity usage doesn’t have to be complicated. With a few smart habits and the right technology, you can reduce your average electricity consumption and save money every month. Here’s how:
1. Upgrade to Energy-Efficient Appliances
Older fridges, washing machines, and dishwashers consume much more power than modern, energy-efficient models. Look for A-rated or energy-labelled appliances—they use less electricity without sacrificing performance.
2. Optimize Lighting
Switching from incandescent or halogen bulbs to LEDs can cut lighting electricity use by up to 80%. LEDs last longer, waste less energy as heat, and come in various color temperatures for a comfortable home environment.
3. Minimize Standby Power
Many devices—TVs, consoles, smart speakers, and chargers—draw electricity even when “off.” Using smart plugs or unplugging devices when not in use can reduce this hidden consumption, known as phantom load.
4. Adjust Your Habits
Simple changes in daily routines make a difference:
  • Only run washing machines and dishwashers with full loads.
  • Dry clothes outdoors when possible instead of using a tumble dryer.
  • Close fridge and freezer doors quickly and keep them defrosted.
  • Cook efficiently by using microwaves, air fryers, or induction hobs for small meals.
5. Use Smart Technology
Smart meters and energy-monitoring apps help you track your average home electricity consumption in real time. They make it easier to spot high-usage patterns and take action before your bills climb.
6. Consider Renewable Energy & Home Batteries
For those looking to cut electricity bills long-term, investing in solar battery storage can help you store excess solar energy during the day and use it during peak hours.
The EcoFlow STREAM Ultra + 4×450 W Rigid Solar Panel is well-suited for households taking their first step into solar battery storage. The STREAM Ultra combines the inverter and battery into a single, integrated unit with a base capacity of 1.92 kWh, making setup and everyday use more straightforward. Designed to perform in low light conditions, the system continues generating power even on overcast UK days, capturing usable solar energy for longer and extending daily solar collection by up to an extra hour compared with typical systems.
Capacity: 1.92kWh (Expandable up to 11.52kWh) AC Output: 1200W Solar Input: Up to 2,000W Estimated annual savings: Up to £963 on electricity bills. Perfect for: Homeowners seeking an "out-of-the-box" solar and storage solution for energy independence, maximizing self-consumption, and achieving significant long-term savings.
For households that already have solar panels and want to increase on-site storage, consider the EcoFlow STREAM Ultra + STREAM AC Pro. This bundle provides a larger combined capacity of 3.84 kWh, exactly double the STREAM Ultra base, giving more headroom to store daytime solar for evening use, extend backup runtimes, and lower reliance on the grid. That makes this configuration a practical, user-friendly next step for families who need greater autonomy while keeping installation and everyday operation simple.
Capacity: ~3.84kWh (Expandable up to 11.52kWh) AC Output: Up to 2,300W Solar Input: Up to 2,000W Perfect for: Whole-home backup during outages, maximising solar self-consumption, and significantly reducing electricity bills through intelligent time-of-use management.
Some households also aim to rely less on the grid—especially in rural locations or high-usage homes. In this case, exploring an off-grid solar system can offer even greater independence by allowing you to generate and store your own electricity without depending on utility providers.
Understanding your electricity average consumption is the first step toward smarter energy use. By adopting simple habits, upgrading appliances, and exploring modern solutions like home solar batteries, households can cut costs, reduce waste, and make energy use more efficient without sacrificing comfort.
How many kWh does an average house use per day?
The average UK household consumes between 7 and 9 kWh of electricity per day. This figure depends on the size of the property, the number of people living there, and how energy-efficient the appliances are. Smaller flats or one-bedroom homes often use closer to 5 kWh per day, while larger homes with more occupants may reach 11 kWh or more daily. Understanding your daily usage can help you track energy habits, identify waste, and potentially reduce your electricity bills.
Is 20 kWh a day a lot in the UK?
Yes, using 20 kWh of electricity per day is considered very high for a UK household. Most homes consume less than half that amount daily. Such high consumption might occur if you have electric heating, multiple large appliances running at once, or high entertainment and cooking demands. Consistently using this much electricity could lead to significantly higher energy bills, so reviewing usage patterns or investing in energy-saving solutions can make a noticeable difference.
How much electricity does the average 2-person house use?
A typical two-person household in the UK uses about 7.4 kWh of electricity per day, which totals roughly 2,700 kWh per year. This assumes a medium-sized home with standard energy usage for lighting, appliances, and everyday electronics. Lifestyle factors, such as working from home or frequently cooking at home, can increase consumption, while energy-efficient appliances and habits can reduce it. Keeping an eye on your consumption with tools like smart meters or energy monitors can help you manage your bills more effectively.
Saving Bills
