What Woodworking Laser Engraving Adds to Your UK Bill
A laser engraver looks like a small, low-power tool. It rarely runs alone. The extraction fan, air pump, chiller and design laptop all switch on beside it, often for hours, and that is where woodworking laser engraving starts to show up on your bill. Your workshop is probably already feeling the weight of the current electricity prices, which rose by 4% for the 1 October to 31 December quarter to 26.32p/kWh. This means that every hour of running time now counts for a little more.
This article looks at:
  • How much electricity woodworking laser engraving uses
  • What changes the cost of woodwork laser engraving
  • What 1, 3 and 8 hours of woodworking laser engraving cost
  • How your workshop/ small business pays for power
  • How to keep woodworking laser engraving energy costs lower
  • How to manage electricity when running a laser alongside other workshop tools
  • Ways to bring down daytime laser engraving costs using home energy storage
A Woodworking Laser Engraving specialist working from his home office
How Much Electricity Does Woodworking Laser Engraving Use?
Woodworking laser engraving uses roughly 0.25kWh per hour on a hobby diode setup and roughly 1–1.5kWh per hour on a CO2 setup. Those are our assumptions, and the calculation section shows how they play out. At Ofgem's domestic cap rate of 26.32p/kWh, that works out at about 6.6p an hour for a diode rig and 26p to 39p for CO2. Standing charges are excluded from every running-cost figure here.
Note: energy prices change every quarter. Always check the Ofgem website for the latest price cap rates before you budget.
How Much Power Does a Woodworking Laser Engraver Draw?
A woodworking laser engraver is a machine that pulls mains power for its laser source, motors and control board. A diode machine sits at the light end—the engraver itself often draws well under 150W. A desktop CO2 machine is different, because its power supply drives a glass tube that turns only a fraction of that input into light. So one CO2 machine can draw several hundred watts before any extras.
Here's the catch. The optical rating (10W, 40W) describes the light leaving the laser, not the electricity going in. The machine's label tells you more.
Why the Fan, Air Assist and Chiller Matter
The laser rarely runs alone. There's the extraction fan, the air assist pump, a water chiller (CO2 only) and the laptop running your design software. A compressor chiller can add several hundred watts, an extraction fan 100W or more, and a laptop 30–65W. Together these extras often draw as much as the laser itself, so a "40W" machine can behave like a 1kW load once everything is on.
What Changes the Cost of Woodwork Laser Engraving
The real draw of your whole setup, how long it runs and your unit rate determine the cost of woodwork laser engraving. You can control two of these.
Why a Laser Engraver for Woodworking Can Draw More Than Its Label Says
The nameplate wattage only covers the machine and excludes the chiller, extraction and laptop. This means that your laser engraver for woodworking pulls more energy than indicated on the sticker. Also, the start-up draw contributes to this because the pumps, fans and the laser power supply briefly surge when you switch it on. To read the power supply rating, find the input line showing volts and amps, then multiply (230V × 4A is about 920W) for a rough ceiling.
So before you buy a laser engraver woodworking jobs will keep busy for hours, read that label. The best laser engraver for woodworking on your budget is the one whose real draw you've checked, not the one with the biggest number on the box.
How Wood Type and Engraving Time Change the Total
Working on dense hardwoods and deep engraves need slower passes, which increases the time it takes to complete a job. Plywood and softwood are quicker, but the glue in plywood adds to the fume load, and your extraction fan has to work harder to clear it. Time is the biggest lever in the cost of running your woodworking laser engraving:
Cost = wattage x hours x price
What 1, 3 and 8 Hours of Woodworking Laser Engraving Cost
The formula is simple: wattage x hours x price (kW × hours × 26.32p). The figures below are estimates at the domestic price-cap rate, based on our assumed total draw for each setup, and they exclude standing charges.
Setup (total draw incl. extras)
1 hour
3 hours
8 hours
Hobby diode, about 250W (laser, air pump, small fan, laptop)
6.6p
19.7p
52.6p
Desktop CO2, about 1kW (machine, chiller, extraction, air assist, laptop)
26.3p
79p
£2.11
Small-business CO2, about 1.5kW (larger tube, stronger extraction)
39.5p
£1.18
£3.16
Note: These figures move whenever the price cap does. Check Ofgem for the current rate.
Home Workshop Costs
Take a 1kW CO2 setup running 3 hours a session, 8 sessions a month. That's 24kWh, or about £6.32 a month. The cost is modest on its own. But it lands on top of every other tool your workshop draws, and winter lighting and heating are already competing for the same meter.
Small Business Costs
Now take a 1.5kW setup running 8 hours a day over 20 days. That's 240kWh, about £63 a month at the domestic rate. A small-business woodworking laser engraver can add that much before you count a single extra machine. In a production workshop, it adds up quickly.
How UK Home Workshops and Small Businesses Pay for Power
This section covers the UK-specific side of the sum, because the rate you pay depends on your contract.
Domestic Price Cap vs Business Electricity Contracts
The Ofgem cap applies to domestic standard variable tariffs. Business contracts aren't capped, so if you trade, check your own unit rate and substitute it into the calculation formula, and check if your quoted rate includes VAT.
If you are a home-based maker, confirm which tariff supplies your workshop. A garage on your domestic meter uses the domestic cap, while a separately metered unit usually doesn't.
What the Current Ofgem Rate Includes
The current Ofgem price cap for the 1 October to 31 December 2026 is 26.32p per kWh and the daily standing charge is 54.83p. VAT isn’t included on domestic electricity for this quarter, as the government removed it for the period from 1 October 2026 to 31 March 2027. The standing charge will still be there on your bill whether or not you use the laser tool, which is why we left it out of the running-cost figures.
Note: Rates and VAT treatment can change. Check Ofgem and the official UK government portal for current figures.
Time-of-Use Tariffs and the Next Price Cap Change
If you are on a time-of-use tariff, your long engraving jobs can run during these off-peak hours. During the off-peak period, units are cheaper than the standard rate, so electricity costs will be slightly lower than during peak hours.
4 Ways to Keep Woodworking Laser Engraving Energy Costs Low
Four small changes make the biggest difference, and you might overlook all of them. One safety reminder first: none of these savings should come from reducing extraction or cooling while the laser is firing.
Measure Your Machine's Real Draw With a Plug-In Energy Monitor
A plug-in socket meter shows the actual wattage of the whole setup, which often differs from the label. Check that the meter is rated for your load, since a 13A socket tops out around 3kW. Then use the reading in place of our assumed figures. The best laser engraver for woodworking is the one whose real running cost you've measured yourself.
Tune Power, Speed and Focus to Cut Repeat Passes
Before you commit to a finished piece, test your settings on scrap offcuts of the same wood to ensure the machine has correct focus and a clean lens. This helps you get machine marks cleanly in fewer passes, which means fewer minutes of draw from every connected device. This is the easiest and cheapest saving on this list and costs nothing.
Stop the Extras Running When the Laser Isn't
When you are between jobs, switch the air assist and fan off but keep extraction on while the laser fires and for a short while afterwards to clear fumes. While the CO2 tube is in use, keep the chiller running, then switch it off. Once you finish everything, turn the machine off at the wall to prevent it from drawing standby power, which can add up across months. Don’t use a desktop but use a laptop to design and control because laptops draw less power than desktops.
Batch and Nest Jobs so the Machine Works in Fewer, Fuller Sessions
To reduce energy waste, group several small tasks into one job to minimize starts and stops. Also, prepare your designs on a laptop before powering up the laser. These simple steps help reduce the time the chiller and fans run.
Managing Electricity When a Laser Runs Alongside Other Workshop Tools
Why Running a Laser and Woodworking Machinery Together Strains a Circuit
A 13A socket tops out around 3kW. Add a dust extractor, compressor or table saw to a laser setup and you can trip the circuit quickly. Stagger the loads instead, and run the engraver while heavy tools sit idle. It's a small habit that saves you a dark workshop mid-job.
Why You Should Check Input Power Before Using a Storage System
Look at the laser's actual input power and continuous output requirement. The battery or inverter must be capable of supplying the full combined load continuously. Also, allow for start-up draw from the chiller and fans because that surge can catch an undersized unit out.
Ways to Bring Down Daytime Laser Engraving Costs
Once you know your per-hour figure, the next question is how to buy less of that power from the grid.
How Can You Offset Daytime Workshop Electricity Without a Roof Installation?
Most woodworking laser engraving happens in daylight hours, which is exactly when a small solar array produces power. For example, the EcoFlow STREAM Plug-in Solar Kit pairs two 500W panels with an 800VA microinverter that plugs into a wall socket, so there's no roof installation or rewiring. It won't carry a 1kW CO2 setup on its own, and UK winter output is modest. But the electricity it generates can cover the fans, pump and computer, trimming the grid power you buy for long sessions. You'll need to notify your network operator after installation.
Plug it into a compatible wall socket and start saving Cut your electricity bill by up to £187 a year No drilling or rewiring, so your deposit stays safe Renting or in a flat? Solar still works for you Moving house? Just unplug it and take it along Powers your fridge, router and TV with free daytime sunshine Even gloomy days and early mornings still add savings Tough enough to shrug off rain, frost and summer heat Check what you're generating anytime from your phone Panels carry a 15-year warranty, so buy with confidence
How Can You Keep Long Sessions Running Once the Sun Drops?
Eight-hour sessions of woodworking laser engraving run well past the solar peak, which is when stored energy matters. For example, the EcoFlow STREAM 5000 stores 5kWh and can be expanded, so surplus daytime solar or cheaper off-peak power can supply your workshop later. Before connecting a laser, check its actual input power against the continuous output the battery supports, as the unit's AC outlet is rated up to 3,000W. In the UK, it must be installed by a registered electrician.
EcoFlow STREAM 5000
Save an estimated £ 903 per year; results vary by household 5kWh storage with 100% usable capacity, no waste Powers kettles, dryers and more with up to 3000W output Connect up to 12 solar panels with 5000W solar input Expand from 5kWh up to 90kWh as needs grow Intelligent mode charges when cheap, discharges when prices peak 10,000 charge cycles backed by a 10-year warranty Compact design with 40% smaller footprint than comparable 5kWh systems 45.4kg body with a built-in handle for easier placement during installation IP65-rated for indoor or outdoor use, from -20°C to 55°C Keep essentials running during power cuts 15 protection layers plus proactive overload safeguards Hardwired installation by a registered electrician required in the UK
To know the running cost for woodworking laser engraving, use the formula: wattage × hours × price. Using the current Ofgem rate of 26.32p/kWh, running an engraving job for one hour costs 7p for a hobby diode setup and about 40p for a small-business CO2 machine. Don’t overlook the power draw of extras, such as the chiller, fan, pump and laptop, because they draw as much as the tube. It’s also possible to lower your costs by implementing simple strategies, such as tuning settings on scrap, switching off extras when not in use and batching small jobs together.
If you are considering adding solar battery storage, check its real input power first. Measure your own draw first, then decide whether solar or storage makes sense for your workshop. If it does, EcoFlow's STREAM range is a sensible place to start looking.
Frequently Asked Questions About Woodworking Laser Engraving
Can Laser Engraving Be Done on Wood?
Yes. Both diode and CO2 lasers mark wood well, and it's one of the most popular materials for either. Results vary by species, grain and resin content, so test on an offcut first.
Will a 10W Laser Engrave Wood?
Yes. A 10W diode engraves most woods cleanly, though it works more slowly than a CO2 machine. It can also cut thin plywood, usually in several passes.
Can a 40W Laser Cut Through Wood?
Typically, yes, if it's a 40W CO2 laser and the wood is thin. Expect to cut plywood and softwood of a few millimetres, often with multiple passes. Thickness, density and focus all change the result.
How Thick of Wood Can a 100W Laser Cut?
A 100W CO2 laser can often cut roughly 15–25mm of wood, depending on species, speed and optics. Thicker stock means slower passes and a longer run, so the electricity bill rises with it.
Are Cheap Laser Engravers Worth It?
They can be for hobby use, but check the real input power, enclosure and safety features, not just the headline wattage. A cheap laser engraver for woodworking can cost more to run if it needs extra passes. The best laser engraver for woodworking balances purchase price with measured running cost.
