How Much Electricity Does a 3D Printer Use in the UK?
- How Much Electricity Does a 3D Printer Use Per Hour and Per Day
- What a 3D Printer Costs to Run at UK Electricity Prices
- How Much Electricity Does a Resin 3D Printer Use Compared With Filament Machines
- Why Overnight Prints Can Quietly Raise Your UK Electricity Bill
- Simple Ways UK Hobbyists Can Cut 3D Printer Running Costs
- How to Beat Peak Tariffs and Rising Unit Rates Without Pausing Your Prints
- Keeping Your 3D Printing Hobby Affordable This Winter
- How Much Electricity Does A 3D Printer Use FAQs
You probably think a 3D printer sips power like a lightbulb. Then, you run a print for 14 straight hours and you start eyeing your next bill. So, how much electricity does a 3D printer use in your household? A 3D printer consumes about 0.05 to 0.25 kWh per hour, which is slightly higher than a lightbulb. The price per unit is about to matter too. Ofgem's price cap is 26.32p per kWh (October to December 2026, direct debit). Which means a printer costs about 1.3p to 6.5p an hour, or about 32p to 156p over a full 24 hours.
This guide looks at:
A breakdown of how much electricity a 3D printer uses per hour and per day
What a 3D printer costs to run at current UK electricity rates
An electricity comparison between resin 3D printers and filament machines
Why overnight prints can quietly raise your electricity bill
Simple ways hobbyists can cut 3D printer running costs
How to beat peak tariffs and rising unit rates using home energy storage
A desktop 3D printer uses about 0.05 to 0.25 kWh per hour which translates to 0.4 to 2.0 kWh over an 8-hour day or 0.5 to 6.0 kWh over a continuous 24-hour day. To know exactly how much electricity your 3D printer consumes, multiply its power rating with the number of hours you intend to run it.
A printer's hourly draw has two phases. During heat-up, the bed and nozzle pull hard. A Flashforge Adventurer 5M Pro, for example, is rated at 350W on its spec sheet, and that's the ceiling. Once temperatures settle, the heaters cycle on and off and the draw drops.
The average electricity consumption of a hobby FDM printer is between 50W- 250W, with enclosed or high-speed models consuming even higher than this level.
How Much Electricity Does a 3D Printer Use Per Day
Your daily total depends on how long the machine runs, not how often you glance at it. Take a 100W printer on a 10-hour print. That's 1.0 kWh, or 26.3p at 26.32p per kWh. Run it for 24 hours and you've used 2.4 kWh, which costs 63.2p.
Now stretch it out. Three straight days of printing in a month adds up to 7.2 kWh, about £1.90. A printer running non-stop for a full 30 days would use roughly 72 kWh, or about £19. That isn't nothing, but it isn't frightening either. Put simply, the answer to how much electricity does a 3D printer use UK hobbyists see on their bill is a few pence per hour.
Note: These figures use the October to December 2026 cap and will change. Check Ofgem for the current rate.
How Much Does a 3D Printer Use in Electricity per Print
Take a 120W printer at 26.32p per kWh. It costs about 3.2p an hour. A six-hour print lands at roughly 19p, and a 10-hour job at 31.6p. Print five 10-hour jobs a week and you'd spend about £1.58 on electricity. Your filament will cost far more.
One caveat. Your standing charge is paid whether the printer runs or not, so only the unit rate matters here. Leave the standing charge out of any per-print sums.
What the January 2027 Price Cap Rise Could Mean
Cornwall Insight's latest forecast puts the electricity unit rate at about 32.54p per kWh from 1 January. That's a forecast, not a final figure. Re-run the same 120W example and the hourly cost rises to about 3.9p. A 10-hour print costs 39p instead of 31.6p, and a 24-hour run costs about 94p instead of 75.8p.
Treat that as a reason to act now, not a reason to stop printing. The habits further down this guide cut your kWh, so they cut your bill at whatever rate Ofgem sets.
Note: The official cap is confirmed by Ofgem on 25 November. Forecasts can shift, so check Ofgem before budgeting. |
So, how much electricity does a resin 3D printer use next to a filament one? Usually much less. The two types draw very differently, and the table below puts a price on each.
Printer type | Average draw | Energy for a 10-hour print | Cost per hour | Cost per 10-hour print | Cost per 24 hours |
Entry-level FDM (PLA) | 100W | 1.0 kWh | 2.6p | 26.3p | 63.2p |
Enclosed, fast FDM (PLA) | 130W | 1.3 kWh | 3.4p | 34.2p | 82.1p |
Flashforge Adventurer 5M Pro (PLA/PETG) | 120W | 1.2 kWh | 3.2p | 31.6p | 75.8p |
FDM with heated chamber (ABS, nylon) | 200W | 2.0 kWh | 5.3p | 52.6p | 126.3p |
Resin LCD printer | 50W | 0.5 kWh | 1.3p | 13.2p | 31.6p |
The calculation in this table uses the current price cap of 26.32p per kWh for the October to December 2026 quarter. To know your model’s exact consumption, check its energy rating and multiply by the hours you are running it (kWh), and multiply by the up-to-date Ofgem price cap, or your tariff’s price cap.
Note: For up-to-date pricing, use Ofgem’s official website and multiply this value with your printer's hourly consumption. |
Resin Printers and Their Wash and Cure Extras
The printer itself usually draws less than a filament machine. The wash and cure station adds to the total, though only by around 0.5p a batch. It's small, but it happens every print.
Resin prints are often shorter, which helps. Then a failed or reprinted batch erodes the saving. If you're working out how much electricity does a resin 3D printer use across a whole project, count the reprints as well. Count the cure cycles too, not just the main print.
How Much Electricity Does a Flashforge 3D Printer Use
The Flashforge Adventurer 5M and 5M Pro both list a 350W power supply rating. Those are maximum figures. Flashforge's own energy guide puts typical desktop FDM printing at 50–150W, and most hobby machines sit in that range. That's why the table uses 120W for the Adventurer 5M Pro as a realistic average.
Even at the full 350W, you'd pay about 9.2p an hour at the current cap. It never stays there for long. So how much electricity does a Flashforge 3D printer use in practice is a few pence per hour. Check your own model's label if you run a different one.
Why Heated Beds and High-Temperature Filaments Push Usage Up
The PLA model is the cheapest to run, and prints with a warm bed and a moderate nozzle temperature which means the heaters work less. PETG needs a hotter bed, while ABS and nylon also need hotter beds and nozzles. The Adventurer series requires 110°C on the bed and 280°C at the nozzle.
Enclosures and chamber heating add another layer. An enclosure holds heat in, which can help warping. An actively heated chamber is a different matter, and it's why the table above lifts to 200W for ABS and nylon work.
So, how much electric does a 3D printer use overnight, and does it show on your bill? Yes, a 3D printer does push your electric bill up. It's just not by much per print. A 12-hour overnight job at 120W uses about 1.4 kWh, around 38p at today's cap. Repeat that most nights and it's noticeable.
Peak Tariff Windows Versus Off-Peak Rates
Time-of-use tariffs can help you keep your 3D printing running costs low. These tariffs have set overnight windows when per unit price caps are cheaper than peak periods. An example is the Octopus Go tariff that provides a cheap window from 00:30 to 05:30 and the Intelligent Octopus Go from 23:30 to 05:30. The electricity prices for these tariffs sit between 6.5p to 9p per kWh, which is way lower than the current 26.32p per kWh cap. Doing the maths, a 1kWh print during these off-peak times costs under 9p compared to 26.32p during normal times.
Note: Tariff rates and eligibility change. Check your supplier's website and Ofgem's guidance for up-to-date details. |
Standby Draw and the Extras That Add Up
If you search how much electric does a 3D printer use UK forums, you’ll notice a wide range of numbers because most people forget the additional extras. For example, filament dryers can run for hours at tens of watts and enclosure fans and extraction add a steady few watts. If you leave your printer on but it's idle, it may still draw 10-20W around the clock, which is about £1.90 to £3.80 a month at the current cap.
These figures become substantial when you put them together and can actually match the printing itself. A smart plug with an energy monitor shows the real number.
So here's the point. The gap between peak and off-peak rates is where home battery storage helps. A battery charged cheaply can feed your printer later, which we'll come back to shortly.
Start by plugging your printer into a smart plug with an energy monitor. It shows your real kWh per print, the most honest answer to how much electricity does a 3D printer use per hour on your own machine. Then check each tip below against it.
Shorten Print Time Before Touching Any Temperatures
The biggest consumer of electricity in printing is print time. To minimize this, use larger nozzles, thicker layers on non-visible parts and fewer supports. Infill around 10–15% is enough for many parts.
Catch Failed Prints Early So You Stop Paying Twice
If you run a print and it fails during the eighth hour, it means you have wasted eight hours of heating, add on these the reprint hours. You are incurring a double cost for nothing. To avoid this, check the first layer before leaving the room. Also, make it a habit to run small tests before embarking on long print jobs.
Let Leftover Heat Finish the Job
Set your slicer's end-of-print code to switch the heaters off straight away. The bed and nozzle shouldn't sit hot once the job is done. Start the print as soon as the printer reaches temperature instead of leaving it to preheat.
Where your material allows, cut the bed heat for the last layers. PLA parts often stay stuck on a warm bed, so test this on a small print first.
Keep the Printer Out of the Cold
A printer in a cold UK garage or shed works harder to hold bed and nozzle temperature. Move it to a warmer room, add a draught shield or use an enclosure, and keep it away from open windows and fans.
It lifts print quality too. Fewer failures mean fewer wasted hours.
Peak-rate printing, overnight runs and the January rise all point at one fix: use cheaper or free energy at the right time.
Run Overnight Prints on Stored Off-Peak Power
So, how much electricity does a 3D printer use when it runs all night, and could it be cheaper? A home battery can charge at low rates and release that power later. For example, the EcoFlow STREAM AC 5000 stores 5kWh and charges from the grid in low-rate windows. It then supplies your printer, heated bed and extras when unit prices peak. Its Intelligent mode builds charging and discharging around time-of-use tariffs and weather forecasts, and the app lets you monitor usage. It's hardwired in the UK, so a certified electrician must install it.
Power Long Print Runs From Your Own Solar Panels
So, how much electricity does a 3D printer use when the sun is doing the work? Solar plus storage can answer that. The EcoFlow STREAM 5000, for example, accepts up to 5,000W of solar input and holds spare energy in its 5kWh battery. Long prints can then draw on stored daytime generation instead of the grid. You can add extra batteries as your projects grow. UK winter sunshine is limited, so savings will be smaller in December, and a certified electrician must install it.
So, how much electricity does a 3D printer use in UK homes? Most hobby printers average 50–150W. That's about 1.3p to 3.9p an hour at the current cap, and a few pounds a month for typical use. If you're asking how much electricity does a 3D printer use per day, the answer is 0.5 to 3.6 kWh, depending on the machine. Resin printers sit at the bottom of the table, and heated-chamber filament machines sit at the top. How much does a 3D printer use in electricity across a whole month? For most hobbyists, it can cost between £0.50 to £5.00 (2 to 20 kWh per month). With a solar battery storage, you can reduce these figures and stay immune from the high grid electricity price caps by using off-peak tariffs and solar charging. Explore the EcoFlow STREAM range to see whether a home battery fits your setup.
Is It Safe to Have a 3D Printer in Your House?
Yes, but requires a few tricks. Start by placing it on a stable, non-flammable surface and keep the room ventilated. ABS and similar materials need an enclosure and good extraction. When running long prints, make sure somebody is in the house for safety and also install a smoke alarm in case a fire starts.
Is a 3D Printer an Expensive Hobby?
It can be, but usually isn't. Entry-level machines start from roughly £200–£400 in the UK, and electricity adds only pence per print. Filament, spare nozzles and replacement build plates are the bigger ongoing costs. Your spending depends mostly on how often you print.
Is 1000 Hours a Lot on a 3D Printer?
No. If you regularly run maintenance, your printer can handle several thousand hours. Always check the condition of nozzles, belts and build plates because they wear out first but are cheap to replace.
What Is the Lifespan of a 3D Printer?
Most desktop printers last around three to five years with regular use, sometimes longer. The frame and motion system usually outlast the consumables. Replace nozzles, belts and fans as they wear, and keep the machine clean to stretch its life.
Is 3D Printing Expensive in the UK?
The costs are affordable for small or one-off jobs but rises on large models engineering materials, and commercial or high-detail processes. The printer might cost between £200–£600 and the filament about £15–£25 per kilogram.
