EcoFlow DELTA 3 Max vs Max Plus Detailed Comparison
UK households face three unique pain points: unpredictable power outages, soaring electricity bills and noisy gas generators. Homeowners look for reliable indoor backup power that can run their appliances comfortably without being too noisy. The EcoFlow DELTA 3 Max vs Max Plus are portable power stations that can help address these pain points. When choosing power storage solutions, many homeowners consider battery capacity as the main feature. However, these two power stations have similar capacities of 2,048Wh, so how do you choose the best solution for your needs?
This EcoFlow DELTA 3 Max vs Max Plus comparison guide looks at:
  • Side-by-side DELTA 3 Max vs DELTA Max Plus detailed feature comparison
  • The key features that are common between the EcoFlow DELTA 3 Max and DELTA 3 Max Plus
  • The key differences between the DELTA 3 Max and Max Plus
  • Which of these EcoFlow DELTA 3 Max series portable power station 2048wh suits your power needs
  • How solar charging compares between the DELTA 3 Max vs Max Plus
  • Battery expansion and long-term flexibility between the two batteries
  • EcoFlow DELTA 3 Max vs Max Plus weight, price and overall value
  • Which EcoFlow DELTA 3 Max model should you buy?
A buyer picking between EcoFlow DELTA 3 Max vs DELTA 3 Max Plus
DELTA 3 Max vs DELTA Max Plus Feature Comparison
Below is a detailed EcoFlow DELTA 3 Max vs Max Plus spec sheet providing a side-by-side comparison between these two models.
Specification
DELTA 3 Max
DELTA 3 Max Plus
Price (UK, at time of writing)
£1,199
£1,399
12-month 0% plan (Splitit)
£99.91/month
£116.58/month
Colour
Black and Gray
Silver
2,048Wh
2,048Wh
Battery chemistry
Net weight
Approx. 20.3kg
Approx. 22.1kg
494 × 239 × 305mm
494 × 242 × 305mm
AC outlets
4
4
Total output ports
9
10
Max AC output
2,400W
3,000W
Surge output
4,800W
6,000W
Max output with X-Boost
3,200W
3,900W
X-Fusion
No
Yes
Output Priority
No
Yes
USB-A
1 × 18W max
1 × 18W max
USB-C
1 × 100W max; 2 × 30W max (30W total)
1 × 140W max; 2 × 45W max (45W total)
12V DC output
126W max; car power output 12.6V/10A
378W max; car power output 12.6V/10A; Anderson output 12.6V/30A
AC charging
2,300W (68 min); 0–80% in 47 min under optimal conditions
Solar input
500W
1,000W (0–80% in about 96 min, per EcoFlow)
Generator charging
2,400W max
2,400W max
Alternator charging
500W max (via XT60 port)
1,000W max (via 4+8 port)
Car charging
12V/24V, 8A
12V/24V, 8A
Extra battery ports
None
1 (expandable to 2)
Extra battery port type
None
4+8
Compatible extra batteries
None
DELTA 2 Max, DELTA 3 Max Plus, DELTA Pro 3, DELTA 3 Extra Battery
Max capacity with extra batteries
Not expandable
Up to 10kWh
UPS switchover
10ms
10ms + HID
Wi-Fi / Bluetooth / App
Yes / Yes / Yes
Yes / Yes / Yes
Noise
≤25dB at 600W
≤25dB at 600W
3+2 years (the extra 2 years need EcoFlow App registration)
Operating altitude
≤3,000m
≤3,000m
Discharge temperature
-10 to 45°C
-10 to 45°C
Charge temperature
0 to 45°C
0 to 45°C
Storage temperature
-10 to 45°C
-10 to 45°C
What the DELTA 3 Max and DELTA 3 Max Plus Have in Common
Same 2,048Wh Capacity and LFP Battery Chemistry
LFP (lithium iron phosphate, or LiFePO4) is the cell chemistry in both units, valued for thermal stability and long cycle life. The EcoFlow DELTA 3 Max series portable power station 2048Wh gives you the same 2kWh either way.
Four AC Outlets and Smart App Control
Both models have four AC outlets, plus Wi-Fi and Bluetooth for the EcoFlow app. This app displays the battery status and schedules charging, and this is helpful if you are on a time-of-use tariff with cheaper overnight rates.
Fast AC Charging and UPS Backup Protection
Both units have fast AC charging that uses 2,300W from the mains and can take the unit from 0% to 80% in 47 minutes. They also have an uninterruptible power supply (UPS) mode that ensures you switch to battery power in 10ms when the grid drops.
Key Differences Between the DELTA 3 Max and Max Plus
2,400W vs 3,000W AC Output and Surge Power
AC output is the total power a unit delivers to your appliances at once, and it’s where the EcoFlow DELTA 3 Max vs Max Plus gap first appears. The DELTA 3 Max delivers 2,400W (4,800W surge); the Max Plus delivers 3,000W (6,000W surge). X-Boost stretches supported loads to 3,200W and 3,900W.
500W vs 1,000W Solar Input
Solar input is the most panel power a unit accepts. The DELTA 3 Max takes 500W. The Max Plus takes 1,000W and reaches 0–80% in about 96 minutes in ideal conditions. That ceiling only helps if you own enough panels to reach it.
USB-C Charging Power and Total Output Ports
USB-C determines how fast your laptops and smartphones charge. The DELTA 3 MAX has one 100W port and two 30W ports. The EcoFlow DELTA MAX PLUS has one 140W USB-C port and two 45W ports. The total number of output ports is 9 vs. 10.
12V DC Output and Anderson Port Support
12V DC output powers car-style kits, such as fridges, pumps and lighting. The DELTA 3 Max provides 126W through one car power port. The Max Plus lifts that to 378W and adds an Anderson output rated 12.6V/30A.
Expandable Battery Capacity: Fixed vs Up to 10kWh
Expandable capacity means that you can add additional power backup batteries to your existing setup. The DELTA 3 MAX cannot be expanded and remains fixed at 2,048Wh. The DELTA Max Plus has an extra battery port and you can expand it up to 10kWh with compatible batteries.
X-Fusion and Output Priority Features
X-Fusion and Output Priority appear on the Max Plus spec list but not on the DELTA 3 Max. Output Priority lets you pick, via the app, which circuits stay powered, while Smart Power Reserve sheds non-essential loads at a battery level you set. The product page doesn’t explain X-Fusion, so check the manual.
Which Model Suits Your UK Power Needs?
Keeping Essential Home Appliances Running During Power Cuts
Essential power-cut cover is a short list: fridge-freezer, router, lights and phone chargers. They often draw under 300W combined, so the EcoFlow DELTA 3 Max handles them comfortably. Your gas boiler needs electricity for its pump and controls, but most are hard-wired—ask an electrician first, because BS 7671 governs fixed wiring and back-feeding through a plug is dangerous. Report cuts on 105.
Note: Wiring standards are revised periodically. Check the IET or a registered electrician for the current BS 7671 edition.
Running High-Wattage Kitchen Appliances
A UK kettle usually draws 2,200–3,000W, since a 13A plug tops out near 3kW. The DELTA 3 Max covers most kettles at 2,400W, and X-Boost reaches 3,200W for supported heating loads — check the appliance label. The EcoFlow DELTA 3 Max Plus has 3,000W of rated headroom, and EcoFlow says it can run a microwave, kettle, fridge and blender together, based on internal testing.
Powering a Home Office and Sensitive Electronics
Choosing between the EcoFlow DELTA 3 Max vs Max Plus for a home office is slightly easier. Home offices have sensitive electronics that need pure sine wave power, similar to the waveform the mains deliver, and this is precisely what the Max Plus does. The essential electronics in a home office are usually laptops, monitors, and routers, and they draw a combined 100-200W, which is inside the capacity of the batteries. Both batteries also have a 10ms UPS switching which means that in case of a power cut, your desktop won’t shutdown.
Camping, Campervan Trips and Off-Grid Use
Off-grid use means any trip without mains hook-up, and EcoFlow DELTA 3 Max vs Max Plus mostly comes down to your 12V needs. An EcoFlow portable power station DELTA 3 Max Plus setup adds 378W of 12V output, the Anderson port and 1,000W alternator charging (500W on the DELTA 3 Max), though alternator chargers are sold separately.
Solar Charging in the UK: DELTA 3 Max vs Max Plus
Why Solar Input Capacity Matters During British Winters
Solar input capacity refers to the maximum power a power station can accept from solar panels for recharging. During winter, solar panels generate electricity at a fraction of their rated value. This is why capacity matters: If you have solar panels with higher capacity, they can capture more energy during brief bright spells in the winter and on overcast days, ensuring your batteries are sufficiently charged to power your home. Keep the station indoors in frost because it’s rated to charge between 0°C and 45°C.
Note: Check the Met Office for local weather data and the Energy Saving Trust for solar guidance.
How 500W and 1,000W Solar Input Affect Recharging Time
Recharging time is battery capacity divided by the power actually arriving. The DELTA 3 Max has a 500W solar charging capacity and it takes about four hours to fill its 2,048Wh capacity. The EcoFlow DELTA 3 Max Plus has a 1000W solar charging capacity, which means that you can get it from 0% to 80% in around 96 minutes.
Note: These figures only matter at optimum weather conditions. The charging times may increase due to winter weather conditions and overcast skies.
Choosing Compatible Portable Solar Panels
Compatible panels are the ones whose combined wattage and voltage sit inside the station’s solar input range. When selecting for the DELTA Max, match the total panel output to 500W and 1,000W for the DELTA 3 Max Plus. One 400W panel can charge both models, and if you select two (800W), then they make sense on the Max Plus.
Is Solar Charging Worth It for Occasional Backup Use?
Solar charging is worth it if you cycle the battery often, and optional if the station mostly waits for a power cut. Mains charging takes about an hour at 2,300W and uses roughly two units of electricity.
Battery Expansion and Long-Term Flexibility
Why the DELTA 3 Max Has Limited Expansion Options
Limited expansion means the capacity you buy is the capacity you keep. The EcoFlow DELTA 3 Max has no extra battery port, so it stays at 2,048Wh. If your needs grow, you replace the unit rather than add to it.
Expanding the DELTA 3 Max Plus to 10kWh
Expanding the Max Plus means connecting extra batteries through its 4+8 port, expandable to two. Starting from the EcoFlow DELTA 3 Max Plus 2048Wh base, EcoFlow lists two DELTA 3 Max Plus extra batteries for 6kWh and two DELTA Pro 3 extra batteries for 10kWh, via an expansion adapter.
Note: Accessory availability changes. Confirm on the product page before planning a build around it.
Which Model Offers Better Flexibility for Growing Household Energy Needs?
In the EcoFlow DELTA 3 Max vs Max Plus contest, the Max Plus offers more flexibility, plainly. If you might add solar, a home office or heavier appliances later, expansion saves you buying twice. For growth, the better choice is the EcoFlow DELTA 3 Max Plus.
EcoFlow DELTA 3 Max vs DELTA 3 Max Plus Weight, Price and Overall Value
20.3kg vs 22.1kg: Does Portability Make a Difference?
Portability in the EcoFlow DELTA 3 Max vs Max Plus matchup comes down to 1.8kg, which barely changes how you move either unit. Both are firm single-person lifts.
Comparing the Price and Value of Both Models
The EcoFlow DELTA 3 Max vs Max Plus price difference is significant. At the time of writing, the price of the EcoFlow DELTA 3 Max is £1,199. The EcoFlow DELTA 3 Max Plus UK price is £1,399. There is a £200 difference between these two units. Both options have a 12-month repayment plan via Splitit with 0% interest and its £99.91 per month for the DELTA 3 Max and £116.58 per month for the DELTA 3 Max Plus. If you want to hunt for the best EcoFlow DELTA 3 Max Plus best price, start with this.
Note: Prices, offers and shipping dates change. Always check the product pages for current details.
Which Features Justify Paying More for the Max Plus?
For £200 you get 600W more AC output, double the solar input, triple the 12V output, Output Priority and a route to 10kWh. If you cook with a high-wattage kit, charge from solar or an alternator, or plan to expand, the answer is the EcoFlow DELTA 3 Max Plus. If you just want a fridge and Wi-Fi to survive a cut, you’d pay for headroom you won’t use.
Which EcoFlow DELTA 3 Max Model Should You Buy?
Settling EcoFlow DELTA 3 Max vs Max Plus comes down to your heaviest load and your plans for growth.
Choose the DELTA 3 Max for Lighter and Simpler Backup Needs
If your main worry is keeping a fridge, router and lights alive overnight, a mid-sized battery with no add-ons is enough. For example, the EcoFlow DELTA 3 Max is a 2,048Wh station aimed at that job, and it sits at the lower price point. It suits a household wanting dependable standby power and the odd weekend away.
EcoFlow DELTA 3 Max (2048Wh)
Charges to 80% in just 47 minutes Powers heavy-duty appliances up to 3200W with ease Stays whisper-quiet, so it won’t disturb your sleep Switches to backup within 10 milliseconds during power cuts Weighs just 20.3 kg, so it’s easy to carry Big 2048Wh battery keeps your essentials powered through outages Recharge from solar panels or your vehicle on the move Automatically charges ahead of storms, so you’re ready for outages Monitor and control your power from your phone Comes with up to five years’ warranty when registered
Choose the DELTA 3 Max Plus for Higher Power and Greater Flexibility
Heavier loads, solar panels and a growing setup call for spare capacity. For example, the EcoFlow portable power station DELTA 3 Max Plus starts from the same 2,048Wh and leaves room to add output, panels and batteries later. That fits your household if you work from home or cook during outages.
EcoFlow DELTA 3 Max Plus (2048Wh)
Massive 2,048Wh capacity powers your off-grid campsite for days Powerful 3000W output effortlessly runs heavy-duty camping appliances Ultra-fast 47-minute charging gets you back off-grid quickly Rapid 1000W solar input provides sustainable power anywhere outdoors Expandable 10kWh capacity extends your remote adventures for weeks Long-lasting 10-year lifespan delivers reliable energy for countless trips Rugged drop-resistant structure withstands rough, bumpy off-road transport Whisper-quiet operation keeps your outdoor campsite completely peaceful
The EcoFlow DELTA 3 Max vs Max Plus comparison comes down to headroom. Both give you 2,048Wh of LFP storage, four AC outlets, app control, fast AC charging and UPS switching. The EcoFlow DELTA 3 Max Plus adds 3,000W output, 1,000W solar input, stronger 12V and USB-C, Output Priority and expansion to 10kWh, for about £200 more at the time of writing.
Work out your biggest appliance load and how you’ll recharge, then match the model to that, not the longest spec list. When you’re ready, browse the EcoFlow DELTA 3 Max series portable power station 2048Wh range in the EcoFlow UK shop and check current prices.
EcoFlow DELTA 3 Max vs Max Plus Frequently Asked Questions
What Is the Main Difference Between the DELTA 3 Max and Max Plus?
Power and expandability. The two models people search for as EcoFlow DELTA Max 3 and EcoFlow DELTA Max 3 Plus both hold 2,048Wh, but the Max Plus delivers 3,000W AC, accepts 1,000W of solar and expands to 10kWh. The DELTA 3 Max gives 2,400W, 500W solar and no expansion.
Is the DELTA 3 Max Plus Worth the Extra Money?
Yes, if you need above 2,400W, solar above 500W or expansion. Otherwise, probably not. The gap is £200 at the time of writing. Check the EcoFlow DELTA 3 Max Plus UK page for current offers — that’s where any EcoFlow DELTA 3 Max Plus best price deal will appear.
Can the DELTA 3 Max Run a Kettle or Microwave?
Yes. It has a 2,400W AC output that’s sufficient to run most kettles and microwaves. With the X-boost, this figure can reach 3,200W for supported heating loads. If you run both appliances at the same time, their power draw exceeds the battery’s capacity, and therefore can’t run them.
Can You Expand the DELTA 3 Max Battery Capacity?
No. The DELTA 3 Max has no extra battery port, so it stays at 2,048Wh. If you want expansion, the Max Plus accepts extra batteries up to 10kWh.
How Long Can the DELTA 3 Max Plus Power a House?
It depends on the load. The EcoFlow DELTA 3 Max Plus 2048Wh unit alone is rated by EcoFlow for a 4–8 hour outage of essentials, and a lean fridge, router and lights load can stretch to about a day.
Which Model Charges Faster With Solar Panels?
The Max Plus, thanks to its 1,000W solar ceiling against 500W. But panels set the real limit. With only 400W of panels connected, the two charge at similar speeds.
