- EcoFlow DELTA 3 vs DELTA 3 Plus for Your UK Home Backup
- EcoFlow DELTA 3 vs DELTA 3 Plus Detailed Comparison
- What the EcoFlow DELTA 3 and DELTA 3 Plus Have in Common
- Key Differences Between the DELTA 3 and DELTA 3 Plus
- Which Model Suits Your UK Use Case?
- Choosing Solar Panels for the EcoFlow DELTA 3 Plus in UK Weather
- Budget, Charging Needs and Long-Term Flexibility Compared
- How to Beat Power Cuts and Slow Solar Charging in the UK
- Conclusion
- EcoFlow DELTA 3 vs DELTA 3 Plus Frequently Asked Questions
Having a reliable portable power station is an effective way to buffer your home against grid power cuts and to lower your monthly electric bill. The EcoFlow DELTA 3 vs DELTA 3 Plus are among the most common portable power backups on the market. Both units have 1,024Wh of expandable capacity and fast wall charging, making either option a strong contender for emergencies and off-grid trips.
This EcoFlow DELTA 3 vs DELTA 3 Plus guide looks at:
A detailed side-by-side comparison between EcoFlow DELTA 3 vs DELTA 3 Plus
What the EcoFlow DELTA 3 and DELTA 3 Plus have in common
Key differences between the DELTA 3 and DELTA 3 Plus
Which model is suitable for your needs
How to choose solar panels for the EcoFlow DELTA 3 Plus in UK weather
EcoFlow DELTA 3 vs DELTA 3 Plus budget, charging needs and long-term flexibility
Which should you buy based on your situation?
How to beat power cuts and slow solar charging in the UK
Specification | EcoFlow DELTA 3 | EcoFlow DELTA 3 Plus |
Price | £649 | £699 |
Colour | Silver & Grey | Silver |
Capacity | 1,024Wh | 1,024Wh |
Battery chemistry | LFP (LiFePO4) | LFP (LiFePO4) |
Net weight | Up to 12.5kg | Up to 12.5kg |
Dimensions | 398 × 200 × 284mm | 398 × 200 × 284mm |
Total output ports | 11 | 11 |
AC outlets | 4 × 1,800W (3,600W surge) | 4 × 1,800W (3,600W surge) |
X-Boost (max device power) | 2,400W | 2,400W |
USB-A (fast charging) | 2 × 18W max | 2 × 36W max |
USB-C | 2 × 100W max | 2 × 140W max |
Car power port | 1 × 12.6V, 10A, 126W max | 1 × 12.6V, 10A, 126W max |
DC5521 ports | 2 × 12.6V, 3A max | 2 × 12.6V, 3A max |
AC charging | 1,500W (about 56 min) | 1,500W (about 56 min) |
Solar input | 1 × 500W max, 11–60V DC | 2 × 500W max (1,000W total), 11–60V DC each |
Solar charge time (ideal conditions) | About 130 min | About 70 min |
Car charging | 800W (about 1.3 hrs) | 800W (about 1.3 hrs) |
Smart Generator charging | 1,500W (about 56 min) | 1,500W (about 56 min) |
AC + solar charging | 1,500W (about 56 min) | 1,500W (about 56 min) |
NAS / HID support | No | Yes (needs EcoFlow app and NUT server software) |
UPS switchover | Under 10ms | Under 10ms |
Cycle life | 4,000 cycles to 80% capacity | 4,000 cycles to 80% capacity |
Battery pack rating | IP65 | IP65 |
Noise level | Under 30dB at 600W; under 40dB at 1,200W | Under 30dB at 600W; under 40dB at 1,200W |
Expandable capacity | Up to 5kWh | Up to 5kWh |
Compatible extra batteries | DELTA 3, DELTA Pro 3, DELTA 2, DELTA 2 Max | DELTA 3, DELTA Pro 3, DELTA 2, DELTA 2 Max |
App features | TOU / storm warning | TOU / storm warning |
Warranty | 5 years | 5 years |
In the EcoFlow DELTA 3 vs DELTA 3 Plus matchup, most of what matters day to day is identical. The EcoFlow DELTA 3 portable power station and the EcoFlow DELTA 3 Plus portable power station share the same core hardware.
Spec | Both models |
Capacity | 1,024Wh (LFP) |
AC output | 4 × 1,800W (3,600W surge) |
X-Boost | Devices up to 2,400W |
AC charging | Up to 1,500W (about 56 minutes) |
Weight | Up to 12.5kg |
Same 1,024Wh Capacity and 1,800W AC Output
Both units are 1,024Wh lithium iron phosphate (LFP) power stations. The EcoFlow DELTA 3 portable power station 1024Wh and its Plus sibling each carry four AC outlets rated at 1,800W (3,600W surge). X-Boost supports devices up to 2,400W. You get 11 output ports in total, so plugging in a lamp, router and phone charger at once isn’t a problem.
Matching Charging Speed and Battery Expansion up to 5kWh
Both charge from AC at up to 1,500W, reaching full in about 56 minutes. That 1,500W figure is why some buyers call it the EcoFlow DELTA 3 1500. A short top-up before a forecast storm is realistic.
Capacity can grow, too. Both accept the EcoFlow DELTA 3 extra battery (1kWh), plus other EcoFlow DELTA 3 external battery options such as the DELTA Pro 3, DELTA 2 and DELTA 2 Max packs. Expansion tops out at 5kWh.
UPS Protection, Weight and Quiet Running
A UPS (uninterruptible power supply) switchover of under 10ms means plugged-in devices, such as a router, carry on when the mains drops. Both models have it. Don’t rely on it for life-critical medical equipment, though.
The rest matches as well: 4,000 cycles to 80% capacity, a 5-year warranty and an IP65-rated battery pack. Both weigh up to 12.5kg, so the DELTA 3 Plus weight is no reason to pick either. And both run below 30dB under 600W.
Solar Input of 500W Versus 1,000W
Solar input refers to the maximum power your DELTA storage unit can accept from panels through its maximum power point tracking (MPPT) controller. The DELTA 3 has a 500W input and can charge fully in about 130 minutes. The DELTA 3 Plus solar input specs are two 500W inputs and a total of 1,000W total solar charging capacity and can fully charge in 70 minutes in ideal conditions.
USB-C and USB-A Charging Power
EcoFlow DELTA 3 has 2x100W USB-C ports while the EcoFlow DELTA 3 Plus has 2x140W. For the USB-A ports, the DELTA 3 has 2x18W while the DELTA 3 Plus has 2x36W. These ports matter because they determine how fast you can charge your laptops, tablets, smartphones and cameras.
NAS and HID Support for Connected Devices
NAS/HID support lets a compatible NAS or home server learn about an outage and shut down safely. Only the DELTA 3 Plus has it. The setup needs the EcoFlow app and NUT (Network UPS Tools) server software on your NAS.
It’s niche but valuable for home-office and home-lab users—and irrelevant to most campers.
Home Backup During Winter Power Cuts
Your home backup solution should keep your household essentials, such as the fridge, router, lamps and phone chargers alive when the grid drops. For this job, the EcoFlow DELTA 3 vs DELTA 3 Plus choice barely matters because either handles it equally well.
For longer outages, extra batteries matter more than the model. Adding an EcoFlow DELTA 3 extra battery takes you to 2kWh. Dial 105 to reach your network operator, and plug appliances straight into the station. Wiring it into your consumer unit is a job for a qualified electrician under BS 7671 (the IET Wiring Regulations).
Off-Grid Camping and Campervan Trips
Both EcoFlow DELTA 3 vs DELTA 3 Plus have a similar weight and quiet running profile. They also support 800W car charging (about 1.3 hours), which is suitable for UK road trips. The EcoFlow DELTA 3 is enough for weekend trips but the DELTA 3 Plus is suitable if you rely on panels on a longer stay.
With the same DELTA 3 Plus weight of up to 12.5kg, either is easy to carry. Keep it sheltered on damp pitches.
Home Office Equipment
Laptops, monitors and routers run on either model. The EcoFlow DELTA 3 Plus portable power station suits multi-laptop desks thanks to its 140W USB-C ports. NAS or home-server users get HID support on top.
Why Real-World Solar Input Falls Short in the UK
The UK has harsh weather conditions—cloudy skies and short winter days—which makes real-world solar input to sit below the rated 500W and 1,000W maximums. During a grey day, a single EcoFlow DELTA 3 solar panel won’t generate the expected 500W capacity. The provided figures about charge time—about 130 minutes for the DELTA 3 and 70 minutes for the Plus—are best-case scenarios under optimum weather conditions.
How Panel Configuration Differs Between the Two Models
The DELTA 3 has one solar input (11–60V, 500W max), so it needs one panel string. The DELTA 3 Plus has two inputs (11–60V each, 1,000W total) and takes two strings. In the EcoFlow DELTA 3 vs DELTA 3 Plus comparison, this is where the gap widens.
Those DELTA 3 Plus solar input specs mean better use of brief sunny windows. When you shop for solar panels for EcoFlow DELTA 3 Plus, check that each string stays within the voltage range.
Which Panels to Pair with Each Model, and When Solar Is Optional
The EcoFlow DELTA 3 Plus uses 2 × 100W flexible panels and a 220W portable panel. Choosing solar panels for EcoFlow DELTA 3 Plus is simpler than it sounds: one panel per input is the logic, and stock changes, so check the page.
If you plan on not using solar, then the DELTA 3 single input is plenty. The Plus is better if you want to get the most out of a sunny spell.
Note: To get up-to-date information about solar yield, use the Met Office for forecasts and the Energy Saving Trust for current UK solar guidance. |
Price and Value for Money
At the time of writing, the EcoFlow DELTA 3 costs £649. The EcoFlow DELTA 3 Plus UK price is £699, a £50 gap. Price is where the EcoFlow DELTA 3 vs DELTA 3 Plus difference is smallest, so see that £50 as buying extra solar input, faster USB-C and NAS/HID support. Then ask whether you’ll use them. If not, keep the money.
Note: Prices and availability can change. Always check the EcoFlow UK shop for current figures. If you plan to charge off-peak to trim bills, savings depend on your tariff—Ofgem publishes the current energy price cap. |
Device Charging Needs and Room to Grow
If you charge several laptops or want to add solar later, the Plus leaves more headroom. Capacity isn’t a deciding factor, though. Both models can add an EcoFlow DELTA 3 external battery later, up to 5kWh.
So buying the cheaper model now doesn’t lock you out on the battery side—only on solar input and USB power.
Which Should You Buy Based on Your Situation?
Choosing between the EcoFlow DELTA 3 vs DELTA 3 Plus comes down to what your household actually does with it:
If you want to address occasional power cuts and everyday backup, then pick the EcoFlow DELTA 3
If you use regular solar charging or faster recharging between sunny spells then the EcoFloW DELTA 3 Plus portable power station is the best option
For a home office with multiple laptops or a NAS, then the DELTA 3 Plus is the better option
If you are on a tight budget, mainly campervan or camping use, the DELTA 3 is the better option
Power cuts and slow solar are the two pain points above, so here’s how each model answers them.
Keeping the Essentials Running When the Lights Go Out
When the lights go out on a dark January evening, the real worry is keeping the fridge, broadband router and lamps running. The EcoFlow DELTA 3 portable power station 1024Wh can handle this job well. Its 1,800W AC output covers everyday essentials, and a switchover of under 10ms keeps devices on. It recharges from a wall socket in as little as 56 minutes, so it’s ready before the next outage.
Recharging Fast When UK Sunshine Is Limited
If your main pain point is waiting hours for grey skies to refill a battery, or you have several electronics fighting over ports, then the EcoFlow DELTA 3 Plus is a perfect solution. What makes it stand out in the EcoFlow DELTA 3 vs DELTA 3 Plus comparison is its two 500W solar inputs that recharge it in 70 minutes under ideal conditions. The 140W USB-C ports allow fast-charging for electronics, such as laptops. It also has NAS and HID capabilities that protect your home office setup.
The EcoFlow DELTA 3 vs DELTA 3 Plus comparison is a close one because they share a 1,024Wh LFP battery, 1,800W AC output, UPS switchover, quiet running and expansion to 5kWh. They differ mainly in solar input (500W versus 1,000W), USB-C power (100W versus 140W) and NAS/HID support. UK weather means you’ll rarely see maximum solar figures, so judge solar by your own habits.
In short, the DELTA 3 suits dependable everyday backup. The DELTA 3 Plus suits faster solar recharging, higher-powered USB-C charging and more advanced connected-device support.
How Long Does the EcoFlow DELTA 3 Last on One Charge?
Runtime is capacity divided by device watts minus conversion losses of roughly 10–15%. Connecting a router and a lamp with a total draw of 100W means that the EcoFlow DELTA 3 can run for 8-9 hours. If you connect a 1,000W appliance, it can last for about 50 minutes. These are just estimates and real runtime may vary based on the load and temperature.
Can the EcoFlow DELTA 3 Run a Kettle or Other High-Wattage Appliances?
Yes, within limits. Even the EcoFlow DELTA 3 1500, named for its 1,500W AC charging rather than its output, delivers 1,800W as standard. X-Boost handles resistive loads up to 2,400W. Many UK kettles are rated at 3kW, so check the label on yours. Runtime will be short at high draw.
Is the EcoFlow DELTA 3 Plus Waterproof?
The battery pack is IP65-rated, meaning it resists dust and water splashes (IEC 60529). Don’t treat the unit as submersible, and keep it sheltered when camping.
How Long Will the EcoFlow DELTA 3 Plus Last?
It’s rated for 4,000 cycles to 80% capacity, which the product page says equals up to 10 years of use. A 5-year warranty also applies. Real lifespan depends on how often you cycle it and where you store it.
