EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus UK Buying Guide
EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus are two popular portable power stations for UK households. Many homeowners buy these two systems to tackle rising bills, an unreliable grid power supply and harsh weather conditions that make solar alone insufficient. Then comes the challenge of choosing between the two. Which one should you purchase?
This guide looks at:
  • A detailed side-by-side comparison between EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus
  • Why UK households are looking at bigger portable power stations
  • How much power does a UK home actually need?
  • Making better use of solar and off-peak power in the UK
  • Expansion, installation space and portability comparison between EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus
  • Budget and long-term value of the two portable power stations for UK Buyers
  • A scenario-based guide for which power backup to purchase
A couple choosing between EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus
EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus Detailed Feature Comparison
The EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus comparison is a choice between maximum capacity and sensible, accessible backup. Here are the DELTA 3 Ultra Plus specs next to the EcoFlow DELTA Pro 3 portable power station.
Category
Specification
EcoFlow DELTA Pro 3
DELTA 3 Ultra Plus
Capacity and Battery
4,096Wh
3,072Wh
Chemistry
LFP (LiFePO4), automotive-grade cells
Automotive-grade full-tab LFP cells
Lifespan
4,000 cycles to 80% capacity (lab conditions)
About 10 years (EcoFlow’s internal estimate)
Safety and certification
BMS monitoring 40 safety indicators; UL-certified 5VA fireproof shell; cell-to-chassis build
Certified to UL 2743, verified by SGS; cell-to-chassis build; Class B EMC
Power Output
Continuous AC output
4,000W
3,600W
Surge output
8,000W
7,200W
X-Boost
Up to 6,000W for compatible devices
Up to 4,600W
Switchover time
10ms
Under 10ms
Ports
AC outlets
5 outlets
5 outlets
USB-C
2 × 100W
1 × 140W and 2 x 45W
USB-A
2 × (18W max each)
1 x 18W
DC outputs
12V DC (12.6V/30A, 378W total), DC5521, Anderson (30A max)
Anderson and car port (378W and 126W, sharing power)
Charging
Solar input
Up to 2,600W across 2 ports (1,600W high-voltage, 1,000W low-voltage)
Up to 1,600W
AC charging input
2,900W max
1,800W
Fastest charge
0–80% in about 1 hour (multi-input, up to 7,000W)
0–80% in 48 minutes (optimal conditions)
Charging methods
6
6
Charging accessories
AC charging cable included in the box
Smart Generator sold separately
Expansion
Scalable capacity
4kWh to 12kWh
3kWh to 11kWh
Extra batteries
Up to 2 Smart Extra Batteries (4,096Wh and 33kg each)
Compatible with two DELTA 3 Max Plus or two DELTA Pro 3 Smart Extra Batteries through an expansion adapter
Noise
Operating noise
About 30dB at 2,000W
About 25dB at 600W (measured at 1m)
Smart Features
App control
Yes (Wi-Fi, Bluetooth)
Yes
Scheduling and priority
Not listed
Smart Output Priority, Time-of-Use mode, Self-Powered mode
Size and Build
693 × 341 × 410mm
613.1 × 327.71 × 394.95 mm
Weight
51.5kg
33.7
Weather protection
Battery pack IP65, main unit IP20
Rated for 95% humidity and 5% salt spray; 0.2m drop-resistant
Home Connection
Whole-home options
Manual Transfer Switch (electrician needed)
Manual Transfer Switch or Inlet Box (both sold separately)
Compatibility
Notable notes
Not compatible with the original DELTA Pro main unit; the original DELTA Pro Smart Extra Battery works
Works with EcoFlow Smart Generators for longer runtime
Why UK Households Are Looking at Bigger Portable Power Stations
A large portable power station is a battery and inverter that stores several kilowatt-hours and runs mains appliances when the grid fails. A 3–4kWh unit is a different category from a small power bank. A power bank tops up a phone. This keeps a fridge, router and lights alive for hours.
Short power cuts and storm outages still disrupt your heating controls, food storage and broadband. Working from home makes even a brief outage costly. And if you’re on Economy 7 or a smart time-of-use tariff, storing cheaper electricity for later starts to make sense.
Note: Tariffs and the energy price cap change regularly. Check Ofgem official website and your supplier for current rates.
EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus Specs Breakdown
Battery Capacity and the EcoFlow DELTA Pro 3 4096 Wh Advantage
Battery capacity is the energy a unit stores, measured in watt-hours (Wh). The EcoFlow DELTA Pro 3 4096 Wh battery holds about a third more than the Ultra Plus’s 3,072Wh. For the same appliances, that is roughly a third more runtime.
Take 280W of essentials: a fridge, router, lights, phone charger and electric blanket. In ideal conditions the Pro 3 covers about 14.5 hours and the Ultra Plus about 11. Inverter losses trim both. Both use LiFePO4 (LFP) chemistry.
AC Output and Surge Power
An AC output is the power the batteries can supply at once. Surge covers the brief spike when a motor starts. The EcoFlow DELTA Pro 3 provides a continuous 4,000W and 8,000W surge, and has the X-boost capability of up to 6,000W for compatible devices. The EcoFlow DELTA 3 Ultra Plus, on the other hand, provides 3,600W and 7,200W surge.
So, if you were to run a 3,000W kettle, the Pro 3 leaves about 1,000W spare. The Ultra Plus leaves about 600W. So yes, both run several high-draw items, but the Pro 3 does it with more room.
Output Ports and Noise
The Pro 3 has five AC outlets, two USB-C ports at 100W each, two USB-A ports and 12V DC. It runs at about 30dB at 2,000W.
The DELTA 3 Ultra Plus specs include a 140W USB-C, Anderson and car ports. Its Smart Output Priority ensures your essential appliances run longer. It runs at about 25dB under lighter loads, around 600W
How Much Power Does a UK Home Actually Need?
Your power need is the combined wattage of what you run, multiplied by the hours you need it. Two numbers matter: peak wattage and battery capacity.
Running High-Demand Appliances
Peak wattage is the most power an appliance pulls at once, and it must sit under the unit’s AC output. A kettle typically draws around 3,000W, a microwave about 1,300W and a washing machine up to 2,000W while heating. Check your appliance labels.
The capacity determines how long your appliances keep running. For example, a washing machine and microwave running together draw about 3,300W. If you are using the Pro 3, you have 700W to spare while the Ultra Plus leaves about 300W.
Getting Through Winter Power Cuts
Household essentials are fridge, freezer, router, lights, phone charging and an electric blanket. To get how long the units can last, take the power draw of each appliance, add them together, then divide by the output of the battery. For example, if a fridge draws 200W, a router 10W, and light bulbs 10W, then the total draw is 220W. If you divide the capacity of the Ultra Plus battery (3,072 Wh) with the total draw (220W), you get about 14 hours from this battery. If we do the same for the EcoFlow DELTA Pro 3, you get 18 hours.
The Ultra Plus has a Smart Output Priority which lets you rank devices. For example, you can decide the fridge and router to keep going as the battery drops. Before a forecast storm, top up the battery with the EcoFlow DELTA Pro 3 charging cable or the Ultra Plus mains lead.
Supporting a Home Office
The most appliances used in a home office are a laptop, monitor, router and NAS. Their combined draw is 130W. Choosing between EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus for a home office by considering capacity, both batteries can power all the devices and give you a full working day. However, the EcoFlow DELTA Pro 3 adds a 10ms switchover which is fast enough to keep NAS and your equipment running when the grid drops. This is particularly impressive because it protects your unsaved work and spinning drives.
Making Better Use of Solar and Off-Peak Power in the UK
Solar and off-peak charging are two ways to fill a battery cheaply. Both depend on UK weather and your tariff, so keep expectations grounded.
EcoFlow DELTA Pro 3 Solar Panels and Charging Options
The Pro 3 accepts up to 2,600W of solar input across two ports: 1,600W high-voltage and 1,000W low-voltage. It offers six charging methods and reaches 0–80% in about an hour under EcoFlow’s best-case multi-input conditions.
The EcoFlow DELTA Pro 3 charging cable is a standard AC lead supplied in the box. Be realistic about British sunlight. Winter output is low. The best use of EcoFlow DELTA Pro 3 solar panels is storing daytime generation for the evening.
DELTA 3 Ultra Plus Charging and Smart Scheduling
The Ultra Plus also offers six charging methods. Its 48-minute 0–80% figure is an optimal-conditions result using 3,960W of solar plus an EcoFlow Smart Generator, which is sold separately.
Time-of-use mode lets you charge at cheaper hours and discharge at peak times, using the app. Check your supplier for current off-peak windows.
Expansion, Installation Space and Portability
EcoFlow DELTA Pro 3 Extra Battery Options
The EcoFlow DELTA Pro 3 extra battery is a Smart Extra Battery of 4,096Wh weighing 33kg. Add up to two and the system scales from 4kWh to 12kWh. The DELTA 3 Ultra Plus scales from 3kWh to 11kWh.
Space, Weight and Home Connection
The EcoFlow DELTA Pro 3 weighs 51.5Kg and its size is 693 × 341 × 410mm. If you want to install it, plan a dedicated spot in your garage or utility room. The Ultra Plus is positioned as the more compact option, which helps if space is tight.
Whole-home connection through a manual transfer switch or inlet box needs a qualified electrician in the UK. The work must meet BS 7671 (the IET Wiring Regulations) and Part P of the Building Regulations in England. Choose someone registered with NICEIC or NAPIT.
Note: Rules differ across England, Scotland, Wales and Northern Ireland and can change. Check the UK government official portal and the IET for current requirements.
Budget and Long-Term Value for UK Buyers
The EcoFlow DELTA Pro 3 portable power station costs £2,799. If you purchase a bundle with Delta Pro 3 and one smart extra battery the total cost is £4,198 and £6,117 with 2 smart extra batteries.
The EcoFlow DELTA Pro 3 4096 Wh unit works at about £683 per kWh. Purchasing as a bundle drops the price to about £512. Before purchasing, answer this question: are you paying for capacity you will use or the one you won’t?
Note: EcoFlow DELTA Pro 3 UK prices, bundles and finance offers can change. Always check the EcoFlow UK shop for current offers.
Which One Should You Buy? A Scenario-Based Guide
The EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus decision comes down to your load and how long you need cover.
  • If you have a large family running heavy appliances and you have a solar system, the best option is the EcoFlow DELTA Pro 3
  • If you have an average home running essentials and home-office backup with tighter space and budget, then the best option is the DELTA 3 Ultra Plus
If you want to determine the best option in terms of capacity, add up your essential wattage and hours you want to cover then add a 20% buffer. For example, if your essential appliance power draw is 250W running for 10 hours, you need 2.5kWh, or 3kWh with the buffer.
Solving the Biggest UK Home Backup Headaches
Keeping a Busy Household Running Through Long Outages
If your worry is a big household, heavy appliances and outages that drag on, the EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus question tends to favour capacity, which means the EcoFlow DELTA Pro 3. This battery pairs a 4,096Wh battery with 4,000W output, so a kettle and washing machine need not queue. Two Smart Extra Batteries take it to 12kWh when cuts last days, and solar can refill it by day. It costs more up front, but you buy fewer compromises.
EcoFlow DELTA Pro 3
4000W output powers heavy camp appliances effortlessly. Expandable 4kWh capacity prevents running out of power. 2600W solar input rapidly recharges without grid power. Quiet 30dB operation preserves peaceful campsite environments. LFP battery offers 4000 cycles for decade longevity. Integrated wheels and handle ease heavy equipment transport. Fast 10ms switchover prevents sudden electronics shutdown. Zero-emission solar power eliminates expensive fossil fuels. X-Boost safely handles surges up to 6000W.
Getting Dependable Backup Without Overbuilding
If you are looking for a solid backup without rebuilding, the EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus choice lands on a smaller battery—the EcoFlow DELTA 3 Ultra Plus. This battery has 3,072Wh and 3,600W which is sufficient to power your household essentials, such as the fridge, router, lighting and a home office. You can grow it to 11kWh later and schedule charging for off-peak hours.
Runs power-hungry appliances like microwaves and hairdryers with 3600W Recharges to 80% in as little as 48 minutes Keeps your fridge running for up to 24 hours Expands from 3kWh to 11kWh as your needs grow Prioritises your essential devices, so they stay powered for longer Charge by solar, mains, generator or car, whichever suits you Lasts around 10 years thanks to long-life, car-grade batteries Whisper-quiet at 25dB, so it will not disturb your home Control and monitor everything from your phone using the app Handles cold, heat, humidity and rough journeys without losing power
Before you choose between the EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus, consider your household’s wattage demand, available installation space and outage resilience goals. If you are running heavy appliances and solar, then the EcoFlow DELTA Pro 3 portable power station is the better option. It offers 4,096Wh base capacity, 4,000W output, rapid 10ms switchover and can scale to 12kWh. The EcoFlow DELTA 3 Ultra Plus is a compact and budget friendly option with a 3,072Wh capacity that’s sufficient to power everyday essentials, home offices, and smart off-peak tariff scheduling.
Before investing, calculate your essential winter wattage, factor in a 20% capacity buffer, and ensure any whole-home transfer switch installation complies with UK BS 7671 wiring regulations. Once you have figured out your energy requirements, check the current EcoFlow DELTA Pro 3 UK and Ultra Plus bundle pricing to get the best deal that offers long-term value for your home.
EcoFlow DELTA Pro 3 vs DELTA 3 Ultra Plus Frequently Asked Questions
Can the EcoFlow DELTA Pro 3 Be Used Outdoors?
Only with care. The battery pack is IP65-rated, but the main unit is IP20. Use it in a sheltered, well-ventilated space, away from rain and dust.
Is the EcoFlow DELTA Pro 3 Compatible with the Original DELTA Pro?
The main units are not compatible. The original DELTA Pro Smart Extra Battery works with the Pro 3, but the Pro 3 extra battery does not work with the original DELTA Pro.
Is the DELTA 3 Ultra Plus Quiet Enough to Use Indoors?
Yes, for typical loads. It runs at about 25dB at 600W, with stepless fan control that adjusts airflow smoothly.
How Long Will the DELTA 3 Ultra Plus Last?
EcoFlow estimates about 10 years of use from its automotive-grade full-tab LFP cells, certified to UL 2743 and verified by SGS. This is an internal estimate, and real-world results may vary.
Home Solutions
