How Much Does It Cost to Run a Hot Tub in the UK Now?
You love your hot tub in January. Steam off the water, frost on the fence, nobody asking anything of you. Then the bill lands. If you've ever wondered how much does it cost to run a hot tub once the nights draw in, you'll know the answers online don't agree. Ask a few calculators how much to run a hot tub, and you'll get outdated tariff averages that ignore how your household actually uses energy. The current Ofgem electricity price cap is 26.32p per kWh, and is predicted to rise further for the January to March 2027 quarter.
This guide looks at:
  • The current cost of running a hot tub in the UK
  • Why running costs of a hot tub climb during the winter season
  • The cheapest way to run a hot tub in the UK
  • If solar power can lower hot tub running costs
  • How to stop rising energy prices from eating into your hot tub budget using home energy storage
A person enjoying a warm bath in a hot tub
The Cost of Running a Hot Tub in the UK at 26.32p per kWh
How much does it cost to run a hot tub in the UK? About £36- £51 per month at today's cap for the most popular UK models. The type of tub you have accounts for most of the gap.
Note: The running cost has been calculated using the current Ofgem energy price cap of 26.32p per kWh. Electricity prices in the UK are reviewed quarterly, therefore, this figure may rise or fall depending on the price cap. Stay updated using the Ofgem official website for the current energy price caps.
How Much Does a Hot Tub Cost to Run Per Day and Per Month?
How much does a hot tub cost to run each day? Most popular UK tubs are 13-amp plug-and-play models, capped at roughly 2kW of heating (Palm Spas and Outdoor Living sell plenty), and the heater can't run at the same time as the jets. 32-amp hardwired models typically have 3kW heaters. They heat faster, but they draw more.
Popular hot tub type
Heater rating
Daily kWh
Daily cost
Monthly cost
Annual cost
13 amp plug-and-play, such as Palm Spas Value and Dual Lounger ranges
2kW
4.5
about £1.18
about £36
about £432
13 amp plug-and-play, such as Outdoor Living Reef and Harmony
2.1kW
4.7
about £1.24
about £37
about £452
32 amp hardwired, such as Palm Spas Happy+ and Value 7 seater
3kW
6.5
about £1.71
about £51
about £624
The table calculation assumes the heater runs for two hours a day on average and adds 0.5kWh a day for pumps and filtration. The current Ofgem price cap of 26.32p per kWh has also been used. However, keep in mind that real bills may vary due to insulation, cover condition, temperature setting, and soak frequency. So, there is no single figure that answers the question: how much to run a hot tub in the UK because of these factors.
So how much does running a hot tub cost across a year? Roughly £432 to £624 in electricity. Your standing charge stays the same either way, so the tub only adds unit costs.
Note: Unit rates change every quarter. Always check Ofgem before you budget.
How Expensive Is It to Run a Hot Tub in Winter Compared with Summer?
How expensive is it to run a hot tub in winter? Noticeably more, because heat loss grows as the gap between the water and the air widens. Met Office long-term averages put December's mean minimum temperature across southern England at roughly 2°C, so your 38°C water is fighting a 36-degree gap. Wind strips heat off the cover, and the heater simply runs far more often.
Here's the 2kW tub across the seasons:
Season (2kW tub)
Heater hours/day
Daily kWh
Daily cost
Monthly cost
Summer
about 1
2.5
about £0.66
about £20
Winter
about 4
8.5
about £2.24
about £67
Summer bills can be about a third of winter bills.
What Makes the Running Costs of a Hot Tub Climb in a British Winter
Heater Wattage, Pump Run Time and Filtration Cycles
Heater wattage is the biggest lever on the running costs of a hot tub. A 2kW heater costs about 53p for every hour it runs at 26.32p/kWh, and a 3kW heater about 79p. Because 13 amp tubs can't run the jets and heater together, a long soak means a longer reheat afterwards. Circulation pumps and filtration then add a steady base load, whether anyone's in the water or not.
Weak Insulation and a Worn Cover
A poorly fitted or waterlogged cover is the biggest avoidable source of heat loss. Once the foam core absorbs water it stops insulating, and a heavy, sagging lid is usually the giveaway. Foam quality also varies widely between budget and premium tubs, so two tubs with the same heater can post very different bills. So how much is it to run a hot tub with a worn cover? More than the table suggests, because the heater keeps replacing heat that escapes through the lid.
Temperature Settings and Frequent Reheating
Each degree above 36-38°C adds to the cost, because the heater works harder against a wider gap. Also, heating from cold temperatures costs far more than holding a steady temperature. Heating 1,200 litres of water from 10°C to 38°C consumes about 39 kWh, which translates to about £10 based on the current Ofgem price cap; this is before you account for any heat loss. If you use your hot tub occasionally, you will feel this because every cold start pushes up the cost to run a hot tub.
What the January 2027 Price Cap Rise Could Mean for Your Hot Tub Bill
Cornwall Insight's latest forecast has the January to March 2027 cap rising about 26%, which puts the electricity unit rate at roughly 33p/kWh. So how much does it cost to run a hot tub after that? Recalculating for the typical 2kW plug-and-play tub (4.5 kWh a day):
  • Monthly cost rises from about £36 to about £45
  • Annual cost rises from about £432 to about £545, roughly £112 more for the same soaks
How much does a hot tub cost to run UK wide in February? Probably more than that annual average, because the rise lands in the coldest months, when your tub works hardest. And you can't negotiate a grid price. That's the real frustration.
Note: This is a forecast, not a confirmed price. Check Ofgem after 25 November 2026 for the official January cap.
The Cheapest Way to Run a Hot Tub in the UK
The cheapest way to run a hot tub UK owners have isn't one clever trick. It's a stack of small changes, starting with the free ones and ending with storage, that together trim the cost of running a hot tub UK winters throw at you.
Switch to a Time-of-Use Tariff and Heat Off-Peak
Many UK smart tariffs offer overnight rates far below the daytime rate. During off-peak times, you could pay between 6.5p and 17p per kWh. On those example rates, moving the 4 kWh a 2kW heater uses on an average day into the cheap window saves about 72p a day. Set your tub's heating and filtration timers to run inside it, and you directly cut how much to run a hot tub UK suppliers bill you.
Note: Each supplier has their own tariff rates and they are not fixed. So, before switching, check the current rates on your supplier and Ofgem official websites.
Upgrade the Cover, Insulate the Base and Add a Windbreak
You can lower your cost of running a hot tub by implementing simple low-cost fixes before you even touch the thermostat. Start by replacing a waterlogged cover and check the seals sit flush all round. Add an insulating board or foam layer under the base to prevent the hot tub’s shell from losing heat to the concrete floor below. Another simple fix is adding a windbreak, such as a fence panel or hedge on the exposed side, because wind adds to the cost of running a hot tub in UK winters.
Lower the Temperature and Plan Your Soaks
When the tub is unused, lower the set point by a few degrees, then bring it back up before getting in. Also, group your soaks to avoid running two sessions in one evening which increases the power consumed. Work out how much cost to run a hot tub at 38°C adds on days nobody uses it, and a weekend-only timer starts to make sense. Occasional users who ask how expensive is a hot tub to run usually find the idle days are where the money goes.
Store Cheap Electricity in a Home Battery
A home battery lets you buy power when it's cheap and use it when it isn't. Charge it overnight, then let it cover your evening household demand, so less peak-rate electricity is drawn while the tub is also running. It offsets what your home uses; it isn't a dedicated supply for the tub's heater. For example, the EcoFlow STREAM AC 5000 can charge from the grid at off-peak rates. Ask how much is a hot tub to run at 6pm and a battery changes the answer, because peak-rate imports fall.
Can Solar Power Lower Your UK Hot Tub Running Costs?
Why UK Winter Sunshine Won't Fully Heat a Hot Tub
UK winter sunshine is too short and too weak to heat a hot tub on its own. Met Office long-term averages show stations in southern England logging only around 40 to 53 hours of sunshine across the whole of December, under two hours a day. Your heater also works harder during the winter season which means supply and demand are pulling in opposite directions. Ask how much does it cost to run a hot tub on solar alone in December, and the honest answer is that panels barely register. Solar trims the cost of running a hot tub UK owners face rather than wiping it out, and grid power, ideally off-peak, covers the shortfall.
How Spring-to-Autumn Solar Can Cover a Hot Tub's Base Load
From spring to autumn, panels can supply most of your tub's filtration and maintenance heating. How much does running a hot tub cost in July? About £20 a month for a 2kW tub, so solar can cover a large share of it. Panels also offset the rest of your household's daytime use, which helps the whole bill.
Storing Midday Solar for Evening Soaks Instead of Exporting It
Most people soak in the evening, when panels have stopped producing. A battery stores your midday surplus for use after dark instead of exporting it to the grid for less than you pay to import. That's how solar and storage trim the cost to run a hot tub UK homes face after sunset. UK systems like EcoFlow STREAM are hardwired and must be fitted by a registered electrician. And to keep the claim honest, the battery offsets your household's evening demand; it isn't a dedicated supply for the tub's heater.
Ways to Stop Rising Energy Prices Eating Into Your Hot Tub Budget
Storing Cheap Off-Peak Power Before Your Tub Needs It
Nobody wants to sit in the bubbles wondering how much does it cost to run a hot tub while the heater cycles through the priciest hours of the evening. A home battery can take some of that sting out. For example, the EcoFlow STREAM AC 5000 charges from the grid during cheap overnight windows, with no solar panels required, then covers your household loads when rates peak. Its Intelligent mode charges low and discharges high around your tariff, and its 5kWh capacity is expandable if your demand grows, though a certified electrician must fit it.
Save an estimated £ 221 per year; results vary by household 5kWh capacity powers your home from day into night 100% usable capacity, so no stored energy goes to waste Up to 3000W off-grid output for kettles, dryers, stoves, and more Expandable up to 90kWh as your energy needs grow Smart modes use weather and tariffs to cut your bills Backup power during outages for appliances on the AC outlet Compact 44.6kg body designed to fit into spaces around the home IP65-rated for indoor or outdoor installation 40% smaller footprint than comparable 5kWh batteries Built to last: 10,000 cycles and 10-year warranty Control and track your savings from the EcoFlow app Installation by a certified electrician required in the UK 3000W output with expansion battery; single unit delivers 2500W
Using Your Own Solar Power to Dodge the January Price Rise
You can't negotiate a grid price, and the fear is that how much does it cost to run a hot tub will keep creeping up with every cap review. Generating your own power loosens that grip. Take the EcoFlow STREAM 5000: it connects up to 12 panels with 5,000W of solar input, stores surplus summer and shoulder-season generation in its 5kWh battery, then releases it in the evening. It's IP65 rated for outdoor use, carries a 10-year warranty (terms apply), can be expanded and needs an electrician to install.
EcoFlow STREAM 5000
Save an estimated £ 903 per year; results vary by household 5kWh storage with 100% usable capacity, no waste Powers kettles, dryers and more with up to 3000W output Connect up to 12 solar panels with 5000W solar input Expand from 5kWh up to 90kWh as needs grow Intelligent mode charges when cheap, discharges when prices peak 10,000 charge cycles backed by a 10-year warranty Compact design with 40% smaller footprint than comparable 5kWh systems 45.4kg body with a built-in handle for easier placement during installation IP65-rated for indoor or outdoor use, from -20°C to 55°C Keep essentials running during power cuts 15 protection layers plus proactive overload safeguards Hardwired installation by a registered electrician required in the UK
So, how much does it cost to run a hot tub in the UK today? Roughly £36 to £51 a month at the current cap for popular models, with a likely rise in winter 2027 landing just as your heater works hardest. Long heater hours, a worn cover and constant reheating push the cost to run a hot tub up, and the cost of running a hot tub in winter can be about three times the summer figure.
Insulation, timers and smart tariffs come first. They're the cheapest way to run a hot tub UK homes can use, and storage is the next layer, with solar adding to it for the sunnier half of the year. You can't set the price cap, but you can choose when and how you buy power. If you'd like to see how home battery storage could fit your setup, explore the EcoFlow STREAM series at EcoFlow UK.
FAQs About How Much Does It Cost To Run A Hot Tub
Is It Cheaper to Leave a Hot Tub on All the Time?
Yes, but only if you use it at least three times a week and have good insulation. It's cheaper to maintain a steady temperature than to heat from cold, which can take about 39 kWh for 1,200 litres. If you only use the tub once a month, a timer is smarter, and it keeps how much to run a hot tub UK owners spend in check. Check your manufacturer's frost-protection guidance before powering down in winter.
How Much Does It Cost to Run a Hot Tub for 1 Hour?
A 2kW heater costs about 53p an hour at 26.32p/kWh, and a 3kW heater about 79p. That's the heater alone, so add a little for pumps and filtration. How much is a hot tub to run on jets alone? That depends on the pump's rating, and on 13 amp tubs the heater stays off while the jets run. Rates change, so check Ofgem for the current cap.
What Is the Average Annual Cost of Owning a Hot Tub?
Electricity alone answers how much does it cost to run a hot tub over a year: about £432 to £624 for the popular models in our table, which is the core of any cost of running a hot tub in UK budget. Water, chemicals, filters, cover replacement and repairs sit on top. So the all-in answer to how much does a hot tub cost to run UK wide is higher than electricity alone.
Why Do So Many People Get Rid of Hot Tubs?
Common reasons include a novelty that fades while the bills don't. Winter electricity, water changes, chemicals and filters add up, and the cost to run a hot tub UK owners see in January is hard to ignore. Some owners never checked how much is it to run a hot tub through a full winter before buying.
What Are the Downsides of Owning a Hot Tub?
The main downsides are:
  • Running costs that peak in winter, when you most want to use the tub
  • Regular upkeep, including water testing, chemicals and filter cleaning
  • Space and groundwork, since a tub needs a level, load-bearing base
  • Electrical needs, as 32 amp hardwired models require an electrician
  • Safety, because an uncovered or unlocked tub is a risk to children
Before you commit, ask how expensive is a hot tub to run across a full winter. Then work out how much cost to run a hot tub adds to your monthly budget.
