EcoFlow STREAM 5000 vs STREAM Ultra X for Your UK Home
A battery that stores too little electricity or struggles to capture your solar surplus will leave you buying power from the grid when you could have used your own. The EcoFlow STREAM 5000 vs STREAM Ultra X comparison comes down to how much energy your household uses, how much solar you generate and what you expect from home energy storage. The STREAM 5000 holds 5kWh / 5024Wh and accepts up to 5000W of solar input, while the STREAM Ultra X stores 3.84kWh and accepts 2000W. Both offer smart energy management, but their capacity, output and expansion options serve different households. Here is what UK buyers need to know before choosing.
EcoFlow STREAM 5000 and STREAM Ultra X home battery systems displayed side by side
How the STREAM 5000 and Ultra X Compare
The EcoFlow STREAM 5000 and STREAM Ultra X are home energy storage systems designed to capture electricity and make it available when household demand rises. Their biggest differences are storage capacity, solar input and the power available to connected appliances.
The STREAM 5000 is the larger system. Its 5kWh / 5024Wh battery and 5000W PV input suit households with larger solar arrays and greater electricity demand. The Ultra X takes a more compact approach, combining a 3.84kWh battery with a built-in inverter and four independent solar inputs.
This difference matters when choosing a battery. A home with a heat pump, induction hob and electric vehicle will need more storage than a smaller home with lower evening electricity use.
Core Specs Side by Side
The EcoFlow STREAM series solar battery STREAM 5000 offers more storage and a higher solar input ceiling. The EcoFlow STREAM Ultra X combines its battery and inverter in one unit.
Specification
STREAM 5000
STREAM Ultra X
Battery capacity
5kWh / 5024Wh
3.84kWh
Solar input
5000W
2000W
MPPT channels
4 × 1,250W
4 × 500W
AC output
Up to 3000W system (2500W main unit)
1200W rated AC output
Grid-connected output
Up to 3000W, configuration-dependent
800W
Maximum device power
3000W
2300W (10A)
AC charging input
3000W
1200W
Maximum expansion
Up to 90kWh system capacity
Up to 23kWh
Cycle life
10,000 cycles
6,000 cycles to 70% capacity
IP rating
IP65
IP65
10 years
10 years
Sources: EcoFlow UK product specifications.
The STREAM 5000 stores approximately 31% more energy than the Ultra X. Its 5000W solar input is 2.5 times the Ultra X's 2000W rating. That does not mean it automatically saves 2.5 times as much money. The actual benefit depends on available sunlight, battery capacity and household consumption.
One output distinction deserves attention. The Ultra X has a 1200W rated AC output, an 800W grid-connected output and supports appliances up to 2300W through its AC outlets. These figures describe different operating conditions, not one continuous output rating.
Charging, Expansion and Smart Control
The STREAM 5000 supports expansion to a 90kWh system using compatible units and expansion batteries. The Ultra X starts at 3.84kWh and expands to 23kWh through compatible STREAM equipment.
Both systems can charge from solar panels or the grid, but they offer different control options. The STREAM 5000 includes Intelligent Mode+, Self-consumption and Custom settings. It also has Local Mode, which keeps the system operating over a local network. With the Ultra X, you can use the EcoFlow app to control when the battery charges and discharges, including scheduling around cheaper electricity rates.
For households on variable tariffs, this matters. Charging during cheaper periods and using stored electricity during expensive ones gives the battery a job even when winter solar generation is low.
Design, Installation and UK Compatibility
Installation is where the practical differences between these two systems become more important. Both need a suitable electrical arrangement, correctly sized solar connections and consideration of the property's existing consumer unit.
System Design and Solar Compatibility
The STREAM 5000 accepts up to 1250W through each of its four MPPT channels. This allows a larger solar array to generate electricity without reaching the same input ceiling as the Ultra X, giving the larger solar array households more room to generate electricity.
The EcoFlow STREAM 5000 battery has a compact footprint for its capacity, although its 45.4kg weight means careful handling during installation. The Ultra X weighs 38.8kg and measures 420 × 294 × 460mm. Its four 500W MPPT channels suit smaller solar arrangements and panels with different orientations.
Existing rooftop solar needs a separate compatibility assessment. The Ultra X is not an AC coupled battery, but will directly accept PV power via its own PV inputs. To order, please verify the inverter arrangement.
The UK Installation Route
The EcoFlow STREAM 5000 UK installation requires an assessment of the home's wiring, inverter configuration and grid connection. The Ultra X's UK version also uses an open-ended AC cable rather than the standard plug arrangement associated with some European balcony solar products.
Use a qualified electrician to confirm the appropriate connection method, protective devices and consumer-unit requirements. The installer should also establish whether the local Distribution Network Operator (DNO) needs notification before or after installation. G98 and G99 requirements depend on the system's registered generation capacity and connection arrangement.
There is a common misunderstanding around plug-in solar. The UK government's 2026 plug-in solar proposals concern compliant solar microgenerators without batteries. They do not create a general exemption for plug-in battery storage. Neither of these systems should be treated as a DIY socket-connected battery installation simply because similar products are marketed as plug-and-play in other countries.
Durability, Outdoor Use and Warranty
Both batteries have an IP65 protection rating and come with a 10-year warranty. They operate in temperatures ranging from -20°C to 55°C. Each also has a built-in heating function to help the battery work in cold conditions. However, the heating starts at different temperatures: 10°C for the STREAM 5000 and 5°C for the Ultra X.
The Ultra X's 38.8kg weight makes wall positioning and mounting a two-person job. The STREAM 5000 is heavier at 45.4kg. Both are designed for indoor or outdoor use, but choose a shaded, ventilated position and follow the manufacturer's clearance and mounting instructions. Avoid bedrooms and poorly ventilated cupboards.
Which Battery Suits Your UK Household?
The EcoFlow STREAM 5000 vs STREAM Ultra X decision becomes easier when you look at the appliances running in the home, rather than capacity figures alone.
Homes With High Daytime Use
A household with people working from home, an induction hob and a heat pump often has substantial daytime demand. The STREAM 5000's 3000W output provides more headroom for demanding appliances. The Ultra X's 1200W rated output is better suited to smaller loads, although its AC outlets support devices up to 2300W under the specified conditions.
Better fit: STREAM 5000.
Homes With Existing Rooftop Solar
A homeowner with an existing solar inverter needs to establish how the battery will connect to the installation. The Ultra X accepts solar panels directly through its four MPPT inputs, making it suitable for a separate solar-plus-storage arrangement. It is not a direct replacement for an AC-coupled retrofit battery—for that setup, EcoFlow offers a separate EcoFlow STREAM 5000 AC variant designed specifically to pair with existing rooftop solar systems without direct panel inputs.
Anyone searching for an EcoFlow STREAM Ultra X home solar battery should check panel compatibility and the existing inverter before buying.
Better fit: Ultra X for a suitable direct-PV setup; assess an AC-coupled solution for an existing inverter.
Raising Solar Self-Consumption
Solar panels often produce their strongest output around midday, when many households are out. A battery stores some of that surplus for the evening.
The STREAM 5000 accepts up to 5000W, making it the stronger option for larger arrays. The EcoFlow STREAM 5000 also has more storage to absorb that generation. The Ultra X's 2000W input suits a smaller solar setup.
Better fit: STREAM 5000 for higher solar generation; Ultra X for a smaller array.
Evening Demand
Ofgem's typical domestic electricity consumption figure is 2,500kWh a year, equivalent to roughly 6.8kWh a day. Against that daily figure, 3.84kWh represents about 56% of consumption, while 5.024kWh represents about 74%.
These are capacity comparisons, not guaranteed usable energy. Conversion losses, battery reserve settings and the timing of appliance use all affect the amount delivered.
A STREAM 5000 EcoFlow installation gives a household more stored energy for evening cooking, lighting and entertainment.
Better fit: STREAM 5000 for heavier evening demand.
Household Size and Expansion Path
The Ultra X is a good starting point for a smaller flat or terrace which is occupied by one to three people and uses moderate electricity. Another advantage it has is a 23kWh expansion (scaling ceiling) that allows room for growth.
A larger family with an EV, heat pump or plans to add more solar capacity has a stronger expansion route with the STREAM 5000, whose system capacity reaches 90kWh.
Household size alone does not determine battery requirements. Annual consumption, peak loads and solar generation are better measures.
How Each Battery Cuts Your Electricity Bill
A battery reduces grid imports by storing electricity when it is available and releasing it when the household needs it. The financial result comes from the difference between the price of electricity bought and the value of electricity otherwise exported or left unused.
Storing Surplus Solar Instead of Exporting It
Ofgem's average electricity price cap rate for October to December 2026 is 26.32p/kWh for standard variable tariff customers paying by Direct Debit in Great Britain.
At that rate, one full nominal cycle represents approximately £1.01 of stored electricity for the Ultra X (3.84 × £0.2632) and £1.32 for the STREAM 5000 (5.024 × £0.2632).
These figures are theoretical upper values before conversion losses, reserve settings and other system costs. They are not daily savings forecasts. Winter generation, particularly during short and overcast UK days, reduces the number of full solar charging cycles available.
Note: 26.32p/kWh is Ofgem’s price cap rate for October to December 2026 and changes each quarter. The above cycle values are only theoretical maxes and for illustration. Find the latest cap and your tariff rate at Ofgem.
Shifting to Cheaper Tariff Periods
Time-of-use tariffs offer another route to savings. The electricity generated is stored in the battery in periods of low electricity prices, and used during high electricity price periods to meet domestic demand.
You can estimate the savings by multiplying the amount of electricity shifted by the difference between peak and off-peak rates.
Energy shifted × difference between peak and off-peak rates = gross saving.
For example, if peak and off-peak rates differ by 15p/kWh, using 3kWh of cheaper electricity saves 45p before losses. The STREAM 5000 handles charging schedules through Intelligent Mode+, while the Ultra X lets you manage them through the EcoFlow app.
Check the tariff's charging restrictions and standing charges before calculating the benefit.
Cost per kWh of Storage
The EcoFlow STREAM 5000 price needs to be compared with the Ultra X's price at the same point in time. Promotional offers, solar panel bundles and expansion batteries change the total purchase cost.
To compare the units fairly, divide each battery's current standalone price by its nominal capacity. Then add installation, electrical upgrades and any additional equipment to establish the real project cost. A lower purchase price per kWh does not always mean better value. A household that cannot use the extra storage or solar input has little reason to pay for it.
Which EcoFlow Home Battery Is Right for You?
The EcoFlow STREAM 5000 vs STREAM Ultra X comparison points to two different buying priorities: greater capacity and output on one side, and an integrated, more compact solar-plus-storage unit on the other.
Choose by Household Scenario
The STREAM 5000 is a good fit for homes with larger solar arrays, higher daytime electricity use or plans to add more storage. Its 5kWh capacity, 5000W solar input and expansion potential of up to 90kWh give larger households more room to meet their energy needs.
The Ultra X suits homes that want an integrated battery and inverter, direct solar connections and a smaller initial storage capacity. Its 3.84kWh battery, IP65 enclosure and 23kWh expansion limit make it a practical option for more modest energy requirements. An independent EcoFlow STREAM Ultra X review by TechRadar also highlights its compact integrated design and built-in battery heater, while noting its weight and UK installation considerations.
Recommendation Table
The following EcoFlow STREAM 5000 vs STREAM Ultra X comparison matches the products to household requirements.
Buying consideration
STREAM 5000
STREAM Ultra X
Household
Larger family or high demand
Smaller household
Existing solar
New solar system or larger PV plan
Direct connection to compatible panels
Consumption
Higher daytime and evening loads
Moderate household loads
Storage
5kWh / 5024Wh
3.84kWh
Expansion
Up to 90kWh
Up to 23kWh
Main advantage
Capacity, output and solar input
Integrated battery and inverter
Three Buying Mistakes
  1. Assuming higher solar input guarantees higher savings. It does not. The household needs sufficient generation and demand to use the extra captured energy.
  2. Treating either battery as automatic whole-home backup. The STREAM 5000 has an off-grid AC output for connected loads, while the Ultra X provides its own AC outlets during suitable off-grid operation. Neither automatically supplies every household circuit. Plan the backup loads and installation properly.
  3. Assuming installation is identical. The products have different PV and AC arrangements. The electrician must assess the actual wiring, protection and DNO requirements rather than applying one installation plan to both.
Solving UK Home Energy Storage Problems With the Right Battery
Home energy storage is most useful when it addresses a real mismatch between electricity generation and consumption. A household producing surplus solar at midday needs enough storage to use that electricity later. A different household could care more about low-cost overnight charging or more power in its power-hungry appliances. The right product is the one that will solve the problem and not just the one that has the highest specification.
Higher Capacity and Output for Demanding Homes
The EcoFlow STREAM 5000 is the stronger choice in the EcoFlow STREAM 5000 vs STREAM Ultra X comparison for homes that need more storage and want to make better use of their solar generation. Its 5kWh / 5024Wh capacity gives households more stored energy to use during the evening. It also accepts up to 5000W of solar input across four MPPT channels, making it a better fit for larger solar arrays. With expansion up to 90kWh and 3000W AC output, it gives homeowners more room to build a larger home energy system. Intelligent Mode+ also helps manage charging and discharging based on solar generation and electricity prices.
EcoFlow STREAM 5000
Installed home battery for homes with or without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging on the main unit (up to 3000W with an Expansion Battery) for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.4kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
A Compact Integrated Solar-Plus-Storage Setup
The EcoFlow STREAM Ultra X is a good choice for homeowners who want battery storage and a solar inverter in one compact unit. Its 3.84kWh battery stores electricity for use later in the day, while its four MPPT channels support up to 2000W of direct solar input. If your energy needs increase, you can expand the system to 23kWh. Having the inverter and battery in one unit also makes it a convenient option for homes with compatible solar panel setups.
Massive 3.84kWh capacity providing reliable energy storage from sunset until sunrise Four advanced MPPT channels supporting up to 2000W of solar input Expandable storage capacity scaling up to 23kWh for entire home coverage Up to 2300W AC outlet output (1200W rated / 800W grid-tied Smart AI-driven optimization automatically managing dynamic time-of-use electricity pricing Durable IP65 weatherproof design built with an integrated heater for cold climates Long-lasting LFP battery cells delivering 6000 cycles backed by a ten-year warranty Seamless smart home integration connecting easily with third-party automation protocols
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries and systems with integrated batteries, including the EcoFlow STREAM 5000 and STREAM Ultra X, are not plug-in solar products. They must be professionally installed and must comply with the IET Wiring Regulations (BS 7671) and DNO connection requirements. Make sure that any guidance on GOV.UK is up to date and speak to a qualified installer to find out what your home requires.
The STREAM 5000 is the better choice for UK homes that need more battery storage, higher AC output and greater solar input. It also offers more room for future expansion. The EcoFlow STREAM Ultra X UK is better suited to households with lower energy needs. Its integrated inverter, 3.84kWh battery and direct solar inputs make it a practical option, with expansion available up to 23kWh. Neither battery is the right choice for every home. Your electricity use, solar generation, installation costs and tariff should guide your decision.
For homeowners comparing EcoFlow STREAM 5000 vs STREAM Ultra X, the best starting point is an honest assessment of daily electricity use and the solar capacity available at the property. Check out EcoFlow UK and discover the STREAM range to choose the home energy storage system that suits your home.
How much usable electricity does a 5kWh home battery provide?
The nominal energy that can be stored in the 5kWh battery is about 5kWh, however, the energy delivered to the appliances will be less due to conversion losses and battery energy that may be reserved. Useable capacity and limits of discharge before sizing a system.
How long does a home battery take to pay for itself?
Payback depends on purchase price, installation, solar generation, electricity tariffs, export payments and daily cycling. Compare the cost of stored electricity with the grid rate it replaces. Avoid relying on manufacturer savings estimates without checking the assumptions behind them.
Does a larger battery always make more financial sense?
No. A larger battery offers more storage, but it needs enough surplus generation or cheap electricity to charge it regularly. Buying unused capacity increases the upfront cost without necessarily improving annual savings.
