What Is a Smart Home? Devices, Hubs, and Systems Explained
A smart home is a home where connected devices can communicate with each other, automate everyday tasks, and be controlled remotely through an app, voice assistant, or centralized platform. Instead of operating every light, thermostat, lock, or energy device separately, a smart home lets these products work together as part of a connected system.
Understanding the difference between a smart home device, hub, and system is the first step toward building one. This guide explains how each part works, covers must-have smart home devices for beginners, and looks at energy management as an increasingly important part of a connected home.
So, what is a smart home? Simply put, it is a home equipped with connected devices that can be monitored, controlled, or automated. These devices typically connect through Wi-Fi, Bluetooth, Zigbee, Z-Wave, or newer standards such as Matter.
The three terms below describe different parts of a smart homze:
  • Smart home device: A smart home device is an individual connected product. Examples include smart bulbs, plugs, thermostats, cameras, locks, and sensors. Depending on the product, it can be controlled remotely or programmed to perform tasks automatically.
  • Smart home hub: A smart home hub is a central device that connects and coordinates multiple smart devices. For example, a motion sensor could communicate with a hub, which then tells a smart light to turn on. A hub can make it easier for devices using different communication protocols to work together.
  • Smart home system: A smart home system is the complete setup. It can include your connected devices, hub or hubs, smartphone app, voice assistant, and the platform that brings everything together.
Technology is expanding beyond basic lighting and security, too. As smart home technology continues to change how people live, connected systems are increasingly being used to manage energy, heating, appliances, and backup power.
Most smart home guides focus on lights, cameras, and locks. But energy management is another important smart home category, using connected hardware to monitor and control how electricity moves through your home.
Smart Home Energy Management: Hubs and Devices for Power
Energy management is no longer separate from home automation. A smart electrical panel or smart battery backup functions just like a smart security system: a central controller monitors loads, automates when power flows to specific circuits, and lets you manage consumption via an app.
Pairing intelligent power hardware with your home allows you to schedule charging during off-peak utility rates, maintain critical circuits during grid outages, and optimize solar input automatically.
EcoFlow TITAN (Whole-home smart energy system)
The EcoFlow TITAN is a split-phase smart energy storage system. Paired with the EcoFlow Smart Home Panel 10 (SHP10), it backs up and manages up to 10 selected 120V/240V circuits, with app-based circuit control, automatic outage switching, and scheduling.
EcoFlow TITAN 5000
EcoFlow DELTA 3 Max Plus
The EcoFlow DELTA 3 Max Plus is a compact home backup power solution with 2,048Wh capacity, smart output priority, and flexible power management for essential appliances.
EcoFlow DELTA 3 Max Plus (2048Wh)
• 3,000W Output: 6,000W surge. X-Boost mode can run some appliances up to 3,800W, though results vary by device. • Fast Recharging: 5 ways to charge, reaching 0 to 80% in 43 minutes with generator charging. • Expandable Capacity: 2kWh base, expandable to approximately 10kWh with two DELTA Pro 3 Smart Extra Batteries and the EcoFlow Smart Extra Battery Expansion Adapter (sold separately). Pairing with a compatible EcoFlow Smart Generator adds automatic start and stop for longer runtime.
With energy management covered as one smart home category, here's how it fits alongside the must-have devices most people think of first.
Must-Have Smart Home Devices for Beginners
You do not need to automate your entire house at once. Starting with a few useful devices can help you understand how smart home automation works before expanding into additional rooms or categories.
  • Smart plugs and bulbs
Smart plugs and bulbs are among the easiest ways to start. They are generally simple to install and can let you turn appliances or lights on and off remotely, create schedules, or include them in automated routines.
For example, a smart plug could turn a lamp on automatically in the evening, while smart bulbs can be scheduled to switch off at bedtime.
Smart plugs and bulbsSmart plugs and bulbs
  • Smart thermostat
A smart thermostat combines convenience with potential energy savings. Instead of manually adjusting the temperature throughout the day, you can create schedules or let the thermostat respond to occupancy and other settings supported by the system.
For homeowners interested in reducing unnecessary heating or cooling, this can make a smart thermostat one of the more practical additions to a connected home.
Smart thermostatSmart thermostat
  • Smart locks and video doorbells
Smart locks and video doorbells are popular starting points for home security. A smart lock can provide remote access and automation features, while a video doorbell can let you see and communicate with visitors through a connected device.
These products can also become part of broader routines. For example, unlocking a smart door could trigger specific lights or other compatible devices.
Locks and video doorbellsLocks and video doorbells
  • Voice assistant or hub device
A voice assistant or hub can provide a convenient way to control multiple connected devices. Instead of opening separate apps, you may be able to control compatible lights, thermostats, plugs, or other products using a single command.
The exact capabilities depend on the ecosystem and devices you choose, so compatibility should be considered before building a larger setup.
Voice assistantVoice assistant
  • Smart energy device
Energy management rounds out the list of must-have smart home devices for homeowners who want their connected home to do more than automate lights and security. Smart energy equipment can provide visibility into power use, control selected circuits, and integrate battery backup into the broader home automation experience.
This is where smart home energy management becomes particularly useful: it brings the same principles of monitoring, automation, and centralized control to one of the most important systems in the house.
Smart energy deviceSmart energy device
Once you know which devices you want, the next consideration is how they will communicate and work together.
Best Smart Home System: What to Look for Before You Buy
Choosing the best smart home system is less about finding one universally superior platform and more about choosing an ecosystem that works with the devices you already own or plan to buy.
  • Compatibility and standards
Matter is a newer smart home standard built to make devices from different brands work together without extra hubs or workarounds. Choosing devices that support Matter 1.4 can make it easier to use compatible devices across different smart-home ecosystems, and it's especially relevant for energy devices that need to talk to lights, thermostats, and other systems in your home.
  • Hub-based vs. hub-less systems
Hub-based systems use a central device to coordinate compatible products. This can simplify automation and provide a common point for managing multiple devices, although it adds another piece of hardware to the setup.
Hub-less devices can connect directly through technologies such as Wi-Fi and may be simpler to install. However, depending on the products involved, they may offer fewer options for advanced automation or local coordination.
The right choice depends on how large and complex you expect your smart home to become.
  • Local control vs. cloud-dependent systems
Some smart home systems process automations locally, so your lights and locks keep working even if the internet goes down. Others depend on the cloud, meaning an outage could leave you unable to control your devices until service is restored.
For energy-focused systems, interoperability is becoming equally important. A modern smart home energy management setup may need to coordinate batteries, electrical panels, appliances, and other connected equipment, making compatibility a key consideration from the beginning.
Once you have selected a compatible ecosystem and devices, installation is usually more straightforward than building an entire smart home may sound.
Smart Home Installation Basics
Many individual smart home products are designed for DIY installation. Smart plugs, bulbs, cameras, and some sensors can typically be installed by following the manufacturer's instructions and connecting the device through its app.
Whole-home systems require more planning, particularly when they interact with the home's electrical infrastructure.
A smart energy panel or other equipment that connects directly to electrical circuits should be installed by a qualified, licensed electrician. This is similar to other panel-level electrical work and helps ensure the installation complies with applicable electrical requirements.
A practical approach is to start small and expand. You might begin with a hub, a few smart lights or plugs, and one security device. Once those products are working reliably, you can add thermostats, locks, cameras, and energy management equipment. This gradual approach also makes it easier to identify compatibility issues before investing in a larger system.
With the individual components in place, the overall concept becomes simple: devices perform specific functions, hubs coordinate them, and the system brings everything together into one connected home.
A smart home is built from individual devices, coordinated by a hub, into a system you control from one place. Energy management deserves a clear spot on that list alongside lighting and security because it adds both convenience and practical resilience when the grid fails.
Start with one or two must-have devices that solve an immediate need. If backup power and energy control are priorities, the EcoFlow TITAN paired with the SHP10 delivers whole-home circuit management, while the EcoFlow DELTA 3 Max Plus offers a flexible, self-contained entry point that requires no panel work.
Explore the EcoFlow TITAN and EcoFlow DELTA 3 Max Plus to compare configurations and choose the setup that fits your home.
What's the difference between a smart home device and a smart home hub?
A smart home device is a single connected product (bulb, plug, thermostat, lock) that can be controlled or automated on its own. A hub is the central coordinator that lets multiple devices work together and often provides unified app control.
Do I need a hub, or can smart devices work independently?
Not always. Some smart devices connect directly through Wi-Fi or Bluetooth and can work independently. A hub becomes useful when you want multiple devices to communicate, coordinate automations, or use different communication protocols together.
Is a smart home battery or panel actually considered a "smart home device"?
Yes. A battery with app control, scheduling, and prioritization, or a smart panel that monitors and switches circuits, functions as both a device and (in the panel's case) a hub within the energy category.
How much does a basic smart home setup cost to start?
Entry points can begin under $100 with a few smart plugs or bulbs. Adding a thermostat, lock, or portable energy device raises the cost, while whole-home panels represent a larger long-term investment.
Can I add smart home energy management to an existing home without rewiring everything?
In most cases, yes. Portable options like the DELTA 3 Max Plus need no rewiring at all and work right out of the box. A whole-home panel like TITAN's SHP10 does need professional installation, but it typically works with your home's existing electrical setup rather than replacing it.
