What Is a Gale Warning? Wind Speeds, Flags, and What to Do
- What Is a Gale Warning?
- What Flag Is Used to Indicate a Gale Warning?
- Gale Warning vs. Other Wind Alerts
- Why Gale Warnings Often Mean Power Outages, Even Far From the Coast
- Built for Actual Gale-Force Wind: The Iceland Case
- Power Where Gales Are Routine: Iceland's "Loneliest House"
- What to Do When a Gale Warning Is Issued
- Conclusion
- FAQs
A gale warning covers sustained winds or frequent gusts of 34 to 47 knots (39 to 54 mph) that are expected or occurring and are not directly associated with a tropical cyclone. It is primarily a marine alert for boaters and shipping traffic. Advance notice varies by forecast area; check the local National Weather Service product for its timing. The same weather system can also bring damaging winds and power outages on land. This guide explains the wind thresholds, warning flags, and practical preparation steps.
A gale warning is issued when sustained winds of 39 to 54 mph, or 34 to 47 knots, are expected. It's primarily aimed at coastal, marine, and Great Lakes areas, where wind speed directly affects boating and shipping safety.
Gale warnings are a marine-focused alert first and a general public one second. Inland communities near open water routinely feel the same wind speeds that trigger the warning offshore.
The term comes from the Beaufort wind force scale, where gale specifically covers forces 8 and 9. That's distinct from a storm, which covers forces 10 and 11. Hurricane force is force 12 on the same scale.
The Beaufort scale also describes what that wind actually does. Force 8 breaks twigs off trees and makes walking into the wind noticeably difficult. Force 9, at the top of gale range, can strip chimney pots and loosen roof slating. Those are land effects, not just marine ones, and they line up closely with why gale-force wind causes real damage well away from open water.
Boaters specifically rely on a visual signal for this warning, not just a forecast they might miss, so it's worth knowing what that looks like.
The flag system is simpler than a lot of people assume, and it's easy to get backward. A single red pennant signals a small craft advisory. A gale warning is signaled by two of those same red pennants flown together, not one flag with any added markings.
Square flags mean something different from pennants. A storm warning is a single red square flag with a black square in the center. Two of those same red-and-black squares flown together signal a hurricane warning instead of a tropical storm-specific alert.
Warning Level | Flag Shown | Wind Speed |
Small Craft Advisory | One red pennant | 25 to 38 mph |
Gale Warning | Two red pennants | 39 to 54 mph |
Storm Warning | One red square, black center | 55 to 73 mph |
Hurricane Warning | Two red squares, black centers | 74 mph or higher |
Most of the original coastal warning towers that displayed these flags have been retired in favor of digital and radio alerts. But the flag system itself hasn't disappeared. The Coast Guard still uses it at some stations, and it's still taught in maritime safety training.
The flag signals one specific alert level. Here's how it stacks up against the other wind warnings the National Weather Service issues.
Gale, storm, and hurricane-force wind warnings use distinct non-tropical wind thresholds. A Small Craft Advisory is different: its criteria vary by region and may reflect hazardous seas or icing as well as wind, so it is not a single nationwide wind-speed band.
Alert | Wind Criteria | Typical Focus |
Small Craft Advisory | Varies by forecast area; wind, sea, and icing criteria may apply | Smaller boats, choppy conditions |
Gale Warning | 34–47 knots (39–54 mph), sustained winds or frequent gusts | Coastal and marine areas broadly |
Storm Warning | 48–63 knots (55–73 mph), sustained winds or frequent gusts | Severe marine and coastal impact |
Hurricane Force Wind Warning | 64 knots (74 mph) or higher, sustained winds or frequent gusts | Non-tropical systems reaching hurricane-strength wind |
These thresholds apply to non-tropical systems specifically. A tropical storm or hurricane triggers its own separate warning category, even at overlapping wind speeds.
A gale warning sits in the middle of this scale. It's strong enough to down tree limbs and power lines on land, well before reaching storm or hurricane-force thresholds.
That land-side impact is the part most inland readers actually care about. Gale-force wind doesn't stay offshore.
Sustained winds in the 39 to 54 mph range are enough to snap weakened tree limbs and topple untrimmed trees onto power lines. That's not just a brief gust, either. Utility infrastructure often isn't built to handle that kind of sustained load for hours at a stretch.
Coastal and near-water communities feel gale-force conditions more often than most people realize. These systems form regularly along both coasts and the Great Lakes throughout the year, not just during hurricane season.
A Nor'easter moving up the Atlantic coast is a classic example, and Pacific storms deliver similar wind to West Coast communities through the winter months. Great Lakes gales run on their own separate cycle. They're tied more to lake-effect weather patterns than to the tropical storm calendar most people associate with wind warnings.
Understanding how different wind speeds translate into real-world impact makes it easier to judge how seriously to take a given forecast. That's worth doing before the wind actually picks up, not after.
A whole-home battery system is one of the more reliable ways to ride out a gale-driven outage. It doesn't need refueling mid-storm the way a fuel-powered generator does, and it can pick up the load the moment the grid drops.
Multi-day outages are where the EcoFlow TITAN Plus earns its place. Battery output is the same 7.2kW, rising to up to 10kW only when compatible solar is connected and producing, and its 8kW solar input allows faster recharging between storms.
Between the two, the EcoFlow TITAN covers a household that mainly needs selected circuits backed up during an outage. The EcoFlow TITAN Plus adds more AC output only when compatible solar is connected and producing, plus a larger solar input. That matters most in longer outages, where recharging counts as much as stored capacity.
We put this power solution through the toughest real test on a remote, grid-free island in Iceland. It's a place where gale-force wind isn't an occasional warning. It's closer to routine weather.
Elliðaey Island, part of Iceland's Vestmannaeyjar archipelago in the North Atlantic, sits in one of the windiest inhabited regions on Earth. Conditions at or above gale force are common there well outside any single named storm.
EcoFlow says a TITAN Plus unit runs as the sole power source for a house on the island. There's no grid connection to fall back on. On the mainland, that same wind would just as easily knock out a utility line.
The system is paired with solar panels and off-grid power management hardware. Operating under European 230V/50Hz island conditions, it reportedly keeps heaters, refrigeration, lighting, and water pumps running continuously through Iceland's harsh, wind-exposed winter. For North American homes, the TITAN series is engineered for standard 120V/240V split-phase electrical systems.
According to EcoFlow, the full installation was completed by a single operator in three to four hours. There was no heavy equipment involved, and no fallback plan if the system hadn't held up.
Technology holds up genuinely in extreme wind. Here's what to actually do the next time a gale warning is issued closer to home.
Elliðaey sits in Iceland's Westman Islands, out in the North Atlantic. Its only building is a hunting lodge from 1953, famous online as the loneliest house in the world. Boats can land only in calm weather, and that's mostly in summer.
Coverage of the island's new power system put winds there at around 100 km/h, about 60 mph, with waves topping 9 meters, roughly 30 feet. On the NWS scale, that's past gale force and into storm-warning territory. For decades, the lodge ran on gasoline and propane winched up the cliffs from boats, a delivery that only works when the sea allows it.
In 2026, the island association installed a 5kWh EcoFlow TITAN home battery system with two solar panels, Reuters reported. It powers the stove, kettle, and lighting; communications equipment was mentioned as a potential additional use. Installer Simon Smith described the remote setting as having no backup. That illustrates the importance of planning the loads and available energy carefully at an isolated site.
On the mainland US, the lesson is simpler. A gale-driven outage is a bad time to be hunting for fuel. Stored power that's already charged, plus a way to recharge it, takes that problem off the list.
A gale warning usually gives enough lead time to take a few practical steps before the wind arrives. It's easy to underestimate a gale warning specifically, since it doesn't carry the same weight in people's minds as a named storm.
Secure or bring in loose outdoor items, trash cans, patio furniture, and anything else wind can turn into a projectile
If you're near the coast or on the water, follow the National Weather Service's marine guidance and avoid unnecessary boat travel until the warning lifts
Charge devices and any battery backup system ahead of time, since gale-driven outages often arrive with less lead time than a named storm
Coastal wind risk doesn't start and end with one warning. Working through a broader home protection checklist for hurricane-prone areas covers the steps worth taking well before any single warning gets issued.
Gale warnings also cluster heavily in certain seasons for a lot of coastal regions. Getting ahead of seasonal storm prep heading into spring means less scrambling once the first warning of the year actually shows up.
Wind alone can strain power lines before anything ever falls. Seeing how exposed power lines hold up against sustained wind and winter conditions helps explain outages that happen without a single visible tree failure nearby.
Anyone whose main gale-warning concern is a boat rather than a house has different priorities. Portable power built for boats and marine use covers that scenario directly. A house battery system doesn't do much good tied up at a dock.
A gale warning covers sustained winds or frequent gusts of 34 to 47 knots (39 to 54 mph) that are expected or occurring and are not directly associated with a tropical cyclone. Follow local marine guidance, secure loose outdoor items, and keep backup power charged ahead of an expected outage. EcoFlow TITAN and EcoFlow TITAN Plus, connected through Smart Home Panel 10 by a qualified electrician, can back up selected household circuits within their output and energy limits.
What wind speed qualifies as a gale warning?
A gale warning covers sustained winds of 39 to 54 mph, or 34 to 47 knots. It's issued mainly for coastal, marine, and Great Lakes areas rather than as a general inland alert.
What flag is used to indicate a gale warning?
Two red pennants flown together signal a gale warning. A single red pennant means a small craft advisory instead, and the square red-and-black flags are reserved for storm and hurricane warnings.
How is a gale warning different from a storm warning?
A gale warning covers 39 to 54 mph winds, while a storm warning covers 55 to 73 mph. Storm warnings represent a meaningfully more severe and destructive category of wind.
Can gale-force wind cause power outages far from the coast?
Yes. Winds in the 39 to 54 mph range are enough to topple weakened trees onto power lines well inland. A whole-home battery system like TITAN or TITAN Plus can keep the essentials running through that kind of outage.
How long do gale warnings typically last?
There's no fixed duration. A gale warning stays in effect as long as the National Weather Service expects those wind speeds. That can range from several hours to a couple of days depending on the system. Checking the latest marine forecast is the most reliable way to know when it's expected to lift.
