Is a 5000-watt Generator Enough for Your Home? What It Can Run
For many homeowners concerned about the increased frequency of extreme weather events, natural disasters, and blackouts, investing in reliable home backup power for peace of mind and family safety has gone from a priority to a necessity.
5000-watt generators are often promoted as an “entry-level” whole-home standby generator solution, but conventional 5kW generators may not power as many of your appliances and systems like heating and air conditioning as you might think.
Understanding exactly how much power a generator can supply vs. how much your high-wattage appliances require to start and run is an essential step in choosing the right size and type of generator for your home.
For one thing, different 5000W generators from different manufacturers often output significantly varying amounts of power even though they’re marketed as having a 5kW.
There are also unique types of output power in watts that you’re unlikely to have encountered if you’re unfamiliar with how generators work.
Understanding the basic principles behind off-grid generator power is essential to making an informed purchase decision for a 5000W generator that can actually run what you think it can.
Otherwise, you could be left in the dark with an expensive mistake.
First of all, what exactly is a 5000W generator, and what can it run?
What Is a 5000W Generator?
A 5000W generator is a machine that produces electrical power independent of the utility grid.
An advertised rating of 5000W usually means that the generator can output a maximum of 5000 watts of continuous power (also called running or operating watts) as alternating current (AC) electricity.
However, it’s essential to understand that generators are rated for two types of wattage: starting watts and running watts.
Manufacturers of conventional generators sometimes market generators as 5000W despite the continuous power output being significantly lower.
For example, a portable gas generator may be advertised as 5000W, but in practice, it can only output 5000W as a short burst of surge power to start appliances — particularly those with engines or compressors — and the running wattage is significantly lower.
More on that below.
Overview of Wattage
Watts (kW) and kilowatts (kW) are units of electricity that measure the rate of power generated or consumed at a specific moment in time.
Wattage reflects the instantaneous supply or demand of electrical energy.
For example, a 5kW generator rated for 5000W of continuous power can supply a maximum of 5000W of electricity to operate devices and appliances over a period of time — often determined by how much energy is stored in a battery or the level of fuel in a tank.
Watts and kilowatts measure electrical power…
Watt-hours (Wh) and kilowatt-hours (kWh) measure energy — the amount of power consumed over time.
For example, a 150W television left on for an hour consumes 150Wh of electricity.
Power and energy are often used interchangeably but they’re distinct — if related —metrics.
Starting Watts
Air conditioners, refrigerators, dishwashers, washing machines, dryers…
What do all these appliances have in common?
Each relies on motors or compressors to operate and requires significantly more power to start than to run — often double the wattage or more.
When an appliance that relies on a motor or compressor is turned (or cycles) off, the rotor inside the motor comes to a standstill.
A burst of starting watts is required to overcome inertia and get the rotor spinning again, enabling the motor to deliver mechanical power.
It’s a similar principle to requiring a starter battery in a traditional automobile to deliver a surge of power to get the engine running.
Many people are unfamiliar with the concept of starting wattage because it’s rarely an issue when you’re plugging your appliances into a wall socket, i.e., the utility grid.
You’ve probably had the experience of turning on one too many appliances on an overloaded and throwing a circuit breaker in your home.
Often, it’s the surge power required by an appliance switching on causes breakers to trip.
High-wattage appliances like refrigerators and HVAC systems that automatically cycle on and off can also cause circuit breaker trips.
Often, a tripped breaker caused by a circuit overload is no more than a minor inconvenience…
However, if you’re relying on a generator to provide power for your home and turn on an appliance that overmatches its starting wattage capacity, the device won’t start.
In most cases, the generator will auto-shutdown due to overvoltage protection, which may permanently damage the unit.
If you want to run multiple appliances with a generator — or even just one — it’s essential to ensure that the starting wattage does not exceed its capacity.
Even if the running wattage is sufficient to meet the load requirements of all the appliances you run simultaneously, just one of them switching on and off could cause a surge of demand that will overpower the generator.
Carefully examine the starting and running wattage requirements of the appliances you want to operate and the generator’s output capacity.
It’s crucial to note…
Manufacturer’s labels and product manuals usually list the running wattage requirements of appliances — not the starting watts.
Most consumers are concerned with how much electricity a device will consume over time, not the surge power required to start it up.
Starting wattage is rarely a concern when your home runs on grid power.
With generators, it’s of essential importance.
Running Watts
Most people are familiar with the concept of running wattage, even if they don't know the technical term.
Frequently known as operating or continuous power, running wattage is the electrical load a device or appliance requires to function once it’s turned on.
Many devices and appliances don’t need any additional surge power to turn on — or, at most, a negligible amount unlikely to impact generator performance.
For example, televisions, electric stoves, phone chargers, and incandescent lightbulbs require no additional starting wattage to switch on and operate.
Modern LED lights may cause a slight surge in electrical load, but it’s unlikely you’ll notice.
Home appliances typically only list their operating wattages on manufacturer’s labels or in manuals, as starting wattage is rarely a concern when using on-grid power.
Estimating the total running wattage of all the appliances you want to operate simultaneously remains essential to deciding on the right size and type of generator for your home.
However, you must also factor in the starting wattage to make an informed purchase decision, even if it means spending more.
With careful planning and load management, a 5000W generator that offers no additional starting wattage may be able to run your desired appliances...
But buying a generator with more output is probably wiser if your budget allows.
Surge Power
Surge power or (surge wattage) is closely related to starting wattage, but the terms aren’t always used the same way.
Starting wattage always refers to the additional power an appliance needs to start.
Surge power typically refers to the electricity a generator can produce in a short burst to overcome inertia in motors and compressors and meet the starting wattage requirements of connected appliances.
Many conventional gas generators — especially budget models — can only provide 10% - 15% above their operating wattage as surge power.
Some fossil fuel generators with sophisticated electronics — such as high-end inverter generators — can produce up to 50% above continuous rated power, but may provide less. It depends on the model.
EcoFlow’s whole home backup generators can produce up to double their AC output as surge power.
For example, EcoFlow DELTA Pro 3 is expandable from 4kW to 12kW of operating AC output that provides 8kW to 24kW of surge power.
Thanks to proprietary X-Core 3.0 technology, a single DELTA Pro 3 can power up to 6000W of appliances simultaneously.
With multiple charging options, including solar panels, grid power, gas generators, and an 800W alternator (vehicle) adapter, the DELTA Pro series gives you far more options to keep your home running than a conventional generator.
Watt-Hours/Kilowatt Hours
Watts measure instantaneously available electrical power.
Watt-hours (wH) and kilowatt-hours (kWh) measure electricity consumption over time.
Specifically, the continuous wattage an electrical device requires to run for one hour.
You’re likely familiar with kilowatt-hours because utility companies charge you for electricity consumption in cents per kWh (¢/kWh) on your energy bills.
Watt-hours and kilowatt-hours are also used to measure battery storage capacity in solar generators, portable power stations, and other rechargeable backup applications.
What Can a 5000-Watt Generator Run?
Now that you understand the concepts of starting and running wattages and how essential they are to sizing a generator accurately, you can better evaluate what a specific model can run.
In the tables below, we’ve listed the average starting and running wattages of appliances and devices in several categories.
Averages can vary, and the closer you get to a generator’s maximum AC output, the more likely a system will shut down or fail.
Keep in mind, also, that’s it’s not advisable to run most generators at maximum capacity as it will shorten the lifespan of the unit and lead to diminished performance.
Can a 5000-Watt Generator Power a House?
A 5kW generator can power multiple household appliances simultaneously.
During many hours of the day, the average household will likely consume less than 5000W of electricity.
However, it’s easy to envision a scenario where peak demand hours may require more starting and running wattage than a 5000W generator can supply.
For example, cooking dinner on a hot summer day where you’re running central air conditioning, high-wattage kitchen appliances, and an electric water heater cycles on at the same time.
Remember, the wattages below are just estimates.
Calculating your actual energy consumption is essential.
Average Power Requirements of Household Appliances
Average Wattage (W)
Average Starting Wattage (W)
Air Conditioner Window Unit (8,000 BTU)
800-1,500W
2400-4500W
Blender
300-1,000W
N/A
Ceiling Fan
50-100W
N/A
Clothes Dryer
1,800-5,000W
N/A (See Caveats)
Coffee Maker
800-1,200W
N/A
Computer (Desktop)
100-400W
N/A
Dehumidifier
200-800W
N/A
Electric Bike
250-750W
N/A
Electric Blanket
50-200W
N/A
Electric Deep Fryer
1,000-2,000W
N/A
Electric Fireplace
750-2,400W
N/A
Electric Grill
1,200-1,800W
N/A
Electric Hedge Trimmer
400-800W
800-1600W
Electric Lawn Edger
500-1,200W
1000-2400W
Electric Pressure Cooker
600-1,200W
N/A
Electric Scooter
250-750W
N/A
Electric Shaver
10-20W
N/A
Electric Skateboard
200-500W
N/A
Electric Wok
1,200-1,800W
N/A
Fluorescent Light (15W)
15-50W
N/A
Garage Door Opener
100-500W
300-1500W
Garbage Disposal
400-1000W
800-2000W
Game Console
50-150W
N/A
Hair Dryer
1,200-1,800W
N/A
Hedge Trimmer
400-800W
800-1600W
Humidifier
30-300W
N/A
Incandescent Light (60W)
60-120W
N/A
Induction Cooktop (Single)
1000-1800W
N/A
Instant Hot Water Dispenser
1300-1500W
N/A
Iron
1,000-1,800W
N/A
Laptop charger
30-120W
N/A
LED Light Bulb (10W)
10W
N/A
Refrigerator/Freezer
100-400W
300-1200W
Space Heater
750-1500W
N/A
Television (42"" LCD/LED)
70-200W
N/A
Television (42"" Plasma)
150-400W
N/A
Toaster
800-1,500W
N/A
Washing Machine
300-500W
600-1000W
Wi-Fi Router
5-20W
N/A
Is a 5000-Watt Generator Suitable for a Work Site?
Power Tools
Average Wattage (W)
Angle Grinder
500-2,000W
1000-4000W
Band Saw
800-1,500W
1600-3000W
Belt Sander
800-1,200W
1600-2400W
Circular Saw
1,200-2,400W
2400-4800W
Dust Extractor/Vacuum
500-1,500W
1000-3000W
Electric Screwdriver
100-300W
N/A
Impact Driver
800-1,500W
1600-3000W
Impact Wrench
800-1,500W
1600-3000W
Jigsaw
300-800W
600-1600W
Miter Saw
1,200-1,800W
2400-3600W
Orbital Sander
200-400W
N/A
Paint Mixer/Stirrer
500-1,000W
N/A
Paint Sprayer
400-800W
N/A
Planer
800-1,500W
1600-3000W
Polisher/Buffing Machine
500-1,000W
N/A
Reciprocating Saw
600-1,200W
1200-2400W
Rivet Gun
100-500W
N/A
Rotary Tool
100-300W
N/A
Router
800-1,500W
1600-3000W
Soldering Iron
20-100W
N/A
Tile Cutter
600-1,200W
1200-2400W
Tile Saw
800-1,200W
1600-2400W
Wood Lathe
500-1,500W
1000-3000W
Can a 5000-Watt Generator Power an RV?
RV and Camping Appliances
Average Wattage (W)
Bread Maker
500-1,000W
N/A
Camping Blender
300-800W
N/A
Camping Fan (Battery or USB)
3-20W
N/A
Camping Fridge/Freezer (12V/24V/AC)
30-100W
N/A
Camping Grill
1,000-2,000W
N/A
Camping Ice Maker
100-500W
N/A
Camping Lantern (LED)
5-50W
N/A
Camping Oven
800-1,500W
N/A
Camping Shower
100-400W
N/A
Camping Stove
1,000-2,500W
N/A
Camping TV (LCD/LED)
50-500W
N/A
Camping Water Kettle
500-1,000W
N/A
Camping Water Pump
50-200W
N/A
Camping Water Purifier
10-50W
N/A
Coffee Machine
500-1,000W
N/A
Crepe Maker
500-1,200W
N/A
Electric Blanket
50-200W
N/A
Electric Fondue Set
500-1,000W
N/A
Electric Grill Pan
500-1,200W
N/A
Electric Griddle
800-1,500W
N/A
Electric Hot Plate
500-1,500W
N/A
Electric Ice Crusher
200-500W
N/A
Electric Juicer
200-500W
N/A
Electric Pancake Maker
500-1,000W
N/A
Electric Raclette Grill
500-1,200W
N/A
Electric Skillet
500-1,200W
N/A
Electric Smoker
800-1,500W
N/A
Electric Steamer
800-1,200W
N/A
Electric Wok
1,200-1,800W
N/A
Egg Cooker
200-500W
N/A
Food Dehydrator
200-500W
N/A
Hair Dryer
500-1,500W
N/A
Heater
500-1,500W
N/A
Hot Dog Maker
500-1,000W
N/A
Ice Cream Maker
200-500W
N/A
Kettle
500-1,000W
N/A
Portable Cooktop
500-1,500W
N/A
Portable Cooler/Warmer
30-100W
N/A
Portable Fan Heater
500-1,500W
N/A
Radio
5-15W
N/A
Slow Cooker
200-500W
N/A
Soup Maker
500-1,000W
N/A
Toaster
500-1,000W
N/A
Yogurt Maker
100-300W
N/A
Can a 5000-Watt Generator Power Computers and Communications Devices?
Average Wattage (W)
Cordless Phone
2-5W
N/A
Ethernet Cable
Does not consume power
N/A
Ethernet Switch
5-30W
N/A
External Hard Drive
5-15W
N/A
Fax Machine
10-50W
N/A
Fiber Optic Cable
N/A
IP Camera
5-15W
N/A
IP Phone
2-5W
N/A
KVM Switch
5-30W
N/A
Laptop
30-120W
N/A
Mobile Phone Charger
5-15W
N/A
Modem
5-15W
N/A
Network Access Point (AP)
5-20W
N/A
Network Adapter/Converter
Varies based on type
N/A
Network Attached Storage (NAS)
20-100W
N/A
Network Bridge
5-20W
N/A
Network Diagnostic Tool
N/A
Network Firewall
10-50W
N/A
Network Hub
5-30W
N/A
Network Load Balancer
10-50W
N/A
Network Media Converter
5-20W
N/A
Network Modem
5-15W
N/A
Network Rack
Varies based on equipment inside
N/A
Network Repeater/Extender
5-20W
N/A
Network Storage Enclosure
20-100W
N/A
Network Switch
5-30W
N/A
Network Test Equipment
N/A
Network Video Recorder (NVR)
50-200W
N/A
Patch Cable
N/A
Patch Panel
5-20W
N/A
Powerline Adapter
3-10W
N/A
Printer
20-100W
N/A
Projector
150-300W
N/A
Router
5-20W
N/A
Scanner
10-50W
N/A
Server
Varies based on configuration
N/A
Server Rack
N/A
Smart Speaker
10-30W
N/A
Tablet Charger
5-15W
N/A
UPS (Uninterruptible Power Supply)
Varies based on capacity
N/A
UPS Battery Backup
N/A
Video Conferencing System
100-500W
N/A
Video Encoder/Decoder
10-50W
N/A
Video Surveillance System
50-500W
N/A
VoIP Gateway
5-20W
N/A
VoIP Phone System
N/A
VPN Router
5-20W
N/A
Wi-Fi Router
5-20W
N/A
Wireless Access Point (WAP)
5-20W
N/A
Workstation Computer
100-400W
N/A
Find the complete appliance wattage chart and energy usage calculator here.
Can a 5000-Watt Generator Run an Air Conditioner?
A 5000W generator will run window AC units but may not output sufficient starting and running wattage to operate central HVAC systems. Central AC typically requires 2x to 3x its operating wattage to start. For example, a 3-ton (36,000 BTU) central AC may require under 5000W to run but over 8000W to start. Ensure the generator has sufficient surge power to start central HVAC systems.
How Many Amps Does a 5000-Watt Generator Produce?
The amperage of a 5000W generator depends on its voltage. Most home generators and appliances run at 120V. The formula for calculating amps from watts and volts is Amperage = Watts/Volts. At 120V, a 5000W generator outputs 41.66A. At 240V, it outputs 20.8 amps. Many 5000W generators have multiple outlets, each likely to have its own amperage limit — typically 15A or 2A for standard 120V outputs.
How Much Does a 5000-Watt Generator Cost?
“How much does a car cost?” The price range may not be quite as wide for 5000W generators as it is between a Hyundai and a Rolls Royce or truck, but it’s not far off. A basic 5000W portable gas generator with no sophisticated electronics can cost around $500. A high-quality inverter generator with throttling and power conditioning, closer to $1500. A 4000-5000W solar generator costs around $3000, with no ongoing fuel costs. Some models offer double their running watts as surge power. They’re typically whisper quiet and safe for indoor use.
Will a 5000 Watt Generator Run Central Air
Probably not. The most common central AC system size is 3-ton (36,000), with an average running wattage of about 4000W. However, that same unit likely requires 8000W or more to start. Even inverter generators max out at about 50% surge power. In that case, a 5000W inverter would output 7500W max. Not enough to start the unit. Many basic gas generators produce surge power of just 10-15%. Solar generators frequently offer double their AC output, making them a viable alternative to gas.
Will a 5000 Watt Generator Run My House
It’s unlikely, particularly if you use electricity for heating and/or air conditioning. While many homes use less than 5000W during off-peak times, power consumption spikes significantly during peak hours. And that doesn’t account for the starting wattage requirements of HVAC systems and many high-wattage appliances. With careful load management, you should be able to run many essential appliances with a 5000W generator with sufficient surge power, but not the entire home around the clock.
Understanding the unique characteristics of how generators supply power to home appliances and how they differ from plugging directly into the grid is an essential first step to choosing a home backup power solution that will meet your unique needs.
Conventional 5000W gas and inverter generators have limitations you may well have been unaware of, particularly when it comes to surge power and starting watts.
EcoFlow’s whole home generator systems, like DELTA Pro 3, offer double their running watts as surge power with expandable AC output and LiFePO4 battery storage.
There are no ongoing fuel costs when you charge with solar and multiple other options for keeping your backup batteries topped up.
Not only that, EcoFlow’s smart power management features can help you save significant money on electricity bills by avoiding time-of-use rates (on-peak hours) and energy demand charges…
Features that fossil fuel generators simply can’t provide.
Whether you need portable power for road trips and camping or a whole home generator, EcoFlow has a system for you.
Check out our selection today.
Home Backup
