Washington Wildfires: Inside Its Worst Season Since 2021
Washington just faced its worst wildfire season in years. It is not completely over yet. Fires that kicked off in early August tore through Spokane neighborhoods. They destroyed hundreds of homes. Statewide burned acreage pushed past 850,000. The scale of the Washington wildfires has put communities across the state on alert.
This breakdown covers what happened and which fires are still burning. You will also learn what sparked this crisis and whether fall rains bring real relief.
Washington's 2026 Wildfire Season, By the Numbers
Washington's fire season accelerated quickly during the summer. By the end of August, the numbers had reached levels the state hadn't seen in years.
  • About 425,000 acres were burned by July 31, 2026.
  • Numbers doubled within four weeks. The fire count hit 1,456 across Washington state, burning 851,557 acres.
  • Washington reached Preparedness Level 5, the highest national wildland fire preparedness level.
  • The state also banned most outdoor and agricultural burning.
  • Climate scientist Daniel Swain noted that Washington and Oregon combined have already surpassed their historical full-season acreage records, with weeks of fire season still ahead.
These numbers show how quickly Washington state wildfires can grow when dry conditions meet strong winds.
A season running this hot changes how a household should think about backup power. Working through a few practical steps for staying ready before red flag conditions hit is worth doing before the next dry stretch arrives.
Wildfires in WashingtonWildfires in Washington
Nowhere felt that acceleration harder than Spokane. A handful of fast-moving fires became the season’s biggest disaster.
Inside the Spokane Fires: Old Trails, Fairview, and Autumn Lane
The Old Trails fire broke out on a Saturday afternoon in early August. By the next morning, it had chewed through 3,500 acres near Riverside State Park.
  • Urgent evacuations: Officials issued Level 3 evacuation orders across large parts of Spokane. Residents received an urgent warning: "Leave NOW! This may be your only notice."
  • Widespread damage: The Spokane blazes damaged or destroyed more than 830 structures, pushing damage estimates past $1 billion.
  • Emergency shelter: Officials opened the Spokane Convention Center to take in hundreds of displaced families.
  • Widespread blackouts: Nearly 11,000 customers lost electricity, leaving over 8,000 Spokane County households in the dark.
Governor Bob Ferguson declared a statewide emergency as the blazes overwhelmed local crews. These intense fires in Washington state left thousands facing sudden, dangerous power outages.
When high winds and wildfires knock down transmission lines, the grid can cut out for days. If you need to keep your entire house running, from central AC and well pumps to large freezers, a whole-home backup system is the way to go. The EcoFlow DELTA Pro Ultra X ties right into your breaker panel and takes over before your lights even flicker.
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. •Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. • High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
If you do not need to back up the entire house or you need power that moves with you during an evacuation, a portable setup makes much more sense. A portable power station keeps your fridge, phones, and radios alive without complex installation. The EcoFlow DELTA 3 Max is built for rapid departures when minutes matter.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. •4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Level 3 evacuation warnings leave zero time to search your garage for loose flashlights. Keeping a portable power station ready by the front door keeps your phone and radios charged.
Spokane drew most of the headlines, but it was far from the only part of the state fighting a major fire this summer.
The Bigger Picture: Sinlahekin, Little Giant, and the Rest of the State
Sinlahekin and Little Giant
The Sinlahekin and Little Giant fires, both in north-central Washington, each burned more than 150,000 acres on their own. That dwarfs the acreage lost in the Spokane fires.
Kittitas County's fires
Further south, the Three Queens, King, and Goat fires burned a combined 10,600-plus acres in Kittitas County, east of Snoqualmie Pass. That added to an already stretched firefighting effort.
By late August, DNR tracked 18 large fires actively burning statewide. Fires this size rarely stop at state lines. Major complexes flared up across Oregon, Idaho, and western Canada at the same time. That regional surge pulled hard on the shared pool of smokejumpers, hand crews, and tanker planes.
Extreme heat, dry brush, and gusty winds always trigger early weather alerts. Knowing what a red flag warning means for your home's backup power helps you charge gear before the grid cuts out.
A brutal season like this does not happen by accident. A dangerous mix of weather set the stage months before the first spark caught.
What's Actually Driving This Record Season
A brutal mix of dry ground, heat, and shifting winds set up the state for disaster:
  • Record-setting drought: Months of dry weather parched local forests and grasslands. Fuels reached critical dryness weeks before peak season arrived.
  • Severe fire weather: Howling winds and single-digit humidity drove rapid spread. Smaller brush fires quickly erupted into dangerous crown runs.
  • Strained firefighting crews: The scale of the fires stretched available resources so thin that the National Guard had to step in with helicopter crews and roughly 110 members approved for hand-crew duty.
  • Extreme landscape vulnerability: DNR Commissioner Dave Upthegrove laid out the reality plainly: "Any new spark on our tinder-dry landscapes can lead to another devastating wildfire."
Escaping dry, wind-driven fires requires moving fast before local roads get cut off. Running through a dedicated wildfire evacuation checklist helps you pack essential portable power and gear before a Level 2 notice turns into a Level 3 run for safety.
After weeks of exactly those conditions, the first real break in the weather finally showed up in September.
The First Fall Storm: How Much Relief Is Actually Coming
The Pacific Northwest caught a major break in early September. A solid three-day storm brought widespread rain right when firefighters needed it most.
The rain came at an important time. Much of Washington had spent weeks dealing with hot, dry conditions that helped fuel major wildfires.
 The First Fall Storm: How Much Relief Is Actually Coming The First Fall Storm: How Much Relief Is Actually Coming
Rain May Slow Fires, But It Won't End Fire Season
The I-5 corridor, including Seattle and Portland, received an estimated 1 to 2 inches of rain. Heavier rainfall was expected along the coast, Olympic Peninsula, and Cascades.
Cooler temperatures and higher humidity should also help slow fire growth. However, forecasters flagged a Level 1 flash flood risk for parts of eastern Washington and Idaho.
One storm won't end a wildfire season this severe. But it marks a meaningful shift after weeks of heat, dryness, and rapid fire growth.
What the Rain Means for Wildfire Smoke
Rain helps clear the sky eventually, but fine particulate smoke hangs around for days. Learning how to track wildfire smoke PM2.5 levels ensures you run your home air purifiers effectively until conditions clear.
For households affected by Washington state fires, the storm offers some relief. Still, residents should keep monitoring fire activity, evacuation alerts, and air quality as September continues.
How to Prepare If Wildfire Risk Is Still Rising Near You
Do not wait for smoke to roll over the ridge before taking action. A few simple chores around your yard make a massive difference:
  • Check local burn restrictions: Washington's statewide burn ban covers most outdoor and agricultural burning. Check current restrictions before burning anything outside.
  • Track active fire movement: The state DNR portal updates fire perimeters in real time. Check it daily if you live east of the Cascades or near timber.
  • Clear dry vegetation: Remove dead brush, leaves, and other dry vegetation around your home's foundation. This can reduce the chance of fire reaching your property.
  • Know your evacuation status: Learn your neighborhood's zone before a crisis hits. That saves precious minutes if a Level 1 alert suddenly jumps to Level 3. You should also know which structural changes can help protect your home from wildfire embers, especially if you live near wildland terrain.
Washington's 2026 wildfire season has burned more than 851,000 acres. Hundreds of homes were destroyed around Spokane, making this the state's worst season since 2021. Check local burn restrictions and evacuation zones before the next red flag warning. Keep backup power ready for unexpected outages. EcoFlow's DELTA Pro Ultra X provides whole-home backup power. DELTA 3 Max offers portable power during evacuations.
How many acres have burned in Washington's 2026 wildfires?
Washington had burned more than 851,557 acres across 1,456 fires by late August 2026, per DNR data reported by Axios. That already made it the state's worst wildfire season since 2021, with weeks of fire season still ahead at the time.
What caused the Old Trails fire near Spokane?
Authorities arrested a suspect for suspected arson after investigating the origin near Riverside State Park. Extreme drought conditions and 45-mph winds quickly blew the small ignition into a massive, fast-moving blaze.
Are wildfires close to Seattle?
No active wildfires threaten Seattle directly. Most major blazes burn east of the Cascades. However, easterly winds periodically push thick smoke and fine particulate pollution over Puget Sound neighborhoods.
Is Washington's wildfire season getting better after the September rain?
Early fall storms brought welcome moisture, knocking down open flames and clearing air across the state. However, deep timber root systems remain hot, so full recovery requires soaking late-fall rains and mountain snow.
What's the best way to keep power on if a wildfire forces an evacuation?
A whole-home battery like the EcoFlow DELTA Pro Ultra X keeps essential circuits running if a fire knocks out utility power at home. For a fast evacuation, a portable unit like the DELTA 3 Max travels with you and keeps phones, medical devices, and small appliances charged.
Power Outages
