Tsunami vs Hurricane: What Actually Sets Them Apart
Both can send a wall of water toward a coastline, force people to evacuate, and cause serious damage. But a tsunami and a hurricane have almost nothing in common when it comes to what causes them. One starts with a sudden shift beneath the ocean, while the other grows from warm water and atmospheric conditions. They also move at very different speeds and give coastal communities very different amounts of warning. Here's how the two compare, why storm surge isn't the same as a tsunami, and whether a hurricane can cause one.
What Actually Causes a Tsunami
A tsunami is caused by a sudden shifting of a large volume of ocean water. Normally this is caused by an undersea earthquake, but landslides or volcanic eruptions under the sea can also cause them. Unlike a hurricane, which begins with something forming in the atmosphere, a tsunami starts with something moving in the ocean.
What Actually Causes a TsunamiWhat Actually Causes a Tsunami
What Has to Happen for a Tsunami to Form?
Most destructive tsunamis come from large, shallow earthquakes at subduction zones, where one tectonic plate pushes beneath another. When the seafloor suddenly moves upward, it pushes the water above it and sends waves racing across the ocean. The earthquake has to move enough of the seafloor to displace a large volume of water.
The earthquake also needs to be strong and shallow enough to create a serious tsunami threat. USGS guidance puts the risk of a destructive local tsunami at around magnitude 7.6 or higher, while earthquakes above magnitude 7.9 can cause damage across a much wider stretch of coastline. The earthquake generally needs to occur less than about 100 kilometers deep and under or very close to the ocean.
Once a tsunami forms, its waves can travel across the open ocean at roughly 500 to 600 mph. That speed can leave coastal communities near the source with very little time to react. If you live near the coast, knowing how to read official alerts can help you recognize a warning and know when it's time to move to higher ground.
What Actually Causes a Hurricane
A hurricane starts with a completely different set of conditions than a tsunami. Instead of movement beneath the ocean, it develops from warm ocean water and atmospheric conditions that allow a tropical system to organize and strengthen.
What Does a Hurricane Need to Form?
Ocean water generally needs to be at least 80°F for a hurricane to develop and strengthen. That warm water provides the heat that fuels the storm as it organizes. The system also needs to form roughly 300 miles or more from the equator, where the Earth's rotation can help give the storm its spin. Low wind shear matters, too, because strong winds higher in the atmosphere can disrupt a developing storm before it has a chance to organize.
When Does a Storm Become a Hurricane?
A tropical system becomes a hurricane when its sustained winds reach 74 mph. Below that threshold, it's classified as a tropical depression or tropical storm. The Atlantic hurricane season officially runs from June 1 through November 30, although tropical systems can develop outside those dates. If you want to see how the wind-speed cutoff works, this guide to tropical storms and hurricanes breaks down the difference.
Tsunami vs Hurricane at a Glance
The biggest difference between a tsunami and a hurricane is how they start and how quickly they affect the coast. A tsunami can cross the open ocean at 500 to 600 mph, while a hurricane usually moves forward at only 10 to 15 mph. That speed difference also affects how much warning people get, with hurricanes typically tracked days in advance, while a tsunami can give a nearby coastline only minutes to react.
Feature
Tsunami
Hurricane
Cause
Underwater earthquake, landslide, or volcanic eruption
Warm ocean water, wind, and atmospheric pressure
Typical warning time
Minutes to a couple of hours
Days, tracked in advance
Travel speed
500 to 600 mph in open ocean
10 to 15 mph forward speed
Wave or surge height
Up to 100+ feet near shore in extreme cases
Typically several feet, higher in severe storms
Duration at a given location
Minutes
Hours to days
Regardless of which coastal disaster strikes, severe water damage and utility failure often leave homes without grid power for days. A compact, fast-charging power station ensures your family stays connected and essential devices stay online when the power goes out.
EcoFlow DELTA 3 Classic (1,024Wh)
•Fast Charging: Recharges 0–80% in 45 minutes via AC power. • 1,800W Output: Features 3,600W surge and powers up to 2,600W with X-Boost™. • 10ms UPS Backup: Instant auto-switching protects sensitive electronics like NAS servers. •Durable LFP Battery: Built with automotive-grade cells rated for 10 years and whisper-quiet operation ( ≤ 30dB at 600W). •Smart App Control: Features OASIS 3.0 with Storm Guard, real-time monitoring, and scheduled savings.
Storm surge is one reason tsunamis and hurricanes sometimes get confused, since both can push large amounts of water onto the coast.
Storm Surge Isn't a Tsunami, Even Though It Looks Like One
Storm surge is one reason tsunamis and hurricanes can get confused. Both can push large amounts of water onto the coast, but storm surge comes from a hurricane's winds and low air pressure, while a tsunami starts with a sudden disturbance beneath the ocean.
How Does Storm Surge Form?
As a hurricane approaches, its winds push seawater toward the coast while low air pressure raises the water level. The surge builds as the storm gets closer and can cause flooding for hours. NOAA uses models such as SLOSH to estimate how much water a hurricane could push onto shore.
Why Is Storm Surge Mistaken for a Tsunami?
Historical reports sometimes described storm surge as a "wall of water." During the 1909 Grand Isle Hurricane, NOAA confirmed that the reported flooding was storm surge, not a tsunami. The key difference is timing: storm surge builds with the approaching hurricane, while a tsunami can arrive much faster after an undersea disturbance. Storm surge is also one of the deadliest hurricane hazards, making hurricane landfall risks worth understanding.
Can a Hurricane Actually Cause a Tsunami?
A hurricane's wind and rain don't create the seafloor movement needed for a true tsunami. Hurricanes can, however, trigger a different kind of wave called a meteotsunami, which forms when a sudden change in air pressure pushes water.
Can a Hurricane Create a Tsunami?
A true tsunami needs a sudden disturbance beneath the ocean, usually from an earthquake, landslide, or volcanic eruption. A hurricane doesn't provide that trigger, so its strong winds and heavy rain can't create the kind of earthquake-driven tsunami discussed earlier.
What Is a Meteotsunami?
A fast-moving storm system can sometimes cause a meteotsunami when a sudden jump in air pressure creates a wave in the water. NOAA has recorded meteotsunamis reaching 6 feet or more, including events along the East Coast, Gulf Coast, and Great Lakes. They're difficult to forecast because the pressure disturbance also has to line up with local features such as a bay or shallow continental shelf. Better weather forecasting can help track these fast-moving threats, but meteotsunamis remain much harder to predict than hurricanes.
How Much Warning Do You Actually Get?
Warning time is one of the biggest differences between a tsunami and a hurricane. A hurricane can be tracked days ahead, while a tsunami may leave nearby communities only minutes to react.
How Much Warning Do You Actually Get?How Much Warning Do You Actually Get?
How Much Warning Do You Get for a Tsunami?
NOAA's DART network uses about 39 buoys, most of them in the Pacific, to detect changes in seafloor pressure that could signal a tsunami. When the system detects something unusual, the buoys switch to faster reporting to help warning centers assess the threat. Even with that monitoring in place, communities close to the source may have only minutes to a couple of hours to evacuate. That's why knowing your evacuation route before a tsunami warning matters.
How Much Warning Do You Get for a Hurricane?
Hurricanes usually give people much more time to prepare because forecasters can track a storm as it develops and moves toward land. The National Hurricane Center updates its track and intensity forecast every six hours during an active storm and looks ahead as far as five days. That gives you time to secure your home, charge backup batteries, learn how long a power outage can last, gather supplies, and make plans.
A tsunami and a hurricane can both threaten coastal communities, but they develop in very different ways. Tsunamis are caused by a sudden movement under the ocean, while hurricanes are formed by warm water and good atmospheric conditions. That difference matters in everything from travel speed to warning time. Hurricanes can be tracked days in advance, while a tsunami could give nearby communities minutes to evacuate. A storm surge can also cause serious coastal flooding during a hurricane, but it is not the same as a tsunami. You can’t control what happens, but you can know what hazard affects your area, have a plan for evacuation, supplies and backup power so you can react to changing conditions.
What's the main difference between a tsunami and a hurricane?
A tsunami is caused by sudden movement under the ocean, usually an undersea earthquake, while a hurricane is caused by warm ocean water and atmospheric conditions. They differ in speed and in warning time and in their effects on the coast. A tsunami can be on the shore in minutes. A hurricane can usually be tracked days in advance.
Can a hurricane actually cause a tsunami?
A hurricane will not create a real tsunami, the kind that is caused by earthquakes, because its wind and rain don’t cause the sudden movement of the seafloor needed to make one. But a rapidly moving storm can sometimes cause a meteotsunami due to a sudden change in air pressure. Waves of this type can occur along the East Coast, Gulf Coast, and Great Lakes.
Which one gives you more warning time, a tsunami or a hurricane?
A hurricane generally gives you more warning time. Forecasters can track hurricanes for days and update their forecasts as the storm approaches. A tsunami can give coastal communities near the source only minutes to a couple of hours to evacuate, so knowing your evacuation route ahead of time is important.
Is storm surge the same thing as a tsunami?
No. Storm surge is when hurricane winds drive seawater ashore and the low air pressure causes the water level to rise. What causes a tsunami ? A sudden disturbance under the ocean. The surge from a hurricane usually builds up as the hurricane approaches and can last for hours. A tsunami can arrive much more rapidly.
What's a simple way to keep essentials powered after a tsunami or hurricane outage?
A portable power station can keep the essentials, like your phone, lights and small electronics running when the power goes out. For a longer outage, choose a battery with enough capacity for the devices you need the most and keep it charged before severe weather hits.
Power Outages
