Does California Get Hurricanes? What the Data Shows
In early September, Hurricane Marie spun off the coast of Baja California, sending high surf advisories to Southern California beaches. So does California actually get hurricanes? Almost never, and this piece explains exactly why, what's different about the handful of storms that have come close, when the state's own hurricane season technically runs, and what a storm like Hurricane Marie meant for people on the coast.
Yes, But Barely: California's Hurricane History
California has seen a few tropical systems over the years, but true hurricane strikes are extremely rare. The most notable example came in October 1858, when the San Diego Hurricane reached the area as a Category 1 storm, bringing sustained winds of roughly 75 mph, flooding, and wind damage.
California's Hurricane HistoryCalifornia's Hurricane History
California's Most Notable Tropical Storms
More recently, Hurricane Kathleen weakened before reaching California in 1976 but still brought heavy rain to the desert. Hurricane Nora retained tropical-storm strength as it moved into Southern California in 1997. Then, in 2023, Hurricane Hilary brought significant rainfall and prompted Southern California's first-ever tropical storm watch from the National Weather Service.
So California has seen tropical storms before, but most have weakened considerably before reaching the state. That's a big reason the state rarely experiences the kind of hurricane impacts common along the Gulf and Atlantic coasts.
Why Hurricanes Almost Never Reach California
California's location makes it a tough place for hurricanes to reach. Cold ocean water and prevailing winds usually weaken storms or push them away before they get close to the coast.
Cold Water Makes It Hard for Hurricanes to Survive
The biggest obstacle is the water. California's coastal waters usually stay in the 50s to 70s°F, while hurricanes need water around 80°F to maintain their strength. The California Current also carries cold water south along the coast, making it harder for a tropical system to stay organized as it moves toward California.
Winds Keep Most Storms Away
The wind pattern works against hurricanes, too. Prevailing winds over the eastern Pacific generally steer storms away from the West Coast, while stronger wind shear can weaken them as they move north. By the time many tropical systems get close to California, they've already lost much of their strength.
Conditions can vary from year to year, though. Ocean temperatures and larger weather patterns can affect how tropical systems develop and move. El Niño and La Niña can also shift storm patterns, which is one reason some years bring tropical systems closer to Southern California than others.
Hurricane Marie 2026: What Southern California Can Expect
As of September 4, 2026, Hurricane Marie was a Category 2 storm with 100 mph sustained winds well off the coast of Baja California. The National Hurricane Center's forecast kept Marie offshore as it curved northwest and weakened, making a direct strike on Southern California very unlikely.
The Main Risk Is Along the Coast
For Southern California, Marie's biggest effects are expected at the coast rather than from a hurricane landfall. South-facing beaches could see high surf and dangerous rip currents, with some risk of beach erosion and coastal flooding if large waves line up with evening high tides of around 6.5 to 7 feet.
Could Marie Still Cause Power Problems?
Even an offshore storm can cause local problems. Strong surf, gusty winds, or falling trees can damage utility equipment and lead to power outages, especially in coastal communities. Light rain and gusty easterly winds are also possible, but a direct hurricane impact isn't the main concern.
That makes backup power worth arranging before the surf picks up. A whole-home system like the EcoFlow DELTA Pro Ultra X keeps essential circuits running through an outage, and a portable unit like the DELTA 3 Max goes with you if you need to leave:
• 100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. •High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Marie was staying offshore, but its effects brought up another question: what happens when a tropical system actually reaches inland California?
When Is Hurricane Season in California, Really?
California doesn't have its own separate hurricane season, but tropical systems can still affect the state during the Eastern Pacific hurricane season.
When Does Hurricane Season Start?
The Eastern Pacific hurricane season officially runs from May 15 through November 30, according to the National Hurricane Center. It starts about two weeks before the Atlantic season, which begins June 1. California usually sees little direct impact during this period because most storms stay offshore or weaken before reaching the coast.
When Is California Most at Risk?
The busiest part of the season is usually August through October, when Pacific waters are warmest. That's also when California is most likely to see a rare brush with a tropical system. Hurricane season can look different across regions, but late summer and early fall are the key months to watch along the California coast.
What Actually Happens When a Tropical System Reaches California
When a tropical system reaches California, the biggest problems usually aren't hurricane-force winds. Heavy rain, rough surf, and flooding tend to cause more trouble, especially in areas that don't often deal with tropical weather.
What Happens When a Tropical Reaches CaliforniaWhat Happens When a Tropical Reaches California
Heavy Rain Can Be the Biggest Problem
California's mountains and desert areas can struggle with a sudden burst of tropical rain. Hurricane Hilary showed just how much rain these storms can bring. In 2023, downtown Los Angeles got 2.30 inches in one day, breaking an August rainfall record that had stood since 1977. Mount San Jacinto received 9.91 inches, while Palm Springs got about 3.18 inches.
The Coast Can Get Dangerous, Too
High surf and strong rip currents can affect California beaches even when a storm stays hundreds of miles offshore. That can make conditions dangerous for swimmers and surfers, while large waves can also cause beach erosion and coastal flooding.
Flash Flooding Is Another Risk
Heavy tropical rain can also trigger flash flooding in mountain, desert, and canyon communities. When that happens, roads can become dangerous quickly, so knowing the basics of flash flood safety is worth keeping in mind before a tropical system moves in.
Could a Real Hurricane Ever Hit California?
A hurricane-strength landfall in California is still extremely unlikely. A few things make it hard for a storm to stay strong enough to reach the coast with sustained hurricane-force winds.
Why a California Landfall Is So Unlikely
  • Cold coastal water: California's coastal waters are usually too cold to support a strong hurricane.
  • Prevailing winds: Winds over the eastern Pacific generally steer storms away from the West Coast.
  • Wind shear: Stronger wind shear can weaken a tropical system before it gets close to California.
Warmer water closer to the coast has allowed some storms to hold onto tropical-storm strength a little longer in recent years. That's part of why Hilary and Marie drew attention, but it doesn't mean California is becoming a regular hurricane target.
What Would Count as a Hurricane?
A storm needs sustained winds of at least 74 mph to be classified as a hurricane. Hurricane categories are based on those wind speeds. So if a tropical system ever reached California with sustained winds of 74 mph or more, it would qualify as a hurricane, even though that remains very unlikely.
So, does California get hurricanes? Yes, but almost never. The state has had one confirmed direct hurricane-strength hit, while storms such as Kathleen, Nora, Hilary, and Marie either weakened before reaching California or stayed offshore. For most Californians, the bigger concerns are heavy rain, flash flooding, high surf, rip currents, and occasional power outages rather than a direct hurricane landfall. That can still mean dangerous conditions, especially along the coast and in mountain or desert areas. If a tropical system is heading your way, keep an eye on local weather and surf advisories, and be ready for the hazards that matter most where you live.
Has California ever actually been hit by a hurricane?
Yes, but it's extremely rare. The San Diego Hurricane of October 1858 is the only confirmed direct hit by a hurricane-strength storm in California. It reached the area as a Category 1 storm and brought sustained winds of roughly 75 mph, flooding, and wind damage. Since then, several tropical systems have affected the state, but they weakened before reaching California or stayed offshore.
Why don't hurricanes hit California?
Cold ocean water is the main reason. California's coastal waters are usually in the 50s to 70s°F, while hurricanes need water around 80°F to maintain their strength. Prevailing winds also tend to push Eastern Pacific storms away from the West Coast, and stronger wind shear can weaken them before they reach California.
When is hurricane season in California?
California doesn't have its own separate hurricane season. The Eastern Pacific hurricane season runs from May 15 through November 30, with the busiest stretch usually falling between August and October. That's when Pacific waters are warmest and California is most likely to see a tropical system come close to the coast.
Will Hurricane Marie make landfall in California?
Based on the National Hurricane Center's September 4, 2026 forecast, a direct strike on Southern California was very unlikely. Marie was a Category 2 hurricane well off the coast of Baja California and was expected to curve northwest and weaken. Its main effects for Southern California were high surf, dangerous rip currents, and a possible risk of coastal flooding and beach erosion.
What's the best way to keep the power on if a tropical storm knocks it out along the coast?
Start by following local outage and weather updates, then focus on keeping essential devices powered. A portable power station can handle smaller backup needs, while a whole-home system makes more sense for a longer outage or larger electrical loads. Even an offshore tropical system can cause localized outages if strong winds or falling trees damage utility equipment.
Power Outages
