The Top Wireless Chargers for the iPhone 17
The iPhone 17 takes wireless charging to the next level with faster speeds and wider compatibility thanks to the new Qi2.2 standard. Whether you’re working remotely, traveling off-grid, or just want a more efficient daily setup, the right charger makes all the difference.
In this guide, we’ll highlight the top-performing options from portable power stations to magnetic power banks and explain how MagSafe and Qi2 are shaping the future of wireless charging for Apple users and beyond.
EcoFlow RAPID Magnetic Power Bank (10,000mAh)
The new iPhone 17 is equipped with wireless charging, which is now the preferred method for many iPhone users. Wireless charging utilizes electromagnetic induction, where the coils in the charger generate energy that is picked up by similar coils in the phone and converted to battery power.
No more worrying about lost charger cables, simply place your phone on the charger and it charges wirelessly.
The EcoFlow RAPID Magnetic Power Bank (10,000mAh) offers Qi2-certified 15W wireless charging for your iPhone 17. It also offers flash recharging with 30W of input, allowing for a charge from 0% to 70% in under 33 minutes.
Additionally, if you prefer ultra-fast wired charging, a built-in 65W USB-C cable is included to charge your phone even faster. It will also provide your 13-inch MacBook Air with an extra 8 hours of power, which is excellent news for busy commuters.
The built-in stand also makes it easy to use, offering upright or side views for hands-free use as a desktop stand. Finally, you can also enable “Healthy Charging Mode” to help protect your battery and locate your power bank using the embedded buzzer, in case you misplace it.
EcoFlow RIVER 3 Plus
For those who love to travel on road trips or embark on off-grid adventures, you will want a robust charger that can recharge your iPhone multiple times and also handle additional devices, such as laptops, camping lights, and even small kitchen appliances.
The EcoFlow RIVER 3 Plus is the perfect off-grid travel companion. It’s a compact and lightweight portable power station offering 600W of rated output and 1200W of X-boost to cover those starting watts of small appliances. It also offers ultra-fast solar charge (up to 220W), with ultra-quiet operation (<30dB), so it won’t disturb the peaceful surroundings of your off-grid adventures.
Finally, it also acts as a <10 ms pro-grade Uninterruptable Power Supply (UPS) for sensitive electronics like MacBooks, so you can keep working remotely without having to worry about damaging your equipment.
MagSafe and Qi2: A Compatibility Guide
MagSafe was introduced by Apple in 2020 as a proprietary magnetic wireless charging system that utilizes a ring of magnets to snap the charger into the optimal position on their phones in order to ensure reliable 15W charging speeds.
Qi2, developed by the Wireless Power Consortium (WPC), represents the next evolution of the open Qi standard, which is used by nearly all wireless chargers today. Just like MagSafe, Qi2 also now includes a Magnetic Power Profile (MPP) that ensures a perfect alignment between the phone and charger, but in an open, cross-platform format that all manufacturers can use.
What this means for compatibility with iPhones is that you can now use any MagSafe or Qi2.2 wireless technology for your modern iPhone, as well as the next generation of AirPods, iPads, MacBooks, and other Apple products and accessories.
In the meantime, MagSafe chargers can still charge older Qi2 and Qi-compatible devices, but they will default to slower speeds of 7.5W or even 5W, depending on the certification and manufacturer.
Key Features to Look for in a Wireless Charger
Here are some key features to consider when deciding which chargers work best.
  1. Check if it's compatible with MagSafe and Qi2.2 for fast wireless charging.
  2. Wired charger options are ideal for those with busy schedules who may need their device charged more quickly than with wireless chargers. This usually means a multi-device charger, as they tend to offer both a charging cable and wireless capabilities.
  3. Do you need to charge just your iPhone 17 or do you also need to charge AirPods, an Apple Watch, or your MacBook Air? In this case, look for a multi-device charger with a higher total wattage and multiple output ports, allowing you to charge multiple devices simultaneously.
  4. Is a stand important to you? Will you be using your phone while it is on the stand? In that case, the ability to use a stand in upright or side views hands-free using the enhanced magnetic alignment is crucial since it will allow the user to scroll, stream, or make video calls while it sits on the charge port and not have to worry about the phone slipping off and not charging anymore.
  5. If you spend a lot of time traveling or commuting to and from work or school, you will want a compact model that easily fits in your pocket alongside your phone, so you can always have it ready when needed.
Under 10ms UPS keeps sensitive devices safe, with 600W output and 1200W X-Boost. Expandable, ultra-quiet, and lightweight—with fast 1-hour charging and up to 220W solar input for all-day, anywhere use.
What Type of Charger Does the iPhone 17 Take?
The iPhone 17 uses a USB-C cable for charging and data transfer, so it's compatible with a wide range of manufacturers’ chargers. With a powerful enough adapter, it supports up to 40W of wired charging, and with MagSafe, it will allow 25W of compatible wireless charging.
Does the iPhone 17 Have Wireless Charging?
Yes, wireless charging is a standard feature on all new iPhones, including the iPhone 17. The latest models utilize a magnetic array for precise alignment and support wireless charging with the new Qi2.2 standard, supporting MagSafe with speeds of up to 25W, depending on the model.
Choosing the right charger for your iPhone 17 depends on how and where you power up. For everyday use and on-the-go convenience, the EcoFlow RAPID Magnetic Power Bank (10,000mAh) delivers fast Qi2-certified wireless charging in a sleek, portable design.
With new MagSafe and Qi2 compatibility, you can now charge faster, smarter, and more efficiently wherever life takes you.
