Tennessee Flooding: What Happened in Polk County and How to Stay Safe in a Flood
Early on November 5, 2026, heavy overnight rain dropped 8 to 10 inches over parts of the watershed above Copperhill, Tennessee. The Ocoee River rose to a record crest, and state crews had made 68 rescues by early afternoon. Floods like this can build in just a few hours. This guide covers what TEMA reported about the Polk County flooding and how to get official flood alerts. It also covers what to do before and during a flood, and how to use power safely once you're in a dry, safe place.
Heavy rain fell overnight from November 4 into November 5, 2026. It caused flash flooding that hit hardest in the small city of Copperhill. The Ocoee River set a record crest, and Polk County declared a state of emergency.
Key Facts From TEMA's Flash Report
TEMA's Polk County flood report, posted at 12:48 p.m. on November 5, gives the official picture. Here are the key facts from that report.
What happened
Details from TEMA Flash Report #1
Rainfall
8 to 10 inches overnight in parts of the watershed that affects Polk County
River crest
Record 18.05 feet, per NOAA; below Action stage by 11:00 a.m. CT
Rescues
68, coordinated by TEMA and carried out by the Tennessee Highway Patrol and Tennessee National Guard
Emergency status
Polk County declared a State of Emergency; the State Emergency Operations Center in Nashville was activated at Level 4 (Elevated)
Shelter
The American Red Cross supported an evacuation center at Copper Basin Fire and Rescue
Water and parks
Copperhill Utilities issued a mandatory water conservation notice, and Ocoee River State Park closed
What Copper Basin Residents Should Know
The river fell below Action stage within hours, but recovery was just starting. Families still had to cut back on water use until the conservation notice was lifted.
Live in the Copper Basin? Follow updates from TEMA, Polk County Emergency Management, and your utility. TEMA's online map lists open shelters, and local groups have set up donation funds for flood victims.
Why Mountain Flash Floods Rise So Fast
Steep ground turns heavy rain into fast runoff. Water rushes off hills into creeks, and when several creeks peak at once, the river can climb several feet in a few hours. Towns in narrow valleys feel it first, so the rain upstream matters as much as the rain on your street.
A flood in Tennessee can hit low ground almost anywhere, not just river towns like Copperhill. Storms that bring flooding can also spin up tornadoes in Tennessee, so it pays to plan for both threats.
After rescue and evacuation, the next problem is power. You'll need it for phones, lights, and cold food once it's safe to return.
Power After a Flood: Safe Backup for Shelters and Homes
Never use electrical gear in or near floodwater. Once you're at a dry shelter, or back home after officials say it's safe, a power station can keep phones charged and lights on. A larger unit can also run a fridge, but only once the home is confirmed safe.
Keeping Hope and Lights AliveKeeping Hope and Lights Alive
Safety Rules Before You Plug In
Before you plug anything in, check live conditions. Your local emergency managers and the National Weather Service (NWS) post them. Leaving comes first, and power planning comes second. Keep these rules in mind:
  • Keep any power station away from rain, standing water, and wet floors.
  • Never connect an appliance that sat in floodwater.
  • Don't plan risky hookups or wiring work in flood conditions.
  • Leave any repair of wet outlets or wiring to a licensed electrician.
What to Power First
On battery power, every watt counts. Rank your needs before you plug anything in:
  1. Communication: Phones and a weather radio come first, so you can reach family and hear new alerts.
  2. Light: LED lamps and flashlights draw very little power and make a dark shelter or home much safer.
  3. Medical devices: If someone relies on powered medical gear, ask their provider for a backup plan and check the maker's battery advice.
  4. Food: A fridge comes last, and only in a home that officials have cleared.
Timing matters for food. The CDC food safety guidance says a closed fridge keeps food safe for up to 4 hours without power. A full freezer holds for about 48 hours, and a half full one for about 24 hours. After 4 hours without power, the CDC says to throw out refrigerated foods like meat, fish, eggs, milk, and leftovers.
Gas Generator vs Battery Power Station
A gas generator can work outdoors, but it brings real risks in a flood zone. Here's how the two options compare.
Factor
Gas generator
Battery power station
Where it runs
Outdoors only, at least 20 feet from doors, windows, and vents, per the CDC
Indoors in a dry room, with no exhaust fumes
Fuel
Needs gas, which may be hard to find after a flood
Recharges from a wall outlet, a car, or solar panels
Noise
Loud enough to bother a crowded shelter or neighbors
Quiet enough for a shared room
Runtime
Runs as long as you refuel it
Limited by battery capacity and the load you connect
Neither option makes wet wiring or flooded appliances safe. Both only help once you're in a dry place and the circuits you use have been checked.
Choosing the Right Power Station
After a flood, you first need a charged phone and some light. Later, once officials clear your home, cold food matters more. EcoFlow portable power stations can cover both stages if they stay well away from water.
At a shelter or a relative's home, a 1kWh unit can keep phones, a weather radio, and a lamp going for many hours. It's also light enough to carry when you have to leave, and the EcoFlow DELTA 3 Classic fits that job.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Once your home is confirmed safe and dry, the power may still be off. A 3.7kWh unit can keep the fridge running for a limited time, and extra batteries can extend it if repairs drag on. The EcoFlow DELTA 3800 Gen4 is built for that second stage.
•Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. •Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴ . •Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3-4kWh capacity and 3,600W output. •4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery. • UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs.
As of November 10, 2026, EcoFlow's US page says the EcoFlow DELTA 3800 Gen4 ships in late November. Check delivery timing, and don't count on it for an outage happening now.
How Long Will It Last? (Estimates)
These are rough estimates: rated capacity times 0.85 for losses, divided by the load in watts. Check your own device labels.
Example load (estimate)
Watts used
EcoFlow DELTA 3 Classic (about 870Wh usable)
EcoFlow DELTA 3800 Gen4 (about 3,199Wh usable)
Phones, weather radio, and LED lamp (assumed combined draw)
About 30W
About 29 hours
About 107 hours
13.9 cu ft fridge (about 38W average) plus 20W of lights
About 58W
About 15 hours
About 55 hours
The fridge figure comes from an ENERGY STAR fridge listing for a 13.9 cu ft model rated at 332 kWh a year. Real use rises in a warm room or when the door opens often.
Flooding and outages often go together. Steps for preventing flash flood disasters include planning your power before the storm ever arrives.
Power is one piece of the puzzle. The bigger part of flood safety is acting on alerts.
Flood Alerts in Tennessee: Watches vs Warnings
The NWS issues flood watches and warnings for Tennessee from its offices in Morristown, Nashville, and Memphis. A warning means you act now, not later. Sign up for local alerts before the next storm.
How Each Flood Alert Compares
The NWS flood alert guide explains what each alert means. Here's how they compare.
Alert
What NWS says
What to do
Flash Flood Warning
Issued "when a flash flood is imminent or occurring"
Move to high ground right away if you're in a flood prone area
Flood Warning
Issued "when flooding is imminent or occurring"
Take action and follow local orders
Flood Watch
Issued "when conditions are favorable for flooding"
Get ready and keep checking updates
Flood Advisory
Flooding isn't expected to be bad enough for a warning, but it "may cause significant inconvenience"
Stay alert and avoid low roads
Where to Get Tennessee Flood Alerts
Each alert names its area and how long it lasts. A warning for the next county can still matter if you drive through it or its rain drains toward you.
Checking Tennessee flooding today? Start with your local NWS forecast page. Then follow TEMA and your county emergency management office for shelter and road news. Keep Wireless Emergency Alerts turned on, since a warning can come in the middle of the night. Alerts are your best early clue for flooding in Tennessee.
Watch and warning wording trips a lot of people up. Knowing flash flood warnings versus watches can save you critical minutes.
Here's what to do once that alert comes in. The steps below cover the hours before, during, and after the water rises.
Flood Safety: Before, During, and After
Get to high ground fast. Never drive through water. Stay out of floodwater after the storm, too. These steps apply to all kinds of floods in Tennessee, from slow river floods to fast flash floods.
Prevention Today, Protection TomorrowPrevention Today, Protection Tomorrow
Before a Flood
Every flash flood Tennessee has faced is a reminder that time can run short. Plan ahead while the sky is clear:
  • Know the fastest route to higher ground from home, work, and school.
  • Pack a go bag with medicine, papers, chargers, and a flashlight.
  • Keep phones and a power station charged when storms are in the forecast.
  • Check on neighbors who may need help, such as older adults and people with medical needs.
  • Take photos of your belongings, and ask your agent about flood insurance, since standard homeowners policies usually don't cover floods.
During a Flood
TEMA's message during the flooding Tennessee saw in Polk County was simple: "Do not drive through flooded roadways. Turn around, don't drown." Anyone in immediate danger should call 9-1-1. Be ready to leave right away if officials tell you to go.
Don't walk through moving water, even if it looks shallow. Roads can wash out under the surface, and you can't see the damage.
After a Flood
Go home only when officials say it's safe. Floodwater can hide debris and other hazards, so stay out of it. Don't use outlets or appliances that got wet until an electrician checks them.
If you use a gas generator, follow CDC generator safety advice. Never run it inside your home, garage, or carport. Keep it outside, at least 20 feet from doors, windows, and vents. Follow any water notice from your utility until it's lifted.
During cleanup, wear boots and gloves, and photograph damage before you throw anything out. For food from a fridge without power, the CDC's rule is: when in doubt, throw it out.
The basics of how to survive a flash flood apply anywhere in the state. Learning them now beats learning them during the next round of Tennessee floods.
On November 5, 2026, 8 to 10 inches of rain caused record flash flooding in Polk County, and TEMA reported 68 rescues and a county state of emergency. Sign up for alerts, act on warnings, turn around at flooded roads, and keep power gear dry. The EcoFlow DELTA 3 Classic covers phones and lights at a shelter. Once your home is safe, the EcoFlow DELTA 3800 Gen4 can run a fridge for a limited time, so check delivery timing first.
What happened with the Tennessee flooding in November 2026?
Overnight rain of 8 to 10 inches hit parts of the watershed above Copperhill on November 5, 2026. TEMA said the Ocoee River crested at a record 18.05 feet and that crews made 68 rescues. Polk County also declared a state of emergency.
Where can I get Tennessee flood alerts?
Use the NWS forecast for your area, since it posts every watch and warning. TEMA and your county emergency management office share shelter, road, and water updates. Keeping phone emergency alerts turned on adds one more layer.
What is a flash flood warning?
The NWS issues one when a flash flood is imminent or already happening. If you're in a flood prone area, move to high ground right away. Don't wait to see how high the water gets.
Is it safe to drive through floodwater?
No, it isn't. TEMA's advice is "Turn around, don't drown." Water can hide a washed out road, and you can't tell how deep or fast it is.
Can I use a power station after a flood?
Yes, but only in a dry, safe place, and never in or near water. Don't plug in appliances that sat in floodwater until an electrician checks them. Wait for officials to clear your home before you use a power station there.
Power Outages
