Tornadoes in Tennessee: Stay Safe and Powered with EcoFlow
With the eastward shift of the infamous Tornado Alley, storms in Tennessee are now more frequent and severe than ever before, especially in spring and late fall. Knowing how to prepare and having the right tools can mean the difference between danger and safety. From identifying safe rooms and building an emergency kit to securing reliable backup power, this guide walks you through how to protect your household. Now, let’s get prepared so you can stay connected and powered through the next storm.
When Is Tornado Season in Tennessee?
The changing of the seasons and the blending of cold and hot air masses lead to increased tornado activity throughout Tennessee, but especially in the western and middle portions of the state, now that the infamous “Tornado Alley” is shifting eastward from the Great Plains and into the Volunteer State. This happens mainly in the spring from March to May, peaking in April. However, a secondary peak occurs in November as the seasons change again.
How To Stay Updated on Tennessee Tornado Warnings
  1. Listen to your local commercial radio or television channels.
  2. Check Nashville Severe Weather for alerts in the Nashville area.
  3. Check for alerts on the National Weather Service.
  4. Listen for Wireless Emergency Alerts (WEA) on your phone (similar to an Amber Alert).
  5. Check to see if your local community has an emergency alert system and sign up for it. Also, check to see if your community has a tornado siren and familiarize yourself with the sound.
  6. Listen to NOAA Weather Radio (requires a special receiver).
  7. Check for Emergency Alert System (EAS) alerts.
  8. Install a weather app on your phone.
  9. Use your EcoFlow RAPID Magnetic Power Bank to keep your phone charged up if the power goes out.
How To Prepare for a Tornado in Tennessee
The best way to keep you and your family safe is to take action now to prepare for emergencies before one strikes.
Identify Safe Rooms or Tornado Shelters
First, locate the nearest safe room or storm shelter according to FEMA standards or the closest thing to it you can find. Basements, cellars, and interior rooms with cement walls are ideal. You must locate one at home, work, school, and other locations where you and your family spend a lot of time. A typical tornado warning only gives you about 10 minutes to find safety, so you won’t have time to drive to one, and driving during tornadoes puts you in serious danger. This is why identifying safe areas in advance is critical.
Watch For Warning Signs
Tornadoes strike with little to no warning, so learning to watch for the signs of a developing tornado yourself could save your life. Don’t wait for an emergency alert if you see the following signs; immediately seek shelter:
  • Dark skies even in daytime, often with a greenish hue
  • A loud roar, similar to a passing freight train
  • Dark, low, rotating, or funnel-shaped clouds
  • Approaching debris clouds
Prepare Your Emergency Kit
Every home should have an emergency kit to help prepare for storms and other emergencies. Keep your kit in a waterproof bin in your storm shelter, safe room, or near the door if you need to leave your home to find safe shelter. Ensure your kit contains the following:
  • 1 gallon of water per day per person for 3 days
  • Non-perishable food for each person for 3 days
  • Food and water for your pets
  • Complete first aid kit
  • Any necessary prescription drugs
  • Dust masks
  • Soap, toilet paper, hand sanitizer
  • Emergency whistle
  • Rechargeable LED flashlights
  • Can opener, eating utensils
  • Multi-tool and duct tape
  • Lighter or matches in a waterproof container
  • Fire extinguisher
  • The EcoFlow DELTA 3 Plus portable power station charges flashlights and devices so you can stay safe, connected, and informed
Prepare a Family Communication Plan
In addition to your emergency kit, you also need an emergency plan. Everyone in your family should know who to contact in an emergency, how to contact them, what to do if a family member isn’t home, and have a backup meeting place in case your house is unsafe. They also need to know exactly what to do and where to seek shelter, whether at home, work, or school.
Finally, they also need to know where the emergency kit is located, what’s in it, and what to do with the contents, including some basic first aid. You should practice a yearly drill so everyone in your family can act out their roles to ensure they know what to do. Your yearly drill is also the perfect time to refresh your water, food, and medical supplies and ensure flashlights are charged.
Purchase an Emergency Power Supply
Power outages are common after storms; if the damage is severe, they could last several days. A household emergency power supply will help keep your family safe and ensure that essential appliances like refrigerators, freezers, medical equipment, routers, and computers stay running. The EcoFlow DELTA Pro 3 is the best storm generator since it offers 4000W output and can power 120V and 240V appliances. It’s also expandable with extra batteries, providing enough power for a complete whole-home generator.
The EcoFlow DELTA Series Solar Generators are also the best for use indoors since they use no fossil fuels and will not cause carbon monoxide poisoning, which kills 400 people every year in the USA. The power station comes in various capacities to suit everyone’s needs, and they come with solar panels so you can stay powered up even during extended blackouts. If you have rooftop panels installed, now is a good time to inspect them, ensuring their mounts and connections are secure to help prevent storm damage. For those using portable solar panels, just wait until all signs of the storm have passed before going outside to set them up.
What To Do When a Tornado Hits Tennessee
When the inevitable eventually happens, follow these steps carefully to help you stay safe.
  1. When you hear an emergency alert or see the warning signs of an approaching tornado, immediately seek safe shelter.
  2. Stay indoors, and do not try to drive to a shelter.
  3. For buildings without safe rooms, head to the lowest floor and find the most interior location, putting as many interior walls between you and the outside as possible.
  4. Stay away from all doors, windows, and glass.
  5. Climb inside an interior closet or under a sturdy desk or table if available.
  6. If you’re outdoors or in your car, head to the nearest sturdy building and get inside. If none is available, seek a ravine, ditch, or other low point in the landscape and climb inside, getting as low as possible.
  7. Crouch down low and cover your head and neck with your arms.
  8. Stay tuned to emergency alerts for updates. Use your EcoFlow Portable Power Station to keep your devices charged so you can stay connected.
  9. Do not yell for help if you get trapped to avoid inhaling dust. If you have an emergency whistle, use it or bang on pipes to make a lot of noise.
  10. Never leave unless you have a critical medical emergency. The roads and buildings may be unsafe, and you must keep the streets clear for emergency responders.
Are Tornadoes Common in Tennessee?
Tornadoes are relatively common in Tennessee and have been becoming more common, increasing from 19 per year on average to 31 per year on average ever since Tornado Alley started shifting eastward from the Great Plains into Tennessee.
Is Tennessee in Danger of Tornadoes?
Yes, Tennessee is more at risk from tornadoes than in the past, with an increase from an average of 19 per year to 31 per year. Tennessee also experiences tornado outbreaks, severe EF3s like the one in early spring of 2025, occasional EF4s, and the most deadly EF5 tornadoes.
Tornadoes are becoming more frequent and severe in Tennessee, making preparation more critical than ever. Knowing when tornado season peaks, how to monitor warnings, and what steps to take before, during, and after a storm could save your life. Also, build your emergency kit, make a family communication plan, and invest in a reliable backup power source. The EcoFlow DELTA Series Solar Generators are perfect for powering essential devices during outages since they produce no toxic fumes, making them perfectly safe to use indoors. Stay prepared and stay safe, everyone!
Home Backup
