Off-Grid Water Heater Options: How to Get Hot Water Without the Grid
Hot water can be one of the biggest challenges in an off-grid cabin, RV, or small home. Heating it takes a fair amount of energy, so the right setup depends on how much water you use and which fuel sources you have available. Options include propane tankless heaters, solar thermal systems, wood-fired heaters, and small electric tanks. Some need little or no electricity, while others rely on a battery to run their controls or heating elements. This guide compares the main options and explains how to plan the power they need.
Off-Grid Water Heater Options Compared
The heat source determines what an off-grid water heater needs to operate. Propane, sunlight, wood, and electricity all have different installation and maintenance requirements. Start by looking at your daily hot water use, available fuel, and the space where you plan to install the heater.
Type | Heat source | Needs electricity? | Best for |
Propane tankless (indoor or outdoor) | Propane | Many models: 120V for controls and fan | Cabins, homes with propane |
Portable propane tankless | Propane | Some use batteries for ignition | Camps, outdoor showers |
Solar thermal | Sun | Active systems: a pump and controller | Sunny sites with storage |
Wood-fired | Wood | Usually none | Remote cabins with wood supply |
Small electric tank (point-of-use) | Electricity | Yes, the element itself | Sinks, small cabins with solar or batteries |
Propane tankless water heaters
Propane tankless heaters warm water as it flows through the unit, making them a practical choice for cabins with a steady propane supply. Many indoor models also need electricity for ignition, controls, and fans. For example, the Rinnai RUCS75i uses 120V AC and draws 89W during normal operation, with 1.3W standby consumption and 167W for anti-frost protection. Some portable models use batteries for ignition, but outdoor-only units must stay outside.
Solar thermal water heaters
Solar thermal systems use collectors to absorb sunlight and heat water for storage. Active systems need electricity to run pumps and controllers, while passive systems can circulate water without an electric pump. Roof angle, shading, and local weather affect performance, so check solar water heater placement before choosing a system.
Wood-fired water heaters
Wood-fired heaters burn wood to heat water directly or through a storage tank. They usually don't need electricity, but you'll need a steady wood supply and a suitable installation. Follow the manufacturer's instructions for ventilation, clearances, and fire safety.
Small electric tank water heaters
Small point-of-use tanks supply hot water to nearby fixtures, such as a kitchen or bathroom sink. Rheem's range includes 2.5- to 30-gallon models, with some 120V units rated at 1,440W. A battery must handle both the heater's running wattage and the energy needed to heat the water, so include it in your off-grid power plan.
Powering an Off-Grid Water Heater: Controls, Pumps, and Small Electric Tanks
Gas tankless heaters use electricity for ignition, controls, and fans, while small electric tanks need more power to heat water. The EcoFlow DELTA 3 Classic can run compatible 120V gas heater controls, fans, and small water pumps. The EcoFlow DELTA 3 Max Plus can support a suitable 120V small electric tank and offers expandable battery capacity. Both can recharge with solar panels, but neither is designed for 240V heaters or high-power electric tankless models. Check your heater's voltage, wattage, startup demand, and grounding requirements before connecting a power station.
A small 120V electric tank under a sink needs more power because its heating element draws well over 1,000W while running. You'll need a power station with enough output and battery capacity to handle that load, with room to expand if you use hot water regularly.
How the two products divide the job
The EcoFlow DELTA 3 Classic can power compatible 120V gas heater controls, fans, and small external water pumps. The EcoFlow DELTA 3 Max Plus can support a suitable 120V point-of-use electric tank, with extra battery capacity available if needed.
Energy estimates:
Load (example) | Energy used per day | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3 Max Plus (2,048Wh × 0.85 = 1,741Wh) |
Gas tankless controls at 89W while running, 1 hour a day (Rinnai RUCS75i example) + 1.3W standby | about 120Wh | about 7 days | about 14 days |
1,440W point-of-use tank, 1.5 hours of element time a day (placeholder) | about 2,160Wh | not suitable | under 1 day without solar or expansion |
These are estimates based on 85% usable battery capacity. Actual runtime depends on power consumption, conversion losses, and operating conditions. The electric tank estimate assumes 1.5 hours of heating per day; actual heating time depends on water use and incoming water temperature. To estimate daily energy use, multiply the appliance's wattage by its running hours. Then divide the battery's usable capacity by that figure. For more details, see our guide to powering a tankless heater with a battery. Once you've planned the power supply, the next step is choosing a heater that matches your daily hot water needs.
Sizing an Off-Grid Water Heater for Your Water Use
Choose a heater based on the hot water you use each day. A cabin with one sink has different needs from a home where several people shower, wash dishes, and do laundry. Start with the fixtures you plan to use and whether they'll need hot water at the same time.
List your daily hot water needs
Make a simple list of the places where you use hot water:
Kitchen sink: Washing dishes, rinsing food, and cleaning cookware.
Bathroom sink: Handwashing and everyday grooming.
Shower: Daily showers, including how many people use the system.
Laundry: Hot water for a washing machine, if you plan to run one.
You can measure a fixture's water flow with a bucket and a timer. Run the water for a set period, measure how much the bucket collects, and use that result to estimate your daily demand. Repeat the process for the fixtures you expect to use regularly. If several fixtures may run at once, account for that when choosing a tankless heater. A tankless model's capacity is usually listed in gallons per minute at a specified temperature rise. A storage tank, on the other hand, is rated by the number of gallons it holds. Check the product specifications and compare them with your expected use.
Account for cold weather and water storage
Cold incoming water makes a tankless heater work harder to reach the set temperature. In freezing weather, protect exposed pipes, pumps, and the heater from damage. Some models have electric freeze protection; the Rinnai RUCS75i, for example, lists a 167W anti-frost setting. Include that power use in your battery estimate, and follow the manufacturer's instructions for draining or protecting the system if temperatures drop below freezing.
Off-grid water heater safety: Venting, CO, and freezing
Most propane and wood-fired water heaters burn fuel, so installation and ventilation need careful attention. A battery can supply power to a compatible control board or fan, but it doesn't remove the risks associated with combustion. Follow the heater manufacturer's instructions and keep carbon monoxide alarms working.
Follow the heater's venting requirements
Indoor gas water heaters need proper venting to carry combustion gases outside, along with the required air supply and clearances. Have a qualified installer handle the setup if you're unsure about the requirements. Keep outdoor-only portable propane heaters outside; never use them in cabins, garages, RVs, tents, or other enclosed spaces. The CPSC's carbon monoxide guidance also warns against using fuel-burning portable heaters or lanterns while sleeping in enclosed spaces.
Install and maintain carbon monoxide alarms
Carbon monoxide has no smell, so you can't rely on your senses to detect it. Install carbon monoxide alarms near sleeping areas and on each level of your home, following the alarm manufacturer's placement instructions. Use battery-operated alarms or models with battery backup where appropriate, and check them regularly. If an alarm sounds or anyone experiences possible carbon monoxide symptoms, get outside into fresh air and call emergency services. Don't go back inside until the space has been checked and declared safe.
Protect the system from freezing
Water left in pipes, pumps, and heater components can freeze and cause damage. If your system isn't designed for freezing temperatures, drain it or use the manufacturer's approved protection method before a cold spell. Check outdoor connections and exposed plumbing as well as the heater itself. If you rely on a battery for control or freeze protection, account for that power use when estimating capacity. You may need extra storage or a reliable way to recharge during cloudy weather. Your choice of portable solar equipment should account for seasonal sunlight and the location of the panels.
The right off-grid water heater depends on your fuel supply, daily water use, and available power. Propane tankless heaters can provide hot water while using a relatively small amount of electricity for compatible controls and fans. Solar thermal and wood-fired systems offer other ways to heat water, while small 120V electric tanks need more battery capacity. Choose the heat source first, then size the battery for the electrical loads. The EcoFlow DELTA 3 Classic can support compatible gas heater controls and small pumps, while the EcoFlow DELTA 3 Max Plus can support a suitable 120V point-of-use tank within its limits. Check the nameplate and installation requirements before connecting either unit.
What is the best off-grid water heater?
It depends on your fuel supply and how much hot water you need. Propane tankless heaters can suit cabins with propane access, solar thermal systems work well in sunny locations with suitable storage, and small electric tanks can serve individual sinks when you have enough battery or solar power.
Do propane tankless water heaters need electricity?
Many propane tankless heaters need electricity for electronic ignition, controls, and fans. The Rinnai RUCS75i, for example, lists 120V AC power and 89W normal consumption. Some portable models use batteries for ignition, so check the specifications for the exact heater you're considering.
Can a solar generator run a water heater?
A solar generator can power compatible gas heater controls or a small 120V point-of-use electric tank if its output and battery capacity meet the heater's requirements. Heating water uses much more energy than running controls, so check both the wattage and expected daily energy use. Don't connect a 240V heater or a high-power electric tankless unit unless the equipment is specifically rated for that load.
How do I get hot water off the grid without electricity?
A wood-fired water heater can heat water without electricity, and some propane models use battery ignition rather than a grid connection. A passive solar thermal system may also work without an electric pump. Check the installation and safety requirements for each design before choosing one.
Is it safe to use a portable propane water heater indoors?
Only use a portable propane water heater indoors if the manufacturer specifically rates it for indoor installation and provides the required venting instructions. Outdoor-only models must stay outdoors. Fuel-burning equipment can produce carbon monoxide, so follow the manufacturer's directions and maintain working CO alarms.
