Solar Power Inverter for RV Use: How Built-In Inverter-Chargers and All-in-One Power Stations Compare
A solar power inverter for an RV converts 12V battery power into 120V AC for household appliances and outlets. A built-in system pairs an inverter-charger, such as the Victron MultiPlus 12/2000/80 or Xantrex Freedom XC PRO 2000, with a separate battery bank and solar charge controller. The EcoFlow DELTA 3 Max combines an inverter, battery, and solar charging in one portable unit. The term RV solar inverter can mean a standalone inverter, a built-in inverter-charger with a transfer switch, or an all-in-one power station. Each setup handles power differently, and the right choice depends on the appliances you want to run, the battery capacity you need, and how you plan to connect everything to your RV. Here's how the main options compare, including their published output ratings, charging capabilities, and limitations for a typical 30A RV.
What an RV Solar Inverter Does and What Else the System Needs
Solar panels generate DC electricity, and the battery stores that energy for later use. An inverter converts the stored DC power into 120V AC, which most household-style RV appliances use. The inverter is only one part of the setup, though. You also need to account for charging, battery storage, and how power reaches your RV's electrical system.
Part | What it does | Built-in RV system | All-in-one power station |
Solar charge controller (MPPT) | Charges the battery from the panels | Separate unit | Built in |
Battery | Stores energy as DC | Separate 12V bank | Built in (LFP in the EcoFlow DELTA 3 models) |
Inverter | Turns battery DC into 120V AC | Separate or part of an inverter-charger | Built in |
Charger and transfer switch | Charges from shore power or a generator and switches loads between sources | Inside an inverter-charger | AC charging built in; feeds devices plugged into it |
Converter | Turns shore power into 12V DC for RV lights, pumps and the house battery | Already in most RVs | Not a replacement for the RV's converter |
The distinction between an inverter and a converter matters. An inverter makes AC power from DC, while a converter changes AC power into DC. A portable power station doesn't automatically replace either component in your RV. If you're sorting out the difference between these parts, read our guide to RV power stations before choosing a setup.
RV Inverter Comparison: Inverter-Chargers vs. Portable Power Stations
The figures below come from the manufacturers' published specifications and datasheets, checked October 26, 2026. The Victron and Xantrex units require a separate battery bank and solar charge controller, so their listed weights don't include those components.
Product (US, 120V) | Continuous AC output | Surge/peak | Battery included | Solar charging built in | AC charging | RV / transfer connection | Weight |
Victron MultiPlus 12/2000/80 | 1,600W at 77°F (2,000VA) | 4,000W | No (12V bank, sold separately) | No controller listed (add a separate MPPT) | Up to 80A to the house battery | 50A transfer switch | 25 lb |
Xantrex Freedom XC PRO 2000 | 2,000W at 104°F | 4,000W (up to 5 seconds) | No (12V bank, sold separately) | No controller listed (add a separate MPPT) | Up to 100A DC | Transfer relay 30A surge, 24A continuous | 17.1 lb |
EcoFlow DELTA 3 Max (2048Wh) | 2,400W total (20A max per outlet) | 4,800W | Yes, 2,048Wh LFP | Yes, up to 500W PV | Built-in (100 to 120V, 15A input) | No TT-30 outlet; devices plug into its outlets | About 44.8 lb (20.3 kg) |
EcoFlow DELTA 3 Ultra Plus (3072Wh) | 3,600W total | 7,200W | Yes, 3,072Wh LFP | Yes, up to 1,600W PV | Built-in (1,800W) | TT-30R outlet, 30A max | About 74.3 lb (33.7 kg) |
These ratings describe different parts of a power system, so don't compare them by wattage alone. The Victron MultiPlus 12/2000/80 and Xantrex Freedom XC PRO 2000 are inverter-chargers designed for permanent installations. Both use separate batteries and solar controllers. The EcoFlow DELTA 3 models combine the battery, inverter, and solar charging hardware in a portable unit. Temperature can also affect output. For example, the Victron MultiPlus 12/2000/80 is rated at 1,600W at 77°F and 1,450W at 104°F. A setup that works in cool weather may have less available output on a hot summer day.
Two EcoFlow options for RV power
For RV owners who want an inverter, battery, and solar charging in one unit, the EcoFlow DELTA 3 Max and EcoFlow DELTA 3 Ultra Plus offer different output and capacity levels.
For RV owners who need more power and room to expand, the EcoFlow DELTA 3 Ultra Plus offers a larger battery capacity, smart output controls, and flexible charging options.
The EcoFlow DELTA 3 Max works well for RV owners who need to run compatible appliances at different times, such as a fridge and coffee maker. For higher combined loads or more stored energy, the EcoFlow DELTA 3 Ultra Plus offers greater output, more capacity, and a TT-30R outlet. Neither automatically runs every RV air conditioner or replaces the RV's built-in inverter or converter, so check your appliances' running and startup watts before choosing. For a closer look at how solar inverters work, read our solar inverter guide. Once you know which setup fits your RV, the next step is to calculate how much power your appliances actually need.
How to Size an Inverter for RV Loads
The right inverter size depends on which appliances you want to run at the same time. You also need enough surge capacity for equipment with motors or compressors, such as refrigerators and air conditioners. Use this process before buying an inverter for your RV:
List your 120V appliances. Check each appliance's label or manual for its running wattage. Include the refrigerator, microwave, coffee maker, and air conditioner if you plan to run them on inverter power.
Add the loads that will run together. Keep the combined wattage below the inverter's continuous output rating. Don't use the surge rating as your everyday operating limit.
Check startup demand. Motors and compressors can draw more power when they start. Make sure the inverter's surge rating can handle that brief demand.
Account for battery capacity. Wattage tells you how much power the inverter can supply at once. Battery capacity, measured in watt-hours (Wh), helps estimate how long the system can run those loads.
Check DC current and wiring. A 12V inverter supplying 1,600W draws about 133A before losses. The cable size, fuse, and battery connections must be rated for the actual current.
What does a 30A RV need?
A 30A RV connection supplies up to 3,600W at 120V, but that doesn't mean you need a 3,600W inverter. Add up the running watts of the appliances you'll use together, then check their startup demands and how long you need them to run. A 2,400W inverter with a 2,048Wh battery may suit smaller loads, but high-wattage appliances drain the battery faster. For permanent installations, have an RV electrician check the wiring, fuses, and battery setup. If you're using solar, make sure your solar panels meet the power station's voltage, current, and wattage limits.
Connecting an RV Inverter or Power Station Safely
A built-in inverter-charger is wired into the RV's AC system and uses a transfer switch to manage power sources. A portable power station can power devices plugged directly into its outlets. Some models, including the EcoFlow DELTA 3 Ultra Plus, also have a TT-30R outlet for a compatible 30A RV connection. The connection method matters as much as the inverter's output rating. Follow these rules before powering your RV:
Never connect two power sources at once. Don't connect a power station to the RV's shore inlet while the RV is still plugged into a campground pedestal or generator.
Use the correct connection hardware. A 30A RV connection needs hardware rated for that service. Don't improvise a connection or use an adapter that bypasses electrical protection.
Check the converter. When a power station feeds the RV, the RV's converter may try to charge the house battery from that same source. Check the RV manual for how to control the converter and avoid unnecessary power draw.
Avoid a charging loop. Never plug the power station's own charging cable into an RV outlet that the same power station is powering.
Keep outlet ratings in mind. The EcoFlow DELTA 3 Max has a 20A maximum per outlet, while the EcoFlow DELTA 3 Ultra Plus has four 20A outlets and one 30A TT-30R outlet. The total output limit still applies.
Leave permanent wiring to a professional. An RV electrician should install a fixed inverter, transfer switch, or shore-power connection and confirm the system meets applicable requirements.
If you only need power for a laptop, phone, or small appliance, plugging it directly into a portable power station is usually the simpler arrangement. Feeding the RV's full electrical system requires more care because the converter, shore inlet, and existing wiring all affect how power flows.
Choosing a solar power inverter for your RV comes down to what you need to run and how you want to set up your power system. A built-in inverter-charger works with a separate battery bank and solar charge controller, while an all-in-one power station combines those parts in one portable unit. Before buying, add up the wattage of the appliances you'll run at the same time. Check their startup demand, the inverter's continuous output, and how you'll connect it to your RV. For everyday AC loads that fit within its 2,400W output, consider the EcoFlow DELTA 3 Max. If you need more capacity, higher output, or a compatible 30A RV connection, take a look at the EcoFlow DELTA 3 Ultra Plus. Match the unit to your actual power needs before making a decision.
What size inverter do I need for my RV?
Add the running watts of the appliances you plan to use at the same time, then choose an inverter with a continuous rating above that total. Check the startup wattage of refrigerators, microwaves, and air conditioners against the inverter's surge rating. Battery capacity also affects how long you can run those appliances.
What is the difference between an RV inverter and a converter?
An inverter turns 12V battery power into 120V AC for household-style appliances. A converter does the opposite: it turns shore power from AC into 12V DC for RV lights, pumps, and house-battery charging. Most RVs already have a converter, but the exact setup depends on the rig.
Do I need a pure sine wave inverter for an RV?
Pure sine wave output is suitable for sensitive electronics and most household appliances. The Victron MultiPlus 12/2000/80 and Xantrex Freedom XC PRO 2000 list true sine wave output. EcoFlow lists pure sine wave output for the EcoFlow DELTA 3 Max and EcoFlow DELTA 3 Ultra Plus.
Can a portable power station replace an RV inverter?
A portable power station can power 120V devices plugged directly into its outlets. Some models also support a compatible RV connection through a TT-30R outlet. However, a power station doesn't automatically replace the RV's fixed inverter or converter, and a connection to the RV's electrical system must follow the proper safety requirements.
Can an RV solar inverter run the air conditioner?
It can only run an RV air conditioner if the unit's running and startup wattage fit within the inverter's continuous and surge ratings. The battery must also have enough stored energy for the expected runtime. Check the air conditioner's label and the inverter's specifications before connecting it.
