RV Water Heater Maintenance: How to Shut Down, Drain, Clean and Restart Tank and Tankless Units
A cold shower can ruin the start of a camping day. So can a rotten-egg smell coming from the hot water tap. Both are good reasons to put RV water heater maintenance on your regular checklist. The routine depends on whether your rig has a tank or a tankless heater, but the basics are similar: shut off the power and gas, let the unit cool, relieve the pressure, and follow the right cleaning procedure. You'll also want to check the anode rod if your tank has one and winterize the system before freezing weather arrives. A few careful steps can help prevent damage and keep your next trip on track.
Know Which RV Water Heater You Have Before You Start
RV water heaters vary by design, so identify your unit before removing a drain plug or opening a service valve. Tank models hold a supply of hot water, while tankless models heat water as it flows through the system. Their drain points and maintenance needs are different.
Heater type (manufacturer example)
Heat sources
Drain point
Key maintenance item
Tank with anode rod (Suburban 6-gallon SW6D: 12,000 Btu/h gas; optional electric element input listed as 1,440W)
LP gas; optional 120V element on electric models
Anode rod doubles as the drain (Suburban)
Inspect and replace the anode rod
Tank with plastic drain plug
Varies by model
Plastic plug (Winnebago notes some heaters use one)
Drain and flush; no anode to check
Tankless (Truma AquaGo)
LP gas with electric controls
Yellow "Easy Drain Lever" and inlet filter (Truma)
Decalcify on schedule; store the filter for winter
Check the data plate and owner's manual for your heater's exact requirements. Don't assume every tank has an anode rod or that every model uses the same drain plug. Some heaters also use more than one energy source. The gas burner, 120V heating element, and 12V controls serve different purposes, and a battery can't replace the energy needed to run an LP gas burner. If you're reviewing your rig's electrical setup at the same time, EcoFlow's guide to RV power options can help you understand where a portable power station fits into your camping setup. With the heater identified, start by shutting it down safely.
How to Drain an RV Water Heater, Step by Step
Draining a water heater takes more care than removing a plug. Hot water can cause serious burns, and pressure can send water spraying out of the opening. Turn off every heat source and let the unit cool before you begin.
How to Drain an RV Water Heater, Step by StepHow to Drain an RV Water Heater, Step by Step
For tank water heaters
  1. Turn off the heater. Switch off the LP gas heating function and the electric element. If your model has an electric element, turn off its breaker as directed in the manual.
  2. Let the water cool. Wait until the water has cooled to room temperature before opening the drain.
  3. Shut off the water supply. Turn off the RV's water pump and disconnect the city water supply.
  4. Open the faucets. Open a hot water faucet and a cold water faucet inside the RV to help relieve pressure.
  5. Open the pressure relief valve. Follow the manufacturer's instructions to release any remaining pressure.
  6. Remove the drain plug or anode rod. Let the tank empty completely. Keep track of the parts so you can reinstall the correct plug or rod later.
Never turn on the electric heating element while the tank is empty. It can burn out quickly, and running the heater without water can damage the equipment.
Tankless heaters (Truma AquaGo example)
Tankless heaters drain differently from tank models. For the Truma AquaGo, follow these steps:
  1. Turn off the unit and let it cool completely.
  2. Shut off the water supply and open the hot and cold faucets to relieve pressure.
  3. Flip the yellow Easy Drain Lever as directed in the manual to release the inlet filter.
  4. Let the unit drain, then remove and store the filter according to the manufacturer's instructions.
Other tankless models may use different drain valves, so check your owner's manual before starting. Add water heater draining to your RV trip checklist alongside tire, battery, and seal inspections.
Keeping the RV Livable While the Water Heater Is Offline
Maintenance can take longer than expected, especially if you're flushing sediment or waiting for a tankless heater's descaling cycle to finish. You'll still need lights, a charged phone, and perhaps an internet connection. The right portable power station can keep those smaller loads running while the water heater stays switched off.
Match each load to the right port
Start by checking the voltage and power requirements of each device.
  • Lights, phone chargers, and a Wi-Fi router: These can often run from a portable power station's AC outlets or USB ports, depending on their plugs and power requirements.
  • A 12V water pump: The connection must match the pump's voltage and current draw. For example, the SHURflo 4008-101-A65 lists a maximum draw of 7.5A at 12V DC. That's below the 10A rating of the EcoFlow DELTA 3 Ultra Plus car outlet, but the connection still needs suitable wiring and fusing.
  • A 120V water heater element: Consider this only after the tank is completely full. Check the heater's data plate to confirm its actual wattage and voltage before connecting it.
Gas heating is different. A battery can run compatible electrical controls, but it doesn't supply the energy for an LP gas burner.
Labeled estimates
Battery capacity and the size of the load determine runtime. The following examples use 85% of the rated battery capacity as usable energy. They're estimates, not guaranteed operating times.
Setup
Calculation
Estimate
EcoFlow DELTA 3 Classic: router (12V 2A adapter, 24W ceiling, TP-Link Archer AX55) plus LED lights (example value 20W)
1,024Wh × 0.85 ÷ 44W
About 19.8 hours
EcoFlow DELTA 3 Ultra Plus: 1,440W element running without cycling (after refill)
3,072Wh × 0.85 ÷ 1,440W
About 1.8 hours of continuous element time
Two EcoFlow DELTA 3 models can help keep essential devices running during water heater maintenance. The right choice depends on your power needs and the equipment you plan to connect.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
For longer maintenance sessions or extra power needs, the EcoFlow DELTA 3 Ultra Plus offers expandable capacity and more charging options.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•Smart Output Priority: Choose in the app which outputs stay powered to stretch runtime when it counts. Controlling home circuits requires a compatible home connection installed by an electrician. • Expandable Capacity: 3kWh base, expandable to approximately 11kWh. Pairs with a compatible EcoFlow Smart Generator for automatic start and stop. •6 Ways to Charge: Reaches 0 to 80% in 48 minutes with combined solar and generator charging.
The EcoFlow DELTA 3 Classic can power lights, phones, and Wi-Fi while the heater is offline. The EcoFlow DELTA 3 Ultra Plus offers more capacity and a 12V outlet for compatible water pumps. It can also run a compatible 120V heating element once the tank is full. Check power requirements before connecting equipment. Use properly rated wiring and fuses for 12V connections, and consult an RV electrician if needed. Never power a drained or disconnected heater. If using the RV's 30A cord with the TT-30 outlet, keep the electric heating element off until the tank is full. Neither unit is intended for high-wattage electric tankless heaters. Long maintenance sessions can also drain your house battery. Learn how to keep your RV battery charged. Once the power setup is sorted, move on to flushing sediment, removing scale, and checking the anode rod.
Flushing, Descaling and Checking the Anode Rod
Minerals and sediment can collect inside a tank over time, especially when you regularly fill up in areas with hard water. Tankless units can develop scale in their water passages. The cleaning method depends on the heater type, so follow the instructions for your specific model.
Tank heaters: flush and inspect
After draining the tank, flush out any remaining sediment and inspect the parts that help protect the heater from corrosion and pressure buildup. These checks can help you spot wear before refilling the tank. Once the tank is empty:
  1. Flush the tank with clean water through the drain opening until the water runs clear.
  2. Inspect the anode rod if your model has one. Look for wear and follow the manual's criteria for replacement.
  3. Reinstall the anode rod or drain plug correctly.
  4. Check the pressure relief valve according to the manufacturer's instructions.
An anode rod helps protect compatible tank heaters from corrosion. It's a service part, so inspect it regularly rather than waiting for a problem to appear. The replacement schedule varies with the heater and water conditions. Use the guidance in your own manual instead of applying a rule from another model. If your heater uses a plastic drain plug, don't look for an anode rod that isn't there.
Tankless heaters: decalcify on schedule
Tankless heaters need periodic descaling instead of tank flushing. For the Truma AquaGo, the manufacturer recommends decalcification after every 1,585 gallons of water use. That can work out to roughly once a year for light to moderate use, although hard water may call for more frequent service. Truma's process uses its specified decalcification tablets and can take up to three hours. Once the process starts, it can't be stopped midway. Read the instructions for your particular control panel and gather everything you need before beginning.
Task
Tank heater
Tankless heater (Truma AquaGo)
Main cleaning job
Drain and flush sediment
Decalcify with Truma tablets
How often
Depends on water quality (Suburban)
Every 1,585 gallons, about yearly for light use (Truma)
Part to inspect
Anode rod (if equipped)
Inlet filter
Time to plan
Varies depending on model and sediment buildup
Up to 3 hours, can't be stopped (Truma)
If you often camp without hookups, remember that water quality can change from one campground to the next. Your dry camping plan should account for both your water supply and the power you'll need to run essential devices.
Winterizing the Water Heater, Then Refilling Before You Heat
Freezing temperatures can damage RV plumbing and water-heating equipment. Before storing your rig for winter, drain the heater and follow the manufacturer's winterizing procedure. In spring, take your time restarting it. An empty tank must never be heated.
Truma AquaGo Easy Drain Lever and removable inlet filter (Truma manufacturer illustration)Truma AquaGo Easy Drain Lever and removable inlet filter (Truma manufacturer illustration)
Winterizing
For a tank heater, drain the water completely and set the bypass valve, if equipped, so RV antifreeze doesn't enter the tank. Follow the manual for any additional steps, including how to protect the drain opening and anode rod. For a Truma AquaGo, use the Easy Drain Lever to drain the unit, then remove and store the inlet filter as instructed. Follow the manufacturer's winterizing guide for the exact model. Don't assume every heater uses the same bypass arrangement or storage procedure. If your rig doesn't have a bypass kit, check the heater manual or ask an RV service professional how to prepare it for storage.
Refilling and restarting
Before using the water heater again, make sure the tank is full and the plumbing is ready. Follow these steps to restore the water supply and restart the heater safely.
  1. Close the drain and reinstall the correct plug or anode rod.
  2. Take the heater out of bypass, if applicable.
  3. Reconnect the water supply and turn on the pump or city water.
  4. Open a hot water faucet and let it run until water flows steadily, which helps fill the tank and push air out of the lines.
  5. Check for leaks around the drain and connections.
  6. Only after the tank is full should you restore gas or electric heating, following the manufacturer's instructions.
This order matters. Operating an electric element with an empty tank can damage the element or other components. If you're unsure whether the tank has filled completely, keep the heating function off until you've confirmed it. Winterizing is also a good time to review other equipment. If your RV uses rooftop solar, check the manufacturer's storage guidance and include your solar equipment in your seasonal maintenance plan.
Good RV water heater maintenance comes down to a safe shutdown, the right cleaning method, and a careful restart. Drain and flush tank heaters, inspect the anode rod if your model has one, and descale tankless units on the manufacturer's schedule. Before winter storage, drain the system and keep antifreeze out of the heater unless the manual specifically directs otherwise. When spring comes, refill the tank fully before turning on any heat source. Read your heater's manual and data plate before your next trip, then set a reminder to inspect it during routine maintenance. If you want power for lights and communications while the heater is offline, the EcoFlow DELTA 3 Classic is a practical option. For compatible 12V pump connections and larger electrical loads, consider the EcoFlow DELTA 3 Ultra Plus after checking the requirements of your RV's equipment.
How do I drain an RV water heater?
Turn off the gas and electric heating element, let the water cool, and shut off the water pump and city water supply. Open a faucet to relieve pressure, then follow your heater's manual to operate the pressure relief valve and remove the drain plug or anode rod. Keep the heater off until the tank is refilled.
How often should I flush my RV water heater?
The schedule depends on your heater model, how often you use it, and your water quality. Follow the manufacturer's recommendations and check for sediment more often if you use water with high mineral content. Regular flushing helps remove buildup that can affect the heater's performance.
Do all RV water heaters have an anode rod?
No. Some tank heaters have an anode rod that also serves as the drain plug, while others use a plastic drain plug. Tankless heaters, such as the Truma AquaGo, don't have a storage tank or tank anode rod. Check your manual to identify the parts your model uses.
How often should I descale a tankless RV water heater?
For the Truma AquaGo, Truma recommends decalcification after every 1,585 gallons (6,000 liters) of water use. Hard water or frequent use may require more frequent servicing. Follow your model's instructions and use the recommended descaling products. Check the manual before starting, as the process can take time.
Can I turn on the electric element with the tank empty?
No. Always fill the tank before turning on the electric heating element. Running it dry can damage the element and other components. After refilling, open a hot water faucet until water flows steadily to help confirm the tank is full. Then restart the heater according to the manufacturer's instructions.
RV and Motorhomes
