Heater in Camper Guide: Choosing a Safe RV Space Heater and Keeping It Running
The first cold night in a camper can catch you off guard. Your propane furnace kicks in, the fan hums through the night, and you start wondering whether a small electric heater might be a quieter or cheaper option. Choosing the right heater in camper setups comes down to three things: your available power source, the electrical capacity you have left, and safety in a compact space. Whether you stay at a campground with hookups or prefer off-grid adventures, understanding your options helps you stay comfortable without draining your batteries or creating unnecessary risks.
Types of Heaters for a Camper and How They Compare
The size of your camper, its insulation, and the circumstances you often camp in all play a role in determining which heater makes sense. Most RVs are equipped with a propane furnace, and portable electric heaters can add a little heat if you’re plugged into shore power.
Heater type | Power source | Best use | Main consideration |
Built-in furnace | Propane and 12V electricity | Heating the whole RV | Uses propane and battery power for the blower |
Ceramic space heater | 120V AC | Quick, targeted warmth | Draws substantial current |
Oil-filled radiator | 120V AC | Quiet, steady heat | Heavy and slow to warm up |
Portable propane heater | Propane | Limited use while awake, if approved for the setting | Carbon monoxide and ventilation risks |
Which Heater Fits Your Camping Style?
A built-in RV furnace is often the most practical choice for cold nights because it distributes heat throughout the vehicle and may help protect plumbing, depending on the RV's design. Electric space heaters work well at campgrounds with electrical hookups, with ceramic models heating quickly and oil-filled radiators providing gradual warmth. A 1,500W heater produces approximately 5,118 BTU per hour, although actual heating needs depend on insulation and outdoor temperatures. Before choosing a setup, explore different power options for RVs to understand how to support your electrical needs. Portable fuel-burning heaters require extra caution, so always follow the manufacturer's instructions and never operate an unvented heater while sleeping.
How to Size an RV Electric Heater for Your Camper's Power
An RV space heater can be one of the largest electrical loads in your camper. Its wattage matters more than its physical size, so check the appliance label before plugging it in. Most RVs use either 30-amp, 120V service or 50-amp, 120/240V service. These systems have different capacities, and the appliances running simultaneously determine how much power remains available.
Do the amp check before you plug in
Check how much power your RV's electrical service can supply. Understanding the relationship between watts, volts, and amps helps you estimate the load, avoid overloading circuits, and determine whether other appliances can run safely at the same time. Use this simple formula:
Amps = Watts ÷ Volts
A 1,500W heater operating at 120V draws approximately 12.5A. A 750W setting, if your heater offers one, draws about 6.25A.
Here's what that means in practice:
30A service: The nominal supply is 3,600W at 120V. A 1,500W heater uses about 12.5A, leaving roughly 17.5A before accounting for other loads.
50A service: An RV typically has two 120V legs, each rated at 50A. The available capacity depends on how loads are distributed and the equipment's limits.
Multiple appliances: A 1,500W heater and another 1,500W appliance draw about 25A combined at 120V if they share the same supply.
Lower heat settings: A 750W setting can reduce the load, but check the heater's label rather than assuming every model offers one.
Remember that other appliances can reduce the available electrical capacity, even when your RV's shore power has a high-rated supply. Understanding how shore power, batteries, and the converter work together through this explanation of how an RV electrical system works can help you manage your power use more confidently. Never modify breakers or wiring to accommodate a heater, and consult a qualified RV electrician if you encounter electrical problems.
Running a Camper Heater Without Shore Power
At a dry campsite, there is no electrical pedestal to plug into. You can use the built-in propane furnace, run a generator where permitted, or power a standard 120V electric heater from a compatible portable power station. Each option has different operating costs, limitations, and safety considerations.
How long can a power station run an electric heater?
A battery's watt-hour capacity determines how much energy it stores, while its AC output rating determines whether it can run the heater. A 1,500W heater consumes energy quickly, so portable power is better suited to short warm-ups than continuous overnight heating. The following figures assume 85% usable energy after conversion losses. They are estimates, not guaranteed runtimes.
Power station | Heater setting | Estimated runtime |
EcoFlow DELTA 3 Max (2,048Wh) | 1,500W | About 1.2 hours |
EcoFlow DELTA 3 Max (2,048Wh) | 750W | About 2.3 hours |
EcoFlow DELTA 3 Ultra Plus (3,072Wh) | 1,500W | About 1.7 hours |
EcoFlow DELTA 3 Ultra Plus (3,072Wh) | 750W | About 3.5 hours |
A thermostat-controlled heater may cycle off periodically, extending runtime, but cold conditions, inverter losses, heater settings, and other appliances can affect how long a battery lasts. Before relying on battery power for heating, review these portable power station runtime considerations to estimate what your setup can realistically handle. The EcoFlow DELTA 3 models offer different storage capacities for limited-time electric heating away from hookups, so choose one based on your heater's power demand and the other devices you need to run.
EcoFlow DELTA 3 Max (2048Wh)
The EcoFlow DELTA 3 Max is an option for campers who want to run one compatible 120V electric heater for a limited period while keeping smaller essentials, such as a phone or router, powered when capacity allows.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
If you need more stored energy for a heater alongside a fridge or other essential appliances, the EcoFlow DELTA 3 Ultra Plus offers a larger starting capacity. Remember that every additional appliance reduces the energy available for heating.
Both EcoFlow DELTA 3 models provide portable power rather than heat, so match your heater's wattage to the unit's continuous output and expect shorter runtimes at higher settings. Before choosing a setup, review how portable power stations can run heaters to understand their limitations and estimate realistic runtime. Whichever power source you choose, prioritize safety in a small living space and follow the heater and power station manufacturers' instructions.
Space Heater for a Camper: Safety Rules That Matter in Small Spaces
A camper puts curtains, bedding, clothes, and furniture close to the heater, making placement and electrical safety especially important. The U.S. Consumer Product Safety Commission (CPSC) estimates that portable heaters, including electric space heaters, were involved in an average of 1,600 fires annually from 2020 to 2022, causing about 70 deaths and 150 injuries per year. Following CPSC's winter heating safety guidance can help you understand essential precautions and reduce risks when heating a small living space.
Maintain clearance: Keep the heater at least three feet from curtains, furniture, bedding, and other combustible materials.
Plug in safely: Connect an electric space heater directly to a suitable wall outlet. Never use an extension cord or power strip.
Turn it off before sleeping: Switch off the heater whenever you go to bed or leave the camper unattended.
Choose safety features: Place the heater on a stable, level surface and choose a model with tip-over and overheat protection.
Prevent carbon monoxide exposure: Fuel-burning heaters can produce carbon monoxide, a dangerous, odorless gas. Keep a working CO alarm installed and test it regularly. Look for an alarm listed for RV use, and never operate an unvented propane heater while sleeping.
If you use a propane heater during cold-weather trips, understanding the hidden dangers of carbon monoxide in winter emergencies can help you recognize the risks and prepare safer backup heating arrangements. Safe heating is easier when your camper loses less heat in the first place. Improving insulation, sealing drafts, and covering windows can help maintain a comfortable temperature while reducing how often your heater needs to run.
Ways to Need Less Heat in a Camper
Reducing heat loss helps your camper stay warm while using less propane or electricity. Simple steps, such as sealing drafts, insulating windows, and covering cold floors, can make a noticeable difference on chilly nights. These improvements are especially useful in older RVs with limited insulation or drafty windows.
Cover windows and vents: Use suitable reflective window covers or thermal curtains at night, without obstructing required ventilation.
Limit the heated area: Close doors to unused sections where appropriate, and concentrate warmth in the occupied living area.
Warm the bed safely: Use suitable bedding, insulated sleeping gear, or a heated mattress pad according to its instructions rather than leaving a portable space heater running while you sleep.
Reduce drafts: Check door seals and window gaps, and park out of strong winds when possible.
Prepare for long stays: RV skirting can reduce cold air circulating beneath a parked camper. Follow campground rules and keep ventilation openings clear.
Cold weather can affect your camper's batteries, plumbing, and water systems, so preparation is essential before an extended trip. Reviewing practical advice on living in an RV during winter can help you plan for cold conditions and manage essential power needs. Before each trip, check the forecast, test your alarms, inspect your heating equipment, and ensure you have enough fuel or stored electricity for the temperatures you expect.
Choosing the right camper heater depends on your power source, electrical capacity, and expected temperatures. Electric heaters work well with sufficient shore power, while a propane furnace can provide heat on colder nights. Before your next trip, check your 30A or 50A service, heater wattage, and carbon monoxide alarm. For limited-time electric heating and essential off-grid devices, consider the EcoFlow DELTA 3 Max. If you need to power a refrigerator and additional appliances, explore the EcoFlow DELTA 3 Ultra Plus.
Can I run a space heater in my camper on 30 amp service?
Yes, provided the total electrical load stays within the service and circuit limits. A 1,500W heater draws about 12.5A at 120V, so account for other appliances before switching them on.
Is it safe to leave an RV electric heater on overnight?
No. The CPSC advises turning portable space heaters off while sleeping. Use suitable warm bedding and follow your RV furnace manufacturer's safety instructions instead.
What size heater do I need for a camper?
The right size depends on the camper's insulation, interior volume, outdoor temperature, and available power. A typical 1,500W electric heater produces about 5,118 BTU per hour, but larger or poorly insulated rigs may need their built-in heating system.
Can a portable power station run a camper heater?
Yes, if the station's continuous AC output supports the heater. A 2,048Wh unit running a 1,500W heater may provide roughly 1.2 hours under the stated assumptions, so it is better suited to limited heating than guaranteed overnight warmth.
Do I need a carbon monoxide alarm if I only use an electric heater?
Yes. Many RVs have propane appliances, including furnaces, stoves, or water heaters. Keep a working CO alarm suitable for RV use, and test it according to its manufacturer's instructions.
