How to Keep RV Water From Freezing on Cold-Weather Trips
You turn on the faucet, hear the water pump kick in, and nothing comes out. On a winter RV trip, that can mean a frozen water line, a blocked inlet, or a tank that's getting too cold. Leave the problem alone, and ice can damage fittings, valves, and plumbing connections. The best protection starts with knowing which parts freeze first. From there, you can hold heat inside the RV, protect exposed plumbing, and run tank heaters when you're away from campground hookups. And when the forecast calls for a prolonged freeze, draining the system may be the safest option.
What Freezes First in an RV (and at What Temperature)
Not every part of your RV's plumbing freezes at the same time. Exposed hoses, dump valves, and tanks underneath the floor lose heat quickly, while pipes inside a heated cabin tend to stay warmer. The National Weather Service (NWS) defines a freeze as a widespread period when surface temperatures are expected to reach 32°F or below for a climatologically significant time. A hard freeze generally means temperatures of 28°F or lower for an extended period. These are weather definitions, not exact freezing points for RV plumbing. Wind exposure, insulation, and how long the cold lasts all affect the risk.
Where RV plumbing is most vulnerable
Check these areas before temperatures drop:
City water hose and inlet: An exposed hose or connection can freeze and block your water supply.
Outside shower: Exposed faucets and lines can lose heat quickly overnight.
Dump valves and sewer hose: Water left inside can freeze and make dumping difficult.
Holding tanks under the floor: Tanks exposed to cold air and wind may freeze sooner than those inside an enclosed space.
Lines in uninsulated storage bays: Pipes in these compartments can freeze even when the living area feels warm.
RVs typically have less insulation than houses, with 1 to 2.5 inches in walls, floors, and roofs compared with 4 to 6 inches in home walls. Some models have a heated, enclosed underbelly to protect plumbing, so check your owner's manual. For more cold-weather advice, see our guide to living in an RV in winter. Next, focus on keeping heat inside and protecting vulnerable plumbing.
Insulate, Skirt, and Heat the Tanks
Start with the basics before buying tank heaters. Blocking cold wind, keeping warm air moving, and protecting exposed connections can reduce the strain on your RV's heating system. If those steps aren't enough, thermostat-controlled tank heater pads can help keep holding tanks above freezing, provided they have a reliable power supply.
Hold heat in first
RV skirting helps block cold wind from reaching exposed tanks and pipes underneath your rig. Keep the furnace running when needed, leave floor ducts open, and open interior doors to help warm air circulate. Open cabinets that hide plumbing, too. A temperature sensor in the water bay can alert you if the area gets too cold.
Protect the fresh water supply and hose
When camping with the furnace running, Winnebago recommends filling the fresh water tank and disconnecting the city water hose. Drain the hose and store it somewhere protected from the cold. A heated hose can help, but it still depends on electricity, and a campground outage can leave it vulnerable to freezing. Check the manufacturer's instructions and remember that a heated hose won't necessarily protect the RV's inlet or internal plumbing.
Keep gray and black tanks from freezing
Keep the gray and black tank dump valves closed while you're camping. Leaving a valve open can allow liquid to trickle into the sewer hose, where it may freeze. When it's time to dump, a fuller tank generally drains more effectively than a tank with only a small amount of liquid in it. For extended cold-weather trips, Keystone says RV antifreeze can be added to gray and black tanks. Use a product made for RV plumbing, and follow the manufacturer's directions. Never use automotive antifreeze in your RV's water or waste system.
Choose tank heater pads that match your setup
Tank heater pads add heat directly to a holding tank. Some run on 12V DC, while others use 120V AC. They aren't interchangeable, so check the label before connecting one. Here are two examples from RecPro's product listings:
Example heater pad | Voltage | Rated draw | Thermostat range |
RecPro 12 × 18-inch pad | 12V DC | 65W, 5A | On at 45°F, off at 68°F |
RecPro 8 × 25-inch pad | 120V AC | 84W, 0.7A | On at 45°F, off at 65°F |
Both examples are rated for holding tanks up to 50 gallons, according to their listings. Check the exact product specifications before buying because pad sizes, electrical requirements, and tank compatibility can vary. Follow the heater manufacturer's instructions carefully. RecPro advises switching the pads off when tanks or pipes are empty, while dumping, and during winterization. The pads also need uninterrupted power to work as intended.
Never plug a 12V pad into a 120V outlet or connect a 120V pad to a 12V supply. Check the pad's voltage and current draw, along with the outlet or circuit rating, before connecting it. Tank heaters and the RV furnace fan both use electricity, so it's important to plan for their combined power needs. Before a cold trip, learn how an RV electrical system works to estimate your needs and avoid overloading your setup.
Powering Tank Heaters and the Furnace Without Shore Power
Without hookups, your RV's house battery may need to run the furnace fan, water pump, lights, and 12V tank heaters. A portable power station can provide extra energy, but the setup depends on whether you're powering a single heater pad or the RV through its electrical inlet. Keep the power station inside the heated living space, within its rated operating temperature range and away from water. The EcoFlow DELTA 3 Max may suit a single tank heater pad, while the EcoFlow DELTA 3 Ultra Plus may suit an RV with a compatible 30A TT-30 inlet. Check your RV's wiring, heater requirements, and product instructions before connecting either model.
For setups that need to power more than a single tank heater pad, the EcoFlow DELTA 3 Ultra Plus offers a larger battery and a TT-30 connection to run compatible RV appliances through the coach's electrical system.
How the two products differ: The EcoFlow DELTA 3 Max can power a single tank heater pad, while the EcoFlow DELTA 3 Ultra Plus may suit RVs that use a compatible TT-30 inlet to power multiple appliances. Before choosing, check the wattage, voltage, and current requirements of everything you plan to run, including the furnace fan. A larger battery provides more stored energy, but it can't guarantee your tanks won't freeze or that power will last through a cold snap.
Example runtime estimates
These estimates show how long each setup might last under continuous use, assuming 85% of the battery capacity is usable. Actual runtimes will vary with conditions and power consumption.
EcoFlow DELTA 3 Max: A 65W, 12V tank heater pad could run for about 27 hours continuously, based on a 2,048Wh capacity and an estimated 85% usable energy.
EcoFlow DELTA 3 Ultra Plus: Two 84W pads and a 50W furnace blower would draw 218W combined, giving an estimated 12 hours based on a 3,072Wh capacity and the same 85% assumption.
These are estimates, not guaranteed runtimes. Actual results depend on heater cycling, temperature, insulation, wind, and conversion losses. The 50W blower figure is an example; use the rating in your furnace manual for a more accurate estimate. A TT-30 inlet is the same type used for campground hookups. Understanding RV shore power can help you assess whether this setup suits your needs. Even with good insulation and a reliable power supply, a prolonged cold snap can overwhelm your RV's heating system.
When to Stop Fighting the Cold and Winterize
If the forecast calls for several days well below freezing and you can't keep the RV warm or recharge your batteries, consider draining the plumbing. Winterizing takes time, but it reduces the chance that trapped water will freeze and damage fittings, valves, or the water heater.
Quick drain for a short cold snap
If you need to protect the system temporarily, Winnebago's guidance recommends emptying the black tank first, then the gray tank, followed by the fresh water tank. Open the low-point drains to let water leave the plumbing. Keep the drains and valves open until you're ready to refill, then close them before using the system again. Check your owner's manual for the exact drain locations and procedure on your RV. Plumbing layouts vary by model, and some systems need additional steps to protect the water heater, pump, and outside shower.
Full winterization
For longer periods of freezing weather, use the winterization method specified by your RV manufacturer. Winnebago describes a wet method that uses RV antifreeze to protect plumbing.
Turn off the water heater. Do this the night before winterizing so the water can cool to room temperature.
Drain the tanks. Empty and clean the black tank, then empty the gray and fresh tanks. Open the low-point drains and close them before adding antifreeze.
Drain the water heater. Disconnect city water and turn off the pump. Open the pressure relief valve as directed by the manufacturer, then close it after draining.
Bypass the water heater. Follow the instructions for your model because valve arrangements differ.
Pump RV antifreeze through the plumbing. Run it through each faucet, hot and cold, as well as the outside shower and toilet. Pour some into each drain to protect the P-traps.
Use antifreeze made for RV plumbing and follow its label. Never substitute automotive antifreeze. Some RV owners use the dry, or air blow-out, method instead. That requires a compressor, regulator, and blow-out plug. The correct air pressure depends on the RV's plumbing, so use the pressure specified in your owner's manual rather than guessing. Turn off tank heater pads after draining the tanks, as RecPro advises. Heater pads aren't designed to run against empty tanks unless the product instructions specifically permit it. If you plan to spend winter away from hookups, compare the practical differences between boondocking and campground camping. Access to water, electricity, and a safe place to drain or winterize can change what works for your trip.
To keep RV water from freezing, protect exposed hoses and valves, hold heat inside the coach, and use tank heater pads that match your power supply. Plan how you'll run those heaters before leaving shore power, and check the forecast each day. If you can't keep the RV warm or recharge the battery during a long freeze, drain and winterize the system. The EcoFlow DELTA 3 Max can suit a single heater pad, while the EcoFlow DELTA 3 Ultra Plus can power a compatible RV through its TT-30 inlet. Always check your manuals before connecting equipment.
At what temperature do RV water lines freeze?
Water freezes at 32°F, but there's no single temperature at which every RV water line will freeze. Wind, insulation, exposure, and how long the cold lasts all affect the risk. The NWS defines a hard freeze as 28°F or lower for an extended period.
Do RV tank heaters work without shore power?
Yes. A 12V tank heater pad can run from a suitable house battery or another compatible power source. It needs a steady supply of electricity, though. If the battery runs down, the pad stops heating and the tank can freeze.
Should I keep my RV water tank full or empty in winter?
If you're camping with the furnace running, Winnebago recommends filling the fresh tank and disconnecting the city water hose. If you'll leave the RV unheated during freezing weather, drain the system and winterize it according to the owner's manual.
Can I put RV antifreeze in my holding tanks while camping?
Keystone says RV antifreeze can be added to gray and black tanks during extended cold-weather trips. Use only antifreeze made for RV plumbing and follow the product directions. Never use automotive antifreeze.
Can a portable power station run my RV furnace?
An RV propane furnace still needs electricity for its fan and controls. A compatible power station, such as the EcoFlow DELTA 3 Ultra Plus, can supply power through the RV's 30A TT-30 inlet when the setup meets the instructions for both systems. Check the manuals for grounding, adapters, and electrical protection, and never back-feed power.
