Solar Panel Sizes: Dimensions, Weight, and How Much Roof Space You Need
Solar panel size sounds like a simple spec, but it actually drives some of the biggest decisions in a solar project. It determines how many panels fit on a roof and how much a full system weighs. It also shapes whether a portable option beats a permanent mount. Standard residential panels run about 65 by 39 inches and weigh 40 to 50 pounds, while portable panels can weigh a third of that. This guide breaks down dimensions, weight, and space requirements by panel type. That way, you can plan a system that actually fits your roof or your setup.
Standard Solar Panel Dimensions: 60-Cell vs. 72-Cell
Solar panels can be described by cell count as well as their physical dimensions, but cell count alone does not determine how a panel is used. Panel size, wattage, efficiency, and mounting requirements all matter when choosing a system.
Traditional residential solar panels commonly used 60-cell designs, while larger 72-cell panels were widely used in commercial and utility-scale installations. Today, many modern panels use half-cut cells, with common configurations labeled as 120-cell or 144-cell. Physical dimensions vary by manufacturer, so the panel's specification sheet is the best source for exact measurements.
60-cell vs. 72-cell panel specs
60-cell (residential)
72-cell (commercial)
About 65 x 39 x 1.5 in
About 77-80 x 39-40 x 1.5 in
Panel area
About 17.6 sq ft
About 20.85 sq ft
Weight
40 to 50 lbs
50 to 60 lbs
Typical output
350 to 400W
415 to 450W+
Some of that size gap comes down to differences between residential and commercial solar projects themselves, not just panel size. Larger buildings need more total output, and they can support heavier equipment too. Some panels also use half-cut cell technology and are labeled 120-cell or 144-cell. These are physically the same size as standard 60-cell and 72-cell panels, just with each cell split in half for efficiency gains.
Exact dimensions vary slightly by manufacturer. Always confirm the specific panel's spec sheet before finalizing a layout or mounting plan.
Those dimensions cover the panel on its own. Pairing the right panel type with the right storage system is the next practical question.
Matching Panel Size to the Right System
Panel size does not exist in isolation. It has to work with a storage system that can actually use what the panel produces.
Rigid, rooftop-style panels in the 400W range are built for permanent installation. They pair with a home battery system to store what they generate for use after the sun goes down. Portable, foldable panels trade raw wattage for size and weight. They work well for RVs, off-grid setups, or anyone who needs to move their solar source rather than mount it permanently.
Whichever panel type fits the use case, the storage system on the other end needs to be sized correctly. It should actually use what the panels produce, not just handle backup duty. Before settling on a system, it helps to look at how panel size affects total output and roof compatibility across different panel types.
EcoFlow 400W Rigid Solar Panel
1. A 23% conversion rate to sunlight 2. All-black design that fits any house style 3. Built to last with an IP68 waterproof rating 4. Fast and Easy Installation 5. Up to a 10-year warranty
EcoFlow 220W Bifacial Portable Solar Panel
1. ollect up to 25% more energy with a two-in-one bifacial design 2. Up to 25% conversion efficiency rate 3. 30-60° adjustable angle bracket and integrated solar angle guide 4. Durable tempered glass & ETFE coating; built to last 5. Lightweight and compact; ultra portable
EcoFlow DELTA Pro 3
1. Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. 2. Maintains stable 120/240V output at 4000W during pass-through charging. 3. Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. 4. EV-grade LFP battery retains 80% capacity after 4000 cycles.
With panel-to-system pairing covered, here is the weight question in more detail. It directly affects what your roof or setup can actually support.
How Much Does a Solar Panel Weigh?
solar panel weightsolar panel weight
Weight is not just a spec-sheet number. It determines what a roof can safely carry and what a portable setup requires you to lift.
Most residential 60-cell panels weigh between 40 and 50 pounds. Larger 72-cell commercial panels typically run 50 to 60 pounds. Weight varies by frame material, glass thickness, and how weather-resistant the panel is designed to be. Most panels use lightweight aluminum framing, and thicker, more durable glass adds weight along with durability.
A full installation adds mounting hardware on top of panel weight. That generally works out to 2 to 3 pounds per square foot once panels and mounting materials are combined. A full rooftop system can add 500 to over 1,000 pounds to a roof, depending on system size. Most modern roofs handle that added weight without issue. Confirming whether a roof can structurally support solar panels is still worth doing before committing to a layout, especially on an older home.
Roof suitability depends on more than weight alone. The U.S. Department of Energy notes that a roof's solar potential depends on its size, the shade it gets, the direction it faces, and its general location.
Those figures are for fixed rooftop panels. Portable panels are a different category entirely, both in size and in weight.
Portable and Foldable Solar Panel Sizes
 Portable and Foldable Solar Panel Sizes Portable and Foldable Solar Panel Sizes
Portable panels are not just smaller versions of rooftop panels. They are built around a different set of priorities entirely.
Portable panels typically use a foldable design built for transport and temporary placement rather than permanent rooftop mounting. Their cell count and physical dimensions vary by model. A 200W-class portable panel can measure roughly 5 to 7 feet long when unfolded, depending on the design. That is smaller than a fixed residential panel's 65 by 39 inch footprint, and it can weigh a third as much or less.
Weight is where portable panels differ most. A folding panel can weigh well under 25 pounds, and some flexible panels weigh closer to 10 pounds. Compare that with 40 or more pounds for a rigid rooftop panel of similar output. That tradeoff, less weight and a smaller footprint in exchange for less total output, is really the whole story here. It is why some people choose flexible solar panels over rigid ones for a specific use case.
Whichever panel size and type fits a specific use case, the practical planning question is usually the same. How many panels, and how much space, does a full system actually need?
How Many Panels (and How Much Space) You'll Need
otal system size drives everything else. Once you know the target output, panel count and roof space follow pretty directly.
Most home solar systems fall between 6kW and 11kW in total capacity, requiring roughly 15 to 28 panels depending on individual panel wattage. Recent national data backs this range up. According to Lawrence Berkeley National Laboratory, a U.S. Department of Energy research lab, the median residential solar system reached 7.4kW in 2023. Most systems fell between 5kW and 11kW.
Using 400W panels at about 17.6 square feet each, a 7kW system needs around 18 panels. That is roughly 317 square feet of panel surface area before accounting for roof setbacks, gaps, walkways, and other required clearances. Higher-wattage panels reduce the total panel count needed for the same system capacity. That matters most for roofs with limited usable space. Every layout still needs clearance from ridges, edges, chimneys, vents, and other obstructions per local code.
Actual panel count always comes down to your household's real energy usage rather than a national average. It helps to work through how many solar panels it takes to power a house of your specific size before finalizing a system.
Standard residential solar panels measure about 65 by 39 inches and weigh 40 to 50 pounds, while commercial 72-cell panels run larger and heavier. Portable panels trade wattage for a fraction of the size and weight. Before finalizing a layout, confirm exact dimensions against the specific panel's spec sheet and have an older roof assessed. Whether you need a permanent rooftop setup or something portable, EcoFlow has options for both. The 400W Rigid Solar Panel, 220W Bifacial Portable Solar Panel, and DELTA Pro 3 cover both ends of that choice.
What is the standard size of a residential solar panel?
Most residential solar panels are 60-cell panels measuring about 65 by 39 by 1.5 inches, or roughly 17.6 square feet. They typically weigh 40 to 50 pounds and produce 350 to 400 watts.
How much does a solar panel weigh?
A standard 60-cell residential panel weighs 40 to 50 pounds. Larger 72-cell commercial panels weigh 50 to 60 pounds, while portable folding panels can weigh well under 25 pounds.
What's the difference between a 60-cell and 72-cell solar panel?
60-cell panels are the residential standard, arranged 10 by 6 cells. 72-cell panels, arranged 12 by 6, are larger, heavier, and typically reserved for commercial and industrial installations.
How big are portable solar panels compared to rooftop panels?
A common 200W portable panel measures roughly 5 feet by 2 feet unfolded, well under the footprint of a fixed residential panel. The EcoFlow 220W Bifacial Portable Solar Panel, for example, weighs about 15.4 pounds folded, a fraction of a rigid panel's weight.
How much roof space do I need for a full solar system?
Using 400W panels, a 7kW system needs around 18 panels and roughly 317 square feet of space. Exact space needs depend on your panel wattage, roof shape, and local code clearance requirements.
Solar Panels
