Solar Energy Examples: How Sunlight Becomes Power, Heat, and Stored Energy
Solar energy shows up in more places than rooftop panels. It runs calculators and yard lights, heats pool water and homes, and powers entire utility-scale plants. Pair it with a battery and it can keep a fridge cold after sunset. The U.S. Energy Information Administration (EIA) sorts solar into two main types: photovoltaic systems that make electricity and solar thermal systems that make heat. This guide walks through each solar energy example, explains how it works in plain words, and shows how home storage turns daytime sunlight into power you can use later.
What Counts as a Solar Energy Example?
Solar energy is energy from the sun. Technologies that capture and convert it are of two basic types: photovoltaic (PV) systems, which generate electricity, and solar thermal systems, which collect heat. A third option combines solar electricity with battery storage so you can use that energy later. According to the U.S. Energy Information Administration, photovoltaic devices generate electricity directly from sunlight. Solar thermal systems work differently by capturing the sun's heat to warm water, air, or other fluids.
1. Photovoltaic Solar Energy
Photovoltaic technology is what most people picture when they think about solar panels. Solar cells contain semiconductor materials, commonly silicon. When sunlight reaches these cells, it creates an electrical current. An inverter then converts the direct current (DC) electricity into alternating current (AC), which most household appliances use. If you want to understand the process behind these systems, learning how sunlight is converted into usable household electricity makes the different applications easier to understand.
PV technology works at different scales:
Small solar cells power devices such as calculators and watches by converting sunlight into electricity.
Outdoor solar lights collect energy during the day and use stored power to provide lighting after sunset.
Rooftop solar panels generate electricity for homes and help run everyday household appliances.
Large solar arrays produce electricity on a larger scale and supply it to the utility grid.
2. Solar Thermal Energy
Solar thermal technology uses sunlight to generate heat rather than electricity. Solar collectors absorb sunlight and transfer the captured heat to water or another fluid, which can then be used for household hot water, swimming pools, space heating, and other applications.
Solar water heaters use sunlight to heat water for bathing, cooking, and other household activities.
Solar pool heating systems collect solar energy to maintain comfortable swimming pool temperatures.
Solar air heating systems absorb sunlight and use the captured heat to warm indoor spaces.
Greenhouse heating systems use solar energy to maintain suitable temperatures for growing plants.
3. Solar Energy With Battery Storage
Solar panels do not have to supply electricity only when the sun is shining. A compatible battery can store electricity generated during the day and make it available later. For example, a portable power station connected to solar panels can charge during daylight hours. You can then use its stored electricity to operate lights, charge a laptop, or power compatible household appliances in the evening. This list builds on the many practical uses of solar energy around the home. One particularly useful example combines solar panels with battery storage.
Solar Energy Example: Storing Solar Power in a Battery
A solar panel charges a power station during the day. The battery stores that energy as electricity, allowing you to use it when sunlight is unavailable. Imagine charging a portable power station on a sunny afternoon. Later, you can connect lights, a laptop, and a compatible 120V refrigerator without relying on direct sunlight at that moment. This setup is useful for camping, outdoor activities, and planned home backup. It also demonstrates an important difference: solar panels generate electricity, while the power station stores and supplies it.
How Does a Solar Battery Setup Work?
A solar battery setup captures energy from sunlight, converts it into electricity, and stores that energy for later use. A portable power station manages the stored electricity and supplies power to compatible household appliances when needed. The process involves four main steps:
Capture sunlight: Solar panels collect sunlight and convert it into direct current (DC) electricity.
Charge the battery: The generated electricity flows through the solar input to charge the portable power station.
Store electricity: The power station's internal battery stores the generated energy for use during nighttime or power outages.
Power appliances: The built-in inverter converts stored DC electricity into alternating current (AC) to operate compatible household devices and appliances.
EcoFlow DELTA Gen4: Turning Daytime Solar Into Evening Power
A clear home example of solar energy is a panel on the deck charging a battery by day, then running lights and a fridge at night. EcoFlow DELTA Gen4 power stations accept solar input and store electricity for later use. They store energy; the compatible panels make it. For a household that wants to demonstrate this complete cycle, a 3kWh power station can provide stored energy for lighting, laptops, and compatible 120V appliances.
EcoFlow DELTA 3000 Gen4
The EcoFlow DELTA 3000 Gen4 is designed for households that want to store solar electricity and use it for everyday backup needs. Its 3kWh capacity makes it an example of how solar storage can support several essential devices and appliances.
EcoFlow DELTA 3800 Gen4
Some households need more stored energy, especially when a refrigerator runs throughout the day or several appliances need backup. A larger battery capacity can provide more flexibility between solar charging opportunities. The EcoFlow DELTA 3800 Gen4 offers 3.8kWh of capacity and two solar inputs, making it a suitable example for longer recharge gaps or setups that may benefit from additional battery expansion.
How Long Can a Battery Power Household Devices?
Battery capacity and appliance consumption determine how long stored electricity lasts. The following figures are estimates, not guaranteed runtimes.
Example load | Average power | EcoFlow DELTA 3000 Gen4 | EcoFlow DELTA 3800 Gen4 |
Lights and laptop | 80W | About 33 hours | About 40 hours |
13.9 cu. ft. refrigerator | 38W | About 69 hours | About 84 hours |
These estimates use approximately 85% of rated battery capacity as usable energy:
Usable capacity (Wh) ÷ appliance load (W) = estimated runtime (hours).
Actual results depend on appliance cycling, inverter consumption, operating conditions, and other connected loads. Before connecting solar panels, check their open-circuit voltage, current, and connector compatibility against the power station's specifications. Solar panels are sold separately. Cloud cover, winter daylight, panel angle, and shading can also affect charging. Storage adds to the benefits of solar energy at home by making some daytime electricity available after sunset. However, battery capacity is finite, so plan around realistic daily consumption rather than assuming unlimited operation.
More Solar Energy Examples
Solar energy can be used in many ways, from powering small everyday devices to supplying electricity for entire communities. Some systems convert sunlight directly into electricity, while others use solar energy to produce heat for water or swimming pools. These examples show how solar technology supports different household, commercial, and utility-scale needs.
Example | Type | How it works |
Calculator or yard light | PV | A solar cell supplies a calculator with electricity, sometimes alongside a backup battery; a yard light typically charges a rechargeable battery for use after dark |
Rooftop solar panels | PV | Panels feed home circuits through an inverter |
Utility-scale solar farm | PV or solar thermal | Large arrays send power to the grid |
Solar pool heater | Solar thermal | Pump moves pool water through collectors (DOE) |
Solar water heater | Solar thermal | Collectors heat water for the home |
Portable power station with panels | PV + storage | Panels charge a battery for later use |
Solar Energy in Small Devices
You probably use solar-powered technology more often than you realize. A basic calculator may contain a small photovoltaic cell that supplies electricity without needing frequent battery replacement. Outdoor solar lights work similarly. Their panels collect sunlight during the day, charge an internal battery, and provide light after dark. These simple applications demonstrate how solar cells convert sunlight into electricity, even when the system is too small to power household appliances.
Solar Energy in Homes and Buildings
Rooftop solar panels are one of the most common ways to use solar energy in homes and buildings. They capture sunlight and convert it into electricity, which an inverter makes available for household appliances and everyday activities. With a properly sized system and battery storage, homeowners can also use solar battery backup during home power outages to keep essential appliances running when grid electricity is unavailable.
Lighting and ceiling fans: Solar panels can generate electricity to run indoor lights and ceiling fans, reducing dependence on grid electricity.
Refrigerators and kitchen appliances: A properly sized solar system can power refrigerators, microwaves, and other kitchen appliances throughout the day.
Computers, televisions, and electronics: Solar electricity can supply power to computers, televisions, Wi-Fi routers, and mobile charging devices for everyday use.
Air conditioning: Solar energy can also run air conditioners, provided the system can meet their starting and running power requirements. Battery storage can help maintain power when sunlight is limited.
Solar Energy in Large Power Plants
Solar farms use large groups of photovoltaic panels to generate electricity on a much bigger scale than residential installations. They can supply electricity to communities and businesses through the power grid. Some utility-scale facilities also use concentrated solar power. Instead of generating electricity directly through PV cells, mirrors concentrate sunlight to produce heat. That heat can create steam to drive a turbine and generate electricity. These installations show how solar power can support electricity production beyond individual homes.
What Affects Solar Output?
Solar panels do not produce the same amount of electricity every day. Their output depends on sunlight availability, installation conditions, and local weather. Understanding these factors helps you choose a suitable system and set realistic expectations.
1. Sunlight and Day Length
Longer daylight hours generally give solar panels more time to generate electricity. Seasonal changes affect this availability. Winter days are shorter in many locations, which can reduce daily production.
2. Cloud Cover and Weather
Solar panels can still produce electricity on cloudy days, but heavy cloud cover reduces the sunlight reaching their cells. Rain, storms, and extended periods of overcast weather can also affect production.
3. Shade and Panel Placement
Trees, nearby buildings, chimneys, and other obstructions can block sunlight from reaching solar panels. Even partial shading can reduce electricity production, so proper panel placement is important for maintaining consistent performance.
Choose a location with plenty of direct sunlight throughout the day to help panels generate electricity efficiently.
Avoid placing panels where trees, buildings, or other objects create unnecessary shade and reduce sunlight exposure.
Clean the panels regularly to remove dust, leaves, and debris that can block sunlight and affect energy production.
Follow the manufacturer's recommended installation angle to ensure panels receive adequate sunlight throughout the day.
4. Temperature and Panel Condition
Solar panels are designed to operate outdoors, but high temperatures can affect their electrical performance. Proper ventilation, suitable mounting, and regular inspection help maintain reliable operation.
5. Battery Capacity and Energy Consumption
Solar panels determine how much electricity a system can collect, while battery capacity determines how much energy can be stored. Your household consumption determines how quickly that stored energy is used. For example, a refrigerator running alongside lights and a laptop requires more energy than a few phone chargers. Understanding how solar panels work when sunlight is unavailable also helps explain why storage matters. Some homeowners also compare solar energy with other renewable energy options when deciding which technology suits their property.
How to Plan for Realistic Solar Production
Planning a solar setup starts with understanding your household's electricity needs and the conditions at your property. A few practical checks can help you choose a suitable system size and battery capacity without expecting more energy than your panels can produce.
Before choosing a solar setup, consider these practical steps:
Review your average daily electricity consumption by checking your electricity bills to understand how much power your household typically uses.
Identify the appliances you want to operate and estimate their electricity requirements to determine the system capacity you need.
Check the available roof or ground space to ensure there is enough room for installing the required number of solar panels.
Evaluate shading throughout the day because trees, buildings, and other obstructions can reduce the amount of sunlight reaching your panels.
Account for seasonal sunlight changes, as shorter days, cloudy weather, and seasonal conditions can affect solar electricity production.
Choose battery capacity based on your actual energy requirements, expected backup duration, and the appliances you want to keep running.
A power station only stores electricity supplied by panels or another charging source. It cannot compensate for insufficient solar generation indefinitely. Some homeowners also compare solar energy versus geothermal energy when exploring renewable energy options. Both use naturally available energy, but they serve different purposes and require different equipment.
Solar energy examples fall into three main categories: photovoltaic electricity, solar thermal heat, and battery storage. From rooftop panels and solar pool heaters to portable power stations, each serves a different purpose. Choose a system based on your energy needs, available sunlight, and shading conditions, and size battery storage according to your actual power requirements. For storing daytime solar energy for later use, consider the EcoFlow DELTA 3000 Gen4 or EcoFlow DELTA 3800 Gen4 with compatible solar panels.
What is an example of solar energy?
Rooftop solar panels producing household electricity, a solar pool heater warming swimming pool water, and a solar-powered calculator are all examples of solar energy.
What are the two main types of solar energy?
The EIA identifies two main types: photovoltaic (PV) technology, which converts sunlight into electricity, and solar thermal technology, which captures sunlight as heat.
How is solar energy used at home?
Homeowners use solar energy to generate electricity, heat swimming pools and household water, operate outdoor lights, and charge battery storage systems.
Can solar power run a fridge?
Yes. A properly sized solar panel and battery setup can power a refrigerator. The system must account for the refrigerator's average energy consumption, startup requirements, battery capacity, and available solar charging.
Does a power station make solar energy?
No. A power station stores electricity supplied by solar panels, a wall outlet, or another compatible source. Solar panels generate electricity, while the power station stores and supplies it when needed.
