Solar Tax Credit 2026 for Businesses: Commercial Solar Cost Per Watt, Deadlines, and a Worked ROI Example
- Which Commercial Solar Projects Still Qualify for the Federal Tax Credit in 2026?
- How Much Does Commercial Solar Cost Per Watt, and What ROI Is Realistic?
- Will Commercial Solar Keep the Office Running in a Power Outage? A Separate Backup Budget Note (EcoFlow TITAN 5000 Classic)
- Commercial Solar Options Compared: Ownership, Mounting, and Storage
- How to Vet a Commercial Solar Quote Before the 2027 Deadline
- Conclusion
- FAQs
No panel qualifies on its own; the whole commercial project must meet Section 48E. That credit still applies in 2026, but solar projects that began construction after July 4, 2026 must be placed in service by December 31, 2027. Systems under 1 MW AC can reach 30%. DOE's 2025Q1 benchmark prices commercial rooftop PV near $1.98 per watt.
The calendar now matters just as much as hardware pricing. A business breaking ground today has roughly 14 months to finish work. On top of that, strict foreign supplier rules now apply to new arrays. Below, we break down sourced cost benchmarks, a step-by-step ROI model, and an installer quote checklist.
The federal commercial solar tax credit operates under Section 48E, the Clean Electricity Investment Credit. The older Section 48 credit generally no longer provides a credit for new solar property beginning construction after 2024. Eligibility now depends on the project's construction date, completion date, size, labor compliance, and equipment supply chain.
New commercial solar projects beginning construction in 2026 and placed in service after 2024 may qualify for the Section 48E clean electricity investment credit. Legacy solar projects that began construction before 2025 may instead qualify under Section 48; a tax advisor should confirm which regime applies. In 2026, eligibility hinges on start dates, completion deadlines, system size, and equipment sourcing.
Federal law changed how clean energy incentives operate through Public Law 119-21. For solar energy property, the Section 48 credit dropped to 0 percent for builds starting after December 31, 2024. All new commercial solar now flows directly through Section 48E. Knowing how commercial and residential solar differ helps explain why a business can still claim a credit that homeowners lost after 2025.
Key statutory deadlines and rules
Under 26 U.S.C. 48E and IRS Notice 2025-42, commercial installations must navigate specific project milestones:
The December 31, 2027 Cutoff: Wind and solar facilities that begin construction after July 4, 2026 must be placed in service by December 31, 2027. If your build misses that date, the tax credit drops to zero.
Beginning of Construction: For facilities subject to Notice 2025-42, the Physical Work Test generally requires significant work on site or at the factory. Low-output solar facilities no greater than 1.5 MW AC may instead use the Five Percent Safe Harbor, subject to the notice's aggregation rules. The notice does not apply to facilities that began construction before September 2, 2025.
Continuity Safe Harbor: Projects started on or before July 4, 2026 avoid the 2027 cliff if placed in service by the end of the fourth calendar year after the year construction began (for example, December 31, 2030 for a 2026 start). Projects outside that safe harbor must establish continuity based on the relevant facts and circumstances.
Prohibited Foreign Entity Rules: Under Section 48E(b)(6), construction starting after December 31, 2025 cannot include material assistance from prohibited foreign entities (FEOCs). IRS Notice 2026-15 provides interim safe harbor guidelines, making detailed supply-chain records mandatory.
System Capacity Thresholds: For new projects beginning construction in 2026, arrays under 1 MW AC qualify for the full 30% credit rate automatically. Systems sized at 1 MW AC or greater drop to a 6% base rate unless they satisfy prevailing wage and registered apprenticeship mandates.
Domestic Content and Energy Communities: Meeting domestic manufacturing standards adds a 10-percentage-point bonus for systems under 1 MW AC. Siting the project in a designated energy community provides an identical 10-point boost.
Commercial solar status summary for 2026
Project Criteria | Statutory Rule Under Federal Law | Credit Rate / Requirement |
Construction began on or before July 4, 2026 | Not bound by the Dec 31, 2027 deadline | 4-year continuity safe harbor applies |
Construction starts after July 4, 2026 | Must be placed in service by Dec 31, 2027 | Strict operational deadline |
Construction started after Dec 31, 2025 | Prohibited foreign entity restrictions apply | Must prove compliant supply chains |
System capacity under 1 MW AC | Exempt from prevailing wage and apprenticeship rules | Full 30% credit rate |
System capacity 1 MW AC or larger | Subject to federal labor standards | 6% base rate, or 30% if labor rules are met |
The investment tax credit generally belongs to the system owner for federal tax purposes, subject to applicable elections and transfer rules. Under a typical third-party solar lease or Power Purchase Agreement (PPA), the developer owns the system and claims the tax benefits. Eligible nonprofits, schools, and local governments can use IRS elective pay, which requires pre-filing registration and a timely return with Form 3468, Form 3800, and applicable attachments. Always confirm tax credit eligibility with a certified tax professional before signing contracts.
Once the deadline math is clear, the next number every owner asks about is the installed price per watt.
DOE's 2025Q1 benchmark puts a 250 kWdc commercial rooftop system at about $1.95 to $1.98 per watt before tax credits. Adding matching battery storage raises total system costs to roughly $3 per watt. Actual quotes vary by facility size, local utility rates, and roof condition.
The National Renewable Energy Laboratory (NREL) and Lawrence Berkeley National Laboratory (LBNL) track national installation trends. Non-residential solar prices remained largely flat year-over-year in LBNL's 2026 data update. Still, commercial solar power cost numbers display strong economies of scale. Larger commercial rooftop systems spread engineering and permitting expenses across more panels, lowering the unit price.
Commercial solar panel installation cost benchmarks
Benchmark System Type | System Size | Minimum Sustainable Price (MSP) | Modeled Market Price (MMP) |
Commercial Rooftop (PV Only) | 250 kWdc | $1.95 / Wdc | $1.98 / Wdc |
Commercial Rooftop (PV + Storage) | 250 kWdc / 250 kWh (DOE summary-table entry; see source note below) | $2.96 / Wdc | $2.98 / Wdc |
Residential Rooftop (Context) | 8 kWdc | $2.78 / Wdc | $2.95 / Wdc |
Utility-Scale (Context) | 100 MWdc | $1.07 / Wdc | $1.12 / Wdc |
DOE defines the Minimum Sustainable Price as the lowest price a viable installer can charge. The Modeled Market Price represents actual commercial transactions. The commercial model uses a school rooftop project meeting BABA domestic-content requirements; this benchmark is not a determination of a specific project's Section 48E or PFE eligibility. Source note: DOE's summary table lists 250 kWh of storage, while its system description states 500 kWh. The prices above reproduce the summary table; confirm storage sizing when obtaining a quote. All benchmark dollar figures are in 2024 U.S. dollars.
Understanding Commercial Solar Pricing Factors
Many building owners ask about commercial solar panel cost per square foot. However, commercial installers do not price projects by building footprint. Equipment efficiency, tilt angles, roof obstructions, and panel wattages alter how much power each square foot generates. When gathering bids, always evaluate quotes on a dollar-per-watt ($/Wdc) basis alongside total usable roof space.
When evaluating how much commercial solar panels cost, remember that commercial solar panel price covers more than solar hardware:
Photovoltaic Hardware: Commercial tier-one modules, commercial string or microinverters, and structural racking.
Balance of System (BOS): Conduit, switchgear, safety disconnects, wiring trays, and monitoring hardware.
Soft Costs: Interconnection studies, structural engineering sign-offs, city permits, and zoning reviews.
Labor and Installation: Mechanical rooftop mounting, electrical tie-ins, crane rentals, and site safety management.
A worked ROI example
Consider a business installing a 250 kW DC rooftop system. This illustration assumes the project qualifies for the 30% Section 48E credit and meets all applicable deadlines and supply-chain requirements.
Calculate the installed cost.
250,000 watts × $1.98 per watt = $495,000
Estimate the federal tax credit.
$495,000 × 30% = $148,500
Calculate the net cost after the credit.
$495,000 − $148,500 = $346,500
Estimate annual electricity production.
Assume the system generates 1,300 kWh per kW DC annually. This is a placeholder, not a site-specific forecast.
250 kW × 1,300 kWh = 325,000 kWh per year
Estimate annual electricity value.
The U.S. Energy Information Administration reported an average commercial electricity price of 14.47 cents per kWh in August 2026. This national average is a comparison point, not necessarily the rate your utility charges.
325,000 kWh × $0.1447 = approximately $47,028 per year.
Estimate simple payback and first-year return.
Metric | Estimate |
Installed cost before credit | $495,000 |
Assumed tax credit | $148,500 |
Net cost after credit | $346,500 |
Annual electricity value | $47,028 |
Simple payback after credit | 7.4 years ($346,500 ÷ $47,028) |
Simple first-year return after credit | 13.6% ($47,028 ÷ $346,500 × 100) |
Simple payback without credit | 10.5 years ($495,000 ÷ $47,028) |
These figures illustrate the calculation. They aren't a promise of savings or investment performance.
The example excludes financing costs, operations and maintenance, panel degradation, changes in electricity rates, demand charges, export compensation, state incentives, and tax depreciation. The EIA average price is not your utility's actual tariff. Your business may receive less value for electricity exported to the grid than for electricity consumed onsite.
The steps for calculating return on solar investment don't change for a business, but demand charges and depreciation make the inputs harder.
This basic model leaves out MACRS depreciation benefits, interest expenses, routine operations and maintenance, panel degradation, and utility demand charges. Commercial tariffs rarely charge a flat energy fee. Most bills include peak power demand charges, which solar panels alone cannot reliably eliminate. Consult your accountant to model tax depreciation schedules accurately.
A rooftop array improves the bill, yet many owners are surprised to learn it usually goes dark with the grid, which is a separate problem with a separate budget.
Grid-tied commercial solar systems shut down automatically during utility blackouts. Anti-islanding protection stops the inverter from energizing the grid during an outage to protect utility lineworkers from electrical backfeed. NREL explains the IEEE 1547-2018 requirements. Without an independent backup source, essential business equipment can lose power when utility service drops.
LBNL's 2026 update reports median price differences for 2025 installations of $2.00/Wdc for small non-residential PV-plus-storage systems and $1.30/Wdc for large systems, compared with stand-alone PV. These are segment medians, not a quoted price range for every battery project. Large commercial storage projects may require switchgear upgrades, safety reviews, and utility approval; confirm the scope and timetable with the project engineer.
For small branch offices, retail shops, or clinics, backing up the whole building is often unnecessary. You only need to keep credit card terminals, modems, emergency lighting, and workstations online. Setting aside a modest emergency power budget handles operational risk without driving up commercial solar installation cost.
When the rooftop array shuts off with the grid, a small office still has to keep its router, phones, and a few lights on. EcoFlow TITAN 5000 Classic is a 120V battery system sized for that kind of short list, and it's priced, wired, and planned on its own, completely apart from the rooftop project.
Sizing the office list (labeled estimate)
To estimate runtime during a blackout, use this standard usable capacity formula:
Estimated runtime = usable battery energy (Wh) ÷ combined equipment load (W)
Assuming 85% usable energy after conversion losses, one unit provides approximately 4,265Wh for this illustration.
Usable energy = 5,017.6Wh × 0.85 (planning assumption for conversion losses) ≈ 4,265Wh.
Estimated runtime (hours) = 4,265 Wh ÷ combined load (W).
Combined label watts of office essentials (placeholder; add up your own) | Estimated hours, one 5kWh unit
300W | about 14.2 hours |
600W | about 7.1 hours |
1,000W | about 4.3 hours |
Audit the nameplate wattage on the back of your mission-critical equipment. Keep heavy 240V machinery, large HVAC compressors, and kitchen appliances off this backup circuit. Counting the hidden costs of business outages, such as lost sales and idle staff, helps set a sensible budget for essential backup.
Note: Dedicated emergency backup storage operates independently from the commercial PV facility. It is not part of the Section 48E project. A licensed electrician must install any sub-panel connections to code. Verify warranty coverage for your specific facility directly with the equipment manufacturer.
Back to the solar project itself: beyond price per watt, owners can choose how the system is mounted, owned, and paired with storage.
Finding the best commercial solar setup depends on capital structure, property layout, and long-term energy goals. Businesses must weigh tax eligibility, structural requirements, and balance sheets rather than brand names.
Commercial financing and ownership models
How you finance solar panels for commercial buildings dictates who keeps federal incentives:
Financing Option | Who Claims the 48E Tax Credit? | Key 2026 Commercial Considerations | Sourced Regulatory Authority |
Direct Cash or Capital Loan | The commercial building owner | Requires sufficient federal income tax liability, or elective credit transfer | |
Solar Lease or Commercial PPA | The third-party project developer | System price may reflect tax savings; developer bears deadline and supply chain risks | 26 U.S.C. 48E; IRS Guidelines |
Tax-Exempt Entity (Nonprofit/Gov) | The nonprofit or municipal entity | Uses elective pay to receive direct payments from the IRS |
Mounting layouts and storage configurations
Mounting configurations also impact your initial commercial solar panel systems cost:
Commercial Rooftops: Rooftop ballasted or mechanically attached systems use existing building space. They utilize existing space and keep electrical runs short. The DOE benchmark of $1.98/Wdc reflects standard rooftop arrays.
Solar Carports and Canopies: Carports shield customer or fleet vehicles while producing renewable power. However, steel framing, deep concrete foundations, and trenching drive up structural costs.
Commercial Ground Mounts: Ground-mounted systems fit properties with surplus acreage. They allow optimal azimuth angles but require civil grading, ground racking, and security fencing.
Paired Commercial Storage: Pairing solar with utility-scale storage lets facilities clip peak demand spikes. Notably, the wind-and-solar termination rule in Section 48E(e)(4) does not apply to energy storage technology, though storage equipment remains subject to distinct foreign entity rules under Section 48E(c)(3).
Comparing microinverters versus string inverters is worth a line item in every commercial quote, since the choice shifts both price and maintenance. DOE's commercial rooftop benchmark uses string inverters paired with DC optimizers; the appropriate design depends on the project.
With the options narrowed, a short checklist helps make sure the quote you sign can actually finish before the deadline.
A low bid does your company no good if installation delays cause you to miss the December 31, 2027 tax credit cutoff. Every commercial solar panel installation cost proposal demands thorough technical and legal review.
Use this operational checklist before signing any commercial solar contract:
Verified Construction Start Proof: Require documented evidence of significant physical work under IRS Notice 2025-42. If the array is 1.5 MW AC or smaller, determine whether the builder relies on physical work or the Five Percent Safe Harbor.
Firm Interconnection Schedule: Demands clear timelines for utility engineering reviews, local structural permits, equipment deliveries, and utility witness testing. Ensure your timeline leaves several months of cushion before December 31, 2027.
AC vs. DC Capacity Ratings: Confirm system size in both kWdc and kWac. Ensure the inverter nameplate stays under 1 MW AC if you plan to avoid prevailing wage tracking.
Labor Compliance Documentation: For systems sized at 1 MW AC or above, verify that the general contractor and electrical subcontractors maintain certified payroll records meeting federal prevailing wage and registered apprenticeship rules.
Supply Chain Certification: Demand written supplier certifications proving all components comply with FEOC restrictions under IRS Notice 2026-15. Request domestic content documentation if claiming bonus credits.
Detailed Price Breakdown: Insist on an unbundled cost sheet showing modules, inverters, racking, balance of system, and engineering. Compare the price against the DOE benchmark of $1.98/Wdc.
Site-Specific Production Model: Request an NREL PVWatts or Helioscope simulation reflecting your roof’s pitch, geographic shading, and historical solar irradiance.
Utility Rate Structure Analysis: Have the developer model your utility bill under actual commercial tariffs, factoring in demand charges, time-of-use pricing, and net billing export rates.
Tax Credit Attribution: Ensure the contract explicitly states which party claims federal tax credits, local utility rebates, and renewable energy certificates (SRECs).
Lighting upgrades and controls are among the ways to cut business energy costs that can shrink the solar system you need. Reducing baseline electricity demand lowers the total panel count required to offset your bills.
The solar tax credit in 2026 still delivers substantial value for businesses through Section 48E. However, new projects must be placed in service by December 31, 2027 and pass strict foreign entity sourcing rules. With DOE benchmarks putting commercial rooftop PV near $1.95 to $1.98 per watt, solid planning is critical. Protect your investment by gathering dated, itemized contractor quotes, running a site-specific production model, and having a tax advisor confirm your credit eligibility and depreciation strategy.
Grid-tied commercial arrays shut down when the local power grid fails. If your small office needs emergency power for critical 120V essentials during outages, the EcoFlow TITAN 5000 Classic offers a separate, dedicated backup option. Sized specifically to keep modems, computers, and essential office circuits running smoothly, it operates completely independent of your rooftop PV array. Have a licensed electrician install it with a dedicated sub-panel to ensure seamless, code-compliant business continuity.
Is there still a commercial solar tax credit in 2026?
Yes. Commercial solar projects qualify under Section 48E. Projects starting construction after July 4, 2026 must be placed in service by December 31, 2027. Facilities starting after December 31, 2025 must also meet prohibited foreign entity sourcing rules.
How much do commercial solar panels cost per watt?
DOE's 2025Q1 cost benchmarks place a typical 250 kWdc commercial rooftop system between $1.95 and $1.98 per watt before tax credits. Smaller commercial builds trend slightly higher due to fixed engineering and permitting overhead.
Is the commercial solar credit 30% or 6%?
For projects beginning construction in 2026, systems under 1 MW AC qualify for the full 30% credit rate automatically. Commercial systems sized at 1 MW AC or larger receive a base credit rate of 6%, increasing to 30% only if the project complies with prevailing wage and registered apprenticeship requirements.
Can a nonprofit or school get the solar tax credit?
Yes. Tax-exempt entities, public schools, tribal governments, and local municipalities can claim the Section 48E tax credit using IRS elective pay rules. This mechanism delivers the value of the credit as a direct cash refund from the IRS.
Does commercial solar work during a power outage?
Most grid-connected systems shut down when the grid fails, so you need storage for backup. A small office can budget for 120V essentials separately, for example with EcoFlow TITAN 5000 Classic.
