Smart Charging Gets Personal: Control Your Power from the EcoFlow App
Plugging your phone or backup battery into a wall outlet will recharge it, but what if there were a smarter way to power your devices? Smart charging is changing how we power our lives, and with the EcoFlow app, control is at your fingertips.
From scheduling charge times to monitoring real-time energy use, the app helps you get the most out of every watt. Whether you’re preparing for a storm or managing off-grid power, smart charging technology reduces waste and helps you save money. Learn why smart charging is the way of the future, and how the EcoFlow app helps you save power with a swipe of your finger.
Why Smart Charging Matters More Than Ever
Smart charging is a more tech-enabled way to power your devices. It gives you more control and efficiency, not to mention the convenience of an always-powered device. Smart charging is a win for everyone because it reduces waste. But if you have a home or RV battery system, smart charging matters even more.
Investing in smart charging helps with:
  • Energy independence: When outages hit, you don’t want to rely on luck (or the grid). Smart charging helps you stay self-sufficient by automating when your batteries charge and discharge. That means your essentials keep running even when the power goes out.
  • Cost savings: AI-driven energy management provides deeper insights into your usage patterns, helping you maximize energy savings. The EcoFlow App lets you schedule charging during off-peak hours, like drawing power from your wall outlet overnight when electricity rates are low.
  • Eco-friendly living: Smart charger analytics give you real insight into your energy habits. You’ll see exactly where your power goes, helping you make small changes that reduce waste and shrink your carbon footprint, all while saving money.
  • Real-time adaptability: When the weather takes a turn, you want your batteries topped up. The EcoFlow App can alert you and automatically adjust charging ahead of storms, using forecasts and historical data to help you stay prepared.
Whether you’re concerned with reliability, waste, or expenses, smart charging ticks all the boxes. It can even help extend the life of your battery bank, helping you make the most of your investment in backup power.
Phone showing app-control for home power
Get to Know the EcoFlow App
The EcoFlow App puts total power control in your palm. Available for both iOS and Android, it connects to your EcoFlow devices via Wi-Fi or Bluetooth so you can monitor and optimize energy use anytime, anywhere. Whether you’re at home, on the road, or off the grid, the EcoFlow app is your command center for smarter, more efficient charging.
Control Charging Speed and Priorities in Real Time
With the EcoFlow App, you can fine-tune exactly how your power flows, especially when paired with a portable system like the EcoFlow DELTA 3 Classic (1024Wh). Use Smart Output Priority to decide which devices get power first—whether that’s topping up your phone before your fridge or giving your tools a quick boost before the rest of your setup charges.
When the weather turns unpredictable, Storm Guard Mode has your back, too. It automatically recharges your power station if a storm is on the way (as long as it’s plugged into an AC outlet), keeping your batteries ready when you need them most.
Custom Schedules: When, Where, and How to Charge Smart
Smart charging isn’t one-size-fits-all. Fortunately, the EcoFlow App makes it easy to tailor every charge to your lifestyle. With time-of-use algorithms, you can schedule your batteries to recharge when electricity rates are lowest and discharge when demand peaks, automatically saving energy and money.
Plus, the app’s Space tab gives you a central hub to manage multiple EcoFlow devices at once. You can monitor, schedule, and optimize your entire power ecosystem from a single screen.
Real-Time Power Monitoring at a Glance
Stay informed with real-time energy statistics that update every hour, providing a clear view of your power usage and performance. From total charge and discharge levels to consumption, energy value, and even estimated savings, the EcoFlow App turns complex data into easy-to-read insights.
You can also control and customize your setup remotely, adjusting input and output settings or extending battery life, all without being near your power station. Based on this data, you can schedule the best times to conduct home battery maintenance, ensuring your battery is always in good condition.
Smart Home Integration: Set It and Forget It
The EcoFlow App plays well with other smart devices, automating energy management so you don’t have to lift a finger. Set up custom automations, like turning on a smart plug to recharge your battery at a specific time. You can even set up third-party smart devices, like thermostats, to manage your power usage.
If you’re using EcoFlow’s whole-home backup power, the app can even automate recharging so you’re always prepared for outages. Plus, you’ll earn EcoCredits rewards, like cash deductions and rewards, for using the app.
Home in darkness, pool and car visible
Is There an App for EcoFlow?
Yes! The EcoFlow App is available for both iOS and Android devices. From monitoring battery levels to creating custom charging schedules, the app gives you complete control over all your EcoFlow products and third-party smart devices.
How Do You Connect to the EcoFlow App?
Connecting is simple. Download the app, create or log in to your EcoFlow account, and then pair your device via Wi-Fi or Bluetooth. Once connected, you can monitor and manage your EcoFlow power stations, smart devices, and home backup systems from anywhere.
Take Control of Your Power With the EcoFlow App
Smart charging saves energy and puts you in control. The EcoFlow App helps you to understand your power usage, cut costs, and automate your home backup system before storms hit. Take charge of your energy, wherever you are: Download the EcoFlow App to see smarter power management in action.
Home Backup
