EcoFlow ImageAsk a Question
Shop Now
EcoFlow Image
EcoFlow DELTA 3 Classic (1024Wh)
EcoFlow Image
EcoFlow Image
Ready in Just 45 Mins
AC charges to 80% in just 45 minutes
EcoFlow Image
Uninterrupted Power
<10ms switchover—fastest-in-class UPS
EcoFlow Image
High Power Output
1800W rated output 3600W surge output
EcoFlow Image
10 Years of Reliable Power[1]
EV-grade full-tab LFP batteries
EcoFlow Image
Whisper-Quiet Operation
As low as 30dB under load—ideal for homes and sensitive environments
EcoFlow Image
Smarter, Safer, 24/7 Protection with BMS
ARM Cortex chipset Cloud Intelligence Algorithm
EcoFlow Image
Compact, Portable — Works Anywhere
A New Level of Fast
Ultra-versatile 4 charging options, 45-minute fast charge.
Remote AC charging for added peace of mind.
X-Stream: Ready in Just 45 Mins
DELTA 3 Classic (1024Wh) charges from 0–80% in just 45 minutes with AC charging. It keeps you powered faster, smarter, and with greater peace of mind—whether indoors, outdoors, or on the move. X-Stream enables ultra-fast charging without compromising battery life. It intelligently adjusts voltage and power to ensure safe, high-speed recharging. With X-Stream, you’re ready in just 45 minutes. [2]
EcoFlow Image
4 Ways to Charge—Anytime, Anywhere
EcoFlow Image
EcoFlow Image
EcoFlow Image
AC Charging
Generator Charging
Car Charging
A New Era of Power Performance
1800W Output, 3600W Surge, 1kWh Capacity
Next-level energy for next-level peace of mind.
1800W Output, 3600W Surge — Power Essentials Without Compromise
EcoFlow DELTA 3 Classic (1024Wh) delivers a steady 1800W pure sine wave output with grid-level stability—enough to handle high-demand appliances like microwaves and power tools.[6] With X-Boost™ mode, it supports devices up to 2600W without tripping or slowing down—giving you seamless power for the moments that matter.
EcoFlow Image
Microwave (1300W)
Refrigerator (120W)
Blender (500W)
Coffee maker (1000W)
EcoFlow Image
50" TV (110W)
PS5 (200W)
Speaker (400W)
Projector (65W)
EcoFlow Image
Heated blanket (120W)
Electric kettle (1500W)
Mini/Car fridge (60W)
Camping light (10W)
EcoFlow Image
Laptop (60W)
Wi-Fi router (50W)
NAS (50W)
PC (500W)
Kitchen
Living Room
Outdoors
Office
EcoFlow Image
Automotive-grade full-tab LFP cells
EcoFlow Image
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Classic (1024Wh) is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a long battery lifespan.
25% more
efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) [7]
25% less
self-heating [8]
EcoFlow Image
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [9] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
16-cell uniform set per 1 kWh
Rigorously tested for capacity
Built to Last
From battery chemistry to structural design, DELTA 3 Classic (1024Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.
EcoFlow Image
Smart, 24/7 Battery Protection
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
EcoFlow Image
EV-Grade CTC Structure
Built with a cell-to-chassis (CTC) structure, DELTA 3 Classic (1024Wh) is drop-resistant — protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions.
EcoFlow Image
Extreme Environment Resistance
DELTA 3 Classic (1024Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air (5% salt spray resistance)—for reliable energy anytime, anywhere. [10]
EcoFlow Image
30dB Whisper-Quiet Operation Under Loads [11]
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
EcoFlow Image
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours and discharge during peak rate periods to save costs.
Output
Output
Solar Generation
Solar Generation
Scheduled Tasks
Scheduled Tasks
Comparison
EcoFlow Image
1024Wh
398 × 200 × 283 mm
Dimension
12.1±0.3kg
Weight
1800W
USB-A: 1 × 18W Max USB-C: 1 × 100W Max, 1 × 30W Max
USB Ports
NO
12V DC Output Port
6
Outlets
1400W
AC Input (Charge Only)
500W
Maximum PV Input Power(W)
YES
Storm Guard Mode
NO
Generator Auto Start/Stop Mode
NO
Expandable Battery
EcoFlow Image
DELTA 3 Plus
1024Wh
Approx. 397.6 × 202 × 283.6 mm
Dimension
Approx. 12.5kg
Weight
1800W
USB-A: 2 × 36W USB-C: 2 × 140W Max
USB Ports
YES(Car Power Output and DC5521)
12V DC Output Port
13
Outlets
1500W
1000W
YES
Storm Guard Mode
YES
YES. 1-5kWh
Expandable Battery
1024Wh
Dimension
Approx. 12.5kg
Weight
1800W
USB-A: 2 × 18W Max USB-C: 2 × 100W Max
USB Ports
12V DC Output Port
13
Outlets
1500W
500W
YES
Storm Guard Mode
YES
YES. 1-5kWh
Expandable Battery
Explore The NEW EcoFlow DELTA Series
EcoFlow Image
EcoFlow Image
EcoFlow DELTA 3 Max Plus (2048Wh)
2kWh Portable Power Station with 3000W Max Output
Learn More
EcoFlow Image
EcoFlow DELTA 3 Ultra Plus (3072Wh)
3kWh Ultra Long-lasting Portable Power Station
Learn More
