RV Winterizing Kit: What's Inside, What to Buy, and How to Use It
An RV winterizing kit bundles the small parts that make storage preparation easier, including a pump converter or siphon hose, a blowout plug for compressed air, and sometimes a water heater bypass. The right kit depends on your RV's plumbing, the winterization method you choose, and the equipment already installed. This guide explains what's included, which parts you actually need, how much RV antifreeze to buy, and how to use each component. You'll also learn how to prepare your workspace when you're winterizing without shore power.
What's in an RV Winterizing Kit?
Most RV winterizing kits are designed for one of two methods: using non-toxic RV antifreeze or pushing water out with compressed air. Some motorhomes already have a pump converter or water heater bypass installed, so you may not need to purchase every component. Check your plumbing setup before choosing a kit. A typical RV winterizing kit may include the following parts:
Part | Used for | Needed if |
Pump converter or siphon hose | Draws antifreeze from the jug into the pump | Your RV has no built-in winterizing valve |
Water heater bypass kit | Keeps antifreeze out of the water heater tank | Your RV has no bypass valves |
Blowout plug | Connects an air compressor to the city water inlet | You plan to use compressed air |
Non-toxic RV antifreeze | Protects plumbing lines, traps, and the toilet | Always, for the antifreeze method and plumbing traps |
Hand tools and drain plug socket | Help drain the water heater and access fittings | Always, as required by your RV design |
1. Pump Converter or Siphon Hose
A pump converter is one of the most useful parts of an RV winterizing kit. It connects to the water pump and allows the pump to draw non-toxic RV antifreeze directly from a container. This saves you from pouring antifreeze into the freshwater tank, which can require additional cleaning before your next trip. Some RVs already have a winterizing valve and hose installed. If yours does, you may only need to check the hose and connections.
2. Water Heater Bypass Kit
A water heater bypass kit redirects antifreeze around the water heater instead of filling the entire tank. This is important because a standard RV water heater holds several gallons of water. If your motorhome already has bypass valves, you don't need another kit. Simply check that the valves operate correctly and follow the manufacturer's instructions to put them in the bypass position.
3. Blowout Plug
A blowout plug connects to the RV's city water inlet and allows compressed air to push remaining water out of the plumbing lines. It is useful for RV owners who prefer the compressed-air method. However, it does not replace every winterizing supply. You may still need RV antifreeze for P-traps, toilets, and other components specified in your owner's manual. Never exceed the air-pressure limit specified by your RV manufacturer.
4. Additional RV Winterizing Supplies
Along with your main winterizing kit, keep a few extra supplies ready to handle small tasks and protect your RV during storage. These include non-toxic RV antifreeze for potable water systems, the correct drain plug socket or water heater tool, gloves, a small draining container, a flashlight, towels, and your RV owner's manual. Also, add keeping your RV battery charged during storage to your preparation checklist so you don't overlook the electrical system. A portable LED work light is especially useful when checking fittings and valves in dim storage bays without shore power.
Lighting the Job Without Shore Power
A portable power station can make RV winterization more convenient when you don't have access to shore power. It can run an LED work light and charge your phone, allowing you to refer to the owner's manual, photograph valve positions, and inspect plumbing connections. It is important to understand that a power station is separate from your RV winterizing kit. It does not remove water from plumbing, circulate antifreeze, or replace the tools required for the job.
Why Consider a Portable Power Station?
A portable power station can help with a few practical tasks:
Work lighting: Run an LED light while checking fittings under sinks or inside storage compartments.
Phone charging: Keep your phone available for reference photos and manufacturer instructions.
Tool charging: Recharge compatible cordless tool batteries when needed.
Winterizing at a storage lot often means working without hookups and sometimes finishing after daylight fades. A portable power station provides a convenient source of electricity for these small tasks without making the winterizing process dependent on a campground connection. For this type of work, you don't need to build a large electrical setup. A compact unit that can handle a work light, phone, and compatible tool charger is a more practical choice.
EcoFlow DELTA 3 Classic for Winterization Tasks
The EcoFlow DELTA 3 Classic offers 1,024Wh of capacity and can provide portable electricity for basic maintenance activities. Its output capacity makes it suitable for compatible work lights, phone chargers, and other small electrical equipment. A work light, a phone, and a cordless charger are all this job needs. A 1kWh power station can also be useful for other electrical needs during your next RV trip.
Estimated Runtime for Small Maintenance Equipment
The following example illustrates how long the DELTA 3 Classic might support a few small electrical loads.
Load (Example) | Estimated Power | Estimated Runtime |
LED work light + phone + tool charger | About 100W | About 8.7 hours |
You can also use a portable power station for other travel-related electrical needs. For example, it can complement your setup when exploring charging an RV battery on the road with compatible charging equipment. Keep the power station dry and follow its operating and storage temperature requirements. Do not place it where water from plumbing work could reach its outlets or connections.
How Much RV Antifreeze Should Your Kit Include?
Most RV owners should plan on approximately two to six gallons of non-toxic RV antifreeze, depending on the vehicle's plumbing layout and winterizing method. Bypassing the water heater can reduce the amount needed because you won't fill the tank with antifreeze. Manufacturer recommendations vary. Winnebago suggests approximately two gallons for some RVs, while Keystone recommends four to six gallons for certain systems. Always check your specific owner's manual before purchasing.
Factors That Affect Antifreeze Requirements
The amount of antifreeze your motorhome needs depends on several things:
RV size: Larger motorhomes may have longer plumbing lines and more fixtures, which can increase the amount of antifreeze needed to protect the system.
Number of water outlets: RVs with additional sinks, showers, toilets, and outdoor connections may require more antifreeze to reach all plumbing lines.
Water heater bypass: Using a water heater bypass prevents antifreeze from filling the heater tank, helping reduce the amount required.
Plumbing layout: Multiple drain points, low-point drains, and extra appliances can affect how much antifreeze is needed to protect the entire plumbing system.
Choose the Correct Type of Antifreeze
Always purchase non-toxic RV antifreeze specifically intended for potable water systems. Automotive antifreeze is not suitable because it is poisonous and must never be used in your RV's drinking-water plumbing. Check the product label and your RV manufacturer's recommendations before purchasing. Buying an extra jug is also sensible if you have a larger motorhome or additional plumbing fixtures. If your RV uses solar equipment, include winterizing off-grid solar gear in your wider storage checklist. Electrical equipment and plumbing have different preparation requirements, so follow the relevant equipment manuals.
How to Use an RV Winterizing Kit
Once you've checked your RV's plumbing and gathered the correct supplies, you can begin winterization. The general process is to drain the water first, bypass the water heater, and then protect the plumbing using your selected method. Before putting your RV away, also check how the camper's electrical hookup connects to shore power to prepare its electrical system for storage. Always follow your RV manufacturer's instructions for valve locations, drain procedures, and compressed-air pressure limits.
Step 1: Drain the Freshwater System
Start by disconnecting your RV from the water supply and switching off the water pump. Drain the freshwater tank and open all low-point drains to remove standing water. Before draining the water heater, turn off both its gas and electric heating modes. Let the water cool, then release pressure as directed in the RV manual. Then remove the drain plug or anode rod according to the manufacturer's instructions.
Step 2: Set the Water Heater Bypass
Locate the water heater bypass valves and move them into the correct position to prevent antifreeze from entering the tank. If your RV does not have bypass valves, check whether a compatible bypass kit is required. Also, follow the manufacturer's instructions for removing whole-house water filter cartridges and draining ice maker lines, as these components may need separate attention.
Step 3: Connect the Pump Converter
Reinstall the low-point drain caps or close the drain valves, then close the faucets opened for draining. Connect the pump converter or siphon hose to the water pump according to the kit instructions. Place the hose into a container of non-toxic RV antifreeze and switch on the pump only after securing all connections. Open one faucet at a time, starting with the hot and cold sides, and allow antifreeze to flow through both before moving to the next fixture.
Step 4: Flush the Toilet and Treat the Drains
Flush the toilet until antifreeze appears in the bowl, then pour the manufacturer-recommended amount into each sink and shower drain to protect the P-traps. Check for additional water outlets, such as outdoor showers and washing machine connections, and treat them if your RV has them. Follow the product instructions to ensure each part of the plumbing system receives adequate protection.
Step 5: Check Every Connection
After winterizing, inspect accessible fittings, valves, and connections for leaks, and confirm that faucets and drains are positioned as recommended by your RV manufacturer. If using compressed air instead of antifreeze, connect a blowout plug to the city water inlet and use only the pressure specified in your owner's manual. Open each fixture individually, remembering that compressed air alone may not protect every trap or appliance.
An RV winterizing kit helps protect your plumbing from freezing and typically includes a pump converter, water heater bypass parts, and a blowout plug. Depending on your RV's size and plumbing layout, you may need two to six gallons of non-toxic RV antifreeze. Never use automotive antifreeze in your freshwater system. Before starting, check your owner's manual and purchase only the components your RV needs. If shore power is unavailable, an EcoFlow DELTA 3 Classic can provide lighting for the job.
What comes in an RV winterizing kit?
A typical RV winterizing kit includes a pump converter or siphon hose, water heater bypass components, and sometimes a blowout plug. Some kits also include fittings and connecting hoses. The exact contents depend on the manufacturer and winterizing method.
Do I need a water heater bypass kit?
You only need a separate bypass kit if your RV doesn't already have bypass valves installed. Check your water heater setup and owner's manual before purchasing additional parts.
How much antifreeze does an RV need?
Most RVs require approximately two to six gallons, depending on the plumbing layout, number of fixtures, and winterizing method. Check your manufacturer's recommendation to determine the correct amount.
Can I use car antifreeze?
No. Automotive antifreeze is poisonous and isn't suitable for potable water systems. Always use non-toxic RV antifreeze specifically designed for RV plumbing.
Is a blowout plug enough?
Not always. A blowout plug helps remove water from plumbing lines using compressed air, but P-traps, toilets, washers, and other components may still require antifreeze. Follow your RV manufacturer's instructions.
